path: root/include/asm-generic
2006-01-10[PATCH] Generic ioctl.hBrian Gerst
Most arches copied the i386 ioctl.h. Combine them into a generic header. Signed-off-by: Brian Gerst <bgerst@didntduck.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, add asm-generic/mutex-[dec|xchg|null].h implementationsIngo Molnar
Add three (generic) mutex fastpath implementations. The mutex-xchg.h implementation is atomic_xchg() based, and should work fine on every architecture. The mutex-dec.h implementation is atomic_dec_return() based - this one too should work on every architecture, but might not perform the most optimally on architectures that have no atomic-dec/inc instructions. The mutex-null.h implementation forces all calls into the slowpath. This is used for mutex debugging, but it can also be used on platforms that do not want (or need) a fastpath at all. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org>
2006-01-08[PATCH] consolidate asm/futex.hJeff Dike
Most of the architectures have the same asm/futex.h. This consolidates them into asm-generic, with the arches including it from their own asm/futex.h. In the case of UML, this reverts the old broken futex.h and goes back to using the same one as almost everyone else. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Kill L1_CACHE_SHIFT_MAXRavikiran G Thirumalai
Kill L1_CACHE_SHIFT from all arches. Since L1_CACHE_SHIFT_MAX is not used anymore with the introduction of INTERNODE_CACHE, kill L1_CACHE_SHIFT_MAX. Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Shai Fultheim <shai@scalex86.org> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] asm-generic/atomic.h needs types.hAndrew Morton
For BITS_PER_LONG Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] x86/x86_64: mark rodata section read only: generic infrastructureArjan van de Ven
Generic prep-work for marking the .rodata section readonly: * Align the rodata section at 4Kb boundary * call the mark_rodata_ro() function when available Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] atomic_long_t & include/asm-generic/atomic.h V2Christoph Lameter
Several counters already have the need to use 64 atomic variables on 64 bit platforms (see mm_counter_t in sched.h). We have to do ugly ifdefs to fall back to 32 bit atomic on 32 bit platforms. The VM statistics patch that I am working on will also make more extensive use of atomic64. This patch introduces a new type atomic_long_t by providing definitions in asm-generic/atomic.h that works similar to the c "long" type. Its 32 bits on 32 bit platforms and 64 bits on 64 bit platforms. Also cleans up the determination of the mm_counter_t in sched.h. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[FLS64]: generic versionStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-14Merge x86-64 update from AndiLinus Torvalds
2005-11-14[PATCH] x86_64: Only use asm/sections.h to declare section symbolsAndi Kleen
Adding __initdata_* to asm-generic/sections.h Replaces a lot of open coded externs in arch/x86_64/* I had to change __bss_end to __bss_stop to match the other architectures. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] RapidIO support: core baseMatt Porter
Adds a RapidIO subsystem to the kernel. RIO is a switched fabric interconnect used in higher-end embedded applications. The curious can look at the specs over at http://www.rapidio.org The core code implements enumeration/discovery, management of devices/resources, and interfaces for RIO drivers. There's a lot more to do to take advantages of all the hardware features. However, this should provide a good base for folks with RIO hardware to start contributing. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fix remaining missing includesTim Schmielau
Fix more include file problems that surfaced since I submitted the previous fix-missing-includes.patch. This should now allow not to include sched.h from module.h, which is done by a followup patch. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: update comments to pte lockHugh Dickins
Updated several references to page_table_lock in common code comments. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: ptd_alloc inline and outHugh Dickins
It seems odd to me that, whereas pud_alloc and pmd_alloc test inline, only calling out-of-line __pud_alloc __pmd_alloc if allocation needed, pte_alloc_map and pte_alloc_kernel are entirely out-of-line. Though it does add a little to kernel size, change them to macros testing inline, calling __pte_alloc or __pte_alloc_kernel to allocate out-of-line. Mark none of them as fastcalls, leave that to CONFIG_REGPARM or not. It also seems more natural for the out-of-line functions to leave the offset calculation and map to the inline, which has to do it anyway for the common case. At least mremap move wants __pte_alloc without _map. Macros rather than inline functions, certainly to avoid the header file issues which arise from CONFIG_HIGHPTE needing kmap_types.h, but also in case any architectures I haven't built would have other such problems. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: tlb_finish_mmu forget rssHugh Dickins
