path: root/include/asm-generic
2009-04-27Remove unused support code for refok sections.Tim Abbott
The old refok sections .text.init.refok .data.init.refok .exit.text.refok have been deprecated since commit 312b1485fb509c9bc32eda28ad29537896658cb8. After the other patches in this patch series nothing is put in these sections, so clean things up by eliminating all the remaining references to them. Signed-off-by: Tim Abbott <tabbott@mit.edu> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-26Add new HEAD_TEXT_SECTION macro.Tim Abbott
This patch is preparation for replacing all uses of ".head.text" or ".text.head" in the kernel with macros, so that the section name can later be changed without having to touch a lot of the kernel. Since some linker scripts do more complex things than referencing HEAD_TEXT, we add a HEAD_TEXT_SECTION macro that just contains the actual name. I've defined HEAD_TEXT_SECTION in a new header, include/linux/section-names.h, so that this section name only needs to appear in one place. I anticipate creating similar macro structures for a number of other section names. The long-term goal here is to be able to change the kernel's magic section names to those that are compatible with -ffunction-sections -fdata-sections. This requires renaming all magic sections with names of the form ".text.foo". Signed-off-by: Tim Abbott <tabbott@mit.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21PERCPU: Collect the DECLARE/DEFINE declarations togetherDavid Howells
Collect the DECLARE/DEFINE declarations together in linux/percpu-defs.h so that they're in one place, and give them descriptive comments, particularly the SHARED_ALIGNED variant. It would be nice to collect these in linux/percpu.h, but that's not possible without sorting out the severe #include recursion between the x86 arch headers and the general headers (and possibly other arches too). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21FRV: Fix the section attribute on UP DECLARE_PER_CPU()David Howells
In non-SMP mode, the variable section attribute specified by DECLARE_PER_CPU() does not agree with that specified by DEFINE_PER_CPU(). This means that architectures that have a small data section references relative to a base register may throw up linkage errors due to too great a displacement between where the base register points and the per-CPU variable. On FRV, the .h declaration says that the variable is in the .sdata section, but the .c definition says it's actually in the .data section. The linker throws up the following errors: kernel/built-in.o: In function `release_task': kernel/exit.c:78: relocation truncated to fit: R_FRV_GPREL12 against symbol `per_cpu__process_counts' defined in .data section in kernel/built-in.o kernel/exit.c:78: relocation truncated to fit: R_FRV_GPREL12 against symbol `per_cpu__process_counts' defined in .data section in kernel/built-in.o To fix this, DECLARE_PER_CPU() should simply apply the same section attribute as does DEFINE_PER_CPU(). However, this is made slightly more complex by virtue of the fact that there are several variants on DEFINE, so these need to be matched by variants on DECLARE. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-15The default CONFIG_BUG=n version of BUG() should have an empty do...whileDavid Howells
The default CONFIG_BUG=n version of BUG() should incorporate an empty a do...while statement to avoid compilation weirdness. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13asm-generic/siginfo.h: update NSIGTRAP definitionAndi Kleen
Impact: (nearly) trivial The patch commit da654b74bda14c45a7d98c731bf3c1a43b6b74e2 Author: Srinivasa Ds <srinivasa@in.ibm.com> Date: Tue Sep 23 15:23:52 2008 +0530 signals: demultiplexing SIGTRAP signal forgot to update the NSIGTRAP define in asm-generic/siginfo.h to the new number of sigtrap subcodes. Nothing in the tree seems to use it, but presumably something in user space might. So update it. Cc: Srinivasa Ds <srinivasa@in.ibm.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-10percpu: unbreak alpha percpuTejun Heo
