path: root/include/asm-sparc64
2006-12-10[SPARC64]: Fix several kprobes bugs.David S. Miller
- relbranch_fixup(), for non-branches, would end up setting regs->tnpc incorrectly, in fact it would set it equal to regs->tpc which would cause that instruction to execute twice Also, if this is not a PC-relative branch, we should just leave regs->tnpc as-is. This covers cases like 'jmpl' which branch to absolute values. - To be absolutely %100 safe, we need to flush the instruction cache for all assignments to kprobe->ainsn.insn[], including cases like add_aggr_kprobe() - prev_kprobe's status field needs to be 'unsigned long' to match the type of the value it is saving - jprobes were totally broken: = jprobe_return() can run in the stack frame of the jprobe handler, or in an even deeper stack frame, thus we'll be in the wrong register window than the one from the original probe state. So unwind using 'restore' instructions, if necessary, right before we do the jprobe_return() breakpoint trap. = There is no reason to save/restore the register window saved at %sp at jprobe trigger time. Those registers cannot be modified by the jprobe handler. Also, this code was saving and restoring "sizeof (struct sparc_stackf)" bytes. Depending upon the caller, this could clobber unrelated stack frame pieces if there is only a basic 128-byte register window stored on the stack, without the argument save area. So just saving and restoring struct pt_regs is sufficient. = Kill the "jprobe_saved_esp", totally unused. Also, delete "jprobe_saved_regs_location", with the stack frame unwind now done explicitly by jprobe_return(), this check is superfluous. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-10[SPARC64]: dma remove extra bracketsMariusz Kozlowski
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-10[SPARC64]: Add irqtrace/stacktrace/lockdep support.David S. Miller
2006-12-08[PATCH] tty: preparatory structures for termios revampAlan Cox
In order to sort out our struct termios and add proper speed control we need to separate the kernel and user termios structures. Glibc is fine but the other libraries rely on the kernel exported struct termios and we need to extend this without breaking the ABI/API To do so we add a struct ktermios which is the kernel view of a termios structure and overlaps the struct termios with extra fields on the end for now. (That limitation will go away in later patches). Some platforms (eg alpha) planned ahead and thus use the same struct for both, others did not. This just adds the structures but does not use them, it seems a sensible splitting point for bisect if there are compile failures (not that I expect them) Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Pass struct dev pointer to dma_cache_sync()Ralf Baechle
Pass struct dev pointer to dma_cache_sync() dma_cache_sync() is ill-designed in that it does not have a struct device pointer argument which makes proper support for systems that consist of a mix of coherent and non-coherent DMA devices hard. Change dma_cache_sync to take a struct device pointer as first argument and fix all its callers to pass it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Add struct dev pointer to dma_is_consistent()Ralf Baechle
dma_is_consistent() is ill-designed in that it does not have a struct device pointer argument which makes proper support for systems that consist of a mix of coherent and non-coherent DMA devices hard. Change dma_is_consistent to take a struct device pointer as first argument and fix the sole caller to pass it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] remove kernel syscallsArnd Bergmann
The last thing we agreed on was to remove the macros entirely for 2.6.19, on all architectures. Unfortunately, I think nobody actually _did_ that, so they are still there. [akpm@osdl.org: x86_64 fix] Cc: David Woodhouse <dwmw2@infradead.org> Cc: Greg Schafer <gschafer@zip.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] mm: pagefault_{disable,enable}()Peter Zijlstra
Introduce pagefault_{disable,enable}() and use these where previously we did manual preempt increments/decrements to make the pagefault handler do the atomic thing. Currently they still rely on the increased preempt count, but do not rely on the disabled preemption, this might go away in the future. (NOTE: the extra barrier() in pagefault_disable might fix some holes on machines which have too many registers for their own good) [heiko.carstens@de.ibm.com: s390 fix] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Nick Piggin <npiggin@suse.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-02[NET]: SPARC64 checksum annotations and cleanups.Al Viro
* sanitize prototypes, annotate * kill useless shift Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-01Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (28 commits) PCI: make arch/i386/pci/common.c:pci_bf_sort static PCI: ibmphp_pci.c: fix NULL dereference pciehp: remove unnecessary pci_disable_msi pciehp: remove unnecessary free_irq PCI: rpaphp: change device tree examination PCI: Change memory allocation for acpiphp slots i2c-i801: SMBus patch for Intel ICH9 PCI: irq: irq and pci_ids patch for Intel ICH9 PCI: pci_{enable,disable}_device() nestable ports PCI: switch pci_{enable,disable}_device() to be nestable PCI: arch/i386/kernel/pci-dma.c: ioremap balanced with iounmap pci/i386: style cleanups PCI: Block on access to temporarily unavailable pci device pci: fix __pci_register_driver error handling pci: clear osc support flags if no _OSC method acpiphp: fix missing acpiphp_glue_exit() acpiphp: fix use of list_for_each macro Altix: Initial ACPI support - ROM shadowing. Altix: SN ACPI hotplug support. Altix: Add initial ACPI IO support ...
