path: root/include/linux/blkdev.h
2011-03-02block: add @force_kblockd to __blk_run_queue()Tejun Heo
__blk_run_queue() automatically either calls q->request_fn() directly or schedules kblockd depending on whether the function is recursed. blk-flush implementation needs to be able to explicitly choose kblockd. Add @force_kblockd. All the current users are converted to specify %false for the parameter and this patch doesn't introduce any behavior change. stable: This is prerequisite for fixing ide oops caused by the new blk-flush implementation. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jan Beulich <JBeulich@novell.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-01blk-throttle: Do not use kblockd workqueue for throtl workVivek Goyal
o Dominik Klein reported a system hang issue while doing some blkio throttling testing. https://lkml.org/lkml/2011/2/24/173 o Some tracing revealed that CFQ was not dispatching any more jobs as queue unplug was not happening. And queue unplug was not happening because unplug work was not being called as there was one throttling work on same cpu which as not finished yet. And throttling work had not finished as it was tyring to dispatch a bio to CFQ but all the request descriptors were consume to it was put to sleep. o So basically it is a cyclic dependecny between CFQ unplug work and throtl dispatch work. Tejun suggested that use separate workqueue for such cases. o This patch uses a separate workqueue for throttle related work and does not rely on kblockd workqueue anymore. Cc: stable@kernel.org Reported-by: Dominik Klein <dk@in-telegence.net> Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-13Merge branch 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits) block: ensure that completion error gets properly traced blktrace: add missing probe argument to block_bio_complete block cfq: don't use atomic_t for cfq_group block cfq: don't use atomic_t for cfq_queue block: trace event block fix unassigned field block: add internal hd part table references block: fix accounting bug on cross partition merges kref: add kref_test_and_get bio-integrity: mark kintegrityd_wq highpri and CPU intensive block: make kblockd_workqueue smarter Revert "sd: implement sd_check_events()" block: Clean up exit_io_context() source code. Fix compile warnings due to missing removal of a 'ret' variable fs/block: type signature of major_to_index(int) to major_to_index(unsigned) block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p) cfq-iosched: don't check cfqg in choose_service_tree() fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors cdrom: export cdrom_check_events() sd: implement sd_check_events() sr: implement sr_check_events() ...
2011-01-13Merge branch 'for-2.6.38/event-handling' into for-2.6.38/coreJens Axboe
2011-01-05block: fix accounting bug on cross partition mergesJerome Marchand
/proc/diskstats would display a strange output as follows. $ cat /proc/diskstats |grep sda 8 0 sda 90524 7579 102154 20464 0 0 0 0 0 14096 20089 8 1 sda1 19085 1352 21841 4209 0 0 0 0 4294967064 15689 4293424691 ~~~~~~~~~~ 8 2 sda2 71252 3624 74891 15950 0 0 0 0 232 23995 1562390 8 3 sda3 54 487 2188 92 0 0 0 0 0 88 92 8 4 sda4 4 0 8 0 0 0 0 0 0 0 0 8 5 sda5 81 2027 2130 138 0 0 0 0 0 87 137 Its reason is the wrong way of accounting hd_struct->in_flight. When a bio is merged into a request belongs to different partition by ELEVATOR_FRONT_MERGE. The detailed root cause is as follows. Assuming that there are two partition, sda1 and sda2. 1. A request for sda2 is in request_queue. Hence sda1's hd_struct->in_flight is 0 and sda2's one is 1. | hd_struct->in_flight --------------------------- sda1 | 0 sda2 | 1 --------------------------- 2. A bio belongs to sda1 is issued and is merged into the request mentioned on step1 by ELEVATOR_BACK_MERGE. The first sector of the request is changed from sda2 region to sda1 region. However the two partition's hd_struct->in_flight are not changed. | hd_struct->in_flight --------------------------- sda1 | 0 sda2 | 1 --------------------------- 3. The request is finished and blk_account_io_done() is called. In this case, sda2's hd_struct->in_flight, not a sda1's one, is decremented. | hd_struct->in_flight --------------------------- sda1 | -1 sda2 | 1 --------------------------- The patch fixes the problem by caching the partition lookup inside the request structure, hence making sure that the increment and decrement will always happen on the same partition struct. This also speeds up IO with accounting enabled, since it cuts down on the number of lookups we have to do. Also add a refcount to struct hd_struct to keep the partition in memory as long as users exist. We use kref_test_and_get() to ensure we don't add a reference to a partition which is going away. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-17block: max hardware sectors limit wrapperMike Snitzer
