path: root/include/asm-ia64/processor.h
2008-02-05Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] make pfm_get_task work with virtual pids [IA64] honor notify_die() returning NOTIFY_STOP [IA64] remove dead code: __cpu_{down,die} from !HOTPLUG_CPU [IA64] Appoint kvm/ia64 Maintainers [IA64] ia64_set_psr should use srlz.i [IA64] Export three symbols for module use [IA64] mca style cleanup [IA64] sn_hwperf semaphore to mutex [IA64] generalize attribute of fsyscall_gtod_data [IA64] efi.c Add /* never reached */ annotation [IA64] efi.c Spelling/punctuation fixes [IA64] Make efi.c mostly fit in 80 columns [IA64] aliasing-test: fix gcc warnings on non-ia64 [IA64] Slim-down __clear_bit_unlock [IA64] Fix the order of atomic operations in restore_previous_kprobes on ia64 [IA64] constify function pointer tables [IA64] fix userspace compile error in gcc_intrin.h
2008-02-05maps4: rework TASK_SIZE macrosDave Hansen
The following replaces the earlier patches sent. It should address David Rientjes's comments, and has been compile tested on all the architectures that it touches, save for parisc. For the /proc/<pid>/pagemap code[1], we need to able to query how much virtual address space a particular task has. The trick is that we do it through /proc and can't use TASK_SIZE since it references "current" on some arches. The process opening the /proc file might be a 32-bit process opening a 64-bit process's pagemap file. x86_64 already has a TASK_SIZE_OF() macro: #define TASK_SIZE_OF(child) ((test_tsk_thread_flag(child, TIF_IA32)) ? IA32_PAGE_OFFSET : TASK_SIZE64) I'd like to have that for other architectures. So, add it for all the architectures that actually use "current" in their TASK_SIZE. For the others, just add a quick #define in sched.h to use plain old TASK_SIZE. 1. http://www.linuxworld.com/news/2007/042407-kernel.html - MIPS portion from Ralf Baechle <ralf@linux-mips.org> [akpm@linux-foundation.org: fix mips build] Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Matt Mackall <mpm@selenic.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04[IA64] ia64_set_psr should use srlz.iXiantao Zhang
The only in kernel use of ia64_set_psr() needs to follow it with a srlz.i (since it is changing state for PSR.ic). So it is pointless to issue srlz.d inside this function. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-07-25[IA64] rename partial_pageakpm@linux-foundation.org
Jens has added a partial_page thing in splice whcih conflicts with the ia64 one. Rename ia64 out of the way. (ia64 chose poorly). Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-07-19coredump masking: reimplementation of dumpable using two flagsKawai, Hidehiro
This patch changes mm_struct.dumpable to a pair of bit flags. set_dumpable() converts three-value dumpable to two flags and stores it into lower two bits of mm_struct.flags instead of mm_struct.dumpable. get_dumpable() behaves in the opposite way. [akpm@linux-foundation.org: export set_dumpable] Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30Pull percpu-dtc into release branchTony Luck
2007-04-04[PATCH] ia64: desc_empty thinko/typo fixMaciej Zenczykowski
Just a one-byter for an ia64 thinko/typo - already fixed for i386 and x86_64. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-06[IA64] remove per-cpu ia64_phys_stacked_size_p8Chen, Kenneth W
It's not efficient to use a per-cpu variable just to store how many physical stack register a cpu has. Ever since the incarnation of ia64 up till upcoming Montecito processor, that variable has "glued" to 96. Having a variable in memory means that the kernel is burning an extra cacheline access on every syscall and kernel exit path. Such "static" value is better served with the instruction patching utility exists today. Convert ia64_phys_stacked_size_p8 into dynamic insn patching. This also has a pleasant side effect of eliminating access to per-cpu area while psr.ic=0 in the kernel exit path. (fixable for per-cpu DTC work, but why bother?) There are some concerns with the default value that the instruc- tion encoded in the kernel image. It shouldn't be concerned. The reasons are: (1) cpu_init() is called at CPU initialization. In there, we find out physical stack register size from PAL and patch two instructions in kernel exit code. The code in question can not be executed before the patching is done. (2) current implementation stores zero in ia64_phys_stacked_size_p8, and that's what the current kernel exit path loads the value with. With the new code, it is equivalent that we store reg size 96 in ia64_phys_stacked_size_p8, thus creating a better safety net. Given (1) above can never fail, having (2) is just a bonus. All in all, this patch allow one less memory reference in the kernel exit path, thus reducing syscall and interrupt return latency; and avoid polluting potential useful data in the CPU cache. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-09-26[IA64] Move perfmon tables from thread_struct to pfm_contextKeshavamurthy Anil S
This patch renders thread_struct->pmcs[] and thread_struct->pmds[] OBSOLETE. The actual table is moved to pfm_context structure which saves space in thread_struct (in turn saving space in task_struct which frees up more space for kernel stacks). Signed-off-by: Stephane Eranian <eranian@hpl.hp.com> Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-09-26Pull model-name into release branchTony Luck
2006-06-05[IA64] Add "model name" to /proc/cpuinfoTony Luck
Linux ia64 port tried to decode the processor family number to something human-readable, but Intel brandnames don't change synchronously with updates to the family number. Adopt a more i386-like approach and just print the family number in decimal. Add a new field "model name" that uses PAL_BRAND_INFO to find the official name for the cpu, or on older systems, falls back to using the well-known codenames (Merced, McKinley, Madison). Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-22[IA64] add init declaration to cpu initialization functionsChen, Kenneth W
Add init declaration to cpu initialization functions. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-21Pull sn2-mmio-writes into release branchTony Luck
Hand-fixed conflicts: include/asm-ia64/machvec_sn2.h Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-02[IA64] avoid broken SAL_CACHE_FLUSH implementationsBjorn Helgaas
If SAL_CACHE_FLUSH drops interrupts, complain about it and fall back to using PAL_CACHE_FLUSH instead. This is to work around a defect in HP rx5670 firmware: when an interrupt occurs during SAL_CACHE_FLUSH, SAL drops the interrupt but leaves it marked "in-service", which leaves the interrupt (and others of equal or lower priority) masked. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-01-26[IA64] hooks to wait for mmio writes to drain when migrating processesBrent Casavant
On SN2, MMIO writes which are issued from separate processors are not guaranteed to arrive in any particular order at the IO hardware. When performing such writes from the kernel this is not a problem, as a kernel thread will not migrate to another CPU during execution, and mmiowb() calls can guarantee write ordering when control of the IO resource is allowed to move between threads. However, when MMIO writes can be performed from user space (e.g. DRM) there are no such guarantees and mechanisms, as the process may context-switch at any time, and may migrate to a different CPU as part of the switch. For such programs/hardware to operate correctly, it is required that the MMIO writes from the old CPU be accepted by the IO hardware before subsequent writes from the new CPU can be issued. The following patch implements this behavior on SN2 by waiting for a Shub register to indicate that these writes have been accepted. This is placed in the context switch-in path, and only performs the wait when the newly scheduled task changes CPUs. Signed-off-by: Prarit Bhargava <prarit@sgi.com> Signed-off-by: Brent Casavant <bcasavan@sgi.com>
2006-01-16[IA64] Perfmon for MontecitoStephane Eranian
Add Montecito PMU description table for perfmon2 Signed-off-by: Stephane Eranian <eranian@hpl.hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-01-12[PATCH] ia64: task_pt_regs()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] cpusets: Move the ia64 domain setup code to the generic codeJohn Hawkes
Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-08[PATCH] ia64: fix floating-point preemption problemPeter Chubb
There've been reports of problems with CONFIG_PREEMPT=y and the high floating point partition. This is caused by the possibility of preemption and rescheduling on a different processor while saving or restioirng the high partition. The only places where the FPU state is touched are in ptrace, in switch_to(), and where handling a floating-point exception. In switch_to() preemption is off. So it's only in trap.c and ptrace.c that we need to prevent preemption. Here is a patch that adds commentary to make the conditions clear, and adds appropriate preempt_{en,dis}able() calls to make it so. In trap.c I use preempt_enable_no_resched(), as we're about to return to user space where the preemption flag will be checked anyway. Signed-off-by: Peter Chubb <peterc@gelato.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-25[IA64] multi-core/multi-thread identificationSuresh Siddha
Version 3 - rediffed to apply on top of Ashok's hotplug cpu patch. /proc/cpuinfo output in step with x86. This is an updated MC/MT identification patch based on the previous discussions on list. Add the Multi-core and Multi-threading detection for IPF. - Add new core and threading related fields in /proc/cpuinfo. Physical id Core id Thread id Siblings - setup the cpu_core_map and cpu_sibling_map appropriately - Handles Hot plug CPU Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Gordon Jin <gordon.jin@intel.com> Signed-off-by: Rohit Seth <rohit.seth@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-04-25[IA64] Percpu quicklist for combined allocator for pgd/pmd/pte.Robin Holt
This patch introduces using the quicklists for pgd, pmd, and pte levels by combining the alloc and free functions into a common set of routines. This greatly simplifies the reading of this header file. This patch is simple but necessary for large numa configurations. It simply ensures that only pages from the local node are added to a cpus quicklist. This prevents the trapping of pages on a remote nodes quicklist by starting a process, touching a large number of pages to fill pmd and pte entries, migrating to another node, and then unmapping or exiting. With those conditions, the pages get trapped and if the machine has more than 100 nodes of the same size, the calculation of the pgtable high water mark will be larger than any single node so page table cache flushing will never occur. I ran lmbench lat_proc fork and lat_proc exec on a zx1 with and without this patch and did not notice any change. On an sn2 machine, there was a slight improvement which is possibly due to pages from other nodes trapped on the test node before starting the run. I did not investigate further. This patch shrinks the quicklist based upon free memory on the node instead of the high/low water marks. I have written it to enable preemption periodically and recalculate the amount to shrink every time we have freed enough pages that the quicklist size should have grown. I rescan the nodes zones each pass because other processess may be draining node memory at the same time as we are adding. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-04-19[PATCH] freepgt: remove MM_VM_SIZE(mm)Hugh Dickins
There's only one usage of MM_VM_SIZE(mm) left, and it's a troublesome macro because mm doesn't contain the (32-bit emulation?) info needed. But it too is only needed because we ignore the end from the vma list. We could make flush_pgtables return that end, or unmap_vmas. Choose the latter, since it's a natural fit with unmap_mapping_range_vma needing to know its restart addr. This does make more than minimal change, but if unmap_vmas had returned the end before, this is how we'd have done it, rather than storing the break_addr in zap_details. unmap_vmas used to return count of vmas scanned, but that's just debug which hasn't been useful in a while; and if we want the map_count 0 on exit check back, it can easily come from the final remove_vm_struct loop. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
