path: root/include/asm-s390/cio.h
2007-04-27[S390] cio: Channel-path configure function.Peter Oberparleiter
Add a new attribute to the channel-path sysfs directory through which channel-path configure operations can be triggered. Also listen for hardware events requesting channel-path configure operations and process them accordingly. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-04-27[S390] cio/ipl: Clean interface between cio and ipl code.Heiko Carstens
Clean interface between cio and ipl code, so Peter stops complaining. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2006-12-04[S390] cio: Make ccw_dev_id_is_equal() more robust.Cornelia Huck
Using memcmp to compare ccw_dev_id implies that the whole structure (incl. padding) has always been completely initialized to sane values. Comparing the structures field by field doesn't make such assumptions. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] Reset infrastructure for re-IPL.Heiko Carstens
In case of re-IPL and diag308 doesn't work we have to reset all devices manually and wait synchronously that each reset finished. This patch adds the necessary infrastucture and the first exploiter of it. Subsystems that need to add a function that needs to be called at re-IPL may register/unregister this function via struct reset_call { struct reset_call *next; void (*fn)(void); }; void register_reset_call(struct reset_call *reset); void unregister_reset_call(struct reset_call *reset); When the registered function get called the context is: - all cpus beside the current one are stopped - all machine checks and interrupts are disabled - prefixing is disabled - a default machine check handler is available for use The registered functions may not take any locks are sleep. For the common I/O layer part of this patch: Introduce a reset_call css_reset that does the following: - clear all subchannels - perform a rchp on all channel paths and wait for the resulting machine checks This replaces the calls to clear_all_subchannels() and cio_reset_channel_paths() for kexec and ccw reipl. reipl_ccw_dev() now uses reipl_find_schid() to determine the subchannel id for a given device id. Also remove cio_reset_channel_paths() and friends since they are not needed anymore. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-10-11[S390] cio: Use ccw_dev_id and subchannel_id in ccw_device_privateCornelia Huck
Use the proper structures to identify device and subchannel. Change get_disc_ccwdev_by_devno() to get_disc_ccwdev_by_dev_id(). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-09-20[S390] ipl/dump on panic.Michael Holzheu
It is now possible to specify a ccw/fcp dump device which is used to automatically create a system dump in case of a kernel panic. The dump device can be configured under /sys/firmware/dump. In addition it is now possible to specify a ccw/fcp device which is used for the next reboot of Linux. The reipl device can be configured under /sys/firmware/reipl. Signed-off-by: Michael Holzheu <holzheu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-07-12[S390] path grouping and path verifications fixes.Cornelia Huck
1. Multipath devices for which SetPGID is not supported are not handled well. Use NOP ccws for path verification (sans path grouping) when SetPGID is not supported. 2. Check for PGIDs already set with SensePGID on _all_ paths (not just the first one) and try to find a common one. Moan if no common PGID can be found (and use NOP verification). If no PGIDs have been set, use the css global PGID (as before). (Rationale: SetPGID will get a command reject if the PGID it tries to set does not match the already set PGID.) 3. Immediately before reboot, issue RESET CHANNEL PATH (rcp) on all chpids. This will remove the old PGIDs. rcp will generate solicited CRWs which can be savely ignored by the machine check handler (all other actions create unsolicited CRWs). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-06-29[S390] cio async subchannel reprobe.Peter Oberparleiter
Changes in the DASD driver require an asynchronous implementation of the subchannel reprobe loop. This loop was so far only used by the blacklisting mechanism but is now available to all CCW device drivers. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