Implement blk_limits_max_hw_sectors() and make blk_queue_max_hw_sectors() a wrapper around it. DM needs this to avoid setting queue_limits' max_hw_sectors and max_sectors directly. dm_set_device_limits() now leverages blk_limits_max_hw_sectors() logic to establish the appropriate max_hw_sectors minimum (PAGE_SIZE). Fixes issue where DM was incorrectly setting max_sectors rather than max_hw_sectors (which caused dm_merge_bvec()'s max_hw_sectors check to be ineffective). Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@kernel.org Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-17block: Deprecate QUEUE_FLAG_CLUSTER and use queue_limits insteadMartin K. Petersen
When stacking devices, a request_queue is not always available. This forced us to have a no_cluster flag in the queue_limits that could be used as a carrier until the request_queue had been set up for a metadevice. There were several problems with that approach. First of all it was up to the stacking device to remember to set queue flag after stacking had completed. Also, the queue flag and the queue limits had to be kept in sync at all times. We got that wrong, which could lead to us issuing commands that went beyond the max scatterlist limit set by the driver. The proper fix is to avoid having two flags for tracking the same thing. We deprecate QUEUE_FLAG_CLUSTER and use the queue limit directly in the block layer merging functions. The queue_limit 'no_cluster' is turned into 'cluster' to avoid double negatives and to ease stacking. Clustering defaults to being enabled as before. The queue flag logic is removed from the stacking function, and explicitly setting the cluster flag is no longer necessary in DM and MD. Reported-by: Ed Lin <ed.lin@promise.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-16implement in-kernel gendisk events handlingTejun Heo
Currently, media presence polling for removeable block devices is done from userland. There are several issues with this. * Polling is done by periodically opening the device. For SCSI devices, the command sequence generated by such action involves a few different commands including TEST_UNIT_READY. This behavior, while perfectly legal, is different from Windows which only issues single command, GET_EVENT_STATUS_NOTIFICATION. Unfortunately, some ATAPI devices lock up after being periodically queried such command sequences. * There is no reliable and unintrusive way for a userland program to tell whether the target device is safe for media presence polling. For example, polling for media presence during an on-going burning session can make it fail. The polling program can avoid this by opening the device with O_EXCL but then it risks making a valid exclusive user of the device fail w/ -EBUSY. * Userland polling is unnecessarily heavy and in-kernel implementation is lighter and better coordinated (workqueue, timer slack). This patch implements framework for in-kernel disk event handling, which includes media presence polling. * bdops->check_events() is added, which supercedes ->media_changed(). It should check whether there's any pending event and return if so. Currently, two events are defined - DISK_EVENT_MEDIA_CHANGE and DISK_EVENT_EJECT_REQUEST. ->check_events() is guaranteed not to be called parallelly. * gendisk->events and ->async_events are added. These should be initialized by block driver before passing the device to add_disk(). The former contains the mask of all supported events and the latter the mask of all events which the device can report without polling. /sys/block/*/events[_async] export these to userland. * Kernel parameter block.events_dfl_poll_msecs controls the system polling interval (default is 0 which means disable) and /sys/block/*/events_poll_msecs control polling intervals for individual devices (default is -1 meaning use system setting). Note that if a device can report all supported events asynchronously and its polling interval isn't explicitly set, the device won't be polled regardless of the system polling interval. * If a device is opened exclusively with write access, event checking is automatically disabled until all write exclusive accesses are released. * There are event 'clearing' events. For example, both of currently defined events are cleared after the device has been successfully opened. This information is passed to ->check_events() callback using @clearing argument as a hint. * Event checking is always performed from system_nrt_wq and timer slack is set to 25% for polling. * Nothing changes for drivers which implement ->media_changed() but not ->check_events(). Going forward, all drivers will be converted to ->check_events() and ->media_change() will be dropped. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-16block: move register_disk() and del_gendisk() to block/genhd.cTejun Heo
There's no reason for register_disk() and del_gendisk() to be in fs/partitions/check.c. Move both to genhd.c. While at it, collapse unlink_gendisk(), which was artificially in a separate function due to genhd.c / check.c split, into del_gendisk(). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-10block: remove REQ_HARDBARRIERChristoph Hellwig