For the time being, move the generic percpu_*() accessors to linux/percpu.h. asm-generic/percpu.h is meant to carry generic stuff for low level stuff - declarations, definitions and pointer offset calculation and so on but not for generic interface. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-05Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (413 commits) tracing, net: fix net tree and tracing tree merge interaction tracing, powerpc: fix powerpc tree and tracing tree interaction ring-buffer: do not remove reader page from list on ring buffer free function-graph: allow unregistering twice trace: make argument 'mem' of trace_seq_putmem() const tracing: add missing 'extern' keywords to trace_output.h tracing: provide trace_seq_reserve() blktrace: print out BLK_TN_MESSAGE properly blktrace: extract duplidate code blktrace: fix memory leak when freeing struct blk_io_trace blktrace: fix blk_probes_ref chaos blktrace: make classic output more classic blktrace: fix off-by-one bug blktrace: fix the original blktrace blktrace: fix a race when creating blk_tree_root in debugfs blktrace: fix timestamp in binary output tracing, Text Edit Lock: cleanup tracing: filter fix for TRACE_EVENT_FORMAT events ftrace: Using FTRACE_WARN_ON() to check "freed record" in ftrace_release() x86: kretprobe-booster interrupt emulation code fix ... Fix up trivial conflicts in arch/parisc/include/asm/ftrace.h include/linux/memory.h kernel/extable.c kernel/module.c
2009-04-02gpiolib: allow GPIOs to be namedDaniel Silverstone
Allow GPIOs in GPIOLIB chips to be named. This name is then used when the GPIO is exported to sysfs, although it could be used elsewhere if deemed useful. Signed-off-by: Daniel Silverstone <dsilvers@simtec.co.uk> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02Merge branch 'tracing/core-v2' into tracing-for-linusIngo Molnar
Conflicts: include/linux/slub_def.h lib/Kconfig.debug mm/slob.c mm/slub.c
2009-04-01remove unused include/asm-generic/dma-mapping.hFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30cpumask: remove the now-obsoleted pcibus_to_cpumask(): genericRusty Russell
Impact: reduce stack usage for large NR_CPUS cpumask_of_pcibus() is the new version. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-03-30cpumask: remove node_to_first_cpuRusty Russell
Everyone defines it, and only one person uses it (arch/mips/sgi-ip27/ip27-nmi.c). So just open code it there. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: linux-mips@linux-mips.org
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-26Merge branch 'header-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'header-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (50 commits) x86: headers cleanup - setup.h emu101k1.h: fix duplicate include of <linux/types.h> compiler-gcc4: conditionalize #error on __KERNEL__ remove __KERNEL_STRICT_NAMES make netfilter use strict integer types make drm headers use strict integer types make MTD headers use strict integer types make most exported headers use strict integer types make exported headers use strict posix types unconditionally include asm/types.h from linux/types.h make linux/types.h as assembly safe Neither asm/types.h nor linux/types.h is required for arch/ia64/include/asm/fpu.h headers_check fix cleanup: linux/reiserfs_fs.h headers_check fix cleanup: linux/nubus.h headers_check fix cleanup: linux/coda_psdev.h headers_check fix: x86, setup.h headers_check fix: x86, prctl.h headers_check fix: linux/reinserfs_fs.h headers_check fix: linux/socket.h headers_check fix: linux/nubus.h ... Manually fix trivial conflicts in: include/linux/netfilter/xt_limit.h include/linux/netfilter/xt_statistic.h
2009-03-26remove __KERNEL_STRICT_NAMESArnd Bergmann
With the last used of non-strict names gone from the exported header files, we can remove the old libc5 compatibility cruft from our headers and only export strict types. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-26make exported headers use strict posix typesArnd Bergmann
A number of standard posix types are used in exported headers, which is not allowed if __STRICT_KERNEL_NAMES is defined. In order to get rid of the non-__STRICT_KERNEL_NAMES part and to make sane headers the default, we have to change them all to safe types. There are also still some leftovers in reiserfs_fs.h, elfcore.h and coda.h, but these files have not compiled in user space for a long time. This leaves out the various integer types ({u_,u,}int{8,16,32,64}_t), which we take care of separately. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: David Airlie <airlied@linux.ie> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Cc: linux-ppp@vger.kernel.org Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-24dynamic debug: combine dprintk and dynamic printkJason Baron
