path: root/include/linux/audit.h
2008-06-24[PATCH] remove useless argument type in audit_filter_user()Peng Haitao
The second argument "type" is not used in audit_filter_user(), so I think that type can be removed. If I'm wrong, please tell me. Signed-off-by: Peng Haitao <penght@cn.fujitsu.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-28[PATCH] new predicate - AUDIT_FILETYPEAl Viro
Argument is S_IF... | <index>, where index is normally 0 or 1. Triggers if chosen element of ctx->names[] is present and the mode of object in question matches the upper bits of argument. I.e. for things like "is the argument of that chmod a directory", etc. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-28Audit: increase the maximum length of the key fieldEric Paris
Key lengths were arbitrarily limited to 32 characters. If userspace is going to start using the single kernel key field as multiple virtual key fields (example key=key1,key2,key3,key4) we should give them enough room to work. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-28Audit: standardize string audit interfacesEric Paris
This patch standardized the string auditing interfaces. No userspace changes will be visible and this is all just cleanup and consistancy work. We have the following string audit interfaces to use: void audit_log_n_hex(struct audit_buffer *ab, const unsigned char *buf, size_t len); void audit_log_n_string(struct audit_buffer *ab, const char *buf, size_t n); void audit_log_string(struct audit_buffer *ab, const char *buf); void audit_log_n_untrustedstring(struct audit_buffer *ab, const char *string, size_t n); void audit_log_untrustedstring(struct audit_buffer *ab, const char *string); This may be the first step to possibly fixing some of the issues that people have with the string output from the kernel audit system. But we still don't have an agreed upon solution to that problem. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-28Audit: collect sessionid in netlink messagesEric Paris
Previously I added sessionid output to all audit messages where it was available but we still didn't know the sessionid of the sender of netlink messages. This patch adds that information to netlink messages so we can audit who sent netlink messages. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-19Audit: Final renamings and cleanupAhmed S. Darwish
Rename the se_str and se_rule audit fields elements to lsm_str and lsm_rule to avoid confusion. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Acked-by: James Morris <jmorris@namei.org>
2008-04-19SELinux: use new audit hooks, remove redundant exportsAhmed S. Darwish
Setup the new Audit LSM hooks for SELinux. Remove the now redundant exported SELinux Audit interface. Audit: Export 'audit_krule' and 'audit_field' to the public since their internals are needed by the implementation of the new LSM hook 'audit_rule_known'. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Acked-by: James Morris <jmorris@namei.org>
2008-02-14d_path: Use struct path in struct avc_audit_dataJan Blunck
audit_log_d_path() is a d_path() wrapper that is used by the audit code. To use a struct path in audit_log_d_path() I need to embed it into struct avc_audit_data. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01[AUDIT] break large execve argument logging into smaller messagesEric Paris
execve arguments can be quite large. There is no limit on the number of arguments and a 4G limit on the size of an argument. this patch prints those aruguments in bite sized pieces. a userspace size limitation of 8k was discovered so this keeps messages around 7.5k single arguments larger than 7.5k in length are split into multiple records and can be identified as aX[Y]= Signed-off-by: Eric Paris <eparis@redhat.com>
2008-02-01[AUDIT] Add End of Event recordEric Paris
This patch adds an end of event record type. It will be sent by the kernel as the last record when a multi-record event is triggered. This will aid realtime analysis programs since they will now reliably know they have the last record to complete an event. The audit daemon filters this and will not write it to disk. Signed-off-by: Steve Grubb <sgrubb redhat com> Signed-off-by: Eric Paris <eparis@redhat.com>
2008-02-01[AUDIT] add session id to audit messagesEric Paris
In order to correlate audit records to an individual login add a session id. This is incremented every time a user logs in and is included in almost all messages which currently output the auid. The field is labeled ses= or oses= Signed-off-by: Eric Paris <eparis@redhat.com>
