path: root/include/asm-sh/cache.h
2007-06-11sh: Tidy up dependencies for SH-2 build.Paul Mundt
SH-2 can presently get in to some pretty bogus states, so we tidy up the dependencies a bit and get it all building again. This gets us a bit closer to a functional allyesconfig and allmodconfig, though there are still a few things to fix up. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-03-05sh: Use L1_CACHE_BYTES for .data.cacheline_aligned.Paul Mundt
Previously this was using a hardcoded 32, use L1_CACHE_BYTES for cacheline alignment instead. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-27sh: page table alloc cleanups and page fault optimizations.Paul Mundt
Cleanup of page table allocators, using generic folded PMD and PUD helpers. TLB flushing operations are moved to a more sensible spot. The page fault handler is also optimized slightly, we no longer waste cycles on IRQ disabling for flushing of the page from the ITLB, since we're already under CLI protection by the initial exception handler. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-27sh: Optimized cache handling for SH-4/SH-4A caches.Richard Curnow
This reworks some of the SH-4 cache handling code to more easily accomodate newer-style caches (particularly for the > direct-mapped case), as well as optimizing some of the old code. Signed-off-by: Richard Curnow <richard.curnow@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-01-08[PATCH] Kill L1_CACHE_SHIFT_MAXRavikiran G Thirumalai
Kill L1_CACHE_SHIFT from all arches. Since L1_CACHE_SHIFT_MAX is not used anymore with the introduction of INTERNODE_CACHE, kill L1_CACHE_SHIFT_MAX. Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Shai Fultheim <shai@scalex86.org> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
