path: root/include/linux/acpi.h
2007-02-02ACPICA: Remove duplicate table definitions (non-conflicting), contAlexey Starikovskiy
Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Remove duplicate table definitions (non-conflicting)Alexey Starikovskiy
2007-02-02ACPICA: Remove duplicate table definitions.Alexey Starikovskiy
2007-02-02ACPICA: Remove duplicate table managerAlexey Starikovskiy
2007-02-02ACPICA: minimal patch to integrate new tables into LinuxAlexey Starikovskiy
2007-01-04ACPI: Altix: ACPI _PRT supportJohn Keller
Provide ACPI _PRT support for SN Altix systems. The SN Altix platform does not conform to the IOSAPIC IRQ routing model, so a new acpi_irq_model (ACPI_IRQ_MODEL_PLATFORM) has been defined. The SN platform specific code sets acpi_irq_model to this new value, and keys off of it in acpi_register_gsi() to avoid the iosapic code path. Signed-off-by: John Keller <jpk@sgi.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-10-14ACPI: consolidate functions in acpi ec driverLennart Poettering
Unify the following functions: acpi_ec_poll_read() acpi_ec_poll_write() acpi_ec_poll_query() acpi_ec_intr_read() acpi_ec_intr_write() acpi_ec_intr_query() into: acpi_ec_poll_transaction() acpi_ec_intr_transaction() These new functions take as arguments an ACPI EC command, a few bytes to write to the EC data register and a buffer for a few bytes to read from the EC data register. The old _read(), _write(), _query() are just special cases of these functions. Then unified the code in acpi_ec_poll_transaction() and acpi_ec_intr_transaction() a little more. Both functions are now just wrappers around the new acpi_ec_transaction_unlocked() function. The latter contains the EC access logic, the two original function now just do their special way of locking and call the the new function for the actual work. This saves a lot of very similar code. The primary reason for doing this, however, is that my driver for MSI 270 laptops needs to issue some non-standard EC commands in a safe way. Due to this I added a new exported function similar to ec_write()/ec_write() which is called ec_transaction() and is essentially just a wrapper around acpi_ec_{poll,intr}_transaction(). Signed-off-by: Lennart Poettering <mzxreary@0pointer.de> Acked-by: Luming Yu <luming.yu@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-27[PATCH] pgdat allocation for new node add (get node id by acpi)Yasunori Goto
This is to find node id from acpi's handle of memory_device in DSDT. _PXM for the new node can be found by acpi_get_pxm() by using new memory's handle. So, node id can be found by pxm_to_nid_map[]. This patch becomes simpler than v2 of node hot-add patch. Because old add_memory() function doesn't have node id parameter. So, kernel must find its handle by physical address via DSDT again. But, v3 just give node id to add_memory() now. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] Unify pxm_to_node() and node_to_pxm()Yasunori Goto
Consolidate the various arch-specific implementations of pxm_to_node() and node_to_pxm() into a single generic version. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-02-20[PATCH] suspend-to-ram: allow video options to be set at runtimePavel Machek
Currently, acpi video options can only be set on kernel command line. That's little inflexible; I'd like userland s2ram application that just works, and modifying kernel command line according to whitelist is not fun. It is better to just allow s2ram application to set video options just before suspend (according to the whitelist). This implements sysctl to allow setting suspend video options without reboot. (akpm: Documentation updates for this new sysctl are pending..) Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: "Brown, Len" <len.brown@intel.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-10[ACPI] ACPICA 20050930Bob Moore
Completed a major overhaul of the Resource Manager code - specifically, optimizations in the area of the AML/internal resource conversion code. The code has been optimized to simplify and eliminate duplicated code, CPU stack use has been decreased by optimizing function parameters and local variables, and naming conventions across the manager have been standardized for clarity and ease of maintenance (this includes function, parameter, variable, and struct/typedef names.) All Resource Manager dispatch and information tables have been moved to a single location for clarity and ease of maintenance. One new file was created, named "rsinfo.c". The ACPI return macros (return_ACPI_STATUS, etc.) have been modified to guarantee that the argument is not evaluated twice, making them less prone to macro side-effects. However, since there exists the possibility of additional stack use if a particular compiler cannot optimize them (such as in the debug generation case), the original macros are optionally available. Note that some invocations of the return_VALUE macro may now cause size mismatch warnings; the return_UINT8 and return_UINT32 macros are provided to eliminate these. (From Randy Dunlap) Implemented a new mechanism to enable debug tracing for individual control methods. A new external interface, acpi_debug_trace(), is provided to enable this mechanism. The intent is to allow the host OS to easily enable and disable tracing for problematic control methods. This interface can be easily exposed to a user or debugger interface if desired. See the file psxface.c for details. acpi_ut_callocate() will now return a valid pointer if a length of zero is specified - a length of one is used and a warning is issued. This matches the behavior of acpi_ut_allocate(). Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-25[ACPI] delete CONFIG_ACPI_PCILen Brown