This patch combines Greg Bank's dprintk() work with the existing dynamic printk patchset, we are now calling it 'dynamic debug'. The new feature of this patchset is a richer /debugfs control file interface, (an example output from my system is at the bottom), which allows fined grained control over the the debug output. The output can be controlled by function, file, module, format string, and line number. for example, enabled all debug messages in module 'nf_conntrack': echo -n 'module nf_conntrack +p' > /mnt/debugfs/dynamic_debug/control to disable them: echo -n 'module nf_conntrack -p' > /mnt/debugfs/dynamic_debug/control A further explanation can be found in the documentation patch. Signed-off-by: Greg Banks <gnb@sgi.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-13tracing/syscalls: core infrastructure for syscalls tracing, enhancementsFrederic Weisbecker
Impact: new feature This adds the generic support for syscalls tracing. This is currently exploited through a devoted tracer but other tracing engines can use it. (They just have to play with {start,stop}_ftrace_syscalls() and use the display callbacks unless they want to override them.) The syscalls prototypes definitions are abused here to steal some metadata informations: - syscall name, param types, param names, number of params The syscall addr is not directly saved during this definition because we don't know if its prototype is available in the namespace. But we don't really need it. The arch has just to build a function able to resolve the syscall number to its metadata struct. The current tracer prints the syscall names, parameters names and values (and their types optionally). Currently the value is a raw hex but higher level values diplaying is on my TODO list. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1236955332-10133-2-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-10Merge branches 'tracing/doc', 'tracing/ftrace', 'tracing/printk' and 'linus' ↵Ingo Molnar
into tracing/core
2009-03-09tracing: trace_printk() fix, move format array to data sectionIngo Molnar
Impact: fix kernel crash when using trace_printk() trace_printk_fmt section is defined into the readonly section. But we do: trace_printk_fmt = fmt; to fill in that table of format strings - which is not read-only. Under CONFIG_DEBUG_RODATA=y this crashes ... Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1236356510-8381-5-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-08Merge branches 'tracing/doc', 'tracing/ftrace', 'tracing/printk' and ↵Ingo Molnar
'tracing/textedit' into tracing/core
2009-03-06tracing: add trace_bprintk()Lai Jiangshan
Impact: add a generic printk() for tracing, like trace_printk() trace_bprintk() uses the infrastructure to record events on ring_buffer. [ fweisbec@gmail.com: ported to latest -tip, made it work if !CONFIG_MODULES, never free the format strings from modules because we can't keep track of them and conditionnaly create the ftrace format strings section (reported by Steven Rostedt) ] Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1236356510-8381-4-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-06Merge branch 'x86/core' into tracing/texteditIngo Molnar
Conflicts: arch/x86/Kconfig block/blktrace.c kernel/irq/handle.c Semantic conflict: kernel/trace/blktrace.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-24tracing: add event trace infrastructureSteven Rostedt
This patch creates the event tracing infrastructure of ftrace. It will create the files: /debug/tracing/available_events /debug/tracing/set_event The available_events will list the trace points that have been registered with the event tracer. set_events will allow the user to enable or disable an event hook. example: # echo sched_wakeup > /debug/tracing/set_event Will enable the sched_wakeup event (if it is registered). # echo "!sched_wakeup" >> /debug/tracing/set_event Will disable the sched_wakeup event (and only that event). # echo > /debug/tracing/set_event Will disable all events (notice the '>') # cat /debug/tracing/available_events > /debug/tracing/set_event Will enable all registered event hooks. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-01-30linker script: use separate simpler definition for PERCPU()Tejun Heo
Impact: fix linker screwup on x86_32 Recent x86_64 zerobased patches introduced PERCPU_VADDR() to put .data.percpu to a predefined address and re-defined PERCPU() in terms of it. The new macro defined one extra symbol, __per_cpu_load, for LMA of the section so that the init data could be accessed. This new symbol introduced the following problems to x86_32. 1. If __per_cpu_load is defined outside of .data.percpu as an absolute symbol, relocation generation for relocatable kernel fails due to absolute relocation. 2. If __per_cpu_load is put inside .data.percpu with absolute address assignment to work around #1, linker gets confused and under certain configurations ends up relocating the symbol against .data.percpu such that the load address gets added on top of already set load address. As x86_32 doesn't use predefined address for .data.percpu, there's no need for it to care about the possibility of __per_cpu_load being different from __per_cpu_start. This patch defines PERCPU() separately so that __per_cpu_load is defined inside .data.percpu so that everything is ordinary linking-wise. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-29Revert "generic, x86: fix __per_cpu_load relocation"Ingo Molnar
