path: root/include/asm-sparc/irq.h
2007-08-03[SPARC32]: Fix modular build of floppy driver.David S. Miller
2007-07-22take declarations of enable_irq() et.al. to linux/interrupt.hAl Viro
Now that the last inlined instances are gone, all that is left to do is turning disable_irq_nosync on arm26 and m68k from defines to aliases and we are all set - we can make these externs in linux/interrupt.h uncoditional and kill remaining instances in asm/irq.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21[SPARC32]: Take enable_irq/disable_irq out of line.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-21[SPARC32]: clean include/asm-sparc/irq.hAl Viro
Move stuff used only by arch/sparc/kernel/* into arch/sparc/kernel/irq.h and into individual files in there (e.g. macros internal to sun4m_irq.c, etc.) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-09IRQ: Use the new typedef for interrupt handler function pointersDavid Howells
Use the new typedef for interrupt handler function pointers rather than actually spelling out the full thing each time. This was scripted with the following small shell script: #!/bin/sh egrep -nHrl -e 'irqreturn_t[ ]*[(][*]' $* | while read i do echo $i perl -pi -e 's/irqreturn_t\s*[(]\s*[*]\s*([_a-zA-Z0-9]*)\s*[)]\s*[(]\s*int\s*,\s*void\s*[*]\s*[)]/irq_handler_t \1/g' $i || exit $? done Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-08[PATCH] sparc32 pt_regs fixesAl Viro
2006-06-23[PATCH] adjust handle_IRR_event() return typeJan Beulich
Correct the return type of handle_IRQ_event() (inconsistency noticed during Xen development), and remove redundant declarations. The return type adjustment required breaking out the definition of irqreturn_t into a separate header, in order to satisfy current include order dependencies. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-20Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Update defconfig. [SPARC64]: Don't double-export synchronize_irq. [SPARC64]: Move over to GENERIC_HARDIRQS. [SPARC64]: Virtualize IRQ numbers. [SPARC64]: Kill ino_bucket->pil [SPARC]: Kill __irq_itoa(). [SPARC64]: bp->pil can never be zero [SPARC64]: Send all device interrupts via one PIL. [SPARC]: Fix iommu_flush_iotlb end address [SPARC]: Mark smp init functions as cpuinit [SPARC]: Add missing rw can_lock macros [SPARC]: Setup cpu_possible_map [SPARC]: Add topology_init()
2006-06-20[SPARC]: Kill __irq_itoa().David S. Miller
This ugly hack was long overdue to die. It was a way to print out Sparc interrupts in a more freindly format, since IRQ numbers were arbitrary opaque 32-bit integers which vectored into PIL levels. These 32-bit integers were not necessarily in the 0-->NR_IRQS range, but the PILs they vectored to were. The idea now is that we will increase NR_IRQS a little bit and use a virtual<-->real IRQ number mapping scheme similar to PowerPC. That makes this IRQ printing hack irrelevant, and furthermore only a handful of drivers actually used __irq_itoa() making it even less useful. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