REQ_HARDBARRIER is dead now, so remove the leftovers. What's left at this point is: - various checks inside the block layer. - sanity checks in bio based drivers. - now unused bio_empty_barrier helper. - Xen blockfront use of BLKIF_OP_WRITE_BARRIER - it's dead for a while, but Xen really needs to sort out it's barrier situaton. - setting of ordered tags in uas - dead code copied from old scsi drivers. - scsi different retry for barriers - it's dead and should have been removed when flushes were converted to FS requests. - blktrace handling of barriers - removed. Someone who knows blktrace better should add support for REQ_FLUSH and REQ_FUA, though. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-27Merge branch 'next' into upstream-mergeTheodore Ts'o
Conflicts: fs/ext4/inode.c fs/ext4/mballoc.c include/trace/events/ext4.h
2010-10-27Add helper function for blkdev_issue_zeroout (sb_issue_discard)Lukas Czerner
This is done the same way as helper sb_issue_discard for blkdev_issue_discard. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-24Revert "block: fix accounting bug on cross partition merges"Jens Axboe
This reverts commit 7681bfeeccff5efa9eb29bf09249a3c400b15327. Conflicts: include/linux/genhd.h It has numerous issues with the cleanup path and non-elevator devices. Revert it for now so we can come up with a clean version without rushing things. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-22Merge branch 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits) xen-blkfront: disable barrier/flush write support Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c block: remove BLKDEV_IFL_WAIT aic7xxx_old: removed unused 'req' variable block: remove the BH_Eopnotsupp flag block: remove the BLKDEV_IFL_BARRIER flag block: remove the WRITE_BARRIER flag swap: do not send discards as barriers fat: do not send discards as barriers ext4: do not send discards as barriers jbd2: replace barriers with explicit flush / FUA usage jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier jbd: replace barriers with explicit flush / FUA usage nilfs2: replace barriers with explicit flush / FUA usage reiserfs: replace barriers with explicit flush / FUA usage gfs2: replace barriers with explicit flush / FUA usage btrfs: replace barriers with explicit flush / FUA usage xfs: replace barriers with explicit flush / FUA usage block: pass gfp_mask and flags to sb_issue_discard dm: convey that all flushes are processed as empty ...
2010-10-19block: fix accounting bug on cross partition mergesYasuaki Ishimatsu
/proc/diskstats would display a strange output as follows. $ cat /proc/diskstats |grep sda 8 0 sda 90524 7579 102154 20464 0 0 0 0 0 14096 20089 8 1 sda1 19085 1352 21841 4209 0 0 0 0 4294967064 15689 4293424691 ~~~~~~~~~~ 8 2 sda2 71252 3624 74891 15950 0 0 0 0 232 23995 1562390 8 3 sda3 54 487 2188 92 0 0 0 0 0 88 92 8 4 sda4 4 0 8 0 0 0 0 0 0 0 0 8 5 sda5 81 2027 2130 138 0 0 0 0 0 87 137 Its reason is the wrong way of accounting hd_struct->in_flight. When a bio is merged into a request belongs to different partition by ELEVATOR_FRONT_MERGE. The detailed root cause is as follows. Assuming that there are two partition, sda1 and sda2. 1. A request for sda2 is in request_queue. Hence sda1's hd_struct->in_flight is 0 and sda2's one is 1. | hd_struct->in_flight --------------------------- sda1 | 0 sda2 | 1 --------------------------- 2. A bio belongs to sda1 is issued and is merged into the request mentioned on step1 by ELEVATOR_BACK_MERGE. The first sector of the request is changed from sda2 region to sda1 region. However the two partition's hd_struct->in_flight are not changed. | hd_struct->in_flight --------------------------- sda1 | 0 sda2 | 1 --------------------------- 3. The request is finished and blk_account_io_done() is called. In this case, sda2's hd_struct->in_flight, not a sda1's one, is decremented. | hd_struct->in_flight --------------------------- sda1 | -1 sda2 | 1 --------------------------- The patch fixes the problem by caching the partition lookup inside the request structure, hence making sure that the increment and decrement will always happen on the same partition struct. This also speeds up IO with accounting enabled, since it cuts down on the number of lookups we have to do. When reloading partition tables, quiesce IO to ensure that no request references to the partition struct exists. When it is safe to free the partition table, the IO for that device is restarted again. Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-13block: Ensure physical block size is unsigned intMartin K. Petersen
Physical block size was declared unsigned int to accomodate the maximum size reported by READ CAPACITY(16). Make sure we use the right type in the related functions. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-16block: remove BLKDEV_IFL_WAITChristoph Hellwig
