path: root/include/asm-mips/cpu-features.h
2007-07-10[MIPS] Enable support for the userlocal hardware registerRalf Baechle
Which will cut down the cost of RDHWR $29 which is used to obtain the TLS pointer and so far being emulated in software down to a single cycle operation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-17[MIPS] FPU ownership management & preemption fixesAtsushi Nemoto
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-13[MIPS] Use the proper technical term for naming some of the cache macros.Ralf Baechle
2006-07-13[MIPS] Default cpu_has_mipsmt to a runtime checkChris Dearman
Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-29[MIPS] Fix configuration of R2 CPU features and multithreading.Ralf Baechle
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-19[MIPS] FPU affinity for MT ASE.Ralf Baechle
2006-03-18[MIPS] local_r4k_flush_cache_page fixAtsushi Nemoto
If dcache_size != icache_size or dcache_size != scache_size, or set-associative cache, icache/scache does not flushed properly. Make blast_?cache_page_indexed() masks its index value correctly. Also, use physical address for physically indexed pcache/scache. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-01-10MIPS: Reorganize ISA constants strictly as bitmasks.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@ongar.mips.com>
2006-01-10MIPS: Introduce machinery for testing for MIPSxxR1/2.Ralf Baechle
2005-10-29Cleanup the mess in cpu_cache_init.Ralf Baechle
2005-10-29Detect the MIPS R2 vectored interrupt, external interrupt controllerRalf Baechle
options and the precense of the MT ASE. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Redo RM9000 workaround which along with other DSP ASE changes wasRalf Baechle
causing some headache for debuggers knowing about signal frames. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Support the MIPS32 / MIPS64 DSP ASE.Ralf Baechle
2005-10-29Cleanup decoding of MIPSxx config registers.Ralf Baechle
2005-09-05[PATCH] mips: clean up 32/64-bit configurationRalf Baechle
Start cleaning 32-bit vs. 64-bit configuration. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