Delete the ability to build an ACPI kernel that does not include PCI support. When such a machine is created and it requires a tuned kernel, send a patch. http://bugzilla.kernel.org/show_bug.cgi?id=1364 Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-24[ACPI] delete CONFIG_ACPI_INTERPRETERLen Brown
it is a synonym for CONFIG_ACPI Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-24[ACPI] delete CONFIG_ACPI_BOOTLen Brown
it has been a synonym for CONFIG_ACPI since 2.6.12 Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-05[ACPI] Merge acpi-2.6.12 branch into 2.6.13-rc3Len Brown
2005-08-04[ACPI] CONFIG_ACPI=n build fixAndrew Morton
2005-08-04[ACPI] acpi_register_gsi() can return errorKenji Kaneshige
Current acpi_register_gsi() function has no way to indicate errors to its callers even though acpi_register_gsi() can fail to register gsi because of some reasons (out of memory, lack of interrupt vectors, incorrect BIOS, and so on). As a result, caller of acpi_register_gsi() cannot handle the case that acpi_register_gsi() fails. I think failure of acpi_register_gsi() should be handled properly. This series of patches changes acpi_register_gsi() to return negative value on error, and also changes callers of acpi_register_gsi() to handle failure of acpi_register_gsi(). This patch changes the type of return value of acpi_register_gsi() from "unsigned int" to "int" to indicate an error. If acpi_register_gsi() fails to register gsi, it returns negative value. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-29/home/lenb/src/to-linus branch 'acpi-2.6.12'Len Brown
2005-07-29[ACPI] suspend/resume ACPI PCI Interrupt LinksDavid Shaohua Li
Add reference count and disable ACPI PCI Interrupt Link when no device still uses it. Warn when drivers have not released Link at suspend time. http://bugzilla.kernel.org/show_bug.cgi?id=3469 Signed-off-by: David Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-12[ACPI] merge acpi-2.6.12 branch into latest Linux 2.6.13-rc...Len Brown
2005-07-12[ACPI] PNPACPI vs sound IRQDavid Shaohua Li
http://bugme.osdl.org/show_bug.cgi?id=4016 Written-by: David Shaohua Li <shaohua.li@intel.com> Acked-by: Adam Belay <abelay@novell.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-12[ACPI] Evaluate CPEI Processor Override flagAshok Raj
ACPI 3.0 added a Correctable Platform Error Interrupt (CPEI) Processor Overide flag to MADT.Platform_Interrupt_Source. Record the processor that was provided as hint from ACPI. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-06-27[PATCH] PCI: add proper MCFG table parsing to ACPI core.Greg Kroah-Hartman
This patch is the first step in properly handling the MCFG PCI table. It defines the structures properly, and saves off the table so that the pci mmconfig code can access it. It moves the parsing of the table a little later in the boot process, but still before the information is needed. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] ACPI based I/O APIC hot-plug: add interfacesKenji Kaneshige
This patch adds the following new interfaces for I/O xAPIC hotplug. The implementation of these interfaces depends on each architecture. o int acpi_register_ioapic(acpi_handle handle, u64 phys_addr, u32 gsi_base); This new interface is to add a new I/O xAPIC specified by phys_addr and gsi_base pair. phys_addr is the physical address to which the I/O xAPIC is mapped and gsi_base is global system interrupt base of the I/O xAPIC. acpi_register_ioapic returns 0 on success, or negative value on error. o int acpi_unregister_ioapic(acpi_handle handle, u32 gsi_base); This new interface is to remove a I/O xAPIC specified by gsi_base. acpi_unregister_ioapic returns 0 on success, or negative value on error. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-06[PATCH] Include <linux/config.h> before testing CONFIG_ACPIDavid Mosberger
I'm not sure why this issue is suddenly showing, but without this patchlet, the zx1 config won't compile anymore (e.g., to see the compilation-error, look for "***" in [1]). [1] http://www.gelato.unsw.edu.au/kerncomp/results//2005-06-06-17-00/zx1_defconfig-log.html Signed-off-by: David Mosberger-Tang <davidm@hpl.hp.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-27[PATCH] VIA IRQ quirkLen Brown
Delete quirk_via_bridge(), restore quirk_via_irqpic() -- but now improved to be invoked upon device ENABLE, and now only for VIA devices -- not all devices behind VIA bridges. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