2006-12-01Driver core: add dev_archdata to struct deviceBenjamin Herrenschmidt
Add arch specific dev_archdata to struct device Adds an arch specific struct dev_arch to struct device. This enables architecture to add specific fields to every device in the system, like DMA operation pointers, NUMA node ID, firmware specific data, etc... Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Andi Kleen <ak@suse.de> Acked-By: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01PCI: Use pci_generic_prep_mwi on sparc64Matthew Wilcox
The setting of the CACHE_LINE_SIZE register in sparc64's pci initialisation code isn't quite adequate as the device may have incompatible requirements. The generic code tests for this, so switch sparc64 over to using it. Since sparc64 has different L1 cache line size and PCI cache line size, it would need to override the generic code like i386 and ia64 do. We know what the cache line size is at compile time though, so introduce a new optional constant PCI_CACHE_LINE_BYTES. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: David Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-11-05[SPARC]: Fix robust futex syscalls and wire up migrate_pages.David S. Miller
When I added the entries for the robust futex syscall entries, I forgot to bump NR_SYSCALLS. The current situation is error-prone because NR_SYSCALLS lives in entry.S where the system call limit checks are enforced. Move the definition to asm/unistd.h in order to make this mistake much more difficult to make. And wire up sys_migrate_pages since the powerpc folks implemented the compat wrapper for us. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-01[SPARC64]: Fix futex_atomic_cmpxchg_inatomic implementation.David S. Miller
I copied the logic from ll/sc arch implementations, but that was wrong and makes no sense at all. Just do a straight compare-exchange instruction, just like x86. Based upon bug reports from Dennis Gilmore and Fabio Massimo. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-22[SPARC64]: 8-byte align return value from compat_alloc_user_space()David S. Miller
Otherwise we get a ton of unaligned exceptions, for cases such as compat_sys_msgrcv() which go: p = compat_alloc_user_space(second + sizeof(struct msgbuf)); and here 'second' can for example be an arbitrary odd value. Based upon a bug report from Jurij Smakov. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-11[PATCH] Consolidate check_signatureMatthew Wilcox
There's nothing arch-specific about check_signature(), so move it to <linux/io.h>. Use a cross between the Alpha and i386 implementations as the generic one. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-08[PATCH] sparc64 pt_regs fixesAl Viro
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-10-02[SPARC64]: Do not include compat.h from asm-sparc64/signal.h any more.David S. Miller
It's not needed, now that all of that stuff is now in asm/compat_signal.h, and it breaks the build too :-) Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-02[SPARC64]: Move signal compat bits to new header file.David S. Miller
Create asm-sparc64/compat_signal.h and stuff things there. This avoids the "linux/compat.h includes asm/signal.h but asm/signal.h needs compat_sigset_t which isn't defined yet" problems introduced recently. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-02[PATCH] remove remaining errno and __KERNEL_SYSCALLS__ referencesArnd Bergmann
The last in-kernel user of errno is gone, so we should remove the definition and everything referring to it. This also removes the now-unused lib/execve.c file that was introduced earlier. Also remove every trace of __KERNEL_SYSCALLS__ that still remained in the kernel. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Directed yield: cpu_relax variants for spinlocks and rw-locksMartin Schwidefsky
On systems running with virtual cpus there is optimization potential in regard to spinlocks and rw-locks. If the virtual cpu that has taken a lock is known to a cpu that wants to acquire the same lock it is beneficial to yield the timeslice of the virtual cpu in favour of the cpu that has the lock (directed yield). With CONFIG_PREEMPT="n" this can be implemented by the architecture without common code changes. Powerpc already does this. With CONFIG_PREEMPT="y" the lock loops are coded with _raw_spin_trylock, _raw_read_trylock and _raw_write_trylock in kernel/spinlock.c. If the lock could not be taken cpu_relax is called. A directed yield is not possible because cpu_relax doesn't know anything about the lock. To be able to yield the lock in favour of the current lock holder variants of cpu_relax for spinlocks and rw-locks are needed. The new _raw_spin_relax, _raw_read_relax and _raw_write_relax primitives differ from cpu_relax insofar that they have an argument: a pointer to the lock structure. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] Standardize pxx_page macrosDave McCracken
One of the changes necessary for shared page tables is to standardize the pxx_page macros. pte_page and pmd_page have always returned the struct page associated with their entry, while pte_page_kernel and pmd_page_kernel have returned the kernel virtual address. pud_page and pgd_page, on the other hand, return the kernel virtual address. Shared page tables needs pud_page and pgd_page to return the actual page structures. There are very few actual users of these functions, so it is simple to standardize their usage. Since this is basic cleanup, I am submitting these changes as a standalone patch. Per Hugh Dickins' comments about it, I am also changing the pxx_page_kernel macros to pxx_page_vaddr to clarify their meaning. Signed-off-by: Dave McCracken <dmccr@us.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25[libata] No need for all those arch libata-portmap.h headersJeff Garzik
They all contain the same thing. Instead, have a single generic one in include/asm-generic, and permit an arch to override as needed. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-24Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
2006-09-24Merge branch 'master' into upstreamJeff Garzik
2006-09-21Fix exported headers for SPARC, SPARC64David Woodhouse
Mostly removing files which have no business being used in userspace. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-19[HEADERS] One line per header in Kbuild files to reduce conflictsDavid Woodhouse
2006-09-12Merge branch 'master' into upstreamJeff Garzik
2006-09-08[PATCH] IA64,sparc: local DoS with corrupted ELFsKirill Korotaev
This prevents cross-region mappings on IA64 and SPARC which could lead to system crash. They were correctly trapped for normal mmap() calls, but not for the kernel internal calls generated by executable loading. This code just moves the architecture-specific cross-region checks into an arch-specific "arch_mmap_check()" macro, and defines that for the architectures that needed it (ia64, sparc and sparc64). Architectures that don't have any special requirements can just ignore the new cross-region check, since the mmap() code will just notice on its own when the macro isn't defined. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> [ Cleaned up to not affect architectures that don't need it ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-29Merge /spare/repo/linux-2.6 into upstreamJeff Garzik
2006-08-22[SPARC64]: Fix pfn_pte() build failure.David S. Miller
The "%uhi" needs to be "%%uhi" because we want a real "%" character in the assembler here, instead of an assembler variable expansion. Aparently older GCCs were more liberal and interpreted this %-letter as a literal "%" for whatever reason. Based upon a build failure report from Meelis Roos. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-10[PATCH] libata: rework legacy handling to remove much of the cruftAlan Cox
Kill host_set->next Fix simplex support Allow per platform setting of IDE legacy bases Some of this can be tidied further later on, in particular all the legacy port gunge belongs as a PCI quirk/PCI header decode to understand the special legacy IDE rules in the PCI spec. Longer term Jeff also wants to move the request_irq/free_irq out of core which will make this even cleaner. tj: folded in three followup patches - ata_piix-fix, broken-arch-fix and fix-new-legacy-handling, and separated per-dev xfermask into separate patch preceding this one. Folded in fixes are... * ata_piix-fix: fix build failure due to host_set->next removal * broken-arch-fix: add missing include/asm-*/libata-portmap.h * fix-new-legacy-handling: * In ata_pci_init_legacy_port(), probe_num was incorrectly incremented during initialization of the secondary port and probe_ent->n_ports was incorrectly fixed to 1. * Both legacy ports ended up having the same hard_port_no. * When printing port information, both legacy ports printed the first irq. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-07-31[PATCH] IA64: kprobe invalidate icache of jump bufferbibo, mao
