path: root/include/asm-powerpc/oprofile_impl.h
2008-08-04powerpc: Move include files to arch/powerpc/include/asmStephen Rothwell
from include/asm-powerpc. This is the result of a mkdir arch/powerpc/include/asm git mv include/asm-powerpc/* arch/powerpc/include/asm Followed by a few documentation/comment fixups and a couple of places where <asm-powepc/...> was being used explicitly. Of the latter only one was outside the arch code and it is a driver only built for powerpc. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-05[POWERPC] Made FSL Book-E PMC support more genericAndy Fleming
Some of the more recent e300 cores have the same performance monitor implementation as the e500. e300 isn't book-e, so the name isn't really appropriate. In preparation for e300 support, rename a bunch of fsl_booke things to say fsl_emb (Freescale Embedded Performance Monitors). Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-20[CELL] oprofile: add support to OProfile for profiling CELL BE SPUsBob Nelson
From: Maynard Johnson <mpjohn@us.ibm.com> This patch updates the existing arch/powerpc/oprofile/op_model_cell.c to add in the SPU profiling capabilities. In addition, a 'cell' subdirectory was added to arch/powerpc/oprofile to hold Cell-specific SPU profiling code. Exports spu_set_profile_private_kref and spu_get_profile_private_kref which are used by OProfile to store private profile information in spufs data structures. Also incorporated several fixes from other patches (rrn). Check pointer returned from kzalloc. Eliminated unnecessary cast. Better error handling and cleanup in the related area. 64-bit unsigned long parameter was being demoted to 32-bit unsigned int and eventually promoted back to unsigned long. Signed-off-by: Carl Love <carll@us.ibm.com> Signed-off-by: Maynard Johnson <mpjohn@us.ibm.com> Signed-off-by: Bob Nelson <rrnelson@us.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Acked-by: Paul Mackerras <paulus@samba.org>
2007-04-24[POWERPC] pasemi: PA6T oprofile supportOlof Johansson
Oprofile support for PA6T, kernel side. Also rename the PA6T_SPRN.* defines to SPRN_PA6T.*. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-07[POWERPC] Oprofile cleanupOlof Johansson
Clean up the ctr_read/write a bit. It's currently defined in the include but only used in one C file each. The only exception is the classic version, so keep that in the include and define in the C file as appropriate. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-04[POWERPC] cell: Add oprofile supportMaynard Johnson
Add PPU event-based and cycle-based profiling support to Oprofile for Cell. Oprofile is expected to collect data on all CPUs simultaneously. However, there is one set of performance counters per node. There are two hardware threads or virtual CPUs on each node. Hence, OProfile must multiplex in time the performance counter collection on the two virtual CPUs. The multiplexing of the performance counters is done by a virtual counter routine. Initially, the counters are configured to collect data on the even CPUs in the system, one CPU per node. In order to capture the PC for the virtual CPU when the performance counter interrupt occurs (the specified number of events between samples has occurred), the even processors are configured to handle the performance counter interrupts for their node. The virtual counter routine is called via a kernel timer after the virtual sample time. The routine stops the counters, saves the current counts, loads the last counts for the other virtual CPU on the node, sets interrupts to be handled by the other virtual CPU and restarts the counters, the virtual timer routine is scheduled to run again. The virtual sample time is kept relatively small to make sure sampling occurs on both CPUs on the node with a relatively small granularity. Whenever the counters overflow, the performance counter interrupt is called to collect the PC for the CPU where data is being collected. The oprofile driver relies on a firmware RTAS call to setup the debug bus to route the desired signals to the performance counter hardware to be counted. The RTAS call must set the routing registers appropriately in each of the islands to pass the signals down the debug bus as well as routing the signals from a particular island onto the bus. There is a second firmware RTAS call to reset the debug bus to the non pass thru state when the counters are not in use. Signed-off-by: Carl Love <carll@us.ibm.com> Signed-off-by: Maynard Johnson <mpjohn@us.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-01[POWERPC] Fix oprofile support for e500 in arch/powerpcAndy Fleming
Fixed a compile error in building the 85xx support with oprofile, and in the process cleaned up some issues with the fsl_booke performance monitor code. * Reorganized FSL Book-E performance monitoring code so that the 7450 wouldn't be built if the e500 was, and cleaned it up so it was more self-contained. * Added a cpu_setup function for FSL Book-E. The original cpu_setup function prototype had no arguments, assuming that the reg_setup function would copy the required information into variables which represented the registers. This was silly for e500, since it has 1 register per counter (rather than 3 for all counters), so the code has been restructured to have cpu_setup take the current counter config array as an argument, with op_powerpc_setup() invoking op_powerpc_cpu_setup() through on_each_cpu(), and op_powerpc_cpu_setup() invoking the model-specific cpu_setup function with an argument. The argument is ignored on all other platforms at present. * Fixed a confusing line where a trinary operator only had two arguments Signed-off-by: Andrew Fleming <afleming@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-29[PATCH] powerpc: Remove oprofile spinlock backtrace codeAnton Blanchard
Remove oprofile spinlock backtrace code now we have proper calltrace support. Also make MMCRA sihv and sipr bits a variable since they may change in future cpus. Finally, MMCRA should be a 64bit quantity. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-29[PATCH] powerpc: Add oprofile calltrace supportBrian Rogan
Add oprofile calltrace support to powerpc. Disable spinlock backtracing now we can use calltrace info. (Updated to work on both 32bit and 64bit by me). Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-28[PATCH] powerpc: Remove some ifdefs in oprofile_impl.hAnton Blanchard
- No one uses op_counter_config.valid, so remove it - No need to ifdef around function protypes. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: sanitize header files for user space includesArnd Bergmann
include/asm-ppc/ had #ifdef __KERNEL__ in all header files that are not meant for use by user space, include/asm-powerpc does not have this yet. This patch gets us a lot closer there. There are a few cases where I was not sure, so I left them out. I have verified that no CONFIG_* symbols are used outside of __KERNEL__ any more and that there are no obvious compile errors when including any of the headers in user space libraries. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: G4+ oprofile supportAndy Fleming
This patch adds oprofile support for the 7450 and all its multitudinous derivatives. * Added 7450 (and derivatives) support for oprofile * Changed e500 cputable to have oprofile model and cpu_type fields * Added support for classic 32-bit performance monitor interrupt * Cleaned up common powerpc oprofile code to be as common as possible * Cleaned up oprofile_impl.h to reflect 32 bit classic code * Added 32-bit MMCRx bitfield definitions and SPR numbers Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-21[PATCH] powerpc: merge oprofile headersStephen Rothwell
Merge include/asm-ppc64/oprofile_ipml.h and arch/ppc/oprofile/op_impl.h into include/asm-powerpc/oprofile_ipml.h Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
