path: root/include/asm-mips/asm.h
2008-10-11MIPS: Move headfiles to new location below arch/mips/includeRalf Baechle
2008-01-29[MIPS] IP28: added cache barrier to assembly routinesThomas Bogendoerfer
IP28 needs special treatment to avoid speculative accesses. gcc takes care for .c code, but for assembly code we need to do it manually. This is taken from Peter Fuersts IP28 patches. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] checkfiles: Fix "need space after that ','" errors.Ralf Baechle
2006-11-01[MIPS] 16K & 64K page size fixesRalf Baechle
Derived from Peter Watkins <treestem@gmail.com>'s work. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2005-10-29Fix build with CONFIG_PRINTK disabled.Ralf Baechle