zap_pte_range has been counting the pages it frees in tlb->freed, then tlb_finish_mmu has used that to update the mm's rss. That got stranger when I added anon_rss, yet updated it by a different route; and stranger when rss and anon_rss became mm_counters with special access macros. And it would no longer be viable if we're relying on page_table_lock to stabilize the mm_counter, but calling tlb_finish_mmu outside that lock. Remove the mmu_gather's freed field, let tlb_finish_mmu stick to its own business, just decrement the rss mm_counter in zap_pte_range (yes, there was some point to batching the update, and a subsequent patch restores that). And forget the anal paranoia of first reading the counter to avoid going negative - if rss does go negative, just fix that bug. Remove the mmu_gather's flushes and avoided_flushes from arm and arm26: no use was being made of them. But arm26 alone was actually using the freed, in the way some others use need_flush: give it a need_flush. arm26 seems to prefer spaces to tabs here: respect that. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: tlb_is_full_mm was obscureHugh Dickins
tlb_is_full_mm? What does that mean? The TLB is full? No, it means that the mm's last user has gone and the whole mm is being torn down. And it's an inline function because sparc64 uses a different (slightly better) "tlb_frozen" name for the flag others call "fullmm". And now the ptep_get_and_clear_full macro used in zap_pte_range refers directly to tlb->fullmm, which would be wrong for sparc64. Rather than correct that, I'd prefer to scrap tlb_is_full_mm altogether, and change sparc64 to just use the same poor name as everyone else - is that okay? Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: tlb_gather_mmu get_cpu_varHugh Dickins
tlb_gather_mmu dates from before kernel preemption was allowed, and uses smp_processor_id or __get_cpu_var to find its per-cpu mmu_gather. That works because it's currently only called after getting page_table_lock, which is not dropped until after the matching tlb_finish_mmu. But don't rely on that, it will soon change: now disable preemption internally by proper get_cpu_var in tlb_gather_mmu, put_cpu_var in tlb_finish_mmu. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: dma-mapping (simple cases)Al Viro
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-28[PATCH] mm: move_pte to remap ZERO_PAGENick Piggin
Move the ZERO_PAGE remapping complexity to the move_pte macro in asm-generic, have it conditionally depend on __HAVE_ARCH_MULTIPLE_ZERO_PAGE, which gets defined for MIPS. For architectures without __HAVE_ARCH_MULTIPLE_ZERO_PAGE, move_pte becomes a noop. From: Hugh Dickins <hugh@veritas.com> Fix nasty little bug we've missed in Nick's mremap move ZERO_PAGE patch. The "pte" at that point may be a swap entry or a pte_file entry: we must check pte_present before perhaps corrupting such an entry. Patch below against 2.6.14-rc2-mm1, but the same bug is in 2.6.14-rc2's mm/mremap.c, and more dangerous there since it's affecting all arches: I think the safest course is to send Nick's patch and Yoichi's build fix and this fix (build tested) on to Linus - so only MIPS can be affected. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12[PATCH] x86-64: Increase TLB flush array sizeAndi Kleen
The generic TLB flush functions kept upto 506 pages per CPU to avoid too frequent IPIs. This value was done for the L1 cache of older x86 CPUs, but with modern CPUs it does not make much sense anymore. TLB flushing is slow enough that using the L2 cache is fine. This patch increases the flush array on x86-64 to cache 5350 pages. That is roughly 20MB with 4K pages. It speeds up large munmaps in multithreaded processes on SMP considerably. The cost is roughly 42k of memory per CPU, which is reasonable. I only increased it on x86-64 for now, but it would probably make sense to increase it everywhere. Embedded architectures with SMP may keep it smaller to save some memory per CPU. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] i386 / uml: add dwarf sections to static link scriptPaolo 'Blaisorblade' Giarrusso
Inside the linker script, insert the code for DWARF debug info sections. This may help GDB'ing a Uml binary. Actually, it seems that ld is able to guess what I added correctly, but normal linker scripts include this section so it should be correct anyway adding it. On request by Sam Ravnborg <sam@ravnborg.org>, I've added it to asm-generic/vmlinux.lds.s. I've also moved there the stabs debug section, used the new macro in i386 linker script and added DWARF debug section to that. In the truth, I've not been able to verify the difference in GDB behaviour after this change (I've seen large improvements with another patch). This may depend on my binutils version, older one may have worse defaults. However, this section is present in normal linker script, so add it at least for the sake of cleanness. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-08[PATCH] Make sparc64 use setup-res.cDavid S. Miller
