path: root/include/asm-mips/jmr3927/txx927.h
2008-07-15[MIPS] TXx9: Reorganize codeAtsushi Nemoto
Move arch/mips/{jmr3927,tx4927,tx4938} into arch/mips/txx9/ tree. This will help more code sharing and maintainance. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] jmr3927: use generic txx9 gpioAtsushi Nemoto
Use generic txx9 gpio (and gpiolib) for JMR3927 board. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] txx9tmr clockevent/clocksource driverAtsushi Nemoto
Convert jmr3927_clock_event_device to more generic txx9tmr_clock_event_device which supports one-shot mode. The txx9tmr_clock_event_device can be used for TX49 too if the cp0 timer interrupt was not available. Convert jmr3927_hpt_read to txx9_clocksource driver which does not depends jiffies anymore. The txx9_clocksource itself can be used for TX49, but normally TX49 uses higher precision clocksource_mips. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] JMR3927 cleanupAtsushi Nemoto
* Kill dead codes * Rearrange irq chip handlers * Minimize defconfig Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
