path: root/include/asm-generic
2010-08-18Fix the declaration of sys_execve() in asm-generic/syscalls.hDavid Howells
Fix the declaration of sys_execve() in asm-generic/syscalls.h to have various consts applied to its pointers. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: arch/tile: don't validate CROSS_COMPILE needlessly arch/tile: export only COMMAND_LINE_SIZE to userspace. arch/tile: rename ARCH_KMALLOC_MINALIGN to ARCH_DMA_MINALIGN arch/tile: Rename the hweight() implementations to __arch_hweight() arch/tile: extend syscall ABI to set r1 on return as well. arch/tile: Various cleanups. arch/tile: support backtracing on TILE-Gx arch/tile: Fix a couple of issues with the COMPAT code for TILE-Gx. arch/tile: Use separate, better minsec values for clocksource and sched_clock. arch/tