path: root/include/asm-x86/processor.h
2008-08-15x86: invalidate caches before going into suspendMark Langsdorf
When a CPU core is shut down, all of its caches need to be flushed to prevent stale data from causing errors if the core is resumed. Current Linux suspend code performs an assignment after the flush, which can add dirty data back to the cache.  On some AMD platforms, additional speculative reads have caused crashes on resume because of this dirty data. Relocate the cache flush to be the very last thing done before halting.  Tie into an assembly line so the compile will not reorder it.  Add some documentation explaining what is going on and why we're doing this. Signed-off-by: Mark Langsdorf <mark.langsdorf@amd.com> Acked-by: Mark Borden <mark.borden@amd.com> Acked-by: Michael Hohmuth <michael.hohmuth@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-23Merge branch 'cpus4096-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (31 commits) NR_CPUS: Replace NR_CPUS in speedstep-centrino.c cpumask: Provide a generic set of CPUMASK_ALLOC macros, FIXUP NR_CPUS: Replace NR_CPUS in cpufreq userspace routines NR_CPUS: Replace per_cpu(..., smp_processor_id()) with __get_cpu_var NR_CPUS: Replace NR_CPUS in arch/x86/kernel/genapic_flat_64.c NR_CPUS: Replace NR_CPUS in arch/x86/kernel/genx2apic_uv_x.c NR_CPUS: Replace NR_CPUS in arch/x86/kernel/cpu/proc.c NR_CPUS: Replace NR_CPUS in arch/x86/kernel/cpu/mcheck/mce_64.c cpumask: Optimize cpumask_of_cpu in lib/smp_processor_id.c, fix cpumask: Use optimized CPUMASK_ALLOC macros in the centrino_target cpumask: Provide a generic set of CPUMASK_ALLOC macros cpumask: Optimize cpumask_of_cpu in lib/smp_processor_id.c cpumask: Optimize cpumask_of_cpu in kernel/time/tick-common.c cpumask: Optimize cpumask_of_cpu in drivers/misc/sgi-xp/xpc_main.c cpumask: Optimize cpumask_of_cpu in arch/x86/kernel/ldt.c cpumask: Optimize cpumask_of_cpu in arch/x86/kernel/io_apic_64.c cpumask: Replace cpumask_of_cpu with cpumask_of_cpu_ptr Revert "cpumask: introduce new APIs" cpumask: make for_each_cpu_mask a bit smaller net: Pass reference to cpumask variable in net/sunrpc/svc.c ... Fix up trivial conflicts in drivers/cpufreq/cpufreq.c manually
2008-07-20NR_CPUS: Replace per_cpu(..., smp_processor_id()) with __get_cpu_varMike Travis
* Slight optimization when getting one's own cpu_info percpu data. Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-18x86: reduce force_mwait visibilityJan Beulich
It's not used anywhere outside its single referencing file. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-07-16ACPI : Create "idle=nomwait" bootparamZhao Yakui
"idle=nomwait" disables the use of the MWAIT instruction from both C1 (C1_FFH) and deeper (C2C3_FFH) C-states. When MWAIT is unavailable, the BIOS and OS generally negotiate to use the HALT instruction for C1, and use IO accesses for deeper C-states. This option is useful for power and performance comparisons, and also to work around BIOS bugs where broken MWAIT support is advertised. http://bugzilla.kernel.org/show_bug.cgi?id=10807 http://bugzilla.kernel.org/show_bug.cgi?id=10914 Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Li Shaohua <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPI: Create "idle=halt" bootparamZhao Yakui
"idle=halt" limits the idle loop to using the halt instruction. No MWAIT, no IO accesses, no C-states deeper than C1. If something is broken in the idle code, "idle=halt" is a less severe workaround than "idle=poll" which disables all power savings. Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-08x86_64: fix non-paravirt compilationJeremy Fitzhardinge
Make sure SWAPGS and PARAVIRT_ADJUST_EXCEPTION_FRAME are properly defined when CONFIG_PARAVIRT is off. Fixes Ingo's build failure: arch/x86/kernel/entry_64.S: Assembler messages: arch/x86/kernel/entry_64.S:1201: Error: invalid character '_' in mnemonic arch/x86/kernel/entry_64.S:1205: Error: invalid character '_' in mnemonic arch/x86/kernel/entry_64.S:1209: Error: invalid character '_' in mnemonic arch/x86/kernel/entry_64.S:1213: Error: invalid character '_' in mnemonic Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mark McLoughlin <markmc@redhat.com> Cc: xen-devel <xen-devel@lists.xensource.com> Cc: Eduardo Habkost <ehabkost@redhat.com> Cc: Vegard Nossum <vegard.nossum@gmail.com> Cc: Stephen Tweedie <sct@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86/paravirt, 64-bit: add adjust_exception_frameJeremy Fitzhardinge
64-bit Xen pushes a couple of extra words onto an exception frame. Add a hook to deal with them. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: xen-devel <xen-devel@lists.xensource.com> Cc: Stephen Tweedie <sct@redhat.com> Cc: Eduardo Habkost <ehabkost@redhat.com> Cc: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: change identify_cpu to staticYinghai Lu
Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: seperate funcs from setup_64 to cpu common_64.cYinghai Lu
Signed-off-by: Yinghai Lu <yhlu.kernel@mail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-04x86: cacheline_align tss_structRichard Kennedy
The manual padding to align on cacheline size only worked in 32 bit In 64 bit the structure was not aligned and contained wasted space. use the compiler ____cachline_aligned to save space & properly align this structure. x86_64_default size goes from 9136 -> 8960 x86_64_AMD size goes from 9136 -> 8896 built & running on 2.6.26-rc8. Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-30x86: remove Xgt_desc_structAdrian Bunk
The comment says it should have been removed in 2.6.25. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-27fix idle (arch, acpi and apm) and lockdepPeter Zijlstra
OK, so 25-mm1 gave a lockdep error which made me look into this. The first thing that I noticed was the horrible mess; the second thing I saw was hacks like: 71e93d15612c61c2e26a169567becf088e71b8ff The problem is that arch idle routines are somewhat inconsitent with their IRQ state handling and instead of fixing _that_, we go paper over the problem. So the thing I've tried to do is set a standard for idle routines and fix them all up to adhere to that. So the rules are: idle routines are entered with IRQs disabled idle routines will exit with IRQs enabled Nearly all already did this in one form or another. Merge the 32 and 64 bit bits so they no longer have different bugs. As for the actual lockdep warning; __sti_mwait() did a plainly un-annotated irq-enable. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Tested-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86: remove NexGen supportDmitri Vorobiev
It is claimed that NexGen CPUs were never shipped: http://lkml.org/lkml/2008/4/20/179 Also, the kernel support for these chips has been broken for a long time, the code intended to support NexGen thereby being essentially dead. As an outcome of the discussion that can be found using the URL above, this patch removes the NexGen support altogether. The changes in this patch survived a defconfig build for i386, a couple of successful randconfig builds, as well as a runtime test, which consisted in booting a 32-bit x86 box up to the shell prompt. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19x86, fpu: lazy allocation of FPU area - v5Suresh Siddha
Only allocate the FPU area when the application actually uses FPU, i.e., in the first lazy FPU trap. This could save memory for non-fpu using apps. for example: on my system after boot, there are around 300 processes, with only 17 using FPU. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-19x86, fpu: split FPU state from task struct - v5Suresh Siddha
Split the FPU save area from the task struct. This allows easy migration of FPU context, and it's generally cleaner. It also allows the following two optimizations: 1) only allocate when the application actually uses FPU, so in the first lazy FPU trap. This could save memory for non-fpu using apps. Next patch does this lazy allocation. 2) allocate the right size for the actual cpu rather than 512 bytes always. Patches enabling xsave/xrstor support (coming shortly) will take advantage of this. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-19x86: implement prctl PR_GET_TSC and PR_SET_TSCErik Bosman
This patch implements the PR_GET_TSC and PR_SET_TSC prctl() commands on the x86 platform (both 32 and 64 bit.) These commands control the ability to read the timestamp counter from userspace (the RDTSC instruction.) While the RDTSC instuction is a useful profiling tool, it is also the source of some non-determinism in ring-3. For deterministic replay applications it is useful to be able to trap and emulate (and record the outcome of) this instruction. This patch uses code earlier used to disable the timestamp counter for the SECCOMP framework. A side-effect of this patch is that the SECCOMP environment will now also disable the timestamp counter on x86_64 due to the addition of the TIF_NOTSC define on this platform. The code which enables/disables the RDTSC instruction during context switches is in the __switch_to_xtra function, which already handles other unusual conditions, so normal performance should not have to suffer from this change. Signed-off-by: Erik Bosman <ejbosman@cs.vu.nl> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17include/asm-x86/processor.h: checkpatch cleanups - formatting onlyJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: processor.h - use PAGE_SIZE instead of numeric valueCyrill Gorcunov
This patch replaces numeric constant with an appropriate macro Also 0x800000000000UL is changed to bit shifting which is complement to the code comment (thanks hpa for notice) Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: prevent unconditional writes to DebugCtl MSRJan Beulich
Otherwise, enabling (or better, subsequent disabling) of single stepping would cause a kernel oops on CPUs not having this MSR. The patch could have been added a conditional to the MSR write in user_disable_single_step(), but centralizing the updates seems safer and (looking forward) better manageable. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Markus Metzger <markus.t.metzger@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: cleanup duplicate includesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> arch/x86/kernel/reboot.c | 1 - include/asm-x86/elf.h | 5 ++--- include/asm-x86/posix_types.h | 8 +------- include/asm-x86/processor.h | 3 +-- include/asm-x86/unistd.h | 8 +------- 5 files changed, 5 insertions(+), 20 deletions(-) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: introduce initial apicidYinghai Lu
store initial_apicid from early identify. it is could be different from phys_proc_id later. also print it out in /proc/cpuinfo. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: add comments to processor.hIngo Molnar
add comments to the FPU structures of processor.h. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: remove cpu_llc_id from processor.hGlauber Costa
it is already defined in smp.h Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: provide hlt_works function.Glauber Costa
In x86_64, hlt always work. in i386, we'll query the cpuinfo associated with this cpu Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: de-macro start_thread()Ingo Molnar
2008-04-17x86: clean up include/asm-x86/processor.hIngo Molnar
basic style cleanup to flush out years of neglect: - consistent indentation - whitespace fixes - consistent comments Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-19x86: minor cleanup of comments in processor.hMike Travis
Signed-off-by: Mike Travis <travis@sgi.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: linux-mm@kvack.org Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-19remove mca-pentiumAdrian Bunk
This patch removes the mca-pentium boot option that was a noop. besides the source code cleanup factor, this saves some text as well: arch/x86/kernel/cpu/bugs.o: text data bss dec hex filename 651 77 4 732 2dc bugs.o.before 631 53 4 688 2b0 bugs.o.after Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-08aout: move STACK_TOP[_MAX] to asm/processor.hDavid Howells
Move STACK_TOP[_MAX] out of asm/a.out.h and into asm/processor.h as they're required whether or not A.OUT format is available. Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30x86: add framework to disable CPUID bits on the command lineAndi Kleen
There are already various options to disable specific cpuid bits on the command line. They all use their own variable. Add a generic mask to make this easier in the future. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: change size of APICIDs from u8 to u16travis@sgi.com
Change the size of APICIDs from u8 to u16. This partially supports the new x2apic mode that will be present on future processor chips. (Chips actually support 32-bit APICIDs, but that change is more intrusive. Supporting 16-bit is sufficient for now). Signed-off-by: Jack Steiner <steiner@sgi.com> I've included just the partial change from u8 to u16 apicids. The remaining x2apic changes will be in a separate patch. In addition, the fake_node_to_pxm_map[] and fake_apicid_to_node[] tables have been moved from local data to the __initdata section reducing stack pressure when MAX_NUMNODES and MAX_LOCAL_APIC are increased in size. Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: page.h: make pte_t a union to always includeJeremy Fitzhardinge
Make sure pte_t, whatever its definition, has a pte element with type pteval_t. This allows common code to access it without needing to be specifically parameterised on what pagetable mode we're compiling for. For 32-bit, this means that pte_t becomes a union with "pte" and "{ pte_low, pte_high }" (PAE) or just "pte_low" (non-PAE). Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: migration helpers for KVMIngo Molnar
migration helpers for KVM. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: move nop declarations into separate include fileAndi Kleen
Moving things out of processor.h is always a good thing. Also needed to avoid include loop in later patch. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: adds paravirt hook for swapgsGlauber de Oliveira Costa
This patch adds paravirt hook for swapgs operation, which is a privileged operation in x86_64. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: finish processor.h integrationGlauber de Oliveira Costa
What's left in processor_32.h and processor_64.h cannot be cleanly integrated. However, it's just a couple of definitions. They are moved to processor.h around ifdefs, and the original files are deleted. Note that there's much less headers included in the final version. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: x86 i387 unify structsRoland McGrath
The i387_fxsave_struct formats really have the same layout on 32 and 64, with only some slightly different use of a few fields. The i387_fsave_struct and i387_soft_struct formats are never used by 64-bit kernels, but it doesn't hurt to have the unused types in the union and cuts down on the amount of #ifdef hair required throughout the i387 code. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: move i387 definitions to processor.hGlauber de Oliveira Costa
This patch moves i387 definitions from processor_32.h and processor_64.h to processor.h. They are different. Very different. And there's appearently nothing we can do about it, so they're enclosed inside ifdefs. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: unify asm nopsGlauber de Oliveira Costa
There's only one difference between the NOPs used in asm code for i386 and x86_64: i386 has a lot more variants. The code is moved to processor.h, and adjusted accordingly. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: unify prefetch operationsGlauber de Oliveira Costa
This patch moves the prefetch[w]? functions to processor.h Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: move definitions to processor.hGlauber de Oliveira Costa
This patch moves definitions that are present in only one of the files (between processor_32.h and processor_64.h), to processor.h. They're mostly structures and function definitions. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: unify mm_segment_t definitionGlauber de Oliveira Costa
This patch moves the mm_segment_t structure definition to processor.h This makes mmsegment.h file useless, and it is deleted. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: unify x86_cpuinfo struct.Glauber de Oliveira Costa
x86_cpuinfo is one more to the family of "not fundamentally different" structs. It's unified in processor.h, with very specific fields enclosed around ifdefs. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: unify TASK_ALIGN definitionsGlauber de Oliveira Costa
This patch moves the TASK_ALIGN constraints to common header. The base of it is the same for x86_64 and i386. The only difference is the presence of vSMP in x86_64. As it's not a worry in i386, we can safely use the same code for both. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: unify thread struct.Glauber de Oliveira Costa
The thread_struct is not fundamentally different between architectures, and this patch puts it in the common header. What's really unique for each of them is enclosed in ifdefs. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: provide 64-bit with a load_sp0 function.Glauber de Oliveira Costa
Paravirt guests need to inform the underlying hypervisor whenever the sp0 tss field changes. i386 already has such a function, and we use it for x86_64 too. There's an unnecessary (for 64-bit) msr handling part in the original version, and it is placed around an ifdef. Making no more sense in processor_32.h, it is moved to the common header Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: unify tss_structGlauber de Oliveira Costa
Although slighly different, the tss_struct is very similar in x86_64 and i386. The really different part, which matchs the hardware vision of it, is now called x86_hw_tss, and each of the architectures provides yours. It's then used as a field in the outter tss_struct. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: unify current_text_addrGlauber de Oliveira Costa
current_text_addr() has a different implementation in x86_64 and i386, but it is not fundamentally different. I stick to the i386 implementation, that seem to be a common base, and move it to processor.h Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: unify common parts of processor.hGlauber de Oliveira Costa
This patch moves the pieces of processor_32.h and processor_64 that are equal to processor.h. Only what's exactly the same is moved around, the rest not being touched. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