This reverts commit 5a611268b69f05262936dd177205acbce4471358. It is causing occasional boot crashes, caused by certain linker versions (GNU ld version 2.18.50.0.6-2 20080403) messing up: 82dcc000 D __per_cpu_load c16e6000 A __per_cpu_load_abs The __per_cpu_load value is out of whack. Hpa noticed the following detail: * (gdb) p/x -(0xc16e6000-0x82dcc000) * $2 = 0xc16e6000 * I.e. one is the other << 1 The two symbols should be equal. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-26Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (29 commits) xen: unitialised return value in xenbus_write_transaction x86: fix section mismatch warning x86: unmask CPUID levels on Intel CPUs, fix x86: work around PAGE_KERNEL_WC not getting WC in iomap_atomic_prot_pfn. x86: use standard PIT frequency xen: handle highmem pages correctly when shrinking a domain x86, mm: fix pte_free() xen: actually release memory when shrinking domain x86: unmask CPUID levels on Intel CPUs x86: add MSR_IA32_MISC_ENABLE bits to <asm/msr-index.h> x86: fix PTE corruption issue while mapping RAM using /dev/mem x86: mtrr fix debug boot parameter x86: fix page attribute corruption with cpa() Revert "x86: signal: change type of paramter for sys_rt_sigreturn()" x86: use early clobbers in usercopy*.c x86: remove kernel_physical_mapping_init() from init section fix: crash: IP: __bitmap_intersects+0x48/0x73 cpufreq: use work_on_cpu in acpi-cpufreq.c for drv_read and drv_write work_on_cpu: Use our own workqueue. work_on_cpu: don't try to get_online_cpus() in work_on_cpu. ...
2009-01-26generic, x86: fix __per_cpu_load relocationBrian Gerst
This patch fixes this linker error: WARNING: Absolute relocations present Offset Info Type Sym.Value Sym.Name c0a4e07d 00e78001 R_386_32 c0ab0000 __per_cpu_load Now, __per_cpu_load is a section-relative symbol: c0aa4000 D __per_cpu_load c0aa4000 A __per_cpu_load_abs Signed-off-by: Brian Gerst <brgerst@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-21Merge branch 'x86/mm' into core/percpuIngo Molnar
Conflicts: arch/x86/mm/fault.c
2009-01-20linker script: kill PERCPU_VADDR_PREALLOC()Tejun Heo
Impact: cleanup With .data.percpu.first in place, PERCPU_VADDR_PREALLOC() is no longer necessary. Kill it. Signed-off-by: Tejun Heo <tj@kernel.org>
2009-01-20percpu: refactor percpu.hBrian Gerst
Impact: cleanup Refactor the DEFINE_PER_CPU_* macros and add .data.percpu.first section. Signed-off-by: Brian Gerst <brgerst@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2009-01-17linker script: add missing VMLINUX_SYMBOLTejun Heo
The newly added PERCPU_*() macros define and use __per_cpu_load but VMLINUX_SYMBOL() was missing from usages causing build failures on archs where linker visible symbol is different from C symbols (e.g. blackfin). Signed-off-by: Tejun Heo <tj@kernel.org>
2009-01-16percpu: add optimized generic percpu accessorsIngo Molnar
It is an optimization and a cleanup, and adds the following new generic percpu methods: percpu_read() percpu_write() percpu_add() percpu_sub() percpu_and() percpu_or() percpu_xor() and implements support for them on x86. (other architectures will fall back to a default implementation) The advantage is that for example to read a local percpu variable, instead of this sequence: return __get_cpu_var(var); ffffffff8102ca2b: 48 8b 14 fd 80 09 74 mov -0x7e8bf680(,%rdi,8),%rdx ffffffff8102ca32: 81 ffffffff8102ca33: 48 c7 c0 d8 59 00 00 mov $0x59d8,%rax ffffffff8102ca3a: 48 8b 04 10 mov (%rax,%rdx,1),%rax We can get a single instruction by using the optimized variants: return percpu_read(var); ffffffff8102ca3f: 65 48 8b 05 91 8f fd mov %gs:0x7efd8f91(%rip),%rax I also cleaned up the x86-specific APIs and made the x86 code use these new generic percpu primitives. tj: * fixed generic percpu_sub() definition as Roel Kluin pointed out * added percpu_and() for completeness's sake * made generic percpu ops atomic against preemption Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Tejun Heo <tj@kernel.org>
2009-01-16x86: fold pda into percpu area on SMPTejun Heo
