The bogomips calculation triggered via reading from /proc/cpuinfo
can return incorrect values if the qrnnd assembly is called with a
pointer in %r2 with any of the upper 32 bits set.
Fix this by using 64 bit division / remainder operation provided by
gcc instead of calling the assembly.
Preset the bogomips number to the cpu capacity value reported by
store system information in SYSIB 1.2.2. This value is constant
for a particular machine model and can be used to determine
relative performance differences between machines.
