path: root/include/asm-x86/kprobes.h
2008-10-22x86, um: ... and asm-x86 moveAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-13i386: remove kprobes' restore_interrupts in favour of conditional_stiAlexander van Heukelum
x86_64 uses a helper function conditional_sti in traps_64.c which is equal to restore_interrupts in kprobes.h. The only user of restore_interrupts is in traps_32.c. Introduce conditional_sti for i386 and remove restore_interrupts. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-22x86: consolidate header guardsVegard Nossum
This patch is the result of an automatic script that consolidates the format of all the headers in include/asm-x86/. The format: 1. No leading underscore. Names with leading underscores are reserved. 2. Pathname components are separated by two underscores. So we can distinguish between mm_types.h and mm/types.h. 3. Everything except letters and numbers are turned into single underscores. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2008-04-17include/asm-x86/kprobes.h: checkpatch cleanups - formatting onlyJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-04Kprobes: indicate kretprobe support in KconfigAnanth N Mavinakayanahalli
Add CONFIG_HAVE_KRETPROBES to the arch/<arch>/Kconfig file for relevant architectures with kprobes support. This facilitates easy handling of in-kernel modules (like samples/kprobes/kretprobe_example.c) that depend on kretprobes being present in the kernel. Thanks to Sam Ravnborg for helping make the patch more lean. Per Mathieu's suggestion, added CONFIG_KRETPROBES and fixed up dependencies. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30x86: get rid of _MASK flagsGlauber de Oliveira Costa
There's no need for the *_MASK flags (TF_MASK, IF_MASK, etc), found in processor.h (both _32 and _64). They have a one-to-one mapping with the EFLAGS value. This patch removes the definitions, and use the already existent X86_EFLAGS_ version when applicable. [ roland@redhat.com: KVM build fixes. ] Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: kprobes code for x86 unificationMasami Hiramatsu
This patch unifies kprobes code. - Unify kprobes_*.h to kprobes.h - Unify kprobes_*.c to kprobes.c (Differences are separated by ifdefs) - Most differences are related to REX prefix and rip relatives. - Two inline assembly code are different. - One difference in kprobe_handlre() - One fixup exception code is different, but it will be unified if mm/extable_*.c are unified. - Merge history logs into arch/x86/kernel/kprobes.c. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-11i386/x86_64: move headers to include/asm-x86Thomas Gleixner
Move the headers to include/asm-x86 and fixup the header install make rules Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
