path: root/include/asm-um/fixmap.h
2008-10-22x86, um: initial part of asm-um moveAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-02-08uml: runtime host VMSPLIT detectionJeff Dike
Calculate TASK_SIZE at run-time by figuring out the host's VMSPLIT - this is needed on i386 if UML is to run on hosts with varying VMSPLITs without recompilation. TASK_SIZE is now defined in terms of a variable, task_size. This gets rid of an include of pgtable.h from processor.h, which can cause include loops. On i386, task_size is calculated early in boot by probing the address space in a binary search to figure out where the boundary between usable and non-usable memory is. This tries to make sure that a page that is considered to be in userspace is, or can be made, read-write. I'm concerned about a system-global VDSO page in kernel memory being hit and considered to be a userspace page. On x86_64, task_size is just the old value of CONFIG_TOP_ADDR. A bunch of config variable are gone now. CONFIG_TOP_ADDR is directly replaced by TASK_SIZE. NEST_LEVEL is gone since the relocation of the stubs makes it irrelevant. All the HOST_VMSPLIT stuff is gone. All references to these in arch/um/Makefile are also gone. I noticed and fixed a missing extern in os.h when adding os_get_task_size. Note: This has been revised to fix the 32-bit UML on 64-bit host bug that Miklos ran into. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: clean up TASK_SIZE usageJeff Dike
Clean up the calculation and use of the usable address space size on the host. task_size is gone, replaced with TASK_SIZE, which is calculated from CONFIG_TOP_ADDR. get_kmem_end and set_task_sizes_skas are also gone. host_task_size, which refers to the entire address space usable by the UML kernel and which may be larger than the address space usable by a UML process, since that has to end on a pgdir boundary, is replaced by CONFIG_TOP_ADDR. STACK_TOP is now TASK_SIZE minus the two stub pages. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: header untanglingJeff Dike
Untangle UML headers somewhat and add some includes where they were needed explicitly, but gotten accidentally via some other header. arch/um/include/um_uaccess.h loses asm/fixmap.h because it uses no fixmap stuff and gains elf.h, because it needs FIXADDR_USER_*, and archsetjmp.h, because it needs jmp_buf. pmd_alloc_one is uninlined because it needs mm_struct, and that's inconvenient to provide in asm-um/pgtable-3level.h. elf_core_copy_fpregs is also uninlined from elf-i386.h and elf-x86_64.h, which duplicated the code anyway, to arch/um/kernel/process.c, so that the reference to current_thread doesn't pull sched.h or anything related into asm/elf.h. arch/um/sys-i386/ldt.c, arch/um/kernel/tlb.c and arch/um/kernel/skas/uaccess.c got sched.h because they dereference task_structs. Its includes of linux and asm headers got turned from "" to <>. arch/um/sys-i386/bug.c gets asm/errno.h because it needs errno constants. asm/elf-i386 gets asm/user.h because it needs user_regs_struct. asm/fixmap.h gets page.h because it needs PAGE_SIZE and PAGE_MASK and system.h for BUG_ON. asm/pgtable doesn't need sched.h. asm/processor-generic.h defined mm_segment_t, but didn't use it. So, that definition is moved to uaccess.h, which defines a bunch of mm_segment_t-related stuff. thread_info.h uses mm_segment_t, and includes uaccess.h, which causes a recursion. So, the definition is placed above the include of thread_info. in uaccess.h. thread_info.h also gets page.h because it needs PAGE_SIZE. ObCheckpatchViolationJustification - I'm not adding a typedef; I'm moving mm_segment_t from one place to another. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2005-05-05[PATCH] uml: s390 preparation, elf.hBodo Stroesser
This patch make elh.h a symlink to the new arch-specific include files of the form elf-<subarch>.h, as in the same way already is done for some other includes. Also moves Elf-stuff from archparam-<subarch>.h and elf.h to the new elf-<subarch>.h files. Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
