path: root/include/linux/blktrace_api.h
2008-10-09blktrace: use BLKTRACE_BDEV_SIZE as the name size for setup structureJens Axboe
Define as 32, which is is what BDEVNAME_SIZE is/was as well. This keeps the user interface the same and gets rid of the difference between kernel and user api here. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09include blktrace_api.h in headers_installSven Schuetz
This header file is of interest for user space programming, i.e. for tools that process blktrace data. We would like to use it for a tool on-top of blktrace which processes data provided by blktrace. For this purpose, it would be helpful if the blktrace API would make it to /usr/include/linux. The git tree for the blktrace tools comes with its own copy of this header file. I didn't manage to replace that copy with the file generated by the patch below yet. A few more cleanups would be needed. For example, the blktrace ioctl numbers, which are currently defined in usr/include/fs.h, might need to be moved. Should be feasible, though. Signed-off-by: Sven Schuetz <sven@linux.vnet.ibm.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: Add interface to abort queued requestsMike Anderson
Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09blktrace: support discard requestsDavid Woodhouse
Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03Added in user-injected messages into blk tracesAlan D. Brunelle
This allows a user to annotate the blk trace stream: writing a suitable message to {/sys/kernel/debug}/block/<dsf>/msg will have it propagated into the trace stream. Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-28block: make blktrace use per-cpu buffers for message notesJens Axboe
Currently it uses a single static char array, but that risks being corrupted when multiple users issue message notes at the same time. Make the buffers dynamically allocated when the trace is setup and make them per-cpu instead. The default max message size of 1k is also very large, the interface is mainly for small text notes. So shrink it to 128 bytes. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-28Added in MESSAGE notes for blktracesAlan D. Brunelle
Allows messages to be inserted into blktrace streams. Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29Fix blktrace compile warningMartin K. Petersen
request_queue_t is deprecated Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28blktrace: Add blktrace ioctls to SCSI generic devicesChristof Schmitt
Since the SCSI layer uses the request queues from the block layer, blktrace can also be used to trace the requests to all SCSI devices (like SCSI tape drives), not only disks. The only missing part is the ioctl interface to start and stop tracing. This patch adds the SETUP, START, STOP and TEARDOWN ioctls from blktrace to the sg device files. With this change, blktrace can be used for SCSI devices like for disks, e.g.: blktrace -d /dev/sg1 -o - | blkparse -i - Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-12[BLOCK] Better fix for do_blk_trace_setup() for !CONFIG_BLOCKJens Axboe
We don't have the request queue definition, so just make it a macro instead. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-11[BLOCK] Fix failing compile with BLK_DEV_IO_TRACE=nBoaz Harrosh
I get a compilation error in sglist-arch branch with BLK_DEV_IO_TRACE=n: CC block/compat_ioctl.o /usr0/export/dev/bharrosh/git/pub/linux-2.6-block/block/compat_ioctl.c: In function ?compat_blk_trace_setup?: /usr0/export/dev/bharrosh/git/pub/linux-2.6-block/block/compat_ioctl.c:568: error: expected expression before ?do? make[2]: *** [block/compat_ioctl.o] Error 1 Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: handle blk_trace ioctlsArnd Bergmann
blk_trace_setup is broken on x86_64 compat systems, this makes the code work correctly on all 64 bit architectures in compat mode. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-08-11Fix remap handling by blktraceAlan D. Brunelle
This patch provides more information concerning REMAP operations on block IOs. The additional information provides clearer details at the user level, and supports post-processing analysis in btt. o Adds in partition remaps on the same device. o Fixed up the remap information in DM to be in the right order o Sent up mapped-from and mapped-to device information Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-01[PATCH] blktrace: add timestamp messageOlaf Kirch
This adds a new timestamp message to blktrace, giving the timeofday when we starting tracing. This helps user space correlate block trace events with eg an application strace. This requires a (compatible) update to blkparse. The changed blkparse is still able to process traces generated by older kernels, and older versions of blkparse should silently ignore the new records (because they have a pid of 0). Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-09-30[PATCH] blktrace: support for logging metadata readsJens Axboe
Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-30[PATCH] Split struct request ->flags into two partsJens Axboe
Right now ->flags is a bit of a mess: some are request types, and others are just modifiers. Clean this up by splitting it into ->cmd_type and ->cmd_flags. This allows introduction of generic Linux block message types, useful for sending generic Linux commands to block devices. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-07-06[PATCH] Only the first two bits in bio->bi_rw and rq->flags matchJens Axboe
Not three, as assumed. This causes the barrier bit to be needlessly set for some IO. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-07-06[PATCH] blktrace: readahead supportNathan Scott
Provide the needed kernel support for distinguishing readahead from regular read requests when tracing block devices. Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-07-06[PATCH] blktrace: fix barrier vs sync typoNathan Scott
2006-06-23[PATCH] blktrace_api.h: endian annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-23[PATCH] Block queue IO tracing support (blktrace) as of 2006-03-23Jens Axboe
