path: root/include/asm-mips/mach-mips/cpu-feature-overrides.h
2008-07-15[MIPS] Malta: Cleanup organization of code into directories.Ralf Baechle
2006-07-13[MIPS] Use the proper technical term for naming some of the cache macros.Ralf Baechle
2006-06-20Merge git://git.infradead.org/hdrcleanup-2.6Linus Torvalds
* git://git.infradead.org/hdrcleanup-2.6: (63 commits) [S390] __FD_foo definitions. Switch to __s32 types in joystick.h instead of C99 types for consistency. Add <sys/types.h> to headers included for userspace in <linux/input.h> Move inclusion of <linux/compat.h> out of user scope in asm-x86_64/mtrr.h Remove struct fddi_statistics from user view in <linux/if_fddi.h> Move user-visible parts of drivers/s390/crypto/z90crypt.h to include/asm-s390 Revert include/media changes: Mauro says those ioctls are only used in-kernel(!) Include <linux/types.h> and use __uXX types in <linux/cramfs_fs.h> Use __uXX types in <linux/i2o_dev.h>, include <linux/ioctl.h> too Remove private struct dx_hash_info from public view in <linux/ext3_fs.h> Include <linux/types.h> and use __uXX types in <linux/affs_hardblocks.h> Use __uXX types in <linux/divert.h> for struct divert_blk et al. Use __u32 for elf_addr_t in <asm-powerpc/elf.h>, not u32. It's user-visible. Remove PPP_FCS from user view in <linux/ppp_defs.h>, remove __P mess entirely Use __uXX types in user-visible structures in <linux/nbd.h> Don't use 'u32' in user-visible struct ip_conntrack_old_tuple. Use __uXX types for S390 DASD volume label definitions which are user-visible S390 BIODASDREADCMB ioctl should use __u64 not u64 type. Remove unneeded inclusion of <linux/time.h> from <linux/ufs_fs.h> Fix private integer types used in V4L2 ioctls. ... Manually resolve conflict in include/linux/mtd/physmap.h
2006-06-19[MIPS] Fix R4K cache macro namesKumba
Several machines have the R4K cache macro name spelled incorrectly. Namely, they have cpu_has_4kcache defined instead of cpu_has_4k_cache. Signed-off-by: Joshua Kinard <kumba@gentoo.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-20[PATCH] USB: EHCI for AU1200Jordan Crouse
ALCHEMY: Add EHCI support for AU1200 Updated by removing the OHCI support Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-29Fixup a few lose ends in explicit support for MIPS R1/R2.Ralf Baechle
2005-10-29Cleanup the mess in cpu_cache_init.Ralf Baechle
2005-10-29Define cpu_icache_snoops_remote_store. This is slight abuse of somethingRalf Baechle
which originally was meant for SMP cache managment but it can be argued to apply on the 34K as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Rename CONFIG_CPU_MIPS{32,64} to CONFIG_CPU_MIPS{32|64}_R1.Ralf Baechle
