path: root/include/asm-um/ldt.h
2006-03-31[PATCH] uml: split ldt.h in arch-independent and arch-dependant codePaolo 'Blaisorblade' Giarrusso
ldt-{i386,x86_64}.h is made of two different parts - some code for parsing of LDT descriptors, which is arch-dependant, and the code to handle uml_ldt_t (an LDT block inside UML), which is mostly arch-independant (among x86 and x86_64, at least). Join the common part in a single file (ldt.h) and split the rest away (host_ldt-{i386,x86_64}.h). This is needed because processor.h, with next patches, will start including the LDT descriptor parsing macros in host_ldt.h, but it can't include ldt.h because it uses semaphores (and to define semaphores one must first include processor.h!). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-22[PATCH] uml: eliminate anonymous union and clean up symlink lossageJeff Dike
This gives a name to the anonymous union introduced in skas-hold-own-ldt, allowing to build on a wider range of gccs. It also removes ldt.h, which somehow became real, and replaces it with a symlink, and creates ldt-x86_64.h as a copy of ldt-i386.h for now. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] uml: maintain own LDT entriesBodo Stroesser
Patch imlements full LDT handling in SKAS: * UML holds it's own LDT table, used to deliver data on modify_ldt(READ) * UML disables the default_ldt, inherited from the host (SKAS3) or resets LDT entries, set by host's clib and inherited in SKAS0 * A new global variable skas_needs_stub is inserted, that can be used to decide, whether stub-pages must be supported or not. * Uses the syscall-stub to replace missing PTRACE_LDT (therefore, write_ldt_entry needs to be modified) Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-14[PATCH] uml: consolidate modify_ldtPaolo 'Blaisorblade' Giarrusso
*) Reorganize the two cases of sys_modify_ldt to share all the reasonably common code. *) Avoid memory allocation when unneeded (i.e. when we are writing and the passed buffer size is known), thus not returning ENOMEM (which isn't allowed for this syscall, even if there is no strict "specification"). *) Add copy_{from,to}_user to modify_ldt for TT mode. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
