path: root/include/linux/blkdev.h
2009-07-01block: get rid of queue-private command filterJens Axboe
The initial patches to support this through sysfs export were broken and have been if 0'ed out in any release. So lets just kill the code and reclaim some space in struct request_queue, if anyone would later like to fixup the sysfs bits, the git history can easily restore the removed bits. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-16block: Introduce helper to reset queue limits to default valuesMartin K. Petersen
DM reuses the request queue when swapping in a new device table Introduce blk_set_default_limits() which can be used to reset the the queue_limits prior to stacking devices. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Alasdair G Kergon <agk@redhat.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-12Merge branch 'for-2.6.31' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6 * 'for-2.6.31' of git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (29 commits) ide: re-implement ide_pci_init_one() on top of ide_pci_init_two() ide: unexport ide_find_dma_mode() ide: fix PowerMac bootup oops ide: skip probe if there are no devices on the port (v2) sl82c105: add printk() logging facility ide-tape: fix proc warning ide: add IDE_DFLAG_NIEN_QUIRK device flag ide: respect quirk_drives[] list on all controllers hpt366: enable all quirks for devices on quirk_drives[] list hpt366: sync quirk_drives[] list with pdc202xx_{new,old}.c ide: remove superfluous SELECT_MASK() call from do_rw_taskfile() ide: remove superfluous SELECT_MASK() call from ide_driveid_update() icside: remove superfluous ->maskproc method ide-tape: fix IDE_AFLAG_* atomic accesses ide-tape: change IDE_AFLAG_IGNORE_DSC non-atomically pdc202xx_old: kill resetproc() method pdc202xx_old: don't call pdc202xx_reset() on IRQ timeout pdc202xx_old: use ide_dma_test_irq() ide: preserve Host Protected Area by default (v2) ide-gd: implement block device ->set_capacity method (v2) ...
2009-06-11block: add request clone interface (v2)Kiyoshi Ueda
This patch adds the following 2 interfaces for request-stacking drivers: - blk_rq_prep_clone(struct request *clone, struct request *orig, struct bio_set *bs, gfp_t gfp_mask, int (*bio_ctr)(struct bio *, struct bio*, void *), void *data) * Clones bios in the original request to the clone request (bio_ctr is called for each cloned bios.) * Copies attributes of the original request to the clone request. The actual data parts (e.g. ->cmd, ->buffer, ->sense) are not copied. - blk_rq_unprep_clone(struct request *clone) * Frees cloned bios from the clone request. Request stacking drivers (e.g. request-based dm) need to make a clone request for a submitted request and dispatch it to other devices. To allocate request for the clone, request stacking drivers may not be able to use blk_get_request() because the allocation may be done in an irq-disabled context. So blk_rq_prep_clone() takes a request allocated by the caller as an argument. For each clone bio in the clone request, request stacking drivers should be able to set up their own completion handler. So blk_rq_prep_clone() takes a callback function which is called for each clone bio, and a pointer for private data which is passed to the callback. NOTE: blk_rq_prep_clone() doesn't copy any actual data of the original request. Pages are shared between original bios and cloned bios. So caller must not complete the original request before the clone request. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-09Revert "block: Fix bounce limit setting in DM"Jens Axboe
This reverts commit a05c0205ba031c01bba33a21bf0a35920eb64833. DM doesn't need to access the bounce_pfn directly. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-07partitions: add ->set_capacity block device methodBartlomiej Zolnierkiewicz
* Add ->set_capacity block device method and use it in rescan_partitions() to attempt enabling native capacity of the device upon detecting the partition which exceeds device capacity. * Add GENHD_FL_NATIVE_CAPACITY flag to try limit attempts of enabling native capacity during partition scan. Together with the consecutive patch implementing ->set_capacity method in ide-gd device driver this allows automatic disabling of Host Protected Area (HPA) if any partitions overlapping HPA are detected. Cc: Robert Hancock <hancockrwd@gmail.com> Cc: Frans Pop <elendil@planet.nl> Cc: "Andries E. Brouwer" <Andries.Brouwer@cwi.nl> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Emphatically-Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-03block: Fix bounce limit setting in DMMartin K. Petersen