All the blkdev_issue_* helpers can only sanely be used for synchronous caller. To issue cache flushes or barriers asynchronously the caller needs to set up a bio by itself with a completion callback to move the asynchronous state machine ahead. So drop the BLKDEV_IFL_WAIT flag that is always specified when calling blkdev_issue_* and also remove the now unused flags argument to blkdev_issue_flush and blkdev_issue_zeroout. For blkdev_issue_discard we need to keep it for the secure discard flag, which gains a more descriptive name and loses the bitops vs flag confusion. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-16blkio: Core implementation of throttle policyVivek Goyal
o Actual implementation of throttling policy in block layer. Currently it implements READ and WRITE bytes per second throttling logic. IOPS throttling comes in later patches. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-15block: fix an address space warning in blk-map.cNamhyung Kim
Change type of 2nd parameter of blk_rq_aligned() into unsigned long and remove unnecessary casting. Now we can call it with 'uaddr' instead of 'ubuf' in __blk_rq_map_user() so that it can remove following warnings from sparse: block/blk-map.c:57:31: warning: incorrect type in argument 2 (different address spaces) block/blk-map.c:57:31: expected void *addr block/blk-map.c:57:31: got void [noderef] <asn:1>*ubuf However blk_rq_map_kern() needs one more local variable to handle it. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block/scsi: Provide a limit on the number of integrity segmentsMartin K. Petersen
Some controllers have a hardware limit on the number of protection information scatter-gather list segments they can handle. Introduce a max_integrity_segments limit in the block layer and provide a new scsi_host_template setting that allows HBA drivers to provide a value suitable for the hardware. Add support for honoring the integrity segment limit when merging both bios and requests. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2010-09-10block: remove the BLKDEV_IFL_BARRIER flagChristoph Hellwig
Remove support for barriers on discards, which is unused now. Also remove the DISCARD_NOBARRIER I/O type in favour of just setting the rw flags up locally in blkdev_issue_discard. tj: Also remove DISCARD_SECURE and use REQ_SECURE directly. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: pass gfp_mask and flags to sb_issue_discardChristoph Hellwig
We'll need to get rid of the BLKDEV_IFL_BARRIER flag, and to facilitate that and to make the interface less confusing pass all flags explicitly. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: implement REQ_FLUSH/FUA based interface for FLUSH/FUA requestsTejun Heo
Now that the backend conversion is complete, export sequenced FLUSH/FUA capability through REQ_FLUSH/FUA flags. REQ_FLUSH means the device cache should be flushed before executing the request. REQ_FUA means that the data in the request should be on non-volatile media on completion. Block layer will choose the correct way of implementing the semantics and execute it. The request may be passed to the device directly if the device can handle it; otherwise, it will be sequenced using one or more proxy requests. Devices will never see REQ_FLUSH and/or FUA which it doesn't support. Also, unlike the original REQ_HARDBARRIER, REQ_FLUSH/FUA requests are never failed with -EOPNOTSUPP. If the underlying device doesn't support FLUSH/FUA, the block layer simply make those noop. IOW, it no longer distinguishes between writeback cache which doesn't support cache flush and writethrough/no cache. Devices which have WB cache w/o flush are very difficult to come by these days and there's nothing much we can do anyway, so it doesn't make sense to require everyone to implement -EOPNOTSUPP handling. This will simplify filesystems and block drivers as they can drop -EOPNOTSUPP retry logic for barriers. * QUEUE_ORDERED_* are removed and QUEUE_FSEQ_* are moved into blk-flush.c. * REQ_FLUSH w/o data can also be directly passed to drivers without sequencing but some drivers assume that zero length requests don't have rq->bio which isn't true for these requests requiring the use of proxy requests. * REQ_COMMON_MASK now includes REQ_FLUSH | REQ_FUA so that they are copied from bio to request. * WRITE_BARRIER is marked deprecated and WRITE_FLUSH, WRITE_FUA and WRITE_FLUSH_FUA are added. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: rename barrier/ordered to flushTejun Heo
With ordering requirements dropped, barrier and ordered are misnomers. Now all block layer does is sequencing FLUSH and FUA. Rename them to flush. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: drop barrier ordering by queue drainingTejun Heo
