path: root/include/linux/cgroup.h
2011-07-08rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_checkMichal Hocko
Since ca5ecddf (rcu: define __rcu address space modifier for sparse) rcu_dereference_check use rcu_read_lock_held as a part of condition automatically so callers do not have to do that as well. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-26cgroup: remove the ns_cgroupDaniel Lezcano
The ns_cgroup is an annoying cgroup at the namespace / cgroup frontier and leads to some problems: * cgroup creation is out-of-control * cgroup name can conflict when pids are looping * it is not possible to have a single process handling a lot of namespaces without falling in a exponential creation time * we may want to create a namespace without creating a cgroup The ns_cgroup was replaced by a compatibility flag 'clone_children', where a newly created cgroup will copy the parent cgroup values. The userspace has to manually create a cgroup and add a task to the 'tasks' file. This patch removes the ns_cgroup as suggested in the following thread: https://lists.linux-foundation.org/pipermail/containers/2009-June/018616.html The 'cgroup_clone' function is removed because it is no longer used. This is a userspace-visible change. Commit 45531757b45c ("cgroup: notify ns_cgroup deprecated") (merged into 2.6.27) caused the kernel to emit a printk warning users that the feature is planned for removal. Since that time we have heard from XXX users who were affected by this. Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Jamal Hadi Salim <hadi@cyberus.ca> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Acked-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26cgroups: add per-thread subsystem callbacksBen Blum
Add cgroup subsystem callbacks for per-thread attachment in atomic contexts Add can_attach_task(), pre_attach(), and attach_task() as new callbacks for cgroups's subsystem interface. Unlike can_attach and attach, these are for per-thread operations, to be called potentially many times when attaching an entire threadgroup. Also, the old "bool threadgroup" interface is removed, as replaced by this. All subsystems are modified for the new interface - of note is cpuset, which requires from/to nodemasks for attach to be globally scoped (though per-cpuset would work too) to persist from its pre_attach to attach_task and attach. This is a pre-patch for cgroup-procs-writable.patch. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Reviewed-by: Paul Menage <menage@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-16perf: Add cgroup supportStephane Eranian
This kernel patch adds the ability to filter monitoring based on container groups (cgroups). This is for use in per-cpu mode only. The cgroup to monitor is passed as a file descriptor in the pid argument to the syscall. The file descriptor must be opened to the cgroup name in the cgroup filesystem. For instance, if the cgroup name is foo and cgroupfs is mounted in /cgroup, then the file descriptor is opened to /cgroup/foo. Cgroup mode is activated by passing PERF_FLAG_PID_CGROUP in the flags argument to the syscall. For instance to measure in cgroup foo on CPU1 assuming cgroupfs is mounted under /cgroup: struct perf_event_attr attr; int cgroup_fd, fd; cgroup_fd = open("/cgroup/foo", O_RDONLY); fd = perf_event_open(&attr, cgroup_fd, 1, -1, PERF_FLAG_PID_CGROUP); close(cgroup_fd); Signed-off-by: Stephane Eranian <eranian@google.com> [ added perf_cgroup_{exit,attach} ] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <4d590250.114ddf0a.689e.4482@mx.google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-02-16cgroup: Fix cgroup_subsys::exit callbackPeter Zijlstra
Make the ::exit method act like ::attach, it is after all very nearly the same thing. The bug had no effect on correctness - fixing it is an optimization for the scheduler. Also, later perf-cgroups patches rely on it. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Menage <menage@google.com> LKML-Reference: <1297160655.13327.92.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-27cgroup: add clone_children control fileDaniel Lezcano
The ns_cgroup is a control group interacting with the namespaces. When a new namespace is created, a corresponding cgroup is automatically created too. The cgroup name is the pid of the process who did 'unshare' or the child of 'clone'. This cgroup is tied with the namespace because it prevents a process to escape the control group and use the post_clone callback, so the child cgroup inherits the values of the parent cgroup. Unfortunately, the more we use this cgroup and the more we are facing problems with it: (1) when a process unshares, the cgroup name may conflict with a previous cgroup with the same pid, so unshare or clone return -EEXIST (2) the cgroup creation is out of control because there may have an application creating several namespaces where the system will automatically create several cgroups in his back and let them on the cgroupfs (eg. a vrf based on the network namespace). (3) the mix of (1) and (2) force an administrator to regularly check and clean these cgroups. This patchset removes the ns_cgroup by adding a new flag to the cgroup and the cgroupfs mount