path: root/include/linux/bootmem.h
2007-06-01x86_64: allocate sparsemem memmap above 4GZou Nan hai
On systems with huge amount of physical memory, VFS cache and memory memmap may eat all available system memory under 4G, then the system may fail to allocate swiotlb bounce buffer. There was a fix for this issue in arch/x86_64/mm/numa.c, but that fix dose not cover sparsemem model. This patch add fix to sparsemem model by first try to allocate memmap above 4G. Signed-off-by: Zou Nan hai <nanhai.zou@intel.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Andi Kleen <ak@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[PATCH] x86-64: Set HASHDIST_DEFAULT to 1 for x86_64 NUMARavikiran G Thirumalai
Enable system hashtable memory to be distributed among nodes on x86_64 NUMA Forcing the kernel to use node interleaved vmalloc instead of bootmem for the system hashtable memory (alloc_large_system_hash) reduces the memory imbalance on node 0 by around 40MB on a 8 node x86_64 NUMA box: Before the following patch, on bootup of a 8 node box: Node 0 MemTotal: 3407488 kB Node 0 MemFree: 3206296 kB Node 0 MemUsed: 201192 kB Node 0 Active: 7012 kB Node 0 Inactive: 512 kB Node 0 Dirty: 0 kB Node 0 Writeback: 0 kB Node 0 FilePages: 1912 kB Node 0 Mapped: 420 kB Node 0 AnonPages: 5612 kB Node 0 PageTables: 468 kB Node 0 NFS_Unstable: 0 kB Node 0 Bounce: 0 kB Node 0 Slab: 5408 kB Node 0 SReclaimable: 644 kB Node 0 SUnreclaim: 4764 kB After the patch (or using hashdist=1 on the kernel command line): Node 0 MemTotal: 3407488 kB Node 0 MemFree: 3247608 kB Node 0 MemUsed: 159880 kB Node 0 Active: 3012 kB Node 0 Inactive: 616 kB Node 0 Dirty: 0 kB Node 0 Writeback: 0 kB Node 0 FilePages: 2424 kB Node 0 Mapped: 380 kB Node 0 AnonPages: 1200 kB Node 0 PageTables: 396 kB Node 0 NFS_Unstable: 0 kB Node 0 Bounce: 0 kB Node 0 Slab: 6304 kB Node 0 SReclaimable: 1596 kB Node 0 SUnreclaim: 4708 kB I guess it is a good idea to keep HASHDIST_DEFAULT "on" for x86_64 NUMA since x86_64 has no dearth of vmalloc space? Or maybe enable hash distribution for all 64bit NUMA arches? The following patch does it only for x86_64. I ran a HPC MPI benchmark -- 'Ansys wingsolid', which takes up quite a bit of memory and uses up tlb entries. This was on a 4 way, 2 socket Tyan AMD box (non vsmp), with 8G total memory (4G pernode). The results with and without hash distribution are: 1. Vanilla - runtime of 1188.000s 2. With hashdist=1 runtime of 1154.000s Oprofile output for the duration of run is: 1. Vanilla: PU: AMD64 processors, speed 2411.16 MHz (estimated) Counted L1_AND_L2_DTLB_MISSES events (L1 and L2 DTLB misses) with a unit mask of 0x00 (No unit mask) count 500 samples % app name symbol name 163054 6.5513 libansys1.so MultiFront::decompose(int, int, Elemset *, int *, int, int, int) 162061 6.5114 libansys3.so blockSaxpy6L_fd 162042 6.5107 libansys3.so blockInnerProduct6L_fd 156286 6.2794 libansys3.so maxb33_ 87879 3.5309 libansys1.so elmatrixmultpcg_ 84857 3.4095 libansys4.so saxpy_pcg 58637 2.3560 libansys4.so .st4560 46612 1.8728 libansys4.so .st4282 43043 1.7294 vmlinux-t copy_user_generic_string 41326 1.6604 libansys3.so blockSaxpyBackSolve6L_fd 41288 1.6589 libansys3.so blockInnerProductBackSolve6L_fd 2. With hashdist=1 CPU: AMD64 processors, speed 2411.13 MHz (estimated) Counted L1_AND_L2_DTLB_MISSES events (L1 and L2 DTLB misses) with a unit mask of 0x00 (No unit mask) count 500 samples % app name symbol name 162993 6.9814 libansys1.so MultiFront::decompose(int, int, Elemset *, int *, int, int, int) 160799 6.8874 libansys3.so blockInnerProduct6L_fd 160459 6.8729 libansys3.so blockSaxpy6L_fd 156018 6.6826 libansys3.so maxb33_ 84700 3.6279 libansys4.so saxpy_pcg 83434 3.5737 libansys1.so elmatrixmultpcg_ 58074 2.4875 libansys4.so .st4560 46000 1.9703 libansys4.so .st4282 41166 1.7632 libansys3.so blockSaxpyBackSolve6L_fd 41033 1.7575 libansys3.so blockInnerProductBackSolve6L_fd 35762 1.5318 libansys1.so inner_product_sub 35591 1.5245 libansys1.so inner_product_sub2 28259 1.2104 libansys4.so addVectors Signed-off-by: Pravin B. Shelar <pravin.shelar@calsoftinc.com> Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Shai Fultheim <shai@scalex86.org> Signed-off-by: Andi Kleen <ak@suse.de> Acked-by: Christoph Lameter <clameter@engr.sgi.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-03-22[PATCH] FRV: fix unannotated variable declarationsDavid Howells
Fix unannotated variable declarations. Variables that have allocation section annotations (such as __meminitdata) on their definitions must also have them on their declarations as not doing so may affect the addressing mode used by the compiler and may result in a linker error. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] remove HASH_HIGHMEMAndrew Morton
It has no users and it's doubtful that we'll need it again. Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] bootmem: miscellaneous coding style fixesFranck Bui-Huu
It fixes various coding style issues, specially when spaces are useless. For example '*' go next to the function name. Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] bootmem: remove useless headers inclusionsFranck Bui-Huu
2006-09-26[PATCH] bootmem: limit to 80 columns widthFranck Bui-Huu
2006-09-26[PATCH] bootmem: remove useless parentheses in bootmem header fileFranck Bui-Huu
2006-09-26[PATCH] bootmem: remove useless __init in header fileFranck Bui-Huu