[ Based on original patch from Christoph Lameter and Mike Travis. ] Currently pdas and percpu areas are allocated separately. %gs points to local pda and percpu area can be reached using pda->data_offset. This patch folds pda into percpu area. Due to strange gcc requirement, pda needs to be at the beginning of the percpu area so that pda->stack_canary is at %gs:40. To achieve this, a new percpu output section macro - PERCPU_VADDR_PREALLOC() - is added and used to reserve pda sized chunk at the start of the percpu area. After this change, for boot cpu, %gs first points to pda in the data.init area and later during setup_per_cpu_areas() gets updated to point to the actual pda. This means that setup_per_cpu_areas() need to reload %gs for CPU0 while clearing pda area for other cpus as cpu0 already has modified it when control reaches setup_per_cpu_areas(). This patch also removes now unnecessary get_local_pda() and its call sites. A lot of this patch is taken from Mike Travis' "x86_64: Fold pda into per cpu area" patch. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-16x86: make percpu symbols zerobased on SMPTejun Heo
[ Based on original patch from Christoph Lameter and Mike Travis. ] This patch makes percpu symbols zerobased on x86_64 SMP by adding PERCPU_VADDR() to vmlinux.lds.h which helps setting explicit vaddr on the percpu output section and using it in vmlinux_64.lds.S. A new PHDR is added as existing ones cannot contain sections near address zero. PERCPU_VADDR() also adds a new symbol __per_cpu_load which always points to the vaddr of the loaded percpu data.init region. The following adjustments have been made to accomodate the address change. * code to locate percpu gdt_page in head_64.S is updated to add the load address to the gdt_page offset. * __per_cpu_load is used in places where access to the init data area is necessary. * pda->data_offset is initialized soon after C code is entered as zero value doesn't work anymore. This patch is mostly taken from Mike Travis' "x86_64: Base percpu variables at zero" patch. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-15alpha: fix RTC on marvelIvan Kokshaysky
Unlike other alphas, marvel doesn't have real PC-style CMOS clock hardware - RTC accesses are emulated via PAL calls. Unfortunately, for unknown reason these calls work only on CPU #0. So current implementation for arbitrary CPU makes CMOS_READ/WRITE to be executed on CPU #0 via IPI. However, for obvious reason this doesn't work with standard get/set_rtc_time() functions, where a bunch of CMOS accesses is done with disabled interrupts. Solved by making the IPI calls for entire get/set_rtc_time() functions, not for individual CMOS accesses. Which is also a lot more effective performance-wise. The patch is largely based on the code from Jay Estabrook. My changes: - tweak asm-generic/rtc.h by adding a couple of #defines to avoid a massive code duplication in arch/alpha/include/asm/rtc.h; - sys_marvel.c: fix get/set_rtc_time() return values (Jay's FIXMEs). NOTE: this fixes *only* LIB_RTC drivers. Legacy (CONFIG_RTC) driver wont't work on marvel. Actually I think that we should just disable CONFIG_RTC on alpha (maybe in 2.6.30?), like most other arches - AFAIK, all modern distributions use LIB_RTC anyway. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15Merge branches 'cpus4096', 'x86/cleanups' and 'x86/urgent' into x86/percpuIngo Molnar
2009-01-14byteorder: make swab.h include asm/swab.h like a regular headerHarvey Harrison
Add swab.h to kbuild.asm and remove the individual entries from each arch, mark as unifdef as some arches have some kernel-only bits inside. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-13x86 PAT: change track_pfn_vma_new to take pgprot_t pointer paramvenkatesh.pallipadi@intel.com
Impact: cleanup Change the protection parameter for track_pfn_vma_new() into a pgprot_t pointer. Subsequent patch changes the x86 PAT handling to return a compatible memtype in pgprot_t, if what was requested cannot be allowed due to conflicts. No fuctionality change in this patch. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-13x86, generic: mark complex bitops.h inlines as __always_inlineAndi Kleen
Impact: reduce kernel image size Hugh Dickins noticed that older gcc versions when the kernel is built for code size didn't inline some of the bitops. Mark all complex x86 bitops that have more than a single asm statement or two as always inline to avoid this problem. Probably should be done for other architectures too. Ingo then found a better fix that only requires a single line change, but it unfortunately only works on gcc 4.3. On older gccs the original patch still makes a ~0.3% defconfig difference with CONFIG_OPTIMIZE_INLINING=y. With gcc 4.1 and a defconfig like build: 6116998 1138540 883788 8139326 7c323e vmlinux-oi-with-patch 6137043 1138540 883788 8159371 7c808b vmlinux-optimize-inlining ~20k / 0.3% difference. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-06remove linux/hardirq.h from asm-generic/local.hRussell King