option. It enables the copy of the parent cgroup when a child cgroup is created. We can then safely remove the ns_cgroup as this flag brings a compatibility. We have now to manually create and add the task to a cgroup, which is consistent with the cgroup framework. This patch: Sent as an answer to a previous thread around the ns_cgroup. https://lists.linux-foundation.org/pipermail/containers/2009-June/018627.html It adds a control file 'clone_children' for a cgroup. This control file is a boolean specifying if the child cgroup should be a clone of the parent cgroup or not. The default value is 'false'. This flag makes the child cgroup to call the post_clone callback of all the subsystem, if it is available. At present, the cpuset is the only one which had implemented the post_clone callback. The option can be set at mount time by specifying the 'clone_children' mount option. Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Jamal Hadi Salim <hadi@cyberus.ca> Cc: Matt Helsley <matthltc@us.ibm.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-07Merge branch 'rcu/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/rcu
2010-09-09cgroups: fix API thinkoMichael S. Tsirkin
Add cgroup_attach_task_all() The existing cgroup_attach_task_current_cg() API is called by a thread to attach another thread to all of its cgroups; this is unsuitable for cases where a privileged task wants to attach itself to the cgroups of a less privileged one, since the call must be made from the context of the target task. This patch adds a more generic cgroup_attach_task_all() API that allows both the source task and to-be-moved task to be specified. cgroup_attach_task_current_cg() becomes a specialization of the more generic new function. [menage@google.com: rewrote changelog] [akpm@linux-foundation.org: address reviewer comments] Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Tested-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Ben Blum <bblum@google.com> Cc: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-19cgroups: __rcu annotationsArnd Bergmann
Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits) phy/marvell: add 88ec048 support igb: Program MDICNFG register prior to PHY init e1000e: correct MAC-PHY interconnect register offset for 82579 hso: Add new product ID can: Add driver for esd CAN-USB/2 device l2tp: fix export of header file for userspace can-raw: Fix skb_orphan_try handling Revert "net: remove zap_completion_queue" net: cleanup inclusion phy/marvell: add 88e1121 interface mode support u32: negative offset fix net: Fix a typo from "dev" to "ndev" igb: Use irq_synchronize per vector when using MSI-X ixgbevf: fix null pointer dereference due to filter being set for VLAN 0 e1000e: Fix irq_synchronize in MSI-X case e1000e: register pm_qos request on hardware activation ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice net: Add getsockopt support for TCP thin-streams cxgb4: update driver version cxgb4: add new PCI IDs ... Manually fix up conflicts in: - drivers/net/e1000e/netdev.c: due to pm_qos registration infrastructure changes - drivers/net/phy/marvell.c: conflict between adding 88ec048 support and cleaning up the IDs - drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req conflict (registration change vs marking it static)
2010-07-28cgroups: Add an API to attach a task to current task's cgroupSridhar Samudrala
Add a new kernel API to attach a task to current task's cgroup in all the active hierarchies. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Reviewed-by: Paul Menage <menage@google.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com>
2010-06-08sched: Fix PROVE_RCU vs cpu_cgroupPeter Zijlstra
PROVE_RCU has a few issues with the cpu_cgroup because the scheduler typically holds rq->lock around the css rcu derefs but the generic cgroup code doesn't (and can't) know about that lock. Provide means to add extra checks to the css dereference and use that in the scheduler to annotate its users. The addition of rq->lock to these checks is correct because the cgroup_subsys::attach() method takes the rq->lock for each task it moves, therefore by holding that lock, we ensure the task is pinned to the current cgroup and the RCU derefence is valid. That leaves one genuine race in __sched_setscheduler() where we used task_group() without holding any of the required locks and thus raced with the cgroup code. Solve this by moving the check under the appropriate lock. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-27cgroups: make cftype.unregister_event() void-returningKirill A. Shutemov
Since we are unable to handle an error returned by cftype.unregister_event() properly, let's make the callback void-returning. mem_cgroup_unregister_event() has been rewritten to be a "never fail" function. On mem_cgroup_usage_register_event() we save old buffer for thresholds array and reuse it in mem_cgroup_usage_unregister_event() to avoid allocation. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Phil Carmody <ext-phil.2.carmody@nokia.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-04cgroup: Check task_lock in task_subsys_state()Li Zefan