Filesystems will take all the responsibilities for ordering requests around commit writes and will only indicate how the commit writes themselves should be handled by block layers. This patch drops barrier ordering by queue draining from block layer. Ordering by draining implementation was somewhat invasive to request handling. List of notable changes follow. * Each queue has 1 bit color which is flipped on each barrier issue. This is used to track whether a given request is issued before the current barrier or not. REQ_ORDERED_COLOR flag and coloring implementation in __elv_add_request() are removed. * Requests which shouldn't be processed yet for draining were stalled by returning -EAGAIN from blk_do_ordered() according to the test result between blk_ordered_req_seq() and blk_blk_ordered_cur_seq(). This logic is removed. * Draining completion logic in elv_completed_request() removed. * All barrier sequence requests were queued to request queue and then trckled to lower layer according to progress and thus maintaining request orders during requeue was necessary. This is replaced by queueing the next request in the barrier sequence only after the current one is complete from blk_ordered_complete_seq(), which removes the need for multiple proxy requests in struct request_queue and the request sorting logic in the ELEVATOR_INSERT_REQUEUE path of elv_insert(). * As barriers no longer have ordering constraints, there's no need to dump the whole elevator onto the dispatch queue on each barrier. Insert barriers at the front instead. * If other barrier requests come to the front of the dispatch queue while one is already in progress, they are stored in q->pending_barriers and restored to dispatch queue one-by-one after each barrier completion from blk_ordered_complete_seq(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: misc cleanups in barrier codeTejun Heo
Make the following cleanups in preparation of barrier/flush update. * blk_do_ordered() declaration is moved from include/linux/blkdev.h to block/blk.h. * blk_do_ordered() now returns pointer to struct request, with %NULL meaning "try the next request" and ERR_PTR(-EAGAIN) "try again later". The third case will be dropped with further changes. * In the initialization of proxy barrier request, data direction is already set by init_request_from_bio(). Drop unnecessary explicit REQ_WRITE setting and move init_request_from_bio() above REQ_FUA flag setting. * add_request() is collapsed into __make_request(). These changes don't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: deprecate barrier and replace blk_queue_ordered() with blk_queue_flush()Tejun Heo
Barrier is deemed too heavy and will soon be replaced by FLUSH/FUA requests. Deprecate barrier. All REQ_HARDBARRIERs are failed with -EOPNOTSUPP and blk_queue_ordered() is replaced with simpler blk_queue_flush(). blk_queue_flush() takes combinations of REQ_FLUSH and FUA. If a device has write cache and can flush it, it should set REQ_FLUSH. If the device can handle FUA writes, it should also set REQ_FUA. All blk_queue_ordered() users are converted. * ORDERED_DRAIN is mapped to 0 which is the default value. * ORDERED_DRAIN_FLUSH is mapped to REQ_FLUSH. * ORDERED_DRAIN_FLUSH_FUA is mapped to REQ_FLUSH | REQ_FUA. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Boaz Harrosh <bharrosh@panasas.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: David S. Miller <davem@davemloft.net> Cc: Alasdair G Kergon <agk@redhat.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Cc: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: kill QUEUE_ORDERED_BY_TAGTejun Heo
Nobody is making meaningful use of ORDERED_BY_TAG now and queue draining for barrier requests will be removed soon which will render the advantage of tag ordering moot. Kill ORDERED_BY_TAG. The following users are affected. * brd: converted to ORDERED_DRAIN. * virtio_blk: ORDERED_TAG path was already marked deprecated. Removed. * xen-blkfront: ORDERED_TAG case dropped. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10ide: remove unnecessary blk_queue_flushing() test in do_ide_request()Tejun Heo
Unplugging from a request function doesn't really help much (it's already in the request_fn) and soon block layer will be updated to mix barrier sequence with other commands, so there's no need to treat queue flushing any differently. ide was the only user of blk_queue_flushing(). Remove it. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@lst.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-12block: add secure discardAdrian Hunter
Secure discard is the same as discard except that all copies of the discarded sectors (perhaps created by garbage collection) must also be erased. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Jens Axboe <axboe@kernel.dk> Cc: Kyungmin Park <kmpark@infradead.org> Cc: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Ben Gardiner <bengardiner@nanometrics.ca> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-07block: disallow FS recursion from sb_issue_discard allocationMike Snitzer
Filesystems can call sb_issue_discard on a memory reclaim path (e.g. ext4 calls sb_issue_discard during journal commit). Use GFP_NOFS in sb_issue_discard to avoid recursing back into the FS. Reported-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: push down BKL into .locked_ioctlArnd Bergmann