__init in headers is pretty useless because the compiler doesn't check it, and they get out of sync relatively frequently. So if you see an __init in a header file, it's quite unreliable and you need to check the definition anyway. Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22[XFRM]: Dynamic xfrm_state hash table sizing.David S. Miller
The grow algorithm is simple, we grow if: 1) we see a hash chain collision at insert, and 2) we haven't hit the hash size limit (currently 1*1024*1024 slots), and 3) the number of xfrm_state objects is > the current hash mask All of this needs some tweaking. Remove __initdata from "hashdist" so we can use it safely at run time. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-10[PATCH] FRV: Fix FRV arch compile errorsDavid Howells
Fix some FRV arch compile errors, including: (*) Marking nr_kernel_pages as __meminitdata so that references to it end up being properly calculated rather than being assumed to be in the small data section (and thus calculated wrt the GP register). Not doing this causes the linker to emit errors as the offset is too big to fit into the load instruction. (*) Move pm_power_off into an unconditionally compiled .c file as it's now unconditionally accessed. (*) Declare frv_change_cmode() in a header file rather than in a .c file, and declare it asmlinkage. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] wait_table and zonelist initializing for memory hotadd: change to ↵Yasunori Goto
meminit for build_zonelist Change definitions of some functions and data from __init to __meminit. These functions and data can be used after bootup by this patch to be used for hot-add codes. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-09[PATCH] x86_64: Handle empty PXMs that only contain hotplug memoryAndi Kleen
The node setup code would try to allocate the node metadata in the node itself, but that fails if there is no memory in there. This can happen with memory hotplug when the hotplug area defines an so far empty node. Now use bootmem to try to allocate the mem_map in other nodes. And if it fails don't panic, but just ignore the node. To make this work I added a new __alloc_bootmem_nopanic function that does what its name implies. TBD should try to use nearby nodes here. Currently we just use any. It's hard to do it better because bootmem doesn't have proper fallback lists yet. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] for_each_online_pgdat: for_each_bootmemKAMEZAWA Hiroyuki
Add a list_head to bootmem_data_t and make bootmems use it. bootmem list is sorted by node_boot_start. Only nodes against which init_bootmem() is called are linked to the list. (i386 allocates bootmem only from one node(0) not from all online nodes.) A summary: 1. for_each_online_pgdat() traverses all *online* nodes. 2. alloc_bootmem() allocates memory only from initialized-for-bootmem nodes. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] x86_64: Try to allocate node memmap near the end of nodeAndi Kleen
This fixes problems with very large nodes (over 128GB) filling up all of the first 4GB with their mem_map and not leaving enough space for the swiotlb. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] Cleanup bootmem allocator and fix alloc_bootmem_lowRavikiran G Thirumalai
Patch cleans up the alloc_bootmem fix for swiotlb. Patch removes alloc_bootmem_*_limit api and fixes alloc_boot_*low api to do the right thing -- allocate from low32 memory. Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-19[PATCH] swiotlb: make sure initial DMA allocations really are in DMA memoryYasunori Goto
This introduces a limit parameter to the core bootmem allocator; The new parameter indicates that physical memory allocated by the bootmem allocator should be within the requested limit. We also introduce alloc_bootmem_low_pages_limit, alloc_bootmem_node_limit, alloc_bootmem_low_pages_node_limit apis, but alloc_bootmem_low_pages_limit is the only api used for swiotlb. The existing alloc_bootmem_low_pages() api could instead have been changed and made to pass right limit to the core allocator. But that would make the patch more intrusive for 2.6.14, as other arches use alloc_bootmem_low_pages(). We may be done that post 2.6.14 as a cleanup. With this, swiotlb gets memory within 4G for both x86_64 and ia64 arches. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Ravikiran G Thirumalai <kiran@scalex86.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kdump: Retrieve saved max pfnVivek Goyal
This patch retrieves the max_pfn being used by previous kernel and stores it in a safe location (saved_max_pfn) before it is overwritten due to user defined memory map. This pfn is used to make sure that user does not try to read the physical memory beyond saved_max_pfn. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] sparsemem base: simple NUMA remap space allocatorDave Hansen
Introduce a simple allocator for the NUMA remap space. This space is very scarce, used for structures which are best allocated node local. This mechanism is also used on non-NUMA ia64 systems with a vmem_map to keep the pgdat->node_mem_map initialized in a consistent place for all architectures. Issues: o alloc_remap takes a node_id where we might expect a pgdat which was intended to allow us to allocate the pgdat's using this mechanism; which we do not yet do. Could have alloc_remap_node() and alloc_remap_nid() for this purpose. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