Expand task_subsys_state()'s rcu_dereference_check() to include the full locking rule as documented in Documentation/cgroups/cgroups.txt by adding a check for task->alloc_lock being held. This fixes an RCU false positive when resuming from suspend. The warning comes from freezer cgroup in cgroup_freezing_or_frozen(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-03-12cgroups: remove events before destroying subsystem state objectsKirill A. Shutemov
Events should be removed after rmdir of cgroup directory, but before destroying subsystem state objects. Let's take reference to cgroup directory dentry to do that. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hioryu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Dan Malek <dan@embeddedalley.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroup: implement eventfd-based generic API for notificationsKirill A. Shutemov
This patchset introduces eventfd-based API for notifications in cgroups and implements memory notifications on top of it. It uses statistics in memory controler to track memory usage. Output of time(1) on building kernel on tmpfs: Root cgroup before changes: make -j2 506.37 user 60.93s system 193% cpu 4:52.77 total Non-root cgroup before changes: make -j2 507.14 user 62.66s system 193% cpu 4:54.74 total Root cgroup after changes (0 thresholds): make -j2 507.13 user 62.20s system 193% cpu 4:53.55 total Non-root cgroup after changes (0 thresholds): make -j2 507.70 user 64.20s system 193% cpu 4:55.70 total Root cgroup after changes (1 thresholds, never crossed): make -j2 506.97 user 62.20s system 193% cpu 4:53.90 total Non-root cgroup after changes (1 thresholds, never crossed): make -j2 507.55 user 64.08s system 193% cpu 4:55.63 total This patch: Introduce the write-only file "cgroup.event_control" in every cgroup. To register new notification handler you need: - create an eventfd; - open a control file to be monitored. Callbacks register_event() and unregister_event() must be defined for the control file; - write "<event_fd> <control_fd> <args>" to cgroup.event_control. Interpretation of args is defined by control file implementation; eventfd will be woken up by control file implementation or when the cgroup is removed. To unregister notification handler just close eventfd. If you need notification functionality for a control file you have to implement callbacks register_event() and unregister_event() in the struct cftype. [kamezawa.hiroyu@jp.fujitsu.com: Kconfig fix] Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Dan Malek <dan@embeddedalley.com> Cc: Vladislav Buzov <vbuzov@embeddedalley.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Alexander Shishkin <virtuoso@slind.org> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroups: subsystem module unloadingBen Blum
Provides support for unloading modular subsystems. This patch adds a new function cgroup_unload_subsys which is to be used for removing a loaded subsystem during module deletion. Reference counting of the subsystems' modules is moved from once (at load time) to once per attached hierarchy (in parse_cgroupfs_options and rebind_subsystems) (i.e., 0 or 1). Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroups: subsystem module loading interfaceBen Blum
Add interface between cgroups subsystem management and module loading This patch implements rudimentary module-loading support for cgroups - namely, a cgroup_load_subsys (similar to cgroup_init_subsys) for use as a module initcall, and a struct module pointer in struct cgroup_subsys. Several functions that might be wanted by modules have had EXPORT_SYMBOL added to them, but it's unclear exactly which functions want it and which won't. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroups: revamp subsys arrayBen Blum
This patch series provides the ability for cgroup subsystems to be compiled as modules both within and outside the kernel tree. This is mainly useful for classifiers and subsystems that hook into components that are already modules. cls_cgroup and blkio-cgroup serve as the example use cases for this feature. It provides an interface cgroup_load_subsys() and cgroup_unload_subsys() which modular subsystems can use to register and depart during runtime. The net_cls classifier subsystem serves as the example for a subsystem which can be converted into a module using these changes. Patch #1 sets up the subsys[] array so its contents can be dynamic as modules appear and (eventually) disappear. Iterations over the array are modified to handle when subsystems are absent, and the dynamic section of the array is protected by cgroup_mutex. Patch #2 implements an interface for modules to load subsystems, called cgroup_load_subsys, similar to cgroup_init_subsys, and adds a module pointer in struct cgroup_subsys. Patch #3 adds a mechanism for unloading modular subsystems, which includes a more advanced rework of the rudimentary reference counting introduced in patch 2. Patch #4 modifies the net_cls subsystem, which already had some module declarations, to be configurable as a module, which also serves as a simple proof-of-concept. Part of implementing patches 2 and 4 involved updating css pointers in each css_set when the module appears or leaves. In doing this, it was discovered that css_sets