path: root/include/asm-x86/page.h
2008-04-24x86: introduce /dev/mem restrictions with a config optionArjan van de Ven
This patch introduces a restriction on /dev/mem: Only non-memory can be read or written unless the newly introduced config option is set. The X server needs access to /dev/mem for the PCI space, but it doesn't need access to memory; both the file permissions and SELinux permissions of /dev/mem just make X effectively super-super powerful. With the exception of the BIOS area, there's just no valid app that uses /dev/mem on actual memory. Other popular users of /dev/mem are rootkits and the like. (note: mmap access of memory via /dev/mem was already not allowed since a really long time) People who want to use /dev/mem for kernel debugging can enable the config option. The restrictions of this patch have been in the Fedora and RHEL kernels for at least 4 years without any problems. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17x86: replace the now useless max_pfn_mapped defineThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: implement true end_pfn_mapped for 32bitAndi Kleen
Even on 32bit 2MB pages can map more memory than is in the true max_low_pfn if end_pfn is not highmem and not aligned to 2MB. Add a end_pfn_map similar to x86-64 that accounts for this fact. This is important for code that really needs to know about all mapping aliases. Signed-off-by: Andi Kleen <ak@suse.de> Cc: andreas.herrmann3@amd.com Cc: mingo@elte.hu Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-21x86: fix {clear,copy}_user_page() declarations in page.hChuck Lever
Clean up: eliminate some compiler noise on x86 when building with strict warnings enabled, introduced by commit 345b904c. In file included from include2/asm/thread_info_64.h:12, from include2/asm/thread_info.h:4, from /home/cel/src/linux/nfs-2.6/include/linux/thread_info.h:35, from /home/cel/src/linux/nfs-2.6/include/linux/preempt.h:9, from /home/cel/src/linux/nfs-2.6/include/linux/spinlock.h:49, from /home/cel/src/linux/nfs-2.6/include/linux/mmzone.h:7, from /home/cel/src/linux/nfs-2.6/include/linux/gfp.h:4, from /home/cel/src/linux/nfs-2.6/include/linux/slab.h:14, from /home/cel/src/linux/nfs-2.6/fs/nfsd/nfs4acl.c:40: include2/asm/page.h:55: warning: `inline' is not at beginning of declaration include2/asm/page.h:61: warning: `inline' is not at beginning of declaration Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-04x86: rename LARGE_PAGE_SIZE to PMD_PAGE_SIZEAndi Kleen
Fix up all users. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: move page_is_ram() functionThomas Gleixner
2008-01-30x86: introduce max_pfn_mappedThomas Gleixner
64bit uses end_pfn_map and 32bit uses max_low_pfn. There are several files which have #ifdef'ed defines which map either to end_pfn_map or max_low_pfn. Replace this by a universal define and clean up all the other instances. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30add native_pud_val and _pmd_val for 2 and 3Jeremy Fitzhardinge
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: page.h: make pte_t a union to always includeJeremy Fitzhardinge
Make sure pte_t, whatever its definition, has a pte element with type pteval_t. This allows common code to access it without needing to be specifically parameterised on what pagetable mode we're compiling for. For 32-bit, this means that pte_t becomes a union with "pte" and "{ pte_low, pte_high }" (PAE) or just "pte_low" (non-PAE). Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: fix pte_modify() bugIngo Molnar
fix sign extension bug in PTE_MASK / _PTE_CHG_MASK. this resolves the following bootup crash on PAE systems: [ 94.710726] init[1]: segfault at 00000004 ip 49471cbb sp bff0c6c0 error 4 [ 94.717764] init[1]: segfault at 00000004 ip 49471cbb sp bff0c6c0 error 4 [ 94.724772] init[1]: segfault at 00000004 ip 49471cbb sp bff0c6c0 error 4 [ 94.731777] init[1]: segfault at 00000004 ip 49471cbb sp bff0c6c0 error 4 Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: page.h: move things back to their own filesJeremy Fitzhardinge