blk_queue_bounce_limit() is more than a wrapper about the request queue limits.bounce_pfn variable. Introduce blk_queue_bounce_pfn() which can be called by stacking drivers that wish to set the bounce limit explicitly. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22block: Export I/O topology for block devices and partitionsMartin K. Petersen
To support devices with physical block sizes bigger than 512 bytes we need to ensure proper alignment. This patch adds support for exposing I/O topology characteristics as devices are stacked. logical_block_size is the smallest unit the device can address. physical_block_size indicates the smallest I/O the device can write without incurring a read-modify-write penalty. The io_min parameter is the smallest preferred I/O size reported by the device. In many cases this is the same as the physical block size. However, the io_min parameter can be scaled up when stacking (RAID5 chunk size > physical block size). The io_opt characteristic indicates the optimal I/O size reported by the device. This is usually the stripe width for arrays. The alignment_offset parameter indicates the number of bytes the start of the device/partition is offset from the device's natural alignment. Partition tools and MD/DM utilities can use this to pad their offsets so filesystems start on proper boundaries. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22block: Move queue limits to an embedded structMartin K. Petersen
To accommodate stacking drivers that do not have an associated request queue we're moving the limits to a separate, embedded structure. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22block: Use accessor functions for queue limitsMartin K. Petersen
Convert all external users of queue limits to using wrapper functions instead of poking the request queue variables directly. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22Merge branch 'master' into for-2.6.31Jens Axboe
Conflicts: drivers/block/hd.c drivers/block/mg_disk.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-20block: change the tag sync vs async restriction logicJens Axboe
Make them fully share the tag space, but disallow async requests using the last any two slots. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-19block: Un-export blk_rq_append_bioBoaz Harrosh
OSD was the last in-tree user of blk_rq_append_bio(). Now that it is fixed blk_rq_append_bio is un-exported and is only used internally by block layer. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-19block: Add blk_make_request(), takes bio, returns a requestBoaz Harrosh
New block API: given a struct bio allocates a new request. This is the parallel of generic_make_request for BLOCK_PC commands users. The passed bio may be a chained-bio. The bio is bounced if needed inside the call to this member. This is in the effort of un-exporting blk_rq_append_bio(). Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> CC: Jeff Garzik <jeff@garzik.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: move completion related functions back to blk-core.cFUJITA Tomonori
Let's put the completion related functions back to block/blk-core.c where they have lived. We can also unexport blk_end_bidi_request() and __blk_end_bidi_request(), which nobody uses. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: let blk_end_request_all handle bidi requestsFUJITA Tomonori
blk_end_request_all() and __blk_end_request_all() should finish all bytes including bidi, by definition. That's what all bidi users need , bidi requests must be complete as a whole (partial completion is impossible). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: implement and enforce request peek/start/fetchTejun Heo
Till now block layer allowed two separate modes of request execution. A request is always acquired from the request queue via elv_next_request(). After that, drivers are free to either dequeue it or process it without dequeueing. Dequeue allows elv_next_request() to return the next request so that multiple requests can be in flight. Executing requests without dequeueing has its merits mostly in allowing drivers for simpler devices which can't do sg to deal with segments only without considering request boundary. However, the benefit this brings is dubious and declining while the cost of the API ambiguity is increasing. Segment based drivers are usually for very old or limited devices and as converting to dequeueing model isn't difficult, it doesn't justify the API overhead it puts on block layer and its more modern users. Previous patches