Kprobe inserts breakpoint instruction in probepoint and then jumps to instruction slot when breakpoint is hit, the instruction slot icache must be consistent with dcache. Here is the patch which invalidates instruction slot icache area. Without this patch, in some machines there will be fault when executing instruction slot where icache content is inconsistent with dcache. Signed-off-by: bibo,mao <bibo.mao@intel.com> Acked-by: "Luck, Tony" <tony.luck@intel.com> Acked-by: Keshavamurthy Anil S <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-27[SPARC64]: Fix typo in pgprot_noncached().David S. Miller
The sun4v code sequence was or'ing in the sun4u pte bits by mistake. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-27[SPARC64]: Fix quad-float multiply emulation.David S. Miller
Something is wrong with the 3-multiply (vs. 4-multiply) optimized version of _FP_MUL_MEAT_2_*(), so just use the slower version which actually computes correct values. Noticed by Rene Rebe Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[SPARC]: Kill prom_getname, unused and not implemented properly.David S. Miller
The m68k port's sun3 asm/oplib.h had a stray reference too, so I killed that off as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[SPARC64]: Fix more of_device layer IRQ bugs, and correct PROMREG_MAX.David S. Miller
Sabre and Psycho PCI controllers can have partial interrupt-map properties, meaning that on-board devices don't match up to any entries. Instead, they are fully specified from the beginning and we should pass them directly to the IRQ translator as-is. Also, fill in the necessary translator slots for the "graphics" and "expansion UPA" interrupts on Sabre, Psycho, and SYSIO SBUS. Increase PROMREG_MAX to 24, as seen on SUNW,ffb devices. Finally, prevent accidentally writing past the end of the of_device struct resource[] and irqs[] arrays. Spit out a log message when we ignore some entries because there are too many of them. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-14[PATCH] remove set_wmb - arch removalSteven Rostedt
set_wmb should not be used in the kernel because it just confuses the code more and has no benefit. Since it is not currently used in the kernel this patch removes it so that new code does not include it. All archs define set_wmb(var, value) to do { var = value; wmb(); } while(0) except ia64 and sparc which use a mb() instead. But this is still moot since it is not used anyway. Hasn't been tested on any archs but x86 and x86_64 (and only compiled tested) Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-13[SPARC64]: Fix make headers_installDavid Woodhouse
A minor typo in the include/asm-sparc64/Kbuild file prevents the make headers_install from building a useful tree of kernel headers for sparc64. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Tom "spot" Callaway <tcallawa@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-05[SPARC64]: Fix sparc64 build errors when CONFIG_PCI=n.Randy Dunlap
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-04Merge git://git.infradead.org/hdrinstall-2.6Linus Torvalds
* git://git.infradead.org/hdrinstall-2.6: Remove export of include/linux/isdn/tpam.h Remove <linux/i2c-id.h> and <linux/i2c-algo-ite.h> from userspace export Restrict headers exported to userspace for SPARC and SPARC64 Add empty Kbuild files for 'make headers_install' in remaining arches. Add Kbuild file for Alpha 'make headers_install' Add Kbuild file for SPARC 'make headers_install' Add Kbuild file for IA64 'make headers_install' Add Kbuild file for S390 'make headers_install' Add Kbuild file for i386 'make headers_install' Add Kbuild file for x86_64 'make headers_install' Add Kbuild file for PowerPC 'make headers_install' Add generic Kbuild files for 'make headers_install' Basic implementation of 'make headers_check' Basic implementation of 'make headers_install'