2008-02-01[PATCH] get rid of loginuid racesAl Viro
Keeping loginuid in audit_context is racy and results in messier code. Taken to task_struct, out of the way of ->audit_context changes. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-01[PATCH] switch audit_get_loginuid() to task_struct *Al Viro
all callers pass something->audit_context Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-01-30NetLabel: Add auditing to the static labeling mechanismPaul Moore
This patch adds auditing support to the NetLabel static labeling mechanism. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2007-10-21[PATCH] audit: watching subtreesAl Viro
New kind of audit rule predicates: "object is visible in given subtree". The part that can be sanely implemented, that is. Limitations: * if you have hardlink from outside of tree, you'd better watch it too (or just watch the object itself, obviously) * if you mount something under a watched tree, tell audit that new chunk should be added to watched subtrees * if you umount something in a watched tree and it's still mounted elsewhere, you will get matches on events happening there. New command tells audit to recalculate the trees, trimming such sources of false positives. Note that it's _not_ about path - if something mounted in several places (multiple mount, bindings, different namespaces, etc.), the match does _not_ depend on which one we are using for access. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-10-21[PATCH] pass dentry to audit_inode()/audit_inode_child()Al Viro
makes caller simpler *and* allows to scan ancestors Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-10-10[XFRM]: xfrm audit callsJoy Latten
This patch modifies the current ipsec audit layer by breaking it up into purpose driven audit calls. So far, the only audit calls made are when add/delete an SA/policy. It had been discussed to give each key manager it's own calls to do this, but I found there to be much redundnacy since they did the exact same things, except for how they got auid and sid, so I combined them. The below audit calls can be made by any key manager. Hopefully, this is ok. Signed-off-by: Joy Latten <latten@austin.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-23Renumber AUDIT_TTY_[GS]ETMiloslav Trmac
Renumber AUDIT_TTY_[GS]ET to avoid a conflict with netlink message types already used in the wild. Signed-off-by: Miloslav Trmac <mitr@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-22[PATCH] get rid of AVC_PATH postponed treatmentAl Viro
Selinux folks had been complaining about the lack of AVC_PATH records when audit is disabled. I must admit my stupidity - I assumed that avc_audit() really couldn't use audit_log_d_path() because of deadlocks (== could be called with dcache_lock or vfsmount_lock held). Shouldn't have made that assumption - it never gets called that way. It _is_ called under spinlocks, but not those. Since audit_log_d_path() uses ab->gfp_mask for allocations, kmalloc() in there is not a problem. IOW, the simple fix is sufficient: let's rip AUDIT_AVC_PATH out and simply generate pathname as part of main record. It's trivial to do. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: James Morris <jmorris@namei.org>
2007-07-22[PATCH] allow audit filtering on bit & operationsEric Paris
Right now the audit filter can match on = != > < >= blah blah blah. This allow the filter to also look at bitwise AND operations, & Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-07-16Audit: add TTY input auditingMiloslav Trmac
Add TTY input auditing, used to audit system administrator's actions. This is required by various security standards such as DCID 6/3 and PCI to provide non-repudiation of administrator's actions and to allow a review of past actions if the administrator seems to overstep their duties or if the system becomes misconfigured for unknown reasons. These requirements do not make it necessary to audit TTY output as well. Compared to an user-space keylogger, this approach records TTY input using the audit subsystem, correlated with other audit events, and it is completely transparent to the user-space application (e.g. the console ioctls still work). TTY input auditing works on a higher level than auditing all system calls within the session, which would produce an overwhelming amount of mostly useless audit events. Add an "audit_tty" attribute, inherited across fork (). Data read from TTYs by process with the attribute is sent to the audit subsystem by the kernel. The audit netlink interface is extended to allow modifying the audit_tty