path: root/include/asm-sparc64/compat.h
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-17sparc: copy sparc64 specific files to asm-sparcSam Ravnborg
Used the following script to copy the files: cd include set -e SPARC64=`ls asm-sparc64` for FILE in ${SPARC64}; do if [ -f asm-sparc/$FILE ]; then echo $FILE exist in asm-sparc else git mv asm-sparc64/$FILE asm-sparc/$FILE printf "#include <asm-sparc/$FILE>\n" > asm-sparc64/$FILE git add asm-sparc64/$FILE fi done Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-03asm-*/compat.h: fix typo in commentMarcin Ślusarz
Signed-off-by: Marcin Ślusarz <marcin.slusarz@gmail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-07-16Introduce compat_u64 and compat_s64 typesArnd Bergmann
One common problem with 32 bit system call and ioctl emulation is the different alignment rules between i386 and 64 bit machines. A number of drivers work around this by marking the compat structures as 'attribute((packed))', which is not the right solution because it breaks all the non-x86 architectures that want to use the same compat code. Hopefully, this patch improves the situation, it introduces two new types, compat_u64 and compat_s64. These are defined on all architectures to have the same size and alignment as the 32 bit version of u64 and s64. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: David S. Miller <davem@davemloft.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Andi Kleen <ak@suse.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Vasily Tarasov <vtaras@openvz.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-22[SPARC64]: 8-byte align return value from compat_alloc_user_space()David S. Miller
Otherwise we get a ton of unaligned exceptions, for cases such as compat_sys_msgrcv() which go: p = compat_alloc_user_space(second + sizeof(struct msgbuf)); and here 'second' can for example be an arbitrary odd value. Based upon a bug report from Jurij Smakov. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-07[PATCH] compat: be more consistent about [ug]id_tStephen Rothwell
When I first wrote the compat layer patches, I was somewhat cavalier about the definition of compat_uid_t and compat_gid_t (or maybe I just misunderstood :-)). This patch makes the compat types much more consistent with the types we are being compatible with and hopefully will fix a few bugs along the way. compat type type in compat arch __compat_[ug]id_t __kernel_[ug]id_t __compat_[ug]id32_t __kernel_[ug]id32_t compat_[ug]id_t [ug]id_t The difference is that compat_uid_t is always 32 bits (for the archs we care about) but __compat_uid_t may be 16 bits on some. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] compat: introduce compat_time_tStephen Rothwell
This patch is based on work by Carlos O'Donell and Matthew Wilcox. It introduces/updates the compat_time_t type and uses it for compat siginfo structures. I have built this on ppc64 and x86_64. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-18[PATCH] sparc64: Fix statDavid S. Miller
Like Alpha, sparc64's struct stat was defined before we had the nanosecond et al. fields added. So like Alpha I have to cons up a struct stat64 to get this stuff. I'll work on the glibc bits soon. Also, we were forgetting to fill in the nanosecond fields in the sparc compat stat64 syscalls. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