always remain linked to the dummy cgroup, regardless of whether or not any subsystems are actually bound to it (i.e., not mounted on an actual hierarchy). The subsystem loading and unloading code therefore should keep in mind the special cases where the added subsystem is the only one in the dummy cgroup (and therefore all css_sets need to be linked back into it) and where the removed subsys was the only one in the dummy cgroup (and therefore all css_sets should be unlinked from it) - however, as all css_sets always stay attached to the dummy cgroup anyway, these cases are ignored. Any fix that addresses this issue should also make sure these cases are addressed in the subsystem loading and unloading code. This patch: Make subsys[] able to be dynamically populated to support modular subsystems This patch reworks the way the subsys[] array is used so that subsystems can register themselves after boot time, and enables the internals of cgroups to be able to handle when subsystems are not present or may appear/disappear. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroup: introduce coalesce css_get() and css_put()Daisuke Nishimura
Current css_get() and css_put() increment/decrement css->refcnt one by one. This patch add a new function __css_get(), which takes "count" as a arg and increment the css->refcnt by "count". And this patch also add a new arg("count") to __css_put() and change the function to decrement the css->refcnt by "count". These coalesce version of __css_get()/__css_put() will be used to improve performance of memcg's moving charge feature later, where instead of calling css_get()/css_put() repeatedly, these new functions will be used. No change is needed for current users of css_get()/css_put(). Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Paul Menage <menage@google.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroup: introduce cancel_attach()Daisuke Nishimura
Add cancel_attach() operation to struct cgroup_subsys. cancel_attach() can be used when can_attach() operation prepares something for the subsys, but we should rollback what can_attach() operation has prepared if attach task fails after we've succeeded in can_attach(). Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Reviewed-by: Paul Menage <menage@google.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-25sched: Use lockdep-based checking on rcu_dereference()Paul E. McKenney
Update the rcu_dereference() usages to take advantage of the new lockdep-based checking. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1266887105-1528-6-git-send-email-paulmck@linux.vnet.ibm.com> [ -v2: fix allmodconfig missing symbol export build failure on x86 ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-01const: constify remaining file_operationsAlexey Dobriyan
[akpm@linux-foundation.org: fix KVM] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: let ss->can_attach and ss->attach do whole threadgroups at a timeBen Blum
Alter the ss->can_attach and ss->attach functions to be able to deal with a whole threadgroup at a time, for use in cgroup_attach_proc. (This is a pre-patch to cgroup-procs-writable.patch.) Currently, new mode of the attach function can only tell the subsystem about the old cgroup of the threadgroup leader. No subsystem currently needs that information for each thread that's being moved, but if one were to be added (for example, one that counts tasks within a group) this bit would need to be reworked a bit to tell the subsystem the right information. [hidave.darkstar@gmail.com: fix build] Signed-off-by: Ben Blum <bblum@google.com> Signed-off-by: Paul Menage <menage@google.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Reviewed-by: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: change css_set freeing mechanism to be under RCUBen Blum
Changes css_set freeing mechanism to be under RCU This is a prepatch for making the procs file writable. In order to free the old css_sets for each task to be moved as they're being moved, the freeing mechanism must be RCU-protected, or else we would have to have a call to synchronize_rcu() for each task before freeing its old css_set. Signed-off-by: Ben Blum <bblum@google.com> Signed-off-by: Paul Menage <menage@google.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: ensure correct concurrent opening/reading of pidlists across pid ↵Ben Blum
namespaces Previously there was the problem in which two processes from different pid namespaces reading the tasks or procs file could result in one process seeing results from the other's namespace. Rather than one pidlist for each file in a cgroup, we now keep a list of pidlists keyed by namespace and file type (tasks versus procs) in which entries are placed on demand. Each pidlist has its own lock, and that the pidlists themselves are passed around in the seq_file's private pointer means we don't have to touch the cgroup or its master list except when creating and destroying entries. Signed-off-by: Ben Blum <bblum@google.com> Signed-off-by: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: add a read-only "procs" file similar to "tasks" that shows only ↵Ben Blum
