path: root/include/asm-i386/kdebug.h
2007-10-11i386/x86_64: move headers to include/asm-x86Thomas Gleixner
Move the headers to include/asm-x86 and fixup the header install make rules Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-05-14Revert "ipmi: add new IPMI nmi watchdog handling"Linus Torvalds
This reverts commit f64da958dfc83335de1d2bef9d3868f30feb4e53. Andi Kleen is unhappy with the changes, and they really do not seem worth it. IPMI could use DIE_NMI_IPI instead of the new callback, even though that ends up having its own set of problems too, mainly because the IPMI code cannot really know the NMI was from IPMI or not. Manually fix up conflicts in arch/x86_64/kernel/traps.c and drivers/char/ipmi/ipmi_watchdog.c. Cc: Andi Kleen <ak@suse.de> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Corey Minyard <minyard@acm.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08move die notifier handling to common codeChristoph Hellwig
This patch moves the die notifier handling to common code. Previous various architectures had exactly the same code for it. Note that the new code is compiled unconditionally, this should be understood as an appel to the other architecture maintainer to implement support for it aswell (aka sprinkling a notify_die or two in the proper place) arm had a notifiy_die that did something totally different, I renamed it to arm_notify_die as part of the patch and made it static to the file it's declared and used at. avr32 used to pass slightly less information through this interface and I brought it into line with the other architectures. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix vmalloc_sync_all bustage] [bryan.wu@analog.com: fix vmalloc_sync_all in nommu] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08ipmi: add new IPMI nmi watchdog handlingCorey Minyard
Convert over to the new NMI handling for getting IPMI watchdog timeouts via an NMI. This add config options to know if there is the ability to receive NMIs and if it has an NMI post processing call. Then it modifies the IPMI watchdog to take advantage of this so that it can know if an NMI comes in. It also adds testing that the IPMI NMI watchdog works. Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-26[PATCH] Notify page fault call chain for i386Anil S Keshavamurthy
Overloading of page fault notification with the notify_die() has performance issues(since the only interested components for page fault is kprobes and/or kdb) and hence this patch introduces the new notifier call chain exclusively for page fault notifications their by avoiding notifying unnecessary components in the do_page_fault() code path. Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] Notifier chain update: API changesAlan Stern
The kernel's implementation of notifier chains is unsafe. There is no protection against entries being added to or removed from a chain while the chain is in use. The issues were discussed in this thread: http://marc.theaimsgroup.com/?l=linux-kernel&m=113018709002036&w=2 We noticed that notifier chains in the kernel fall into two basic usage classes: "Blocking" chains are always called from a process context and the callout routines are allowed to sleep; "Atomic" chains can be called from an atomic context and the callout routines are not allowed to sleep. We decided to codify this distinction and make it part of the API. Therefore this set of patches introduces three new, parallel APIs: one for blocking notifiers, one for atomic notifiers, and one for "raw" notifiers (which is really just the old API under a new name). New kinds of data structures are used for the heads of the chains, and new routines are defined for registration, unregistration, and calling a chain. The three APIs are explained in include/linux/notifier.h and their implementation is in kernel/sys.c. With atomic and blocking chains, the implementation guarantees that the chain links will not be corrupted and that chain callers will not get messed up by entries being added or removed. For raw chains the implementation provides no guarantees at all; users of this API must provide their own protections. (The idea was that situations may come up where the assumptions of the atomic and blocking APIs are not appropriate, so it should be possible for users to handle these things in their own way.) There are some limitations, which should not be too hard to live with. For atomic/blocking chains, registration and unregistration must always be done in a process context since the chain is protected by a mutex/rwsem. Also, a callout routine for a non-raw chain must not try to register or unregister entries on its own chain. (This did happen in a couple