path: root/include/asm-powerpc/spu.h
2007-02-07[POWERPC] Celleb: consolidate spu management opsIshizaki Kou
Spu management ops in arch/platforms/cell/spu_priv1_mmio.h can be used commonly in of based platform. This patch separates spu management ops from native cell code and uses on celleb platform. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-19[POWERPC] cell: add forward struct declarations to spu.hArnd Bergmann
Needed to be able to include spu.h independant from other headers. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2006-12-04[POWERPC] cell: abstract spu management routinesGeoff Levand
This adds a platform specific spu management abstraction and the coresponding routines to support the IBM Cell Blade. It also removes the hypervisor only resources that were included in struct spu. Three new platform specific routines are introduced, spu_enumerate_spus(), spu_create_spu() and spu_destroy_spu(). The underlying design uses a new type, struct spu_management_ops, to hold function pointers that the platform setup code is expected to initialize to instances appropriate to that platform. For the IBM Cell Blade support, I put the hypervisor only resources that were in struct spu into a platform specific data structure struct spu_pdata. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2006-12-04[POWERPC] coredump: Add SPU elf notes to coredump.Dwayne Grant McConnell
This patch adds SPU elf notes to the coredump. It creates a separate note for each of /regs, /fpcr, /lslr, /decr, /decr_status, /mem, /signal1, /signal1_type, /signal2, /signal2_type, /event_mask, /event_status, /mbox_info, /ibox_info, /wbox_info, /dma_info, /proxydma_info, /object-id. A new macro, ARCH_HAVE_EXTRA_NOTES, was created for architectures to specify they have extra elf core notes. A new macro, ELF_CORE_EXTRA_NOTES_SIZE, was created so the size of the additional notes could be calculated and added to the notes phdr entry. A new macro, ELF_CORE_WRITE_EXTRA_NOTES, was created so the new notes would be written after the existing notes. The SPU coredump code resides in spufs. Stub functions are provided in the kernel which are hooked into the spufs code which does the actual work via register_arch_coredump_calls(). A new set of __spufs_<file>_read/get() functions was provided to allow the coredump code to read from the spufs files without having to lock the SPU context for each file read from. Cc: <linux-arch@vger.kernel.org> Signed-off-by: Dwayne Grant McConnell <decimal@us.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2006-10-25[POWERPC] cell: add support for registering sysfs attributes to spusChristian Krafft
In order to add sysfs attributes to all spu's, there is a need for a list of all available spu's. Adding the device_node makes also sense, as it is needed for proper register access. This patch also adds two functions to create and remove sysfs attributes and attribute_groups to all spus. That allows to group spu attributes in a subdirectory like: /sys/devices/system/spu/spuX/group_name/what_ever This will be used by cbe_thermal to group all attributes dealing with thermal support in one directory. Signed-off-by: Christian Krafft <krafft@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-25[POWERPC] spufs: "stautus" isnt a word.arnd@arndb.de
Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-25[POWERPC] spufs: add support for nonschedulable contextsMark Nutter
This adds two new flags to spu_create: SPU_CREATE_NONSCHED: create a context that is never moved away from an SPE once it has started running. This flag can only be used by tasks with the CAP_SYS_NICE capability. SPU_CREATE_ISOLATED: create a nonschedulable context that enters isolation mode upon first run. This requires the SPU_CREATE_NONSCHED flag. Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-25[POWERPC] cell: remove unused struct spu variableGeoff Levand
Remove the mostly unused variable isrc from struct spu and a forgotten function declaration. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-05[POWERPC] spufs: add infrastructure for finding elf objectsArnd Bergmann
This adds an 'object-id' file that the spe library can use to store a pointer to its ELF object. This was originally meant for use by oprofile, but is now also used by the GNU debugger, if available. In order for oprofile to find the location in an spu-elf binary where an event counter triggered, we need a way to identify the binary in the first place. Unfortunately, that binary itself can be embedded in a powerpc ELF binary. Since we can assume it is mapped into the effective address space of the running process, have that one write the pointer value into a new spufs file. When a context switch occurs, pass the user value to the profiler so that can look at the mapped file (with some care). Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-05[POWERPC] spufs: Add infrastructure needed for gang schedulingArnd Bergmann