attribute, and to allow sending explanatory audit events from user-space (for example, a shell might send an event containing the final command, after the interactive command-line editing and history expansion is performed, which might be difficult to decipher from the TTY input alone). Because the "audit_tty" attribute is inherited across fork (), it would be set e.g. for sshd restarted within an audited session. To prevent this, the audit_tty attribute is cleared when a process with no open TTY file descriptors (e.g. after daemon startup) opens a TTY. See https://www.redhat.com/archives/linux-audit/2007-June/msg00000.html for a more detailed rationale document for an older version of this patch. [akpm@linux-foundation.org: build fix] Signed-off-by: Miloslav Trmac <mitr@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Casey Schaufler <casey@schaufler-ca.com> Cc: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11[PATCH] Abnormal End of ProcessesSteve Grubb
Hi, I have been working on some code that detects abnormal events based on audit system events. One kind of event that we currently have no visibility for is when a program terminates due to segfault - which should never happen on a production machine. And if it did, you'd want to investigate it. Attached is a patch that collects these events and sends them into the audit system. Signed-off-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-05-11[PATCH] complete message queue auditingAmy Griffis
Handle the edge cases for POSIX message queue auditing. Collect inode info when opening an existing mq, and for send/receive operations. Remove audit_inode_update() as it has really evolved into the equivalent of audit_inode(). Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-05-11[PATCH] audit signal recipientsAmy Griffis
When auditing syscalls that send signals, log the pid and security context for each target process. Optimize the data collection by adding a counter for signal-related rules, and avoiding allocating an aux struct unless we have more than one target process. For process groups, collect pid/context data in blocks of 16. Move the audit_signal_info() hook up in check_kill_permission() so we audit attempts where permission is denied. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-05-11[PATCH] add SIGNAL syscall class (v3)Amy Griffis
Add a syscall class for sending signals. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-05-11[PATCH] auditing ptraceAl Viro
2007-03-06[PATCH] linux/audit.h needs linux/types.hJeff Dike
Include linux/types.h here because we need a definition of __u32. This file appears not be exported verbatim by libc, so I think this doesn't have any userspace consequences. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-17[PATCH] AUDIT_FD_PAIRAl Viro
Provide an audit record of the descriptor pair returned by pipe() and socketpair(). Rewritten from the original posted to linux-audit by John D. Ramsdell <ramsdell@mitre.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-12-06audit: Add auditing to ipsecJoy Latten
An audit message occurs when an ipsec SA or ipsec policy is created/deleted. Signed-off-by: Joy Latten <latten@austin.ibm.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-04[PATCH] message types updatedSteve Grubb
Hi, This patch adds a new type for 3rd party module use and cleans up a deprecated message type. Signed-off-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-09-29[NetLabel]: audit fixups due to delayed feedbackPaul Moore
Fix some issues Steve Grubb had with the way NetLabel was using the audit subsystem. This should make NetLabel more consistent with other kernel generated audit messages specifying configuration changes. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[NetLabel]: add audit support for configuration changesPaul Moore
This patch adds audit support to NetLabel, including six new audit message types shown below. #define AUDIT_MAC_UNLBL_ACCEPT 1406 #define AUDIT_MAC_UNLBL_DENY 1407 #define AUDIT_MAC_CIPSOV4_ADD 1408 #define AUDIT_MAC_CIPSOV4_DEL 1409 #define AUDIT_MAC_MAP_ADD 1410 #define AUDIT_MAC_MAP_DEL 1411 Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-11[PATCH] audit: AUDIT_PERM supportAl Viro
add support for AUDIT_PERM predicate Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-09-11[PATCH] audit: more syscall classes addedAl Viro
2006-08-03[PATCH] don't bother with aux entires for dummy contextAl Viro
2006-08-03[PATCH] mark context of syscall entered with no rules as dummyAl Viro
2006-08-03[PATCH] introduce audit rules counterAl Viro