unique tgids struct cgroup used to have a bunch of fields for keeping track of the pidlist for the tasks file. Those are now separated into a new struct cgroup_pidlist, of which two are had, one for procs and one for tasks. The way the seq_file operations are set up is changed so that just the pidlist struct gets passed around as the private data. Interface example: Suppose a multithreaded process has pid 1000 and other threads with ids 1001, 1002, 1003: $ cat tasks 1000 1001 1002 1003 $ cat cgroup.procs 1000 $ Signed-off-by: Ben Blum <bblum@google.com> Signed-off-by: Paul Menage <menage@google.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: revert "cgroups: fix pid namespace bug"Paul Menage
The following series adds a "cgroup.procs" file to each cgroup that reports unique tgids rather than pids, and allows all threads in a threadgroup to be atomically moved to a new cgroup. The subsystem "attach" interface is modified to support attaching whole threadgroups at a time, which could introduce potential problems if any subsystem were to need to access the old cgroup of every thread being moved. The attach interface may need to be revised if this becomes the case. Also added is functionality for read/write locking all CLONE_THREAD fork()ing within a threadgroup, by means of an rwsem that lives in the sighand_struct, for per-threadgroup-ness and also for sharing a cacheline with the sighand's atomic count. This scheme should introduce no extra overhead in the fork path when there's no contention. The final patch reveals potential for a race when forking before a subsystem's attach function is called - one potential solution in case any subsystem has this problem is to hang on to the group's fork mutex through the attach() calls, though no subsystem yet demonstrates need for an extended critical section. This patch: Revert commit 096b7fe012d66ed55e98bc8022405ede0cc80e96 Author: Li Zefan <lizf@cn.fujitsu.com> AuthorDate: Wed Jul 29 15:04:04 2009 -0700 Commit: Linus Torvalds <torvalds@linux-foundation.org> CommitDate: Wed Jul 29 19:10:35 2009 -0700 cgroups: fix pid namespace bug This is in preparation for some clashing cgroups changes that subsume the original commit's functionaliy. The original commit fixed a pid namespace bug which Ben Blum fixed independently (in the same way, but with different code) as part of a series of patches. I played around with trying to reconcile Ben's patch series with Li's patch, but concluded that it was simpler to just revert Li's, given that Ben's patch series contained essentially the same fix. Signed-off-by: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29cgroup avoid permanent sleep at rmdirKAMEZAWA Hiroyuki
After commit ec64f51545fffbc4cb968f0cea56341a4b07e85a ("cgroup: fix frequent -EBUSY at rmdir"), cgroup's rmdir (especially against memcg) doesn't return -EBUSY by temporary ref counts. That commit expects all refs after pre_destroy() is temporary but...it wasn't. Then, rmdir can wait permanently. This patch tries to fix that and change followings. - set CGRP_WAIT_ON_RMDIR flag before pre_destroy(). - clear CGRP_WAIT_ON_RMDIR flag when the subsys finds racy case. if there are sleeping ones, wakes them up. - rmdir() sleeps only when CGRP_WAIT_ON_RMDIR flag is set. Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewed-by: Paul Menage <menage@google.com> Acked-by: Balbir Sigh <balbir@linux.vnet.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29cgroups: fix pid namespace bugLi Zefan
The bug was introduced by commit cc31edceee04a7b87f2be48f9489ebb72d264844 ("cgroups: convert tasks file to use a seq_file with shared pid array"). We cache a pid array for all threads that are opening the same "tasks" file, but the pids in the array are always from the namespace of the last process that opened the file, so all other threads will read pids from that namespace instead of their own namespaces. To fix it, we maintain a list of pid arrays, which is keyed by pid_ns. The list will be of length 1 at most time. Reported-by: Paul Menage <menage@google.com> Idea-by: Paul Menage <menage@google.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Reviewed-by: Serge Hallyn <serue@us.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits) trivial: Update my email address trivial: NULL noise: drivers/mtd/tests/mtd_*test.c trivial: NULL noise: drivers/media/dvb/frontends/drx397xD_fw.h trivial: Fix misspelling of "Celsius". trivial: remove unused variable 'path' in alloc_file() trivial: fix a pdlfush -> pdflush typo in comment trivial: jbd header comment typo fix for JBD_PARANOID_IOFAIL trivial: wusb: Storage class should be before const qualifier trivial: drivers/char/bsr.c: Storage class should be before const qualifier trivial: h8300: Storage class should be before const qualifier trivial: fix where cgroup documentation is not correctly referred to trivial: Give the right path in Documentation example trivial: MTD: remove EOL from MODULE_DESCRIPTION trivial: Fix typo in bio_split()'s documentation trivial: PWM: fix of #endif comment trivial: fix typos/grammar errors in Kconfig texts trivial: Fix misspelling of firmware trivial: cgroups: documentation typo and spelling corrections trivial: Update contact info for Jochen Hein trivial: fix typo "resgister" -> "register" ...
