path: root/include/clocksource/arm_generic.h
2013-01-31arm64: move from arm_generic to arm_arch_timerMark Rutland
The arch_timer driver supports a superset of the functionality of the arm_generic driver, and is not tied to a particular arch. This patch moves arm64 to use the arch_timer driver, gaining additional functionality in doing so, and removes the (now unused) arm_generic driver. Timer-related hooks specific to arm64 are moved into arch/arm64/kernel/time.c. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2012-09-17arm64: Generic timers supportMarc Zyngier
This patch adds support for the ARM generic timers with A64 instructions for accessing the timer registers. It uses the physical counter as the clock source and the virtual counter as sched_clock. The timer frequency can be specified via DT or read from the CNTFRQ_EL0 register. The physical counter is also accessible from user space allowing fast gettimeofday() implementation. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