2006-08-03[PATCH] fix missed create event for directory auditAmy Griffis
When an object is created via a symlink into an audited directory, audit misses the event due to not having collected the inode data for the directory. Modify __audit_inode_child() to copy the parent inode data if a parent wasn't found in audit_names[]. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-08-03[PATCH] fix faulty inode data collection for open() with O_CREATAmy Griffis
When the specified path is an existing file or when it is a symlink, audit collects the wrong inode number, which causes it to miss the open() event. Adding a second hook to the open() path fixes this. Also add audit_copy_inode() to consolidate some code. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-07-01[PATCH] audit syscall classesAl Viro
Allow to tie upper bits of syscall bitmap in audit rules to kernel-defined sets of syscalls. Infrastructure, a couple of classes (with 32bit counterparts for biarch targets) and actual tie-in on i386, amd64 and ia64. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-07-01[PATCH] audit: rename AUDIT_SE_* constantsDarrel Goeddel
This patch renames some audit constant definitions and adds additional definitions used by the following patch. The renaming avoids ambiguity with respect to the new definitions. Signed-off-by: Darrel Goeddel <dgoeddel@trustedcs.com> include/linux/audit.h | 15 ++++++++---- kernel/auditfilter.c | 50 ++++++++++++++++++++--------------------- kernel/auditsc.c | 10 ++++---- security/selinux/ss/services.c | 32 +++++++++++++------------- 4 files changed, 56 insertions(+), 51 deletions(-) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-07-01[PATCH] add rule filterkeyAmy Griffis
Add support for a rule key, which can be used to tie audit records to audit rules. This is useful when a watched file is accessed through a link or symlink, as well as for general audit log analysis. Because this patch uses a string key instead of an integer key, there is a bit of extra overhead to do the kstrdup() when a rule fires. However, we're also allocating memory for the audit record buffer, so it's probably not that significant. I went ahead with a string key because it seems more user-friendly. Note that the user must ensure that filterkeys are unique. The kernel only checks for duplicate rules. Signed-off-by: Amy Griffis <amy.griffis@hpd.com>
2006-06-20Merge branch 'audit.b21' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current * 'audit.b21' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: (25 commits) [PATCH] make set_loginuid obey audit_enabled [PATCH] log more info for directory entry change events [PATCH] fix AUDIT_FILTER_PREPEND handling [PATCH] validate rule fields' types [PATCH] audit: path-based rules [PATCH] Audit of POSIX Message Queue Syscalls v.2 [PATCH] fix se_sen audit filter [PATCH] deprecate AUDIT_POSSBILE [PATCH] inline more audit helpers [PATCH] proc_loginuid_write() uses simple_strtoul() on non-terminated array [PATCH] update of IPC audit record cleanup [PATCH] minor audit updates [PATCH] fix audit_krule_to_{rule,data} return values [PATCH] add filtering by ppid [PATCH] log ppid [PATCH] collect sid of those who send signals to auditd [PATCH] execve argument logging [PATCH] fix deadlocks in AUDIT_LIST/AUDIT_LIST_RULES [PATCH] audit_panic() is audit-internal [PATCH] inotify (5/5): update kernel documentation ... Manual fixup of conflict in unclude/linux/inotify.h
2006-06-20[PATCH] log more info for directory entry change eventsAmy Griffis
When an audit event involves changes to a directory entry, include a PATH record for the directory itself. A few other notable changes: - fixed audit_inode_child() hooks in fsnotify_move() - removed unused flags arg from audit_inode() - added audit log routines for logging a portion of a string Here's some sample output. before patch: type=SYSCALL msg=audit(1149821605.320:26): arch=40000003 syscall=39 success=yes exit=0 a0=bf8d3c7c a1=1ff a2=804e1b8 a3=bf8d3c7c items=1 ppid=739 pid=800 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=ttyS0 comm="mkdir" exe="/bin/mkdir" subj=root:system_r:unconfined_t:s0-s0:c0.c255 type=CWD msg=audit(1149821605.320:26): cwd="/root" type=PATH msg=audit(1149821605.320:26): item=0 name="foo" parent=164068 inode=164010 dev=03:00 mode=040755 ouid=0 ogid=0 rdev=00:00 obj=root:object_r:user_home_t:s0 after patch: type=SYSCALL msg=audit(1149822032.332:24): arch=40000003 syscall=39 success=yes exit=0 a0=bfdd9c7c a1=1ff a2=804e1b8 a3=bfdd9c7c items=2 ppid=714 pid=777 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=ttyS0 comm="mkdir" exe="/bin/mkdir" subj=root:system_r:unconfined_t:s0-s0:c0.c255 type=CWD msg=audit(1149822032.332:24): cwd="/root" type=PATH msg=audit(1149822032.332:24): item=0 name="/root" inode=164068 dev=03:00 mode=040750 ouid=0 ogid=0 rdev=00:00 obj=root:object_r:user_home_dir_t:s0 type=PATH msg=audit(1149822032.332:24): item=1 name="foo" inode=164010 dev=03:00 mode=040755 ouid=0 ogid=0 rdev=00:00 obj=root:object_r:user_home_t:s0 Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-06-20[PATCH] audit: path-based rulesAmy Griffis