As a preparation for the removal of the big kernel lock in the block layer, this removes the BKL from the common ioctl handling code, moving it into every single driver still using it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove unused REQ_TYPE_LINUX_BLOCKFUJITA Tomonori
Nobody uses REQ_TYPE_LINUX_BLOCK (and its REQ_LB_OP_*). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove q->prepare_flush_fn completelyFUJITA Tomonori
This removes q->prepare_flush_fn completely (changes the blk_queue_ordered API). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: implement an unprep function corresponding directly to prepJames Bottomley
Reviewed-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: don't allocate a payload for discard requestChristoph Hellwig
Allocating a fixed payload for discard requests always was a horrible hack, and it's not coming to byte us when adding support for discard in DM/MD. So change the code to leave the allocation of a payload to the lowlevel driver. Unfortunately that means we'll need another hack, which allows us to update the various block layer length fields indicating that we have a payload. Instead of hiding this in sd.c, which we already partially do for UNMAP support add a documented helper in the core block layer for it. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: unify flags for struct bio and struct requestChristoph Hellwig
Remove the current bio flags and reuse the request flags for the bio, too. This allows to more easily trace the type of I/O from the filesystem down to the block driver. There were two flags in the bio that were missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've renamed two request flags that had a superflous RW in them. Note that the flags are in bio.h despite having the REQ_ name - as blkdev.h includes bio.h that is the only way to go for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove wrappers for request type/flagsChristoph Hellwig
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in struct requests. This allows much easier grepping for different request types instead of unwinding through macros. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: kill ISA_DMA_THRESHOLD usageFUJITA Tomonori
block uses ISA_DMA_THRESHOLD for BLK_BOUNCE_ISA. Only SCSI uses ISA_DMA_THRESHOLD for ancient drivers with non-zero unchecked_isa_dma. Nowadays drivers (and subsystems) use dma_mask properly instead of ISA_DMA_THRESHOLD. Documentation/scsi/scsi_mid_low_api.txt says: unchecked_isa_dma - 1=>only use bottom 16 MB of ram (ISA DMA addressing restriction), 0=>can use full 32 bit (or better) DMA address space So block simply uses DMA_BIT_MASK(24) for BLK_BOUNCE_ISA for SCSI. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: add sysfs knob for turning off disk entropy contributionsJens Axboe
There are two reasons for doing this: - On SSD disks, the completion times aren't as random as they are for rotational drives. So it's questionable whether they should contribute to the random pool in the first place. - Calling add_disk_randomness() has a lot of overhead. This adds /sys/block/<dev>/queue/add_random that will allow you to switch off on a per-device basis. The default setting is on, so there should be no functional changes from this patch. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-06-01block: disable preemption before using sched_clock()Jens Axboe
Commit 9195291e5f05e01d67f9a09c756b8aca8f009089 added calls to sched_clock() from preemptible code. sched_clock() is both the wrong interface AND cannot be called without preempt disabled. Apply a temporary fix to get rid of the warnings, a real patch is in the works. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-05-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (577 commits) Staging: ramzswap: Handler for swap slot free callback swap: Add swap slot free callback to block_device_operations swap: Add flag to identify block swap devices Staging: vt6655: use ETH_FRAME_LEN macro instead of custom one Staging: vt6655: use ETH_DATA_LEN macro instead of custom one Staging: vt6655: use ETH_FCS_LEN macro instead of custom one Staging: vt6656: use ETH_HLEN macro instead of custom one Staging: comedi: quatech_daqp_cs.c Replace eos semaphore with a completion. Staging: dt3155v4l: remove private memory allocator Staging: crystalhd: Remove typedefs from driver Staging: winbond: Fix for pointer name format issue in mds.c Staging: vt6656: removed custom UCHAR/USHORT/UINT/ULONG/ULONGLONG typedefs Staging: vt6656: removed custom CHAR/SHORT/INT/LONG typedefs Staging: comedi: Altered the way printk is used in 8255.c staging: iio: adis16350 and similar IMU driver Staging: iio: max1363 Fix two bugs in single_channel_from_ring Staging: iio: adis16220 extract bin_attribute structures from state Staging: iio: adis16220 vibration sensor driver Staging: comedi: Kconfig dependancy fixes Staging: comedi: fix up build error from last Kconfig changes ...