Add the concept of a gang to spufs as a new type of object. So far, this has no impact whatsover on scheduling, but makes it possible to add that later. A new type of object in spufs is now a spu_gang. It is created with the spu_create system call with the flags argument set to SPU_CREATE_GANG (0x2). Inside of a spu_gang, it is then possible to create spu_context objects, which until now was only possible at the root of spufs. There is a new member in struct spu_context pointing to the spu_gang it belongs to, if any. The spu_gang maintains a list of spu_context structures that are its children. This information can then be used in the scheduler in the future. There is still a bug that needs to be resolved in this basic infrastructure regarding the order in which objects are removed. When the spu_gang file descriptor is closed before the spu_context descriptors, we leak the dentry and inode for the gang. Any ideas how to cleanly solve this are appreciated. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-05[POWERPC] spufs: implement error event delivery to user spaceArnd Bergmann
This tries to fix spufs so we have an interface closer to what is specified in the man page for events returned in the third argument of spu_run. Fortunately, libspe has never been using the returned contents of that register, as they were the same as the return code of spu_run (duh!). Unlike the specification that we never implemented correctly, we now require a SPU_CREATE_EVENTS_ENABLED flag passed to spu_create, in order to get the new behavior. When this flag is not passed, spu_run will simply ignore the third argument now. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-05[POWERPC] spufs: scheduler support for NUMA.Mark Nutter
This patch adds NUMA support to the the spufs scheduler. The new arch/powerpc/platforms/cell/spufs/sched.c is greatly simplified, in an attempt to reduce complexity while adding support for NUMA scheduler domains. SPUs are allocated starting from the calling thread's node, moving to others as supported by current->cpus_allowed. Preemption is gone as it was buggy, but should be re-enabled in another patch when stable. The new arch/powerpc/platforms/cell/spu_base.c maintains idle lists on a per-node basis, and allows caller to specify which node(s) an SPU should be allocated from, while passing -1 tells spu_alloc() that any node is allowed. Since the patch removes the currently implemented preemptive scheduling, it is technically a regression, but practically all users have since migrated to this version, as it is part of the IBM SDK and the yellowdog distribution, so there is not much point holding it back while the new preemptive scheduling patch gets delayed further. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-31[POWERPC] cell: Constify & voidify get_property()Jeremy Kerr
Now that get_property() returns a void *, there's no need to cast its return value. Also, treat the return value as const, so we can constify get_property later. cell platform changes. Built for cell_defconfig Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-03[POWERPC] Add new interrupt mapping core and change platforms to use itBenjamin Herrenschmidt
This adds the new irq remapper core and removes the old one. Because there are some fundamental conflicts with the old code, like the value of NO_IRQ which I'm now setting to 0 (as per discussions with Linus), etc..., this commit also changes the relevant platform and driver code over to use the new remapper (so as not to cause difficulties later in bisecting). This patch removes the old pre-parsing of the open firmware interrupt tree along with all the bogus assumptions it made to try to renumber interrupts according to the platform. This is all to be handled by the new code now. For the pSeries XICS interrupt controller, a single remapper host is created for the whole machine regardless of how many interrupt presentation and source controllers are found, and it's set to match any device node that isn't a 8259. That works fine on pSeries and avoids having to deal with some of the complexities of split source controllers vs. presentation controllers in the pSeries device trees. The powerpc i8259 PIC driver now always requests the legacy interrupt range. It also has the feature of being able to match any device node (including NULL) if passed no device node as an input. That will help porting over platforms with broken device-trees like Pegasos who don't have a proper interrupt tree. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (139 commits) [POWERPC] re-enable OProfile for iSeries, using timer interrupt [POWERPC] support ibm,extended-*-frequency properties [POWERPC] Extra sanity check in EEH code [POWERPC] Dont look for class-code in pci children [POWERPC] Fix mdelay badness on shared processor partitions [POWERPC] disable floating point exceptions for init [POWERPC] Unify ppc syscall tables [POWERPC] mpic: add support for serial mode interrupts [POWERPC] pseries: Print PCI slot location code on failure [POWERPC] spufs: one more fix for 64k pages [POWERPC] spufs: fail spu_create with invalid flags [POWERPC] spufs: clear class2 interrupt status before wakeup [POWERPC] spufs: fix Makefile for "make clean" [POWERPC] spufs: remove stop_code from struct spu [POWERPC] spufs: fix spu irq affinity setting [POWERPC] spufs: further abstract priv1 register access [POWERPC] spufs: split the Cell BE support into generic and platform dependant parts [POWERPC] spufs: dont try to access SPE channel 1 count [POWERPC] spufs: use kzalloc in create_spu [POWERPC] spufs: fix initial state of wbox file ... Manually resolved conflicts in: drivers/net/phy/Makefile include/asm-powerpc/spu.h