In this implementation, audit registers inotify watches on the parent directories of paths specified in audit rules. When audit's inotify event handler is called, it updates any affected rules based on the filesystem event. If the parent directory is renamed, removed, or its filesystem is unmounted, audit removes all rules referencing that inotify watch. To keep things simple, this implementation limits location-based auditing to the directory entries in an existing directory. Given a path-based rule for /foo/bar/passwd, the following table applies: passwd modified -- audit event logged passwd replaced -- audit event logged, rules list updated bar renamed -- rule removed foo renamed -- untracked, meaning that the rule now applies to the new location Audit users typically want to have many rules referencing filesystem objects, which can significantly impact filtering performance. This patch also adds an inode-number-based rule hash to mitigate this situation. The patch is relative to the audit git tree: http://kernel.org/git/?p=linux/kernel/git/viro/audit-current.git;a=summary and uses the inotify kernel API: http://lkml.org/lkml/2006/6/1/145 Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-06-20[PATCH] Audit of POSIX Message Queue Syscalls v.2George C. Wilson
This patch adds audit support to POSIX message queues. It applies cleanly to the lspp.b15 branch of Al Viro's git tree. There are new auxiliary data structures, and collection and emission routines in kernel/auditsc.c. New hooks in ipc/mqueue.c collect arguments from the syscalls. I tested the patch by building the examples from the POSIX MQ library tarball. Build them -lrt, not against the old MQ library in the tarball. Here's the URL: http://www.geocities.com/wronski12/posix_ipc/libmqueue-4.41.tar.gz Do auditctl -a exit,always -S for mq_open, mq_timedsend, mq_timedreceive, mq_notify, mq_getsetattr. mq_unlink has no new hooks. Please see the corresponding userspace patch to get correct output from auditd for the new record types. [fixes folded] Signed-off-by: George Wilson <ltcgcw@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-06-20[PATCH] inline more audit helpersAl Viro
pull checks for ->audit_context into inlined wrappers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-06-20[PATCH] update of IPC audit record cleanupLinda Knippers
The following patch addresses most of the issues with the IPC_SET_PERM records as described in: https://www.redhat.com/archives/linux-audit/2006-May/msg00010.html and addresses the comments I received on the record field names. To summarize, I made the following changes: 1. Changed sys_msgctl() and semctl_down() so that an IPC_SET_PERM record is emitted in the failure case as well as the success case. This matches the behavior in sys_shmctl(). I could simplify the code in sys_msgctl() and semctl_down() slightly but it would mean that in some error cases we could get an IPC_SET_PERM record without an IPC record and that seemed odd. 2. No change to the IPC record type, given no feedback on the backward compatibility question. 3. Removed the qbytes field from the IPC record. It wasn't being set and when audit_ipc_obj() is called from ipcperms(), the information isn't available. If we want the information in the IPC record, more extensive changes will be necessary. Since it only applies to message queues and it isn't really permission related, it doesn't seem worth it. 4. Removed the obj field from the IPC_SET_PERM record. This means that the kern_ipc_perm argument is no longer needed. 5. Removed the spaces and renamed the IPC_SET_PERM field names. Replaced iuid and igid fields with ouid and ogid in the IPC record. I tested this with the lspp.22 kernel on an x86_64 box. I believe it applies cleanly on the latest kernel. -- ljk Signed-off-by: Linda Knippers <linda.knippers@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-06-20[PATCH] add filtering by ppidAl Viro
2006-06-20[PATCH] collect sid of those who send signals to auditdAl Viro