converted all block low level drivers to dequeueing model. This patch completes the API transition by... * renaming elv_next_request() to blk_peek_request() * renaming blkdev_dequeue_request() to blk_start_request() * adding blk_fetch_request() which is combination of peek and start * disallowing completion of queued (not started) requests * applying new API to all LLDs Renamings are for consistency and to break out of tree code so that it's apparent that out of tree drivers need updating. [ Impact: block request issue API cleanup, no functional change ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Mike Miller <mike.miller@hp.com> Cc: unsik Kim <donari75@gmail.com> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: David S. Miller <davem@davemloft.net> Cc: Laurent Vivier <Laurent@lvivier.info> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Stefan Weinhuber <wein@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: hide request sector and data_lenTejun Heo
Block low level drivers for some reason have been pretty good at abusing block layer API. Especially struct request's fields tend to get violated in all possible ways. Make it clear that low level drivers MUST NOT access or manipulate rq->sector and rq->data_len directly by prefixing them with double underscores. This change is also necessary to break build of out-of-tree codes which assume the previous block API where internal fields can be manipulated and rq->data_len carries residual count on completion. [ Impact: hide internal fields, block API change ] Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: drop request->hard_* and *nr_sectorsTejun Heo
struct request has had a few different ways to represent some properties of a request. ->hard_* represent block layer's view of the request progress (completion cursor) and the ones without the prefix are supposed to represent the issue cursor and allowed to be updated as necessary by the low level drivers. The thing is that as block layer supports partial completion, the two cursors really aren't necessary and only cause confusion. In addition, manual management of request detail from low level drivers is cumbersome and error-prone at the very least. Another interesting duplicate fields are rq->[hard_]nr_sectors and rq->{hard_cur|current}_nr_sectors against rq->data_len and rq->bio->bi_size. This is more convoluted than the hard_ case. rq->[hard_]nr_sectors are initialized for requests with bio but blk_rq_bytes() uses it only for !pc requests. rq->data_len is initialized for all request but blk_rq_bytes() uses it only for pc requests. This causes good amount of confusion throughout block layer and its drivers and determining the request length has been a bit of black magic which may or may not work depending on circumstances and what the specific LLD is actually doing. rq->{hard_cur|current}_nr_sectors represent the number of sectors in the contiguous data area at the front. This is mainly used by drivers which transfers data by walking request segment-by-segment. This value always equals rq->bio->bi_size >> 9. However, data length for pc requests may not be multiple of 512 bytes and using this field becomes a bit confusing. In general, having multiple fields to represent the same property leads only to confusion and subtle bugs. With recent block low level driver cleanups, no driver is accessing or manipulating these duplicate fields directly. Drop all the duplicates. Now rq->sector means the current sector, rq->data_len the current total length and rq->bio->bi_size the current segment length. Everything else is defined in terms of these three and available only through accessors. * blk_recalc_rq_sectors() is collapsed into blk_update_request() and now handles pc and fs requests equally other than rq->sector update. This means that now pc requests can use partial completion too (no in-kernel user yet tho). * bio_cur_sectors() is replaced with bio_cur_bytes() as block layer now uses byte count as the primary data length. * blk_rq_pos() is now guranteed to be always correct. In-block users converted. * blk_rq_bytes() is now guaranteed to be always valid as is blk_rq_sectors(). In-block users converted. * blk_rq_sectors() is now guaranteed to equal blk_rq_bytes() >> 9. More convenient one is used. * blk_rq_bytes() and blk_rq_cur_bytes() are now inlined and take const pointer to request. [ Impact: API cleanup, single way to represent one property of a request ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: implement blk_rq_pos/[cur_]sectors() and convert obvious onesTejun Heo