There were three changes necessary in order to allow sparc64 to use setup-res.c: 1) Sparc64 roots the PCI I/O and MEM address space using parent resources contained in the PCI controller structure. I'm actually surprised no other platforms do this, especially ones like Alpha and PPC{,64}. These resources get linked into the iomem/ioport tree when PCI controllers are probed. So the hierarchy looks like this: iomem --| PCI controller 1 MEM space --| device 1 device 2 etc. PCI controller 2 MEM space --| ... ioport --| PCI controller 1 IO space --| ... PCI controller 2 IO space --| ... You get the idea. The drivers/pci/setup-res.c code allocates using plain iomem_space and ioport_space as the root, so that wouldn't work with the above setup. So I added a pcibios_select_root() that is used to handle this. It uses the PCI controller struct's io_space and mem_space on sparc64, and io{port,mem}_resource on every other platform to keep current behavior. 2) quirk_io_region() is buggy. It takes in raw BUS view addresses and tries to use them as a PCI resource. pci_claim_resource() expects the resource to be fully formed when it gets called. The sparc64 implementation would do the translation but that's absolutely wrong, because if the same resource gets released then re-claimed we'll adjust things twice. So I fixed up quirk_io_region() to do the proper pcibios_bus_to_resource() conversion before passing it on to pci_claim_resource(). 3) I was mistakedly __init'ing the function methods the PCI controller drivers provide on sparc64 to implement some parts of these routines. This was, of course, easy to fix. So we end up with the following, and that nasty SPARC64 makefile ifdef in drivers/pci/Makefile is finally zapped. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-07[PATCH] Kprobes: prevent possible race conditions genericPrasanna S Panchamukhi
There are possible race conditions if probes are placed on routines within the kprobes files and routines used by the kprobes. For example if you put probe on get_kprobe() routines, the system can hang while inserting probes on any routine such as do_fork(). Because while inserting probes on do_fork(), register_kprobes() routine grabs the kprobes spin lock and executes get_kprobe() routine and to handle probe of get_kprobe(), kprobes_handler() gets executed and tries to grab kprobes spin lock, and spins forever. This patch avoids such possible race conditions by preventing probes on routines within the kprobes file and routines used by kprobes. I have modified the patches as per Andi Kleen's suggestion to move kprobes routines and other routines used by kprobes to a seperate section .kprobes.text. Also moved page fault and exception handlers, general protection fault to .kprobes.text section. These patches have been tested on i386, x86_64 and ppc64 architectures, also compiled on ia64 and sparc64 architectures. Signed-off-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Clean up struct flock64 definitionsStephen Rothwell
This patch gathers all the struct flock64 definitions (and the operations), puts them under !CONFIG_64BIT and cleans up the arch files. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Clean up struct flock definitionsStephen Rothwell
This patch just gathers together all the struct flock definitions except xtensa into asm-generic/fcntl.h. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Clean up the fcntl operationsStephen Rothwell
This patch puts the most popular of each fcntl operation/flag into asm-generic/fcntl.h and cleans up the arch files. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Clean up the open flagsStephen Rothwell
This patch puts the most popular of each open flag into asm-generic/fcntl.h and cleans up the arch files. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Create asm-generic/fcntl.hStephen Rothwell
This set of patches creates asm-generic/fcntl.h and consolidates as much as possible from the asm-*/fcntl.h files into it. This patch just gathers all the identical bits of the asm-*/fcntl.h files into asm-generic/fcntl.h. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] optimise 64bit unaligned access on 32bit kernelRalf Baechle
I've rewriten Atushi's fix for the 64-bit put_unaligned on 32-bit systems bug to generate more efficient code. This case has buzilla URL http://bugzilla.kernel.org/show_bug.cgi?id=5138. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] remove asm-*/hdreg.hChristoph Hellwig