While looking at reducing the amount of architecture namespace pollution in the generic kernel, I found that asm/irq.h is included in the vast majority of compilations on ARM (around 650 files.) Since asm/irq.h includes a sub-architecture include file on ARM, this causes a negative impact on the ccache's ability to re-use the build results from other sub-architectures, so we have a desire to reduce the dependencies on asm/irq.h. It turns out that a major cause of this is the needless include of linux/hardirq.h into asm-generic/local.h. The patch below removes this include, resulting in some 250 to 300 files (around half) of the kernel then omitting asm/irq.h. My test builds still succeed, provided two ARM files are fixed (arch/arm/kernel/traps.c and arch/arm/mm/fault.c) - so there may be negative impacts for this on other architectures. Note that x86 does not include asm/irq.h nor linux/hardirq.h in its asm/local.h, so this patch can be viewed as bringing the generic version into line with the x86 version. [kosaki.motohiro@jp.fujitsu.com: add #include <linux/irqflags.h> to acpi/processor_idle.c] [adobriyan@gmail.com: fix sparc64] Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06documentation: when to BUG(), and when to not BUG()David Brownell
Provide some basic advice about when to use BUG()/BUG_ON(): never, unless there's really no better option. This matches my understanding of the standard policy ... which seems not to be written down so far, outside of LKML messages that I haven't bookmarked. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Hans Verkuil <hverkuil@xs4all.nl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: remove CONFIG_OUT_OF_LINE_PFN_TO_PAGEKOSAKI Motohiro
No architectures use CONFIG_OUT_OF_LINE_PFN_TO_PAGE - it can be removed. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02Merge branch 'cpus4096-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (66 commits) x86: export vector_used_by_percpu_irq x86: use logical apicid in x2apic_cluster's x2apic_cpu_mask_to_apicid_and() sched: nominate preferred wakeup cpu, fix x86: fix lguest used_vectors breakage, -v2 x86: fix warning in arch/x86/kernel/io_apic.c sched: fix warning in kernel/sched.c sched: move test_sd_parent() to an SMP section of sched.h sched: add SD_BALANCE_NEWIDLE at MC and CPU level for sched_mc>0 sched: activate active load balancing in new idle cpus sched: bias task wakeups to preferred semi-idle packages sched: nominate preferred wakeup cpu sched: favour lower logical cpu number for sched_mc balance sched: framework for sched_mc/smt_power_savings=N sched: convert BALANCE_FOR_xx_POWER to inline functions x86: use possible_cpus=NUM to extend the possible cpus allowed x86: fix cpu_mask_to_apicid_and to include cpu_online_mask x86: update io_apic.c to the new cpumask code x86: Introduce topology_core_cpumask()/topology_thread_cpumask() x86: xen: use smp_call_function_many() x86: use work_on_cpu in x86/kernel/cpu/mcheck/mce_amd_64.c ... Fixed up trivial conflict in kernel/time/tick-sched.c manually
2008-12-30Merge branch 'core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (63 commits) stacktrace: provide save_stack_trace_tsk() weak alias rcu: provide RCU options on non-preempt architectures too printk: fix discarding message when recursion_bug futex: clean up futex_(un)lock_pi fault handling "Tree RCU": scalable classic RCU implementation futex: rename field in futex_q to clarify single waiter semantics x86/swiotlb: add default swiotlb_arch_range_needs_mapping x86/swiotlb: add default phys<->bus conversion x86: unify pci iommu setup and allow swiotlb to compile for 32 bit x86: add swiotlb allocation functions swiotlb: consolidate swiotlb info message printing swiotlb: support bouncing of HighMem pages swiotlb: factor out copy to/from device swiotlb: add arch hook to force mapping swiotlb: allow architectures to override phys<->bus<->phys conversions swiotlb: add comment where we handle the overflow of a dma mask on 32 bit rcu: fix rcutorture behavior during reboot resources: skip sanity check of busy resources swiotlb: move some definitions to header swiotlb: allow architectures to override swiotlb pool allocation ... Fix up trivial conflicts in arch/x86/kernel/Makefile arch/x86/mm/init_32.c include/linux/hardirq.h as per Ingo's suggestions.