Implement accessors - blk_rq_pos(), blk_rq_sectors() and blk_rq_cur_sectors() which return rq->hard_sector, rq->hard_nr_sectors and rq->hard_cur_sectors respectively and convert direct references of the said fields to the accessors. This is in preparation of request data length handling cleanup. Geert : suggested adding const to struct request * parameter to accessors Sergei : spotted error in patch description [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Tested-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Ackec-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: add rq->resid_lenTejun Heo
rq->data_len served two purposes - the length of data buffer on issue and the residual count on completion. This duality creates some headaches. First of all, block layer and low level drivers can't really determine what rq->data_len contains while a request is executing. It could be the total request length or it coulde be anything else one of the lower layers is using to keep track of residual count. This complicates things because blk_rq_bytes() and thus [__]blk_end_request_all() relies on rq->data_len for PC commands. Drivers which want to report residual count should first cache the total request length, update rq->data_len and then complete the request with the cached data length. Secondly, it makes requests default to reporting full residual count, ie. reporting that no data transfer occurred. The residual count is an exception not the norm; however, the driver should clear rq->data_len to zero to signify the normal cases while leaving it alone means no data transfer occurred at all. This reverse default behavior complicates code unnecessarily and renders block PC on some drivers (ide-tape/floppy) unuseable. This patch adds rq->resid_len which is used only for residual count. While at it, remove now unnecessasry blk_rq_bytes() caching in ide_pc_intr() as rq->data_len is not changed anymore. Boaz : spotted missing conversion in osd Sergei : spotted too early conversion to blk_rq_bytes() in ide-tape [ Impact: cleanup residual count handling, report 0 resid by default ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Mike Miller <mike.miller@hp.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Doug Gilbert <dgilbert@interlog.com> Cc: Mike Miller <mike.miller@hp.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Darrick J. Wong <djwong@us.ibm.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: ide-cd: fix REQ_QUIET tests in cdrom_decode_status Fix up trivial conflicts in include/linux/blkdev.h
2009-04-30ide-cd: fix REQ_QUIET tests in cdrom_decode_statusBorislav Petkov
Original patch (dfa4411cc3a690011cab90e9a536938795366cf9) was buggy. This is a more proper fix which introduces blk_rq_quiet() macro alleviating the need for dumb, too short caching variables. Thanks to Helge Deller and Bart for debugging this. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Reported-and-tested-by: Helge Deller <deller@gmx.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-28block: make blk_end_request_cur() return boolTejun Heo
In the process of mindlessly copying [__]blk_end_request_all(), [__]blk_end_request_cur() ended up returning void even though they're partial completion functions. Fix it. [ Impact: fix braindead API ] Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28block: kill rq->dataTejun Heo
Now that all block request data transfer is done via bio, rq->data isn't used. Kill it. While at it, make the roles of rq->special and buffer clear. [ Impact: drop now unncessary field from struct request ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Boaz Harrosh <bharrosh@panasas.com>
2009-04-28block: replace end_request() with [__]blk_end_request_cur()Tejun Heo
end_request() has been kept around for backward compatibility; however, it's about time for it to go away. * There aren't too many users left. * Its use of @updtodate is pretty confusing. * In some cases, newer code ends up using mixture of end_request() and [__]blk_end_request[_all](), which is way too confusing. So, add [__]blk_end_request_cur() and replace end_request() with it. Most conversions are straightforward. Noteworthy ones are... * paride/pcd: next_request() updated to take 0/-errno instead of 1/0. * paride/pf: pf_end_request() and next_request() updated to take 0/-errno instead of 1/0. * xd: xd_readwrite() updated to return 0/-errno instead of 1/0. * mtd/mtd_blkdevs: blktrans_discard_request() updated to return 0/-errno instead of 1/0. Unnecessary local variable res initialization removed from mtd_blktrans_thread(). [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Joerg Dorchain <joerg@dorchain.net> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Laurent Vivier <Laurent@lvivier.info> Cc: Tim Waugh <tim@cyberelk.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: unsik Kim <donari75@gmail.com>
