[ Upstream commit 6377f787aeb945cae7abbb6474798de129e1f3ac ]
KASAN report this:
BUG: KASAN: use-after-free in pde_subdir_find+0x12d/0x150 fs/proc/generic.c:71
Read of size 8 at addr ffff8881f41fe5b0 by task syz-executor.0/2806
CPU: 0 PID: 2806 Comm: syz-executor.0 Not tainted 5.0.0-rc7+ #45
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1 04/01/2014
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0xfa/0x1ce lib/dump_stack.c:113
print_address_description+0x65/0x270 mm/kasan/report.c:187
kasan_report+0x149/0x18d mm/kasan/report.c:317
remove_proc_entry+0xe8/0x420 fs/proc/generic.c:667
atalk_proc_exit+0x18/0x820 [appletalk]
atalk_exit+0xf/0x5a [appletalk]
__do_sys_delete_module kernel/module.c:1018 [inline]
__se_sys_delete_module kernel/module.c:961 [inline]
__x64_sys_delete_module+0x3dc/0x5e0 kernel/module.c:961
do_syscall_64+0x147/0x600 arch/x86/entry/common.c:290
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x462e99
Code: f7 d8 64 89 02 b8 ff ff ff ff c3 66 0f 1f 44 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 c7 c1 bc ff ff ff f7 d8 64 89 01 48
RSP: 002b:00007fb2de6b9c58 EFLAGS: 00000246 ORIG_RAX: 00000000000000b0
RAX: ffffffffffffffda RBX: 000000000073bf00 RCX: 0000000000462e99
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 00000000200001c0
RBP: 0000000000000002 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00007fb2de6ba6bc
R13: 00000000004bccaa R14: 00000000006f6bc8 R15: 00000000ffffffff
Allocated by task 2806:
set_track mm/kasan/common.c:85 [inline]
__kasan_kmalloc.constprop.3+0xa0/0xd0 mm/kasan/common.c:496
slab_post_alloc_hook mm/slab.h:444 [inline]
slab_alloc_node mm/slub.c:2739 [inline]
slab_alloc mm/slub.c:2747 [inline]
kmem_cache_alloc+0xcf/0x250 mm/slub.c:2752
kmem_cache_zalloc include/linux/slab.h:730 [inline]
__proc_create+0x30f/0xa20 fs/proc/generic.c:408
proc_mkdir_data+0x47/0x190 fs/proc/generic.c:469
0xffffffffc10c01bb
0xffffffffc10c0166
do_one_initcall+0xfa/0x5ca init/main.c:887
do_init_module+0x204/0x5f6 kernel/module.c:3460
load_module+0x66b2/0x8570 kernel/module.c:3808
__do_sys_finit_module+0x238/0x2a0 kernel/module.c:3902
Freed by task 2806:
__kasan_slab_free+0x130/0x180 mm/kasan/common.c:458
slab_free_hook mm/slub.c:1409 [inline]
slab_free_freelist_hook mm/slub.c:1436 [inline]
slab_free mm/slub.c:2986 [inline]
kmem_cache_free+0xa6/0x2a0 mm/slub.c:3002
pde_put+0x6e/0x80 fs/proc/generic.c:647
remove_proc_entry+0x1d3/0x420 fs/proc/generic.c:684
0xffffffffc10c031c
0xffffffffc10c0166
The buggy address belongs to the object at ffff8881f41fe500
which belongs to the cache proc_dir_entry of size 256
The buggy address is located 176 bytes inside of
256-byte region [ffff8881f41fe500, ffff8881f41fe600)
The buggy address belongs to the page:
page:ffffea0007d07f80 count:1 mapcount:0 mapping:ffff8881f6e69a00 index:0x0
flags: 0x2fffc0000000200(slab)
raw: 02fffc0000000200 dead000000000100 dead000000000200 ffff8881f6e69a00
raw: 0000000000000000 00000000800c000c 00000001ffffffff 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8881f41fe480: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
ffff8881f41fe500: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
>ffff8881f41fe580: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8881f41fe600: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb
ffff8881f41fe680: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
It should check the return value of atalk_proc_init fails,
otherwise atalk_exit will trgger use-after-free in pde_subdir_find
while unload the module.This patch fix error cleanup path of atalk_init
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
[ Upstream commit 27da0d2ef998e222a876c0cec72aa7829a626266 ]
A bugfix just broke compilation of appletalk when CONFIG_SYSCTL
is disabled:
In file included from net/appletalk/ddp.c:65:
net/appletalk/ddp.c: In function 'atalk_init':
include/linux/atalk.h:164:34: error: expected expression before 'do'
#define atalk_register_sysctl() do { } while(0)
net/appletalk/ddp.c:1934:7: note: in expansion of macro 'atalk_register_sysctl'
rc = atalk_register_sysctl();
This is easier to avoid by using conventional inline functions
as stubs rather than macros. The header already has inline
functions for other purposes, so I'm changing over all the
macros for consistency.
Fixes: 6377f787aeb9 ("appletalk: Fix use-after-free in atalk_proc_exit")
Variant of proc_create_data that directly take a struct seq_operations
argument + a private state size and drastically reduces the boilerplate
code in the callers.
All trivial callers converted over.
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
Complete the work started with commit
6602a4baf4d1a73cc4685a39ef859e1c5ddf654c ('net: Make userland include
of netlink.h more sane').
fix the following 'make headers_check' warning:
usr/include/linux/atalk.h:15: found __[us]{8,16,32,64} type without #include <linux/types.h>
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
For the places where we need a pointer to the transport header, it is
still legal to touch skb->h.raw directly if just adding to,
subtracting from or setting it to another layer header.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Since version 4.1 the gcc is warning about ignored attributes. This patch is
using the equivalent attribute on the struct instead of on each of the
structure or union members.
GCC Manual:
"Specifying Attributes of Types
packed
This attribute, attached to struct or union type definition, specifies
that
each member of the structure or union is placed to minimize the memory
required. When attached to an enum definition, it indicates that the
smallest integral type should be used.
Specifying this attribute for struct and union types is equivalent to
specifying the packed attribute on each of the structure or union
members."
Signed-off-by: Jan Blunck <jblunck@suse.de>
Cc: Dave Jones <davej@codemonkey.org.uk>
We're using __be16 in userland visible types, so we
have to include asm/byteorder.h so that works.
This recently got changed to include a lot of kernel internal stuff in the
non-__KERNEL__ area of the header, which isn't so kosher and breaks libc
builds.
The fix is pretty simple.
infrastructure for it.
Let it rip!