2008-12-28Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: (85 commits) [S390] provide documentation for hvc_iucv kernel parameter. [S390] convert ctcm printks to dev_xxx and pr_xxx macros. [S390] convert zfcp printks to pr_xxx macros. [S390] convert vmlogrdr printks to pr_xxx macros. [S390] convert zfcp dumper printks to pr_xxx macros. [S390] convert cpu related printks to pr_xxx macros. [S390] convert qeth printks to dev_xxx and pr_xxx macros. [S390] convert sclp printks to pr_xxx macros. [S390] convert iucv printks to dev_xxx and pr_xxx macros. [S390] convert ap_bus printks to pr_xxx macros. [S390] convert dcssblk and extmem printks messages to pr_xxx macros. [S390] convert monwriter printks to pr_xxx macros. [S390] convert s390 debug feature printks to pr_xxx macros. [S390] convert monreader printks to pr_xxx macros. [S390] convert appldata printks to pr_xxx macros. [S390] convert setup printks to pr_xxx macros. [S390] convert hypfs printks to pr_xxx macros. [S390] convert time printks to pr_xxx macros. [S390] convert cpacf printks to pr_xxx macros. [S390] convert cio printks to pr_xxx macros. ...
2008-12-28Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (241 commits) sched, trace: update trace_sched_wakeup() tracing/ftrace: don't trace on early stage of a secondary cpu boot, v3 Revert "x86: disable X86_PTRACE_BTS" ring-buffer: prevent false positive warning ring-buffer: fix dangling commit race ftrace: enable format arguments checking x86, bts: memory accounting x86, bts: add fork and exit handling ftrace: introduce tracing_reset_online_cpus() helper tracing: fix warnings in kernel/trace/trace_sched_switch.c tracing: fix warning in kernel/trace/trace.c tracing/ring-buffer: remove unused ring_buffer size trace: fix task state printout ftrace: add not to regex on filtering functions trace: better use of stack_trace_enabled for boot up code trace: add a way to enable or disable the stack tracer x86: entry_64 - introduce FTRACE_ frame macro v2 tracing/ftrace: add the printk-msg-only option tracing/ftrace: use preempt_enable_no_resched_notrace in ring_buffer_time_stamp() x86, bts: correctly report invalid bts records ... Fixed up trivial conflict in scripts/recordmcount.pl due to SH bits being already partly merged by the SH merge.
2008-12-25Merge branch 'core/debug' into core/coreIngo Molnar
2008-12-25[S390] __page_to_pfn warningsMartin Schwidefsky
For CONFIG_SPARSEMEM_VMEMMAP=y on s390 I get warnings like init/main.c: In function 'start_kernel': init/main.c:641: warning: format '%08lx' expects type 'long unsigned int', but argument 2 has type 'int' The warning can be suppressed with a cast to unsigned long in the CONFIG_SPARSEMEM_VMEMMAP=y version of __page_to_pfn. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
