add atomic_xchg() to all the architectures. Needed by the new mutex code.
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
Several counters already have the need to use 64 atomic variables on 64 bit
platforms (see mm_counter_t in sched.h). We have to do ugly ifdefs to fall
back to 32 bit atomic on 32 bit platforms.
The VM statistics patch that I am working on will also make more extensive
use of atomic64.
This patch introduces a new type atomic_long_t by providing definitions in
asm-generic/atomic.h that works similar to the c "long" type. Its 32 bits
on 32 bit platforms and 64 bits on 64 bit platforms.
Also cleans up the determination of the mm_counter_t in sched.h.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Introduce an atomic_inc_not_zero operation. Make this a special case of
atomic_add_unless because lockless pagecache actually wants
atomic_inc_not_negativeone due to its offset refcount.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
Introduce an atomic_cmpxchg operation.
This patch consolidates macros used to generate assembly for
compatibility across different CPUs or configs. A new header,
asm-powerpc/asm-compat.h contains the main compatibility macros. It
uses some preprocessor magic to make the macros suitable both for use
in .S files, and in inline asm in .c files. Headers (bitops.h,
uaccess.h, atomic.h, bug.h) which had their own such compatibility
macros are changed to use asm-compat.h.
ppc_asm.h is now for use in .S files *only*, and a #error enforces
that. As such, we're a lot more careless about namespace pollution
here than in asm-compat.h.
While we're at it, this patch adds a call to the PPC405_ERR77 macro in
futex.h which should have had it already, but didn't.
Built and booted on pSeries, Maple and iSeries (ARCH=powerpc). Built
for 32-bit powermac (ARCH=powerpc) and Walnut (ARCH=ppc).
Signed-off-by: David Gibson <dwg@au1.ibm.com>
powerpc: Merge atomic.h and memory.h into powerpc
Merged atomic.h into include/powerpc. Moved asm-style HMT_ defines from
memory.h into ppc_asm.h, where there were already HMT_defines; moved c-style
HMT_ defines to processor.h. Renamed memory.h to synch.h to better reflect
its contents.
Signed-off-by: Kumar Gala <kumar.gala@freescale.com>
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Signed-off-by: Jon Loeliger <linuxppc@jdl.com>
