path: root/include/linux/blkdev.h
2007-07-10[TRIVIAL PATCH] Kill blk_congestion_wait() stub for !CONFIG_BLOCKBenjamin Gilbert
blk_congestion_wait() doesn't exist anymore, but there's still a stub in blkdev.h for the !CONFIG_BLOCK case. Kill it. Signed-off-by: Benjamin Gilbert <bgilbert@cs.cmu.edu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-09kblockd: use flush_workAndrew Morton
Switch the kblockd flushing from a global flush to a more specific flush_work(). (akpm: bypassed maintainers, sorry. There are other patches which depend on this) Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Jens Axboe <axboe@suse.de> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30ll_rw_blk: add io_context private pointerJens Axboe
To be used by as/cfq as they see fit. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-02-11cfq-iosched: remove cfq_io_context last_queueJens Axboe
It hasn't been used for a while, kill it off and remove the old if 0 code chunk. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-19[PATCH] Fixup blk_rq_unmap_user() APIJens Axboe
The blk_rq_unmap_user() API is not very nice. It expects the caller to know that rq->bio has to be reset to the original bio, and it will silently do nothing if that is not done. Instead make it explicit that we need to pass in the first bio, by expecting a bio argument. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-19[PATCH] Remove queue merging hooksJens Axboe
We have full flexibility of merging parameters now, so we can remove the hooks that define back/front/request merge strategies. Nobody is using them anymore. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-12[PATCH] remove blk_queue_activity_fnBoaz Harrosh
While working on bidi support at struct request level I have found that blk_queue_activity_fn is actually never used. The only user is in ide-probe.c with this code: /* enable led activity for disk drives only */ if (drive->media == ide_disk && hwif->led_act) blk_queue_activity_fn(q, hwif->led_act, drive); And led_act is never initialized anywhere. (Looking back at older kernels it was used in the PPC arch, but was removed around 2.6.18) Unless it is all for future use off course. (this patch is against linux-2.6-block.git as off 2006/12/4) Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-01[PATCH] block: support larger block pc requestsMike Christie
This patch modifies blk_rq_map/unmap_user() and the cdrom and scsi_ioctl.c users so that it supports requests larger than bio by chaining them together. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-10-20[PATCH] separate bdi congestion functions from queue congestion functionsAndrew Morton
Separate out the concept of "queue congestion" from "backing-dev congestion". Congestion is a backing-dev concept, not a queue concept. The blk_* congestion functions are retained, as wrappers around the core backing-dev congestion functions. This proper layering is needed so that NFS can cleanly use the congestion functions, and so that CONFIG_BLOCK=n actually links. Cc: "Thomas Maier" <balagi@justmail.de> Cc: "Jens Axboe" <jens.axboe@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: David Howells <dhowells@redhat.com> Cc: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] export clear_queue_congested and set_queue_congestedThomas Maier
Export the clear_queue_congested() and set_queue_congested() functions located in ll_rw_blk.c The functions are renamed to blk_clear_queue_congested() and blk_set_queue_congested(). (needed in the pktcdvd driver's bio write congestion control) Signed-off-by: Thomas Maier <balagi@justmail.de> Cc: Peter Osterlund <petero2@telia.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-12[PATCH] ide-cd: fix breakage with internally queued commandsJens Axboe
We still need to maintain a private PC style command, since it isn't completely unified with REQ_TYPE_BLOCK_PC yet. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-10-04[PATCH] helper function for retrieving scsi_cmd given host based block layer tagDavid C Somayajulu
This was necessitated by the need for a function to get back to a scsi_cmnd, when an hba the posts its (corresponding) completion interrupt with a block layer tag as its reference. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-09-30[PATCH] CONFIG_BLOCK: blk_congestion_wait() fixAndrew Morton
Don't just do nothing: it'll cause busywaits all over writeback and page reclaim. For now, take a fixed-length nap. Will improve when NFS starts waking up throttled processes. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Make it possible to disable the block layer [try #6]David Howells