2009-04-02cgroups: add 'data' field to struct cgroup_scannerLi Zefan
We need to pass some data to test_task() or process_task() in some cases. Will be used later. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02memcg: fix OOM killer under memcgKAMEZAWA Hiroyuki
This patch tries to fix OOM Killer problems caused by hierarchy. Now, memcg itself has OOM KILL function (in oom_kill.c) and tries to kill a task in memcg. But, when hierarchy is used, it's broken and correct task cannot be killed. For example, in following cgroup /groupA/ hierarchy=1, limit=1G, 01 nolimit 02 nolimit All tasks' memory usage under /groupA, /groupA/01, groupA/02 is limited to groupA's 1Gbytes but OOM Killer just kills tasks in groupA. This patch provides makes the bad process be selected from all tasks under hierarchy. BTW, currently, oom_jiffies is updated against groupA in above case. oom_jiffies of tree should be updated. To see how oom_jiffies is used, please check mem_cgroup_oom_called() callers. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: const fix] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroups: show correct file modeLi Zefan
We have some read-only files and write-only files, but currently they are all set to 0644, which is counter-intuitive and cause trouble for some cgroup tools like libcgroup. This patch adds 'mode' to struct cftype to allow cgroup subsys to set it's own files' file mode, and for the most cases cft->mode can be default to 0 and cgroup will figure out proper mode. Acked-by: Paul Menage <menage@google.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroup: fix frequent -EBUSY at rmdirKAMEZAWA Hiroyuki
In following situation, with memory subsystem, /groupA use_hierarchy==1 /01 some tasks /02 some tasks /03 some tasks /04 empty When tasks under 01/02/03 hit limit on /groupA, hierarchical reclaim is triggered and the kernel walks tree under groupA. In this case, rmdir /groupA/04 fails with -EBUSY frequently because of temporal refcnt from the kernel. In general. cgroup can be rmdir'd if there are no children groups and no tasks. Frequent fails of rmdir() is not useful to users. (And the reason for -EBUSY is unknown to users.....in most cases) This patch tries to modify above behavior, by - retries if css_refcnt is got by someone. - add "return value" to pre_destroy() and allows subsystem to say "we're really busy!" Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroup: CSS ID supportKAMEZAWA Hiroyuki
Patch for Per-CSS(Cgroup Subsys State) ID and private hierarchy code. This patch attaches unique ID to each css and provides following. - css_lookup(subsys, id) returns pointer to struct cgroup_subysys_state of id. - css_get_next(subsys, id, rootid, depth, foundid) returns the next css under "root" by scanning When cgroup_subsys->use_id is set, an id for css is maintained. The cgroup framework only parepares - css_id of root css for subsys - id is automatically attached at creation of css. - id is *not* freed automatically. Because the cgroup framework don't know lifetime of cgroup_subsys_state. free_css_id() function is provided. This must be called by subsys. There are several reasons to develop this. - Saving space .... For example, memcg's swap_cgroup is array of pointers to cgroup. But it is not necessary to be very fast. By replacing pointers(8bytes per ent) to ID (2byes per ent), we can reduce much amount of memory usage. - Scanning without lock. CSS_ID provides "scan id under this ROOT" function. By this, scanning css under root can be written without locks. ex) do { rcu_read_lock(); next = cgroup_get_next(subsys, id, root, &found); /* check sanity of next here */ css_tryget(); rcu_read_unlock(); id = found + 1 } while(...) Characteristics: - Each css has unique ID under subsys. - Lifetime of ID is controlled by subsys. - css ID contains "ID" and "Depth in hierarchy" and stack of hierarchy - Allowed ID is 1-65535, ID 0 is UNUSED ID. Design Choices: - scan-by-ID v.s. scan-by-tree-walk. As /proc's pid scan does, scan-by-ID is robust when scanning is done by following kind of routine. scan -> rest a while(release a lock) -> conitunue from interrupted memcg's hierarchical reclaim does this. - When subsys->use_id is set, # of css in the system is limited to 65535. [bharata@linux.vnet.ibm.com: remove rcu_read_lock() from css_get_next()] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroups: relax ns_can_attach checks to allow attaching to grandchild cgroupsGrzegorz Nosek
