path: root/include/asm-x86/dwarf2.h
2008-07-22x86: consolidate header guardsVegard Nossum
This patch is the result of an automatic script that consolidates the format of all the headers in include/asm-x86/. The format: 1. No leading underscore. Names with leading underscores are reserved. 2. Pathname components are separated by two underscores. So we can distinguish between mm_types.h and mm/types.h. 3. Everything except letters and numbers are turned into single underscores. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2008-07-15x86: Fix compile error with CONFIG_AS_CFI=nKevin Winchester
AS arch/x86/lib/csum-copy_64.o arch/x86/lib/csum-copy_64.S: Assembler messages: arch/x86/lib/csum-copy_64.S:48: Error: Macro `ignore' was already defined make[1]: *** [arch/x86/lib/csum-copy_64.o] Error 1 make: *** [arch/x86/lib] Error 2 It appears that csum-copy_64.S and dwarf2.h both define an ignore macro. I would expect one of them can be renamed quite easily, unless they are references elsewhere. Caused-by-commit: 392a0fc96bd059b38564f5f8fb58327460cb5a9d x86: merge dwarf2 headers Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-07-11x86: merge dwarf2 headersGlauber Costa
Merge dwarf2_32.h and dwarf2_64.h into dwarf2.h. Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-11i386/x86_64: move headers to include/asm-x86Thomas Gleixner
Move the headers to include/asm-x86 and fixup the header install make rules Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