Make it possible to disable the block layer. Not all embedded devices require it, some can make do with just JFFS2, NFS, ramfs, etc - none of which require the block layer to be present. This patch does the following: (*) Introduces CONFIG_BLOCK to disable the block layer, buffering and blockdev support. (*) Adds dependencies on CONFIG_BLOCK to any configuration item that controls an item that uses the block layer. This includes: (*) Block I/O tracing. (*) Disk partition code. (*) All filesystems that are block based, eg: Ext3, ReiserFS, ISOFS. (*) The SCSI layer. As far as I can tell, even SCSI chardevs use the block layer to do scheduling. Some drivers that use SCSI facilities - such as USB storage - end up disabled indirectly from this. (*) Various block-based device drivers, such as IDE and the old CDROM drivers. (*) MTD blockdev handling and FTL. (*) JFFS - which uses set_bdev_super(), something it could avoid doing by taking a leaf out of JFFS2's book. (*) Makes most of the contents of linux/blkdev.h, linux/buffer_head.h and linux/elevator.h contingent on CONFIG_BLOCK being set. sector_div() is, however, still used in places, and so is still available. (*) Also made contingent are the contents of linux/mpage.h, linux/genhd.h and parts of linux/fs.h. (*) Makes a number of files in fs/ contingent on CONFIG_BLOCK. (*) Makes mm/bounce.c (bounce buffering) contingent on CONFIG_BLOCK. (*) set_page_dirty() doesn't call __set_page_dirty_buffers() if CONFIG_BLOCK is not enabled. (*) fs/no-block.c is created to hold out-of-line stubs and things that are required when CONFIG_BLOCK is not set: (*) Default blockdev file operations (to give error ENODEV on opening). (*) Makes some /proc changes: (*) /proc/devices does not list any blockdevs. (*) /proc/diskstats and /proc/partitions are contingent on CONFIG_BLOCK. (*) Makes some compat ioctl handling contingent on CONFIG_BLOCK. (*) If CONFIG_BLOCK is not defined, makes sys_quotactl() return -ENODEV if given command other than Q_SYNC or if a special device is specified. (*) In init/do_mounts.c, no reference is made to the blockdev routines if CONFIG_BLOCK is not defined. This does not prohibit NFS roots or JFFS2. (*) The bdflush, ioprio_set and ioprio_get syscalls can now be absent (return error ENOSYS by way of cond_syscall if so). (*) The seclvl_bd_claim() and seclvl_bd_release() security calls do nothing if CONFIG_BLOCK is not set, since they can't then happen. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] Allow file systems to differentiate between data and meta readsJens Axboe
We can use this information for making more intelligent priority decisions, and it will also be useful for blktrace. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-30[PATCH] Add blk_start_queueing() helperJens Axboe
CFQ implements this on its own now, but it's really block layer knowledge. Tells a device queue to start dispatching requests to the driver, taking care to unplug if needed. Also fixes the issue where as/cfq will invoke a stopped queue, which we really don't want. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-30[PATCH] Make sure all block/io scheduler setups are node awareJens Axboe
Some were kmalloc_node(), some were still kmalloc(). Change them all to kmalloc_node(). Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-30[PATCH] Kill various deprecated/unused block layer defines/functionsJens Axboe
2006-09-30[PATCH] cfq-iosched: kill cfq_exit_lockJens Axboe
cfq_exit_lock is protecting two things now: - The per-ioc rbtree of cfq_io_contexts - The per-cfqd linked list of cfq_io_contexts The per-cfqd linked list can be protected by the queue lock, as it is (by definition) per cfqd as the queue lock is. The per-ioc rbtree is mainly used and updated by the process itself only. The only outside use is the io priority changing. If we move the priority changing to not browsing the rbtree, we can remove any locking from the rbtree updates and lookup completely. Let the sys_ioprio syscall just mark processes as having the iopriority changed and lazily update the private cfq io contexts the next time io is queued, and we can remove this locking as well. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-30[PATCH] struct request: shrink and optimize some moreJens Axboe
Move some members around and unionize completion_data and rb_node since they cannot ever be used at the same time. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-30[PATCH] Remove ->rq_status from struct requestJens Axboe