2010-05-21block,ide: simplify bdops->set_capacity() to ->unlock_native_capacity()Tejun Heo
bdops->set_capacity() is unnecessarily generic. All that's required is a simple one way notification to lower level driver telling it to try to unlock native capacity. There's no reason to pass in target capacity or return the new capacity. The former is always the inherent native capacity and the latter can be handled via the usual device resize / revalidation path. In fact, the current API is always used that way. Replace ->set_capacity() with ->unlock_native_capacity() which take only @disk and doesn't return anything. IDE which is the only current user of the API is converted accordingly. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-18swap: Add swap slot free callback to block_device_operationsNitin Gupta
This callback is required when RAM based devices are used as swap disks. One such device is ramzswap which is used as compressed in-memory swap disk. For such devices, we need a callback as soon as a swap slot is no longer used to allow freeing memory allocated for this slot. Without this callback, stale data can quickly accumulate in memory defeating the whole purpose of such devices. Signed-off-by: Nitin Gupta <ngupta@vflare.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Nigel Cunningham <nigel@tuxonice.net> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-11block: allow initialization of previously allocated request_queueMike Snitzer
blk_init_queue() allocates the request_queue structure and then initializes it as needed (request_fn, elevator, etc). Split initialization out to blk_init_allocated_queue_node. Introduce blk_init_allocated_queue wrapper function to model existing blk_init_queue and blk_init_queue_node interfaces. Export elv_register_queue to allow a newly added elevator to be registered with sysfs. Export elv_unregister_queue for symmetry. These changes allow DM to initialize a device's request_queue with more precision. In particular, DM no longer unconditionally initializes a full request_queue (elevator et al). It only does so for a request-based DM device. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-28blkdev: add blkdev_issue_zeroout helper functionDmitry Monakhov
- Add bio_batch helper primitive. This is rather generic primitive for submitting/waiting a complex request which consists of several bios. - blkdev_issue_zeroout() generate number of zero filed write bios. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-28blkdev: generalize flags for blkdev_issue_fn functionsDmitry Monakhov
The patch just convert all blkdev_issue_xxx function to common set of flags. Wait/allocation semantics preserved. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-21blkio: Fix blkio crash during rq stat updateVivek Goyal
blkio + cfq was crashing even when two sequential readers were put in two separate cgroups (group_isolation=0). The reason being that cfqq can migrate across groups based on its being sync-noidle or not, it can happen that at request insertion time, cfqq belonged to one cfqg and at request dispatch time, it belonged to root group. In this case request stats per cgroup can go wrong and it also runs into BUG_ON(). This patch implements rq stashing away a cfq group pointer and not relying on cfqq->cfqg pointer alone for rq stat accounting. [ 65.163523] ------------[ cut here ]------------ [ 65.164301] kernel BUG at block/blk-cgroup.c:117! [ 65.164301] invalid opcode: 0000 [#1] SMP [ 65.164301] last sysfs file: /sys/devices/pci0000:00/0000:00:05.0/0000:60:00.1/host9/rport-9:0-0/target9:0:0/9:0:0:2/block/sde/stat [ 65.164301] CPU 1 [ 65.164301] Modules linked in: dm_round_robin dm_multipath qla2xxx scsi_transport_fc dm_zero dm_mirror dm_region_hash dm_log dm_mod [last unloaded: scsi_wait_scan] [ 65.164301] [ 65.164301] Pid: 4505, comm: fio Not tainted 2.6.34-rc4-blk-for-35 #34 0A98h/HP xw8600 Workstation [ 65.164301] RIP: 0010:[<ffffffff8121924f>] [<ffffffff8121924f>] blkiocg_update_io_remove_stats+0x5b/0xaf [ 65.164301] RSP: 0018:ffff8800ba5a79e8 EFLAGS: 00010046 [ 65.164301] RAX: 0000000000000096 RBX: ffff8800bb268d60 RCX: 0000000000000000 [ 65.164301] RDX: ffff8800bb268eb8 RSI: 0000000000000000 RDI: ffff8800bb268e00 [ 65.164301] RBP: ffff8800ba5a7a08 R08: 0000000000000064 R09: 0000000000000001 [ 65.164301] R10: 0000000000079640 R11: ffff8800a0bd5bf0 R12: ffff8800bab4af01 [ 65.164301] R13: ffff8800bab4af00 R14: ffff8800bb1d8928 R15: 0000000000000000 [ 65.164301] FS: 00007f18f75056f0(0000) GS:ffff880001e40000(0000) knlGS:0000000000000000 [ 65.164301] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 