# HG changeset patch # User Jeremy Fitzhardinge <jeremy@xensource.com> # Date 1199321648 28800 # Node ID 22f6a5902285b58bfc1fbbd9e183498c9017bd78 # Parent bba9287641ff90e836d090d80b5c0a846aab7162 x86: page.h: move things back to their own files Oops, asm/page.h has turned into an #ifdef hellhole. Move 32/64-specific things back to their own headers to make it somewhat comprehensible... Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: page.h: move remaining bits and piecesJeremy Fitzhardinge
# HG changeset patch # User Jeremy Fitzhardinge <jeremy@xensource.com> # Date 1199319657 28800 # Node ID bba9287641ff90e836d090d80b5c0a846aab7162 # Parent d617b72a0cc9d14bde2087d065c36d4ed3265761 x86: page.h: move remaining bits and pieces Move the remaining odds and ends into page.h. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: page.h: move pa and va related thingsJeremy Fitzhardinge
# HG changeset patch # User Jeremy Fitzhardinge <jeremy@xensource.com> # Date 1199319656 28800 # Node ID d617b72a0cc9d14bde2087d065c36d4ed3265761 # Parent 3bd7db6e85e66e7f3362874802df26a82fcb2d92 x86: page.h: move pa and va related things Move and unify the virtual<->physical address space conversion functions. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: page.h: move and unify types for pagetable entry, #6Ingo Molnar
based on: Subject: x86: page.h: move and unify types for pagetable entry From: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: page.h: move and unify types for pagetable entryJeremy Fitzhardinge
# HG changeset patch # User Jeremy Fitzhardinge <jeremy@xensource.com> # Date 1199319654 28800 # Node ID 3bd7db6e85e66e7f3362874802df26a82fcb2d92 # Parent f7e7db3facd9406545103164f9be8f9ba1a2b549 x86: page.h: move and unify types for pagetable entry definitions This patch: 1. Defines arch-specific types for the contents of a pagetable entry. That is, 32-bit entries for 32-bit non-PAE, and 64-bit entries for 32-bit PAE and 64-bit. However, even though the latter two are the same size, they're defined with different types in order to retain compatibility with printk format strings, etc. 2. Defines arch-specific pte_t. This is different because 32-bit PAE defines it in two halves, whereas 32-bit PAE and 64-bit define it as a single entry. All the other pagetable levels can be defined in a common way. This also defines arch-specific pte_val/make_pte functions. 3. Define PAGETABLE_LEVELS for each architecture variation, for later use. 4. Define common pagetable entry accessors in a paravirt-compatible way. (64-bit does not yet use paravirt-ops in any way). 5. Convert a few instances of using a *_val() as an lvalue where it is no longer a macro. There are still places in the 64-bit code which use pte_val() as an lvalue. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: page.h: move and unify types for pagetable entry, #5Ingo Molnar
2008-01-30x86: page.h: move and unify types for pagetable entry, #4Ingo Molnar
2008-01-30x86: page.h: move and unify types for pagetable entry, #3Ingo Molnar
2008-01-30x86: page.h: move and unify types for pagetable entry, #1Ingo Molnar
2008-01-30x86: page.h: unify page copying and clearingJeremy Fitzhardinge
# HG changeset patch # User Jeremy Fitzhardinge <jeremy@xensource.com> # Date 1199317362 28800 # Node ID 4d9a413a0f4c1d98dbea704f0366457b5117045d # Parent ba0ec40a50a7aef1a3153cea124c35e261f5a2df x86: page.h: unify page copying and clearing Move, and to some extent unify, the various page copying and clearing functions. The only unification here is that both architectures use the same function for copying/clearing user and kernel pages. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: page.h: unify constantsJeremy Fitzhardinge
# HG changeset patch # User Jeremy Fitzhardinge <jeremy@xensource.com> # Date 1199317360 28800 # Node ID ba0ec40a50a7aef1a3153cea124c35e261f5a2df # Parent c45c263179cb78284b6b869c574457df088027d1 x86: page.h: unify constants There are many constants which are shared by 32 and 64-bit. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-11i386/x86_64: move headers to include/asm-x86Thomas Gleixner
Move the headers to include/asm-x86 and fixup the header install make rules Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