2009-04-28block: implement and use [__]blk_end_request_all()Tejun Heo
There are many [__]blk_end_request() call sites which call it with full request length and expect full completion. Many of them ensure that the request actually completes by doing BUG_ON() the return value, which is awkward and error-prone. This patch adds [__]blk_end_request_all() which takes @rq and @error and fully completes the request. BUG_ON() is added to to ensure that this actually happens. Most conversions are simple but there are a few noteworthy ones. * cdrom/viocd: viocd_end_request() replaced with direct calls to __blk_end_request_all(). * s390/block/dasd: dasd_end_request() replaced with direct calls to __blk_end_request_all(). * s390/char/tape_block: tapeblock_end_request() replaced with direct calls to blk_end_request_all(). [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Mike Miller <mike.miller@hp.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-28block: clean up request completion APITejun Heo
Request completion has gone through several changes and became a bit messy over the time. Clean it up. 1. end_that_request_data() is a thin wrapper around end_that_request_data_first() which checks whether bio is NULL before doing anything and handles bidi completion. blk_update_request() is a thin wrapper around end_that_request_data() which clears nr_sectors on the last iteration but doesn't use the bidi completion. Clean it up by moving the initial bio NULL check and nr_sectors clearing on the last iteration into end_that_request_data() and renaming it to blk_update_request(), which makes blk_end_io() the only user of end_that_request_data(). Collapse end_that_request_data() into blk_end_io(). 2. There are four visible completion variants - blk_end_request(), __blk_end_request(), blk_end_bidi_request() and end_request(). blk_end_request() and blk_end_bidi_request() uses blk_end_request() as the backend but __blk_end_request() and end_request() use separate implementation in __blk_end_request() due to different locking rules. blk_end_bidi_request() is identical to blk_end_io(). Collapse blk_end_io() into blk_end_bidi_request(), separate out request update into internal helper blk_update_bidi_request() and add __blk_end_bidi_request(). Redefine [__]blk_end_request() as thin inline wrappers around [__]blk_end_bidi_request(). 3. As the whole request issue/completion usages are about to be modified and audited, it's a good chance to convert completion functions return bool which better indicates the intended meaning of return values. 4. The function name end_that_request_last() is from the days when it was a public interface and slighly confusing. Give it a proper internal name - blk_finish_request(). 5. Add description explaning that blk_end_bidi_request() can be safely used for uni requests as suggested by Boaz Harrosh. The only visible behavior change is from #1. nr_sectors counts are cleared after the final iteration no matter which function is used to complete the request. I couldn't find any place where the code assumes those nr_sectors counters contain the values for the last segment and this change is good as it makes the API much more consistent as the end result is now same whether a request is completed using [__]blk_end_request() alone or in combination with blk_update_request(). API further cleaned up per Christoph's suggestion. [ Impact: cleanup, rq->*nr_sectors always updated after req completion ] Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Boaz Harrosh <bharrosh@panasas.com> Cc: Christoph Hellwig <hch@infradead.org>
2009-04-28block: kill blk_end_request_callback()Tejun Heo
With recent IDE updates, blk_end_request_callback() doesn't have any user now. Kill it. [ Impact: removal of unused convoluted interface ] Signed-off-by: Tejun Heo <tj@kernel.org>
2009-04-28block: reorder request completion functionsTejun Heo
Reorder request completion functions such that * All request completion functions are located together. * Functions which are used by only one caller is put right above the caller. * end_request() is put after other completion functions but before blk_update_request(). This change is for completion function cleanup which will follow. [ Impact: cleanup, code reorganization ] Signed-off-by: Tejun Heo <tj@kernel.org>
2009-04-28block: kill blk_start_queueing()Tejun Heo