After Christophs SCSI change, the only usage left is RQ_ACTIVE and RQ_INACTIVE. The block layer sets RQ_INACTIVE right before freeing the request, so any check for RQ_INACTIVE in a driver is a bug and indicates use-after-free. So kill/clean the remaining users, straight forward. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-30[PATCH] Remove struct request_list from struct requestJens Axboe
It is always identical to &q->rq, and we only use it for detecting whether this request came out of our mempool or not. So replace it with an additional ->flags bit flag. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-30[PATCH] Remove ->waiting member from struct requestJens Axboe
As the comments indicates in blkdev.h, we can fold it into ->end_io_data usage as that is really what ->waiting is. Fixup the users of blk_end_sync_rq(). Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] Add one more pointer to struct request for IO scheduler usageJens Axboe
Then we have enough room in the request to get rid of the dynamic allocations in CFQ/AS. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-30[PATCH] as-iosched: remove arq->is_sync memberJens Axboe
We can track this in struct request. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Nick Piggin <npiggin@suse.de>
2006-09-30[PATCH] elevator: abstract out the rbtree sort handlingJens Axboe
The rbtree sort/lookup/reposition logic is mostly duplicated in cfq/deadline/as, so move it to the elevator core. The io schedulers still provide the actual rb root, as we don't want to impose any sort of specific handling on the schedulers. Introduce the helpers and rb_node in struct request to help migrate the IO schedulers. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-30[PATCH] elevator: move the backmerging logic into the elevator coreJens Axboe
Right now, every IO scheduler implements its own backmerging (except for noop, which does no merging). That results in duplicated code for essentially the same operation, which is never a good thing. This patch moves the backmerging out of the io schedulers and into the elevator core. We save 1.6kb of text and as a bonus get backmerging for noop as well. Win-win! Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-30[PATCH] Split struct request ->flags into two partsJens Axboe
Right now ->flags is a bit of a mess: some are request types, and others are just modifiers. Clean this up by splitting it into ->cmd_type and ->cmd_flags. This allows introduction of generic Linux block message types, useful for sending generic Linux commands to block devices. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-29[PATCH] ifdef blktrace debugging fieldsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-23Merge mulgrave-w:git/linux-2.6James Bottomley
Conflicts: include/linux/blkdev.h Trivial merge to incorporate tag prototypes.
2006-09-22Add a real API for dealing with blk_congestion_wait()Trond Myklebust
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-08-31[SCSI] block: add support for shared tag mapsJames Bottomley
The current block queue implementation already contains most of the machinery for shared tag maps. The only remaining pieces are a way to allocate and destroy a tag map independently of the queues (so that the maps can be managed on the life cycle of the overseeing entity) Acked-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-23[PATCH] Rearrange a few struct request membersJens Axboe
This saves 8 bytes of data in 64-bit archs. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-06-23[PATCH] Get rid of struct request request_pm_state memberJens Axboe
The IDE power management can just use the ->end_io_data member to store it's data. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-06-23[PATCH] Kill PF_SYNCWRITE flagJens Axboe
A process flag to indicate whether we are doing sync io is incredibly ugly. It also causes performance problems when one does a lot of async io and then proceeds to sync it. Part of the io will go out as async, and the other part as sync. This causes a disconnect between the previously submitted io and the synced io. For io schedulers such as CFQ, this will cause us lost merges and suboptimal behaviour in scheduling. Remove PF_SYNCWRITE completely from the fsync/msync paths, and let the O_DIRECT path just directly indicate that the writes are sync by using WRITE_SYNC instead. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-06-21Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (85 commits) [SCSI] 53c700: remove reliance on deprecated cmnd fields [SCSI] hptiop: don't use cmnd->bufflen [SCSI] hptiop: HighPoint RocketRAID 3xxx controller driver [SCSI] aacraid: small misc. cleanups [SCSI] aacraid: Update supported product information [SCSI] aacraid: Fix return code interpretation [SCSI] scsi_transport_sas: fix panic in sas_free_rphy [SCSI] remove RQ_SCSI_* flags [SCSI] remove scsi_request infrastructure [SCSI] mptfusion: change driver revision to 3.03.10 [SCSI] mptfc: abort of board reset leaves port dead requiring reboot [SCSI] mptfc: fix fibre channel infinite request/response loop [SCSI] mptfc: set fibre channel fw target missing timers to one second [SCSI] mptfusion: move fc event/reset handling to mptfc [SCSI] spi transport: don't allow dt to be set on SE or HVD buses [SCSI] aic7xxx: expose the bus setting to sysfs [SCSI] scsi: remove Documentation/scsi/cpqfc.txt [SCSI] drivers/scsi: Use ARRAY_SIZE macro [SCSI] Remove last page_address from dc395x.c [SCSI] hptiop: HighPoint RocketRAID 3xxx controller driver ... Fixed up conflicts in drivers/message/fusion/mptbase.c manually (due to the sparc interrupt cleanups)
2006-06-10[SCSI] remove RQ_SCSI_* flagsChristoph Hellwig
The RQ_SCSI_* flags are a vestiage of a long past history. The EH code still sets them but we never make use of that information. The other users is pluto.c which never had a chance to work but needs to be kept compiling to keep Davem happy, so copy over the definition there. We could probably get rid of RQ_ACTIVE/RQ_INACTIVE aswell with some work, there's only two more or less bogus looking uses in ubd and scsi. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-13[SCSI] unify SCSI_IOCTL_SEND_COMMAND implementationsChristoph Hellwig
We currently have two implementations of this obsolete ioctl, one in the block layer and one in the scsi code. Both of them have drawbacks. This patch kills the scsi layer version after updating the block version with the missing bits: - argument checking - use scatterlist I/O - set number of retries based on the submitted command This is the last user of non-S/G I/O except for the gdth driver, so getting this in ASAP and through the scsi tree would be nie to kill the non-S/G I/O path. Jens, what do you think about adding a check for non-S/G I/O in the midlayer? Thanks to Or Gerlitz for testing this patch. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-28[BLOCK] cfq-iosched: seek and async performance fixesJens Axboe
Detect whether a given process is seeky and if so disable (mostly) the idle window if it is. We still allow just a little idle time, just enough to allow that process to submit a new request. That is needed to maintain fairness across priority groups. In some cases, we could setup several async queues. This is not optimal from a performance POV, since we want all async io in one queue to perform good sorting on it. It also impacted sync queues, as async io got too much slice time. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-28[PATCH] [BLOCK] cfq-iosched: change cfq io context linking from list to treeJens Axboe
On setups with many disks, we spend a considerable amount of time looking up the process-disk mapping on each queue of io. Testing with a NULL based block driver, this costs 40-50% reduction in throughput for 1000 disks. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-23[PATCH] Block queue IO tracing support (blktrace) as of 2006-03-23Jens Axboe
2006-03-18[PATCH] fix sysfs interaction and lifetime rules handling for queuesAl Viro
2006-03-18[PATCH] make cfq_exit_queue() prune the cfq_io_context for that queueAl Viro
2006-03-18[PATCH] keep sync and async cfq_queue separateAl Viro
2006-01-24[BLOCK] ll_rw_blk: make max_sectors and max_hw_sectors unsigned intsJens Axboe
IDE lba48 can support full 64k request size, which overflows the max_hw_sectors variable. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-09Merge branch 'blk-softirq' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
Manual merge for trivial #include changes
2006-01-09[BLOCK] ll_rw_blk: Enable out-of-order request completions through softirqJens Axboe
Request completion can be a quite heavy process, since it needs to iterate through the entire request and complete the bio's it holds. This patch adds blk_complete_request() which moves this processing into a dedicated block softirq. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-09[BLOCK] Kill blk_attempt_remerge()Jens Axboe
It's a broken interface, it's done way too late. And apparently it triggers slab problems in recent kernels as well (most likely after the generic dispatch code was merged). So kill it, ide-cd is the only user of it. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-06[BLOCK] Correct blk_execute_rq_nowait() prototypeJens Axboe
