path: root/include/linux/bitops.h
2010-11-15bitops: Provide generic sign_extend32 functionAndreas Herrmann
This patch moves code out from wireless drivers where two different functions are defined in three code locations for the same purpose and provides a common function to sign extend a 32-bit value. Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-09bitops: remove duplicated extern declarationsAkinobu Mita
If CONFIG_GENERIC_FIND_NEXT_BIT is enabled, find_next_bit() and find_next_zero_bit() are doubly declared in asm-generic/bitops/find.h and linux/bitops.h. asm/bitops.h includes asm-generic/bitops/find.h if and only if the architecture enables CONFIG_GENERIC_FIND_NEXT_BIT. And asm/bitops.h is included by linux/bitops.h So we can just remove the extern declarations of find_next_bit() and find_next_zero_bit() in linux/bitops.h. Also we can remove unneeded #ifndef CONFIG_GENERIC_FIND_NEXT_BIT in asm-generic/bitops/find.h. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-09bitops: make asm-generic/bitops/find.h more genericAkinobu Mita
asm-generic/bitops/find.h has the extern declarations of find_next_bit() and find_next_zero_bit() and the macro definitions of find_first_bit() and find_first_zero_bit(). It is only usable by the architectures which enables CONFIG_GENERIC_FIND_NEXT_BIT and disables CONFIG_GENERIC_FIND_FIRST_BIT. x86 and tile enable both CONFIG_GENERIC_FIND_NEXT_BIT and CONFIG_GENERIC_FIND_FIRST_BIT. These architectures cannot include asm-generic/bitops/find.h in their asm/bitops.h. So ifdefed extern declarations of find_first_bit and find_first_zero_bit() are put in linux/bitops.h. This makes asm-generic/bitops/find.h usable by these architectures and use it. Also this change is needed for the forthcoming duplicated extern declarations cleanup. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: x86@kernel.org Cc: Chris Metcalf <cmetcalf@tilera.com>
2010-05-18Merge branch 'core-hweight-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-hweight-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, hweight: Use a 32-bit popcnt for __arch_hweight32() arch, hweight: Fix compilation errors x86: Add optimized popcnt variants bitops: Optimize hweight() by making use of compile-time evaluation
2010-05-04arch, hweight: Fix compilation errorsBorislav Petkov
Fix function prototype visibility issues when compiling for non-x86 architectures. Tested with crosstool (ftp://ftp.kernel.org/pub/tools/crosstool/) with alpha, ia64 and sparc targets. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> LKML-Reference: <20100503130736.GD26107@aftab> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-04-07bitops: remove temporary for_each_bit()Andrew Morton
Migration has been completed so remove this now. There's one straggler in linux-next's drivers/mtd/sm_ftl.c. A patch has been sent. Cc: Akinobu Mita <akinobu.mita@gmail.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-06bitops: Optimize hweight() by making use of compile-time evaluationPeter Zijlstra
Rename the extisting runtime hweight() implementations to __arch_hweight(), rename the compile-time versions to __const_hweight() and then have hweight() pick between them. Suggested-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20100318111929.GB11152@aftab> Acked-by: H. Peter Anvin <hpa@zytor.com> LKML-Reference: <1265028224.24455.154.camel@laptop> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-03-06bitops: rename for_each_bit() to for_each_set_bit()Akinobu Mita
Rename for_each_bit to for_each_set_bit in the kernel source tree. To permit for_each_clear_bit(), should that ever be added. The patch includes a macro to map the old for_each_bit() onto the new for_each_set_bit(). This is a (very) temporary thing to ease the migration. [akpm@linux-foundation.org: add temporary for_each_bit()] Suggested-by: Alexey Dobriyan <adobriyan@gmail.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Artem Bityutskiy <dedekind@infradead.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-04bitops: Ensure the compile time HWEIGHT is only used for suchPeter Zijlstra
Avoid accidental misuse by failing to compile things Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-29bitops: Provide compile time HWEIGHT{8,16,32,64}Peter Zijlstra
Provide compile time versions of hweight. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <20100122155535.797688466@chello.nl> [ Remove some whitespace damage while we are at it ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-23bitops: Add __ffs64 bitopSteven Whitehouse
Finds the first set bit in a 64 bit word. This is required in order to fix a bug in GFS2, but I think it should be a generic function in case of future users. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Reviewed-by: Christoph Lameter <cl@linux.com> Reviewed-by: Willy Tarreau <w@1wt.eu>
2009-01-01bitmap: find_last_bit()Rusty Russell
Impact: New API As the name suggests. For the moment everyone uses the generic one. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-04-29bitops: remove "optimizations"Thomas Gleixner
The mapsize optimizations which were moved from x86 to the generic code in commit 64970b68d2b3ed32b964b0b30b1b98518fde388e increased the binary size on non x86 architectures. Looking into the real effects of the "optimizations" it turned out that they are not used in find_next_bit() and find_next_zero_bit(). The ones in find_first_bit() and find_first_zero_bit() are used in a couple of places but none of them is a real hot path. Remove the "optimizations" all together and call the library functions unconditionally. Boot-tested on x86 and compile tested on every cross compiler I have. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Avoid divides in BITS_TO_LONGSEric Dumazet
BITS_PER_LONG is a signed value (32 or 64) DIV_ROUND_UP(nr, BITS_PER_LONG) performs signed arithmetic if "nr" is signed too. Converting BITS_TO_LONGS(nr) to DIV_ROUND_UP(nr, BITS_PER_BYTE * sizeof(long)) makes sure compiler can perform a right shift, even if "nr" is a signed value, instead of an expensive integer divide. Applying this patch saves 141 bytes on x86 when CONFIG_CC_OPTIMIZE_FOR_SIZE=y and speedup bitmap operations. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-26x86: optimize find_first_bit for small bitmapsAlexander van Heukelum