blk_start_queueing() is identical to __blk_run_queue() except that it doesn't check for recursion. None of the current users depends on blk_start_queueing() running request_fn directly. Replace usages of blk_start_queueing() with [__]blk_run_queue() and kill it. [ Impact: removal of mostly duplicate interface function ] Signed-off-by: Tejun Heo <tj@kernel.org>
2009-04-24block: simplify I/O stat accountingJerome Marchand
This simplifies I/O stat accounting switching code and separates it completely from I/O scheduler switch code. Requests are accounted according to the state of their request queue at the time of the request allocation. There is no need anymore to flush the request queue when switching I/O accounting state. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07block: remove unused REQ_UNPLUGJens Axboe
The request inherits the unplug flag from the bio, but it isn't actually used. The bio flag stops at __make_request(), which tells it to unplug after submission. Passing it on to the request doesn't make any sense. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-06block: Add flag for telling the IO schedulers NOT to anticipate more IOJens Axboe
By default, CFQ will anticipate more IO from a given io context if the previously completed IO was sync. This used to be fine, since the only sync IO was reads and O_DIRECT writes. But with more "normal" sync writes being used now, we don't want to anticipate for those. Add a bio/request flag that informs the IO scheduler that this is a sync request that we should not idle for. Introduce WRITE_ODIRECT specifically for O_DIRECT writes, and make sure that the other sync writes set this flag. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06block: change the request allocation/congestion logic to be sync/async basedJens Axboe
This makes sure that we never wait on async IO for sync requests, instead of doing the split on writes vs reads. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-26block: reduce stack footprint of blk_recount_segments()Jens Axboe
blk_recalc_rq_segments() requires a request structure passed in, which we don't have from blk_recount_segments(). So the latter allocates one on the stack, using > 400 bytes of stack for that. This can cause us to spill over one page of stack from ext4 at least: 0) 4560 400 blk_recount_segments+0x43/0x62 1) 4160 32 bio_phys_segments+0x1c/0x24 2) 4128 32 blk_rq_bio_prep+0x2a/0xf9 3) 4096 32 init_request_from_bio+0xf9/0xfe 4) 4064 112 __make_request+0x33c/0x3f6 5) 3952 144 generic_make_request+0x2d1/0x321 6) 3808 64 submit_bio+0xb9/0xc3 7) 3744 48 submit_bh+0xea/0x10e 8) 3696 368 ext4_mb_init_cache+0x257/0xa6a [ext4] 9) 3328 288 ext4_mb_regular_allocator+0x421/0xcd9 [ext4] 10) 3040 160 ext4_mb_new_blocks+0x211/0x4b4 [ext4] 11) 2880 336 ext4_ext_get_blocks+0xb61/0xd45 [ext4] 12) 2544 96 ext4_get_blocks_wrap+0xf2/0x200 [ext4] 13) 2448 80 ext4_da_get_block_write+0x6e/0x16b [ext4] 14) 2368 352 mpage_da_map_blocks+0x7e/0x4b3 [ext4] 15) 2016 352 ext4_da_writepages+0x2ce/0x43c [ext4] 16) 1664 32 do_writepages+0x2d/0x3c 17) 1632 144 __writeback_single_inode+0x162/0x2cd 18) 1488 96 generic_sync_sb_inodes+0x1e3/0x32b 19) 1392 16 sync_sb_inodes+0xe/0x10 20) 1376 48 writeback_inodes+0x69/0xb3 21) 1328 208 balance_dirty_pages_ratelimited_nr+0x187/0x2f9 22) 1120 224 generic_file_buffered_write+0x1d4/0x2c4 23) 896 176 __generic_file_aio_write_nolock+0x35f/0x393 24) 720 80 generic_file_aio_write+0x6c/0xc8 25) 640 80 ext4_file_write+0xa9/0x137 [ext4] 26) 560 320 do_sync_write+0xf0/0x137 27) 240 48 vfs_write+0xb3/0x13c 28) 192 64 sys_write+0x4c/0x74 29) 128 128 system_call_fastpath+0x16/0x1b Split the segment counting out into a __blk_recalc_rq_segments() helper to avoid allocating an onstack request just for checking the physical segment count. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-02-02block: fix inconsistent parenthesisation of QUEUE_FLAG_DEFAULTJens Axboe
2009-01-30block: add sysfs file for controlling io stats accountingJens Axboe
This allows us to turn off disk stat accounting completely, for the cases where the 0.5-1% reduction in system time is important. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-01-30block: seperate bio/request unplug and sync bitsJens Axboe
2009-01-02[SCSI] block: make blk_rq_map_user take a NULL user-space buffer for WRITEFUJITA Tomonori