unused and useless.. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-06Merge master.kernel.org:/pub/scm/linux/kernel/git/sam/kbuild Linus Torvalds
2005-09-05[PATCH] x86: ptep_clear optimizationZachary Amsden
Add a new accessor for PTEs, which passes the full hint from the mmu_gather struct; this allows architectures with hardware pagetables to optimize away atomic PTE operations when destroying an address space. Removing the locked operation should allow better pipelining of memory access in this loop. I measured an average savings of 30-35 cycles per zap_pte_range on the first 500 destructions on Pentium-M, but I believe the optimization would win more on older processors which still assert the bus lock on xchg for an exclusive cacheline. Update: I made some new measurements, and this saves exactly 26 cycles over ptep_get_and_clear on Pentium M. On P4, with a PAE kernel, this saves 180 cycles per ptep_get_and_clear, for a whopping 92160 cycles savings for a full address space destruction. pte_clear_full is not yet used, but is provided for future optimizations (in particular, when running inside of a hypervisor that queues page table updates, the full hint allows us to avoid queueing unnecessary page table update for an address space in the process of being destroyed. This is not a huge win, but it does help a bit, and sets the stage for further hypervisor optimization of the mm layer on all architectures. Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: Christoph Lameter <christoph@lameter.com> Cc: <linux-mm@kvack.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mm: consolidate get_orderStephen Rothwell
Someone mentioned that almost all the architectures used basically the same implementation of get_order. This patch consolidates them into asm-generic/page.h and includes that in the appropriate places. The exceptions are ia64 and ppc which have their own (presumably optimised) versions. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-04[PATCH] pci and yenta: pcibios_bus_to_resourceDominik Brodowski
In yenta_socket, we default to using the resource setting of the CardBus bridge. However, this is a PCI-bus-centric view of resources and thus needs to be converted to generic resources first. Therefore, add a call to pcibios_bus_to_resource() call in between. This function is a mere wrapper on x86 and friends, however on some others it already exists, is added in this patch (alpha, arm, ppc, ppc64) or still needs to be provided (parisc -- where is its pcibios_resource_to_bus() ?). Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] x86_64: Some cleanup in setup64.cAndi Kleen
Minor cleanup. Move things into their include files, remove obsolete includes, fix indentation, remove obsolete special cases etc. I also added the per cpu section to asm-generic/sections.h and fixed init/main.c to use it. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] Add emergency_restart()Eric W. Biederman
When the kernel is working well and we want to restart cleanly kernel_restart is the function to use. But in many instances the kernel wants to reboot when thing are expected to be working very badly such as from panic or a software watchdog handler. This patch adds the function emergency_restart() so that callers can be clear what semantics they expect when calling restart. emergency_restart() is expected to be callable from interrupt context and possibly reliable in even more trying circumstances. This is an initial generic implementation for all architectures. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-14kbuild: Avoid inconsistent kallsyms dataSam Ravnborg
Several reports on inconsistent kallsyms data has been caused by the aliased symbols __sched_text_start and __down to shift places in the output of nm. The root cause was that on second pass ld aligned __sched_text_start to a 4 byte boundary which is the function alignment on i386. sched.text and spinlock.text is now aligned to an 8 byte boundary to make sure they are aligned to a function alignemnt on most (all?) archs. Tested by: Paulo Marques <pmarques@grupopie.com> Tested by: Alexander Stohr <Alexander.Stohr@gmx.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-06-25[PATCH] kexec: vmlinux: fix physical addressesEric W. Biederman
In vmlinux.lds.h the code is carefull to define every section so vmlinux properly reports the correct physical load address of code, as well as it's virtual address. The new SECURITY_INIT definition fails to follow that convention and and causes incorrect physical address to appear in the vmlinux if there are any security initcalls. This patch updates the SECURITY_INIT to follow the convention in the rest of the file. Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] adjust per_cpu definition in non-SMP caseJan Beulich
