path: root/include/linux/cdrom.h
2008-01-23cdrom: add more GPCMD_* constantsTejun Heo
Add GPCMD_* constants for READ_BUFFER, WRITE_12 and WRITE_BUFFER for completeness. These will be used libata. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-20Typo: depricated -> deprecatedRolf Eike Beer
Typo: depricated -> deprecated Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-07-16cdrom: replace hard-coded constants by kernel.h macro.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] cdrom: use unsigned bitfieldsRandy Dunlap
Fix 23 of these sparse warnings on x86_64 allmodconfig: include/linux/cdrom.h:942:19: error: dubious bitfield without explicit `signed' or `unsigned' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-10[PATCH] cdrom: add endianness annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] kill cdrom ->dev_ioctl methodChristoph Hellwig
Since early 2.4.x all cdrom drivers implement the block_device methods themselves, so they can handle additional ioctls directly instead of going through the cdrom layer. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