The ns_proxy cgroup allows moving processes to child cgroups only one level deep at a time. This commit relaxes this restriction and makes it possible to attach tasks directly to grandchild cgroups, e.g.: ($pid is in the root cgroup) echo $pid > /cgroup/CG1/CG2/tasks Previously this operation would fail with -EPERM and would have to be performed as two steps: echo $pid > /cgroup/CG1/tasks echo $pid > /cgroup/CG1/CG2/tasks Also, the target cgroup no longer needs to be empty to move a task there. Signed-off-by: Grzegorz Nosek <root@localdomain.pl> Acked-by: Serge Hallyn <serue@us.ibm.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroups: fix cgroup.h commentsPaul Menage
Fix the style of some multi-line comments in cgroup.h to match Documentation/CodingStyle Signed-off-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30trivial: fix where cgroup documentation is not correctly referred toThadeu Lima de Souza Cascardo
cgroup documentation was moved to Documentation/cgroups/. There are some places that still refer to Documentation/controllers/, Documentation/cgroups.txt and Documentation/cpusets.txt. Fix those. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-02-11cgroups: fix lockdep subclasses overflowLi Zefan
I enabled all cgroup subsystems when compiling kernel, and then: # mount -t cgroup -o net_cls xxx /mnt # mkdir /mnt/0 This showed up immediately: BUG: MAX_LOCKDEP_SUBCLASSES too low! turning off the locking correctness validator. It's caused by the cgroup hierarchy lock: for (i = 0; i < CGROUP_SUBSYS_COUNT; i++) { struct cgroup_subsys *ss = subsys[i]; if (ss->root == root) mutex_lock_nested(&ss->hierarchy_mutex, i); } Now we have 9 cgroup subsystems, and the above 'i' for net_cls is 8, but MAX_LOCKDEP_SUBCLASSES is 8. This patch uses different lockdep keys for different subsystems. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29cgroups: add cpu_relax() calls in css_tryget() and cgroup_clear_css_refs()Paul Menage
css_tryget() and cgroup_clear_css_refs() contain polling loops; these loops should have cpu_relax calls in them to reduce cross-cache traffic. Signed-off-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: add css_tryget()Paul Menage
Add css_tryget(), that obtains a counted reference on a CSS. It is used in situations where the caller has a "weak" reference to the CSS, i.e. one that does not protect the cgroup from removal via a reference count, but would instead be cleaned up by a destroy() callback. css_tryget() will return true on success, or false if the cgroup is being removed. This is similar to Kamezawa Hiroyuki's patch from a week or two ago, but with the difference that in the event of css_tryget() racing with a cgroup_rmdir(), css_tryget() will only return false if the cgroup really does get removed. This implementation is done by biasing css->refcnt, so that a refcnt of 1 means "releasable" and 0 means "released or releasing". In the event of a race, css_tryget() distinguishes between "released" and "releasing" by checking for the CSS_REMOVED flag in css->flags. Signed-off-by: Paul Menage <menage@google.com> Tested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: add a per-subsystem hierarchy_mutexPaul Menage
These patches introduce new locking/refcount support for cgroups to reduce the need for subsystems to call cgroup_lock(). This will ultimately allow the atomicity of cgroup_rmdir() (which was removed recently) to be restored. These three patches give: 1/3 - introduce a per-subsystem hierarchy_mutex which a subsystem can use to prevent changes to its own cgroup tree 2/3 - use hierarchy_mutex in place of calling cgroup_lock() in the memory controller 3/3 - introduce a css_tryget() function similar to the one recently proposed by Kamezawa, but avoiding spurious refcount failures in the event of a race between a css_tryget() and an unsuccessful cgroup_rmdir() Future patches will likely involve: - using hierarchy mutex in place of cgroup_lock() in more subsystems where appropriate - restoring the atomicity of cgroup_rmdir() with respect to cgroup_create() This patch: Add a hierarchy_mutex to the cgroup_subsys object that protects changes to the hierarchy observed by that subsystem. It is taken by the cgroup subsystem (in addition to cgroup_mutex) for the following operations: - linking a cgroup into that subsystem's cgroup tree - unlinking a cgroup from that subsystem's cgroup tree - moving the subsystem to/from a hierarchy (including across the bind() callback) Thus if the subsystem holds its own hierarchy_mutex, it can safely traverse its own hierarchy. Signed-off-by: Paul Menage <menage@google.com> Tested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: make cgroup_path() RCU-safePaul Menage
Fix races between /proc/sched_debug by freeing cgroup objects via an RCU callback. Thus any cgroup reference obtained from an RCU-safe source will remain valid during the RCU section. Since dentries are also RCU-safe, this allows us to traverse up the tree safely. Additionally, make cgroup_path() check for a NULL cgrp->dentry to avoid trying to report a path for a partially-created cgroup. [lizf@cn.fujitsu.com: call deactive_super() in cgroup_diput()] Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Tested-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: don't put struct cgroupfs_root protected by RCULai Jiangshan
We don't access struct cgroupfs_root in fast path, so we should not put struct cgroupfs_root protected by RCU But the comment in struct cgroup_subsys.root confuse us. struct cgroup_subsys.root is used in these places: 1 find_css_set(): if (ss->root->subsys_list.next == &ss->sibling) 2 rebind_subsystems(): if (ss->root != &rootnode) rcu_assign_pointer(ss->root, root); rcu_assign_pointer(subsys[i]->root, &rootnode); 3 cgroup_has_css_refs(): if (ss->root != cgrp->root) 4 cgroup_init_subsys(): ss->root = &rootnode; 5 proc_cgroupstats_show(): ss->name, ss->root->subsys_bits, ss->root->number_of_cgroups, !ss->disabled); 6 cgroup_clone(): root = subsys->root; if ((root != subsys->root) || All these place we have held cgroup_lock() or we don't dereference to struct cgroupfs_root. It's means wo don't need RCU when use struct cgroup_subsys.root, and we should not put struct cgroupfs_root protected by RCU. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Reviewed-by: Paul Menage <menage@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: remove cgroup_mm_owner_callbacksHugh Dickins
cgroup_mm_owner_callbacks() was brought in to support the memrlimit controller, but sneaked into mainline ahead of it. That controller has now been shelved, and the mm_owner_changed() args were inadequate for it anyway (they needed an mm pointer instead of a task pointer). Remove the dead code, and restore mm_update_next_owner() locking to how it was before: taking mmap_sem there does nothing for memcontrol.c, now the only user of mm->owner. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Paul Menage <menage@google.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-30cgroups: tiny cleanupsLi Zefan
- remove 'private' field from struct subsys - remove cgroup_init_smp() Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20cgroups: fix declaration of cgroup_mm_owner_callbacksPaul Menage
The choice of real/dummy declaration for cgroup_mm_owner_callbacks() shouldn't be based on CONFIG_MM_OWNER, but on CONFIG_CGROUPS. Otherwise kernel/exit.c fails to compile when something other than a cgroups controller selects CONFIG_MM_OWNER Signed-off-by: Paul Menage <menage@google.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