2006-06-21[POWERPC] spufs: remove stop_code from struct spuMasato Noguchi
This patch remove 'stop_code' -- discarded member of struct spu. It is written at initialize and interrupt, but never read in current implementation. Signed-off-by: Masato Noguchi <Masato.Noguchi@jp.sony.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-21[POWERPC] spufs: further abstract priv1 register accessGeoff Levand
To support muti-platform binaries the spu hypervisor accessor routines must have runtime binding. I removed the existing statically linked routines in spu.h and spu_priv1_mmio.c and created new accessor routines in spu_priv1.h that operate indirectly through an ops struct spu_priv1_ops. spu_priv1_mmio.c contains the instance of the accessor routines for running on raw hardware. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-21[POWERPC] cell: register SPUs as sysdevsJeremy Kerr
SPUs are registered as system devices, exposing attributes through sysfs. Since the sysdev includes a kref, we can remove the one in struct spu (it isn't used at the moment anyway). Currently only the interrupt source and numa node attributes are added. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-05-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6David Woodhouse
2006-05-01[PATCH] powerpc: cell: Add numa id to struct spuJeremy Kerr
Add an nid member to the spu structure, and store the numa id of the spu there on creation. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-27[PATCH] spufs: enable SPE problem state MMIO access.Mark Nutter
This patch is layered on top of CONFIG_SPARSEMEM and is patterned after direct mapping of LS. This patch allows mmap() of the following regions: "mfc", which represents the area from [0x3000 - 0x3fff]; "cntl", which represents the area from [0x4000 - 0x4fff]; "signal1" which begins at offset 0x14000; "signal2" which begins at offset 0x1c000. The signal1 & signal2 files may be mmap()'d by regular user processes. The cntl and mfc file, on the other hand, may only be accessed if the owning process has CAP_SYS_RAWIO, because they have the potential to confuse the kernel with regard to parallel access to the same files with regular file operations: the kernel always holds a spinlock when accessing registers in these areas to serialize them, which can not be guaranteed with user mmaps, Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-27[PATCH] spufs: implement mfc access for PPE-side DMAArnd Bergmann
This patch adds a new file called 'mfc' to each spufs directory. The file accepts DMA commands that are a subset of what would be legal DMA commands for problem state register access. Upon reading the file, a bitmask is returned with the completed tag groups set. The file is meant to be used from an abstraction in libspe that is added by a different patch. From the kernel perspective, this means a process can now offload a memory copy from or into an SPE local store without having to run code on the SPE itself. The transfer will only be performed while the SPE is owned by one thread that is waiting in the spu_run system call and the data will be transferred into that thread's address space, independent of which thread started the transfer. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-27[PATCH] spufs: allow SPU code to do syscallsArnd Bergmann
An SPU does not have a way to implement system calls itself, but it can create intercepts to the kernel. This patch uses the method defined by the JSRE interface for C99 host library calls from an SPU to implement Linux system calls. It uses the reserved SPU stop code 0x2104 for this, using the structure layout and syscall numbers for ppc64-linux. I'm still undecided wether it is better to have a list of allowed syscalls or a list of forbidden syscalls, since we can't allow an SPU to call all syscalls that are defined for ppc64-linux. This patch implements the easier choice of them, with a blacklist that only prevents an SPU from calling anything that interacts with its own execution, e.g fork, execve, clone, vfork, exit, spu_run and spu_create and everything that deals with signals. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] spufs: set irq affinity for running threadsArnd Bergmann
For far, all SPU triggered interrupts always end up on the first SMT thread, which is a bad solution. This patch implements setting the affinity to the CPU that was running last when entering execution on an SPU. This should result in a significant reduction in IPI calls and better cache locality for SPE thread specific data. Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] spufs: fix allocation on 64k pagesArnd Bergmann