65.164301] CR2: 000000000040e7f0 CR3: 00000000ba52b000 CR4: 00000000000006e0 [ 65.164301] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 65.164301] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 65.164301] Process fio (pid: 4505, threadinfo ffff8800ba5a6000, task ffff8800ba45ae80) [ 65.164301] Stack: [ 65.164301] ffff8800ba5a7a08 ffff8800ba722540 ffff8800bab4af68 ffff8800bab4af68 [ 65.164301] <0> ffff8800ba5a7a38 ffffffff8121d814 ffff8800ba722540 ffff8800bab4af68 [ 65.164301] <0> ffff8800ba722540 ffff8800a08f6800 ffff8800ba5a7a68 ffffffff8121d8ca [ 65.164301] Call Trace: [ 65.164301] [<ffffffff8121d814>] cfq_remove_request+0xe4/0x116 [ 65.164301] [<ffffffff8121d8ca>] cfq_dispatch_insert+0x84/0xe1 [ 65.164301] [<ffffffff8121e833>] cfq_dispatch_requests+0x767/0x8e8 [ 65.164301] [<ffffffff8120e524>] ? submit_bio+0xc3/0xcc [ 65.164301] [<ffffffff810ad657>] ? sync_page_killable+0x0/0x35 [ 65.164301] [<ffffffff8120ea8d>] blk_peek_request+0x191/0x1a7 [ 65.164301] [<ffffffffa000109c>] ? dm_get_live_table+0x44/0x4f [dm_mod] [ 65.164301] [<ffffffffa0002799>] dm_request_fn+0x38/0x14c [dm_mod] [ 65.164301] [<ffffffff810ad657>] ? sync_page_killable+0x0/0x35 [ 65.164301] [<ffffffff8120f600>] __generic_unplug_device+0x32/0x37 [ 65.164301] [<ffffffff8120f8a0>] generic_unplug_device+0x2e/0x3c [ 65.164301] [<ffffffffa00011a6>] dm_unplug_all+0x42/0x5b [dm_mod] [ 65.164301] [<ffffffff8120b063>] blk_unplug+0x29/0x2d [ 65.164301] [<ffffffff8120b079>] blk_backing_dev_unplug+0x12/0x14 [ 65.164301] [<ffffffff81108a82>] block_sync_page+0x35/0x39 [ 65.164301] [<ffffffff810ad64e>] sync_page+0x41/0x4a [ 65.164301] [<ffffffff810ad665>] sync_page_killable+0xe/0x35 [ 65.164301] [<ffffffff81589027>] __wait_on_bit_lock+0x46/0x8f [ 65.164301] [<ffffffff810ad52d>] __lock_page_killable+0x66/0x6d [ 65.164301] [<ffffffff81055fd4>] ? wake_bit_function+0x0/0x33 [ 65.164301] [<ffffffff810ad560>] lock_page_killable+0x2c/0x2e [ 65.164301] [<ffffffff810aebfd>] generic_file_aio_read+0x361/0x4f0 [ 65.164301] [<ffffffff810e906c>] do_sync_read+0xcb/0x108 [ 65.164301] [<ffffffff811e32a3>] ? security_file_permission+0x16/0x18 [ 65.164301] [<ffffffff810e96d3>] vfs_read+0xab/0x108 [ 65.164301] [<ffffffff810e97f0>] sys_read+0x4a/0x6e [ 65.164301] [<ffffffff81002b5b>] system_call_fastpath+0x16/0x1b [ 65.164301] Code: 00 74 1c 48 8b 8b 60 01 00 00 48 85 c9 75 04 0f 0b eb fe 48 ff c9 48 89 8b 60 01 00 00 eb 1a 48 8b 8b 58 01 00 00 48 85 c9 75 04 <0f> 0b eb fe 48 ff c9 48 89 8b 58 01 00 00 45 84 e4 74 16 48 8b [ 65.164301] RIP [<ffffffff8121924f>] blkiocg_update_io_remove_stats+0x5b/0xaf [ 65.164301] RSP <ffff8800ba5a79e8> [ 65.164301] ---[ end trace 1b2b828753032e68 ]--- Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-09blkio: Changes to IO controller additional stats patchesDivyesh Shah
that include some minor fixes and addresses all comments. Changelog: (most based on Vivek Goyal's comments) o renamed blkiocg_reset_write to blkiocg_reset_stats o more clarification in the documentation on io_service_time and io_wait_time o Initialize blkg->stats_lock o rename io_add_stat to blkio_add_stat and declare it static o use bool for direction and sync o derive direction and sync info from existing rq methods o use 12 for major:minor string length o define io_service_time better to cover the NCQ case o add a separate reset_stats interface o make the indexed stats a 2d array to simplify macro and function pointer code o blkio.time now exports in jiffies as before o Added stats description in patch description and Documentation/cgroup/blkio-controller.txt o Prefix all stats functions with blkio and make them static as applicable o replace IO_TYPE_MAX with IO_TYPE_TOTAL o Moved #define constant to top of blk-cgroup.c o Pass dev_t around instead of char * o Add note to documentation file about resetting stats o use BLK_CGROUP_MODULE in addition to BLK_CGROUP config option in #ifdef statements o Avoid struct request specific knowledge in blk-cgroup. blk-cgroup.h now has rq_direction() and rq_sync() functions which are used by CFQ and when using io-controller at a higher level, bio_* functions can be added. Signed-off-by: Divyesh Shah<dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-02blkio: Increment the blkio cgroup stats for real nowDivyesh Shah
We also add start_time_ns and io_start_time_ns fields to struct request here to record the time when a request is created and when it is dispatched to device. We use ns uints here as ms and jiffies are not very useful for non-rotational media. Signed-off-by: Divyesh Shah<dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