Fix (in the architectures I'm actually building for) the UP definition of per_cpu so that the cpu specified may be any expression, not just an identifier or a suffix expression. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] x86/x86_64: pcibus_to_nodeChristoph Lameter
Define pcibus_to_node to be able to figure out which NUMA node contains a given PCI device. This defines pcibus_to_node(bus) in include/linux/topology.h and adjusts the macros for i386 and x86_64 that already provided a way to determine the cpumask of a pci device. x86_64 was changed to not build an array of cpumasks anymore. Instead an array of nodes is build which can be used to generate the cpumask via node_to_cpumask. Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] msync: check pte dirty earlierAbhijit Karmarkar
It's common practice to msync a large address range regularly, in which often only a few ptes have actually been dirtied since the previous pass. sync_pte_range then goes much faster if it tests whether pte is dirty before locating and accessing each struct page cacheline; and it is hardly slowed by ptep_clear_flush_dirty repeating that test in the opposite case, when every pte actually is dirty. But beware, s390's pte_dirty always says false, since its dirty bit is kept in the storage key, located via the struct page address. So skip this optimization in its case: use a pte_maybe_dirty macro which just says true if page_test_and_clear_dirty is implemented. Signed-off-by: Abhijit Karmarkar <abhijitk@veritas.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] ppc32: platform-specific functions missing from kallsyms.David Woodhouse
The PPC32 kernel puts platform-specific functions into separate sections so that unneeded parts of it can be freed when we've booted and actually worked out what we're running on today. This makes kallsyms ignore those functions, because they're not between _[se]text or _[se]inittext. Rather than teaching kallsyms about the various pmac/chrp/etc sections, this patch adds '_[se]extratext' markers for kallsyms. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-04[PATCH] asm/signal.h unificationAl Viro
New file - asm-generic/signal.h. Contains declarations of __sighandler_t, __sigrestore_t, SIG_DFL, SIG_IGN, SIG_ERR and default definitions of SIG_BLOCK, SIG_UNBLOCK and SIG_SETMASK. asm-*/signal.h switched to including it. The only exception is asm-parisc/signal.h that wants its own declaration of __sighandler_t; that one is left as-is. asm-ppc64/signal.h required one more thing - unlike everybody else it used __sigrestorer_t instead of usual __sigrestore_t. PPC64 switched to common spelling. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] consolidate SIGEV_PAD_SIZEStephen Rothwell
Discussing with Matthew Wilcox some of his outstanding patches lead me to this patch (among others). The preamble in struct sigevent can be expressed independently of the architecture. Also use __ARCH_SI_PREAMBLE_SIZE on ia64. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] add EOWNERDEAD and ENOTRECOVERABLE version 2Joe Korty
Add EOWNERDEAD and ENOTRECOVERABLE to all architectures. This is to support the upcoming patches for robust mutexes. We normally don't reserve parts of the name/number space for external patches, but robust mutexes are sufficiently popular and important to justify it in this case. Signed-off-by: Joe Korty <joe.korty@ccur.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Exterminate PAGE_BUGMatt Mackall
Remove PAGE_BUG - repalce it with BUG and BUG_ON. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] remove all kernel BUGsMatt Mackall
This patch eliminates all kernel BUGs, trims about 35k off the typical kernel, and makes the system slightly faster. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] nice and rt-prio rlimitsMatt Mackall
Add a pair of rlimits for allowing non-root tasks to raise nice and rt priorities. Defaults to traditional behavior. Originally written by Chris Wright. The patch implements a simple rlimit ceiling for the RT (and nice) priorities a task can set. The rlimit defaults to 0, meaning no change in behavior by default. A value of 50 means RT priority levels 1-50 are allowed. A value of 100 means all 99 privilege levels from 1 to 99 are allowed. CAP_SYS_NICE is blanket permission. (akpm: see http://www.uwsg.iu.edu/hypermail/linux/kernel/0503.1/1921.html for tips on integrating this with PAM). Signed-off-by: Matt Mackall <mpm@selenic.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-24[PATCH] __get_unaligned() turned into macroAl Viro
Turns __get_unaligned() and __put_unaligned into macros. That is definitely safe; leaving them as inlines breaks on e.g. alpha [try to build ncpfs there and you'll get unresolved symbols since we end up getting __get_unaligned() not inlined]. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