of places and the code had to be changed to avoid it.) Since atomic chains may be called from within an NMI handler, they cannot use spinlocks for synchronization. Instead we use RCU. The overhead falls almost entirely in the unregister routine, which is okay since unregistration is much less frequent that calling a chain. Here is the list of chains that we adjusted and their classifications. None of them use the raw API, so for the moment it is only a placeholder. ATOMIC CHAINS ------------- arch/i386/kernel/traps.c: i386die_chain arch/ia64/kernel/traps.c: ia64die_chain arch/powerpc/kernel/traps.c: powerpc_die_chain arch/sparc64/kernel/traps.c: sparc64die_chain arch/x86_64/kernel/traps.c: die_chain drivers/char/ipmi/ipmi_si_intf.c: xaction_notifier_list kernel/panic.c: panic_notifier_list kernel/profile.c: task_free_notifier net/bluetooth/hci_core.c: hci_notifier net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_chain net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_expect_chain net/ipv6/addrconf.c: inet6addr_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_expect_chain net/netlink/af_netlink.c: netlink_chain BLOCKING CHAINS --------------- arch/powerpc/platforms/pseries/reconfig.c: pSeries_reconfig_chain arch/s390/kernel/process.c: idle_chain arch/x86_64/kernel/process.c idle_notifier drivers/base/memory.c: memory_chain drivers/cpufreq/cpufreq.c cpufreq_policy_notifier_list drivers/cpufreq/cpufreq.c cpufreq_transition_notifier_list drivers/macintosh/adb.c: adb_client_list drivers/macintosh/via-pmu.c sleep_notifier_list drivers/macintosh/via-pmu68k.c sleep_notifier_list drivers/macintosh/windfarm_core.c wf_client_list drivers/usb/core/notify.c usb_notifier_list drivers/video/fbmem.c fb_notifier_list kernel/cpu.c cpu_chain kernel/module.c module_notify_list kernel/profile.c munmap_notifier kernel/profile.c task_exit_notifier kernel/sys.c reboot_notifier_list net/core/dev.c netdev_chain net/decnet/dn_dev.c: dnaddr_chain net/ipv4/devinet.c: inetaddr_chain It's possible that some of these classifications are wrong. If they are, please let us know or submit a patch to fix them. Note that any chain that gets called very frequently should be atomic, because the rwsem read-locking used for blocking chains is very likely to incur cache misses on SMP systems. (However, if the chain's callout routines may sleep then the chain cannot be atomic.) The patch set was written by Alan Stern and Chandra Seetharaman, incorporating material written by Keith Owens and suggestions from Paul McKenney and Andrew Morton. [jes@sgi.com: restructure the notifier chain initialization macros] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] x86 NMI: better support for debuggersGeorge Anzinger
This patch adds a notify to the die_nmi notify that the system is about to be taken down. If the notify is handled with a NOTIFY_STOP return, the system is given a new lease on life. We also change the nmi watchdog to carry on if die_nmi returns. This give debug code a chance to a) catch watchdog timeouts and b) possibly allow the system to continue, realizing that the time out may be due to debugger activities such as single stepping which is usually done with "other" cpus held. Signed-off-by: George Anzinger<george@mvista.com> Cc: Keith Owens <kaos@ocs.com.au> Signed-off-by: George Anzinger <george@mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] RCU: clean up a few remaining synchronize_kernel() callsPaul E. McKenney
2.6.12-rc6-mm1 has a few remaining synchronize_kernel()s, some (but not all) in comments. This patch changes these synchronize_kernel() calls (and comments) to synchronize_rcu() or synchronize_sched() as follows: - arch/x86_64/kernel/mce.c mce_read(): change to synchronize_sched() to handle races with machine-check exceptions (synchronize_rcu() would not cut it given RCU implementations intended for hardcore realtime use. - drivers/input/serio/i8042.c i8042_stop(): change to synchronize_sched() to handle races with i8042_interrupt() interrupt handler. Again, synchronize_rcu() would not cut it given RCU implementations intended for hardcore realtime use. - include/*/kdebug.h comments: change to synchronize_sched() to handle races with NMIs. As before, synchronize_rcu() would not cut it... - include/linux/list.h comment: change to synchronize_rcu(), since this comment is for list_del_rcu(). - security/keys/key.c unregister_key_type(): change to synchronize_rcu(), since this is interacting with RCU read side. - security/keys/process_keys.c install_session_keyring(): change to synchronize_rcu(), since this is interacting with RCU read side. Signed-off-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
