path: root/include/asm-mips/stackframe.h
2007-02-22[MIPS] Add basic SMARTMIPS ASE supportFranck Bui-Huu
This patch adds trivial support for SMARTMIPS extension. This extension is currently implemented by 4KS[CD] CPUs. Basically it saves/restores ACX register, which is part of the SMARTMIPS ASE, when needed. This patch does *not* add any support for Smartmips MMU features. Futhermore this patch does not add explicit support for 4KS[CD] CPUs since they are respectively mips32 and mips32r2 compliant. So with the current processor configuration, a platform that has such CPUs needs to select both configs: CPU_HAS_SMARTMIPS SYS_HAS_CPU_MIPS32_R[12] This is due to the processor configuration which is mixing up all the architecture variants and the processor types. The drawback of this, is that we currently pass '-march=mips32' option to gcc when building a kernel instead of '-march=4ksc' for 4KSC case. This can lead to a kernel image a little bit bigger than required. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-11[MIPS] Optimize and cleanup get_saved_sp, set_saved_spAtsushi Nemoto
If CONFIG_BUILD_ELF64 was not selected and gcc had -msym32 option (i.e. 4.0 or newer), there is no point to use %highest, %higher for kernel symbols. This patch also fixes 64-bit SMTC version of get_saved_sp() which is broken but harmless since there is no such CPUs for now. A bonus is set_saved_sp() and SMP version of get_saved_sp() are more readable now. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-29[MIPS] Fix use of ehb instruction for non-R2 configurations.Ralf Baechle
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-19[MIPS] MT: Improved multithreading support.Ralf Baechle
2006-03-21[MIPS] Remove CONFIG_BUILD_ELF64.Ralf Baechle
This option is no longer usable with supported compilers. It will be replaced by usage of -msym32 in a separate patch. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Fix get_saved_sp for 64bit address space. Simplify set_save_sp.Thiemo Seufer
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Thiemo Seufer <ths@networkno.de>
2005-10-29Fix 64bit SMP TLB handler and stack frame handling, optimize 32bit SMPThiemo Seufer
TLB handlers a bit, match definitions in pgtable-{32,64}.h better. Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Rewrite to avoid the use of $at. Unfortunately binutils 2.15 and CVSRalf Baechle
binutils are broken and don't warn about this use of $at even though gas is in .set noat mode so this for now is an accident waiting to happen. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-09-09kbuild: mips use generic asm-offsets.h supportSam Ravnborg
Removed obsolete stuff from arch makefile. mips had a special rule for generating asm-offsets.h so preserved it using an architecture specific hook in top-level Kbuild file. Renamed .h file to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-09-05[PATCH] mips: clean up 32/64-bit configurationRalf Baechle
Start cleaning 32-bit vs. 64-bit configuration. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