Avoid a call to find_first_bit if the bitmap size is know at compile time and small enough to fit in a single long integer. Modeled after an optimization in the original x86_64-specific code. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86: generic versions of find_first_(zero_)bit, convert i386Alexander van Heukelum
Generic versions of __find_first_bit and __find_first_zero_bit are introduced as simplified versions of __find_next_bit and __find_next_zero_bit. Their compilation and use are guarded by a new config variable GENERIC_FIND_FIRST_BIT. The generic versions of find_first_bit and find_first_zero_bit are implemented in terms of the newly introduced __find_first_bit and __find_first_zero_bit. This patch does not remove the i386-specific implementation, but it does switch i386 to use the generic functions by setting GENERIC_FIND_FIRST_BIT=y for X86_32. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86, generic: optimize find_next_(zero_)bit for small constant-size bitmapsAlexander van Heukelum
This moves an optimization for searching constant-sized small bitmaps form x86_64-specific to generic code. On an i386 defconfig (the x86#testing one), the size of vmlinux hardly changes with this applied. I have observed only four places where this optimization avoids a call into find_next_bit: In the functions return_unused_surplus_pages, alloc_fresh_huge_page, and adjust_pool_surplus, this patch avoids a call for a 1-bit bitmap. In __next_cpu a call is avoided for a 32-bit bitmap. That's it. On x86_64, 52 locations are optimized with a minimal increase in code size: Current #testing defconfig: 146 x bsf, 27 x find_next_*bit text data bss dec hex filename 5392637 846592 724424 6963653 6a41c5 vmlinux After removing the x86_64 specific optimization for find_next_*bit: 94 x bsf, 79 x find_next_*bit text data bss dec hex filename 5392358 846592 724424 6963374 6a40ae vmlinux After this patch (making the optimization generic): 146 x bsf, 27 x find_next_*bit text data bss dec hex filename 5392396 846592 724424 6963412 6a40d4 vmlinux [ tglx@linutronix.de: build fixes ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-28kernel: add bit rotation helpers for 16 and 8 bitHarvey Harrison
Will replace open-coded variants elsewhere. Done in the same style as the 32-bit versions. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: John W. Linville <linville@tuxdriver.com> Cc: Joe Perches <joe@perches.com> Cc: Jiri Benc <jbenc@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19remove BITS_TO_TYPE macroJiri Slaby
remove BITS_TO_TYPE macro I realized, that it is actually the same as DIV_ROUND_UP, use it instead. [akpm@linux-foundation.org: build fix] Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19define global BIT macroJiri Slaby
define global BIT macro move all local BIT defines to the new globally define macro. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19define first set of BIT* macrosJiri Slaby
define first set of BIT* macros - move BITOP_MASK and BITOP_WORD from asm-generic/bitops/atomic.h to include/linux/bitops.h and rename it to BIT_MASK and BIT_WORD - move BITS_TO_LONGS and BITS_PER_BYTE to bitops.h too and allow easily define another BITS_TO_something (e.g. in event.c) by BITS_TO_TYPE macro Remaining (and common) BIT macro will be defined after all occurences and conflicts will be sorted out in the patches. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16I/OAT: Add support for MSI and MSI-XShannon Nelson
Add support for MSI and MSI-X interrupt handling, including the ability to choose the desired interrupt method. Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> Acked-by: David S. Miller <davem@davemloft.net> [bunk@kernel.org: drivers/dma/ioat_dma.c: make 3 functions static] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-26[PATCH] fix various kernel-doc in header filesRobert P. J. Day
Fix a number of kernel-doc entries for header files in include/linux by making sure they begin with the appropriate '/**' notation and use @var notation. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-03-26[PATCH] bitops: remove unused generic bitops in include/linux/bitops.hAkinobu Mita
generic_{ffs,fls,fls64,hweight{64,32,16,8}}() were moved into include/asm-generic/bitops.h. So all architectures don't use them. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] roundup_pow_of_two() 64-bit fixAndrew Morton
fls() takes an integer, so roundup_pow_of_two() is busted for ulongs larger than 2^32-1. Fix this by implementing and using fls_long(). (Why does roundup_pow_of_two() return a long?) (Why is roundup_pow_of_two() __attribute_const__ whereas long_log2() is __attribute_pure__?) (Why does long_log2() suck so much? Because we were missing fls_long()?) Cc: Roland Dreier <rdreier@cisco.com> Cc: "Chen, Kenneth W" <kenneth.w.chen@intel.com> Cc: John Hawkes <hawkes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] fix generic_fls64()Akinobu Mita
Noticed by Rune Torgersen. Fix generic_fls64(). tcp_cubic is using fls64(). Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[FLS64]: generic versionStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-14[PATCH] x86-64/i386: Intel HT, Multi core detection fixesSiddha, Suresh B
Fields obtained through cpuid vector 0x1(ebx[16:23]) and vector 0x4(eax[14:25], eax[26:31]) indicate the maximum values and might not always be the same as what is available and what OS sees. So make sure "siblings" and "cpu cores" values in /proc/cpuinfo reflect the values as seen by OS instead of what cpuid instruction says. This will also fix the buggy BIOS cases (for example where cpuid on a single core cpu says there are "2" siblings, even when HT is disabled in the BIOS. http://bugzilla.kernel.org/show_bug.cgi?id=4359) Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