2006-07-03[PATCH] lockdep: add per_cpu_offset()Ingo Molnar
Add the per_cpu_offset() generic method. (used by the lock validator) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: SPARC64: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[SPARC64]: Kill sun4v virtual device layer.David S. Miller
Replace with a simple IRQ translater in the PROM device tree builder. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits) [TIPC]: Initial activation message now includes TIPC version number [TIPC]: Improve response to requests for node/link information [TIPC]: Fixed skb_under_panic caused by tipc_link_bundle_buf [IrDA]: Fix the AU1000 FIR dependencies [IrDA]: Fix RCU lock pairing on error path [XFRM]: unexport xfrm_state_mtu [NET]: make skb_release_data() static [NETFILTE] ipv4: Fix typo (Bugzilla #6753) [IrDA]: MCS7780 usb_driver struct should be static [BNX2]: Turn off link during shutdown [BNX2]: Use dev_kfree_skb() instead of the _irq version [ATM]: basic sysfs support for ATM devices [ATM]: [suni] change suni_init to __devinit [ATM]: [iphase] should be __devinit not __init [ATM]: [idt77105] should be __devinit not __init [BNX2]: Add NETIF_F_TSO_ECN [NET]: Add ECN support for TSO [AF_UNIX]: Datagram getpeersec [NET]: Fix logical error in skb_gso_ok [PKT_SCHED]: PSCHED_TADD() and PSCHED_TADD2() can result,tv_usec >= 1000000 ...
2006-06-29[AF_UNIX]: Datagram getpeersecCatherine Zhang
This patch implements an API whereby an application can determine the label of its peer's Unix datagram sockets via the auxiliary data mechanism of recvmsg. Patch purpose: This patch enables a security-aware application to retrieve the security context of the peer of a Unix datagram socket. The application can then use this security context to determine the security context for processing on behalf of the peer who sent the packet. Patch design and implementation: The design and implementation is very similar to the UDP case for INET sockets. Basically we build upon the existing Unix domain socket API for retrieving user credentials. Linux offers the API for obtaining user credentials via ancillary messages (i.e., out of band/control messages that are bundled together with a normal message). To retrieve the security context, the application first indicates to the kernel such desire by setting the SO_PASSSEC option via getsockopt. Then the application retrieves the security context using the auxiliary data mechanism. An example server application for Unix datagram socket should look like this: toggle = 1; toggle_len = sizeof(toggle); setsockopt(sockfd, SOL_SOCKET, SO_PASSSEC, &toggle, &toggle_len); recvmsg(sockfd, &msg_hdr, 0); if (msg_hdr.msg_controllen > sizeof(struct cmsghdr)) { cmsg_hdr = CMSG_FIRSTHDR(&msg_hdr); if (cmsg_hdr->cmsg_len <= CMSG_LEN(sizeof(scontext)) && cmsg_hdr->cmsg_level == SOL_SOCKET && cmsg_hdr->cmsg_type == SCM_SECURITY) { memcpy(&scontext, CMSG_DATA(cmsg_hdr), sizeof(scontext)); } } sock_setsockopt is enhanced with a new socket option SOCK_PASSSEC to allow a server socket to receive security context of the peer. Testing: We have tested the patch by setting up Unix datagram client and server applications. We verified that the server can retrieve the security context using the auxiliary data mechanism of recvmsg. Signed-off-by: Catherine Zhang <cxzhang@watson.ibm.com> Acked-by: Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[SPARC64]: of_device layer IRQ resolutionDavid S. Miller
Do IRQ determination generically by parsing the PROM properties, and using IRQ controller drivers for final resolution. One immediate positive effect is that all of the IRQ frobbing in the EBUS, ISA, and PCI controller layers has been eliminated. We just look up the of_device and use the properly computed value. The PCI controller irq_build() routines are gone and no longer used. Unfortunately sbus_build_irq() has to remain as there is a direct reference to this in the sunzilog driver. That can be killed off once the sparc32 side of this is written and the sunzilog driver is transformed into an "of" bus driver. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[SPARC]: Kill interrupt stuff and linux_phandle from device_node.David S. Miller