The size of the local store is architecture defined and independent from the page size, so it should not be defined in terms of pages in the first place. This mistake broke a few places when building for 64kb pages. Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] spufs: abstract priv1 register access.Arnd Bergmann
In a hypervisor based setup, direct access to the first priviledged register space can typically not be allowed to the kernel and has to be implemented through hypervisor calls. As suggested by Masato Noguchi, let's abstract the register access trough a number of function calls. Since there is currently no public specification of actual hypervisor calls to implement this, I only provide a place that makes it easier to hook into. Cc: Masato Noguchi <Masato.Noguchi@jp.sony.com> Cc: Geoff Levand <geoff.levand@am.sony.com> Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] spufs: clean up use of bitopsArnd Bergmann
checking bits manually might not be synchonized with the use of set_bit/clear_bit. Make sure we always use the correct bitops by removing the unnecessary identifiers. Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: sanitize header files for user space includesArnd Bergmann
include/asm-ppc/ had #ifdef __KERNEL__ in all header files that are not meant for use by user space, include/asm-powerpc does not have this yet. This patch gets us a lot closer there. There are a few cases where I was not sure, so I left them out. I have verified that no CONFIG_* symbols are used outside of __KERNEL__ any more and that there are no obvious compile errors when including any of the headers in user space libraries. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] spufs: Improved SPU preemptability [part 2].Arnd Bergmann
This patch reduces lock complexity of SPU scheduler, particularly for involuntary preemptive switches. As a result the new code does a better job of mapping the highest priority tasks to SPUs. Lock complexity is reduced by using the system default workqueue to perform involuntary saves. In this way we avoid nasty lock ordering problems that the previous code had. A "minimum timeslice" for SPU contexts is also introduced. The intent here is to avoid thrashing. While the new scheduler does a better job at prioritization it still does nothing for fairness. From: Mark Nutter <mnutter@us.ibm.com> Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] spufs: Improved SPU preemptability.Arnd Bergmann
This patch makes it easier to preempt an SPU context by having the scheduler hold ctx->state_sema for much shorter periods of time. As part of this restructuring, the control logic for the "run" operation is moved from arch/ppc64/kernel/spu_base.c to fs/spufs/file.c. Of course the base retains "bottom half" handlers for class{0,1} irqs. The new run loop will re-acquire an SPU if preempted. From: Mark Nutter <mnutter@us.ibm.com> Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] spufs: cooperative scheduler supportArnd Bergmann
This adds a scheduler for SPUs to make it possible to use more logical SPUs than physical ones are present in the system. Currently, there is no support for preempting a running SPU thread, they have to leave the SPU by either triggering an event on the SPU that causes it to return to the owning thread or by sending a signal to it. This patch also adds operations that enable accessing an SPU in either runnable or saved state. We use an RW semaphore to protect the state of the SPU from changing underneath us, while we are holding it readable. In order to change the state, it is acquired writeable and a context save or restore is executed before downgrading the semaphore to read-only. From: Mark Nutter <mnutter@us.ibm.com>, Uli Weigand <Ulrich.Weigand@de.ibm.com> Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] spufs: switchable spu contextsMark Nutter
Add some infrastructure for saving and restoring the context of an SPE. This patch creates a new structure that can hold the whole state of a physical SPE in memory. It also contains code that avoids races during the context switch and the binary code that is loaded to the SPU in order to access its registers. The actual PPE- and SPE-side context switch code are two separate patches. Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] spufs: The SPU file system, baseArnd Bergmann
This is the current version of the spu file system, used for driving SPEs on the Cell Broadband Engine. This release is almost identical to the version for the 2.6.14 kernel posted earlier, which is available as part of the Cell BE Linux distribution from http://www.bsc.es/projects/deepcomputing/linuxoncell/. The first patch provides all the interfaces for running spu application, but does not have any support for debugging SPU tasks or for scheduling. Both these functionalities are added in the subsequent patches. See Documentation/filesystems/spufs.txt on how to use spufs. Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