The commit 818827669d85b84241696ffef2de485db46b0b5e (block: make blk_rq_map_user take a NULL user-space buffer) extended blk_rq_map_user to accept a NULL user-space buffer with a READ command. It was necessary to convert sg to use the block layer mapping API. This patch extends blk_rq_map_user again for a WRITE command. It is necessary to convert st and osst drivers to use the block layer apping API. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] block: fix the partial mappings with struct rq_map_dataFUJITA Tomonori
This fixes bio_copy_user_iov to properly handle the partial mappings with struct rq_map_data (which only sg uses for now but st and osst will shortly). It adds the offset member to struct rq_map_data and changes blk_rq_map_user to update it so that bio_copy_user_iov can add an appropriate page frame via bio_add_pc_page(). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29block: get rid of elevator_t typedefJens Axboe
Just use struct elevator_queue everywhere instead. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29block: simplify empty barrier implementationTejun Heo
Empty barrier required special handling in __elv_next_request() to complete it without letting the low level driver see it. With previous changes, barrier code is now flexible enough to skip the BAR step using the same barrier sequence selection mechanism. Drop the special handling and mask off q->ordered from start_ordered(). Remove blk_empty_barrier() test which now has no user. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29block: make barrier completion more robustTejun Heo
Barrier completion had the following assumptions. * start_ordered() couldn't finish the whole sequence properly. If all actions are to be skipped, q->ordseq is set correctly but the actual completion was never triggered thus hanging the barrier request. * Drain completion in elv_complete_request() assumed that there's always at least one request in the queue when drain completes. Both assumptions are true but these assumptions need to be removed to improve empty barrier implementation. This patch makes the following changes. * Make start_ordered() use blk_ordered_complete_seq() to mark skipped steps complete and notify __elv_next_request() that it should fetch the next request if the whole barrier has completed inside start_ordered(). * Make drain completion path in elv_complete_request() check whether the queue is empty. Empty queue also indicates drain completion. * While at it, convert 0/1 return from blk_do_ordered() to false/true. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29block: make every barrier action optionalTejun Heo
In all barrier sequences, the barrier write itself was always assumed to be issued and thus didn't have corresponding control flag. This patch adds QUEUE_ORDERED_DO_BAR and unify action mask handling in start_ordered() such that any barrier action can be skipped. This patch doesn't introduce any visible behavior changes. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29block: reorganize QUEUE_ORDERED_* constantsTejun Heo
Separate out ordering type (drain,) and action masks (preflush, postflush, fua) from visible ordering mode selectors (QUEUE_ORDERED_*). Ordering types are now named QUEUE_ORDERED_BY_* while action masks are named QUEUE_ORDERED_DO_*. This change is necessary to add QUEUE_ORDERED_DO_BAR and make it optional to improve empty barrier implementation. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29block: use cancel_work_sync() instead of kblockd_flush_work()Cheng Renquan
After many improvements on kblockd_flush_work, it is now identical to cancel_work_sync, so a direct call to cancel_work_sync is suggested. The only difference is that cancel_work_sync is a GPL symbol, so no non-GPL modules anymore. Signed-off-by: Cheng Renquan <crquan@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29block: add queue flag for paravirt frontend driversFernando Luis Vázquez Cao
As is the case with SSD devices, we do not want to idle in AS/CFQ when the block device is a paravirt front-end driver. This patch adds a flag (QUEUE_FLAG_VIRT) which should be used by front-end drivers such as virtio_blk and xen-blkfront to indicate a paravirtualized device. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-05Enforce a minimum SG_IO timeoutLinus Torvalds
There's no point in having too short SG_IO timeouts, since if the command does end up timing out, we'll end up through the reset sequence that is several seconds long in order to abort the command that timed out. As a result, shorter timeouts than a few seconds simply do not make sense, as the recovery would be longer than the timeout itself. Add a BLK_MIN_SG_TIMEOUT to match the existign BLK_DEFAULT_SG_TIMEOUT. Suggested-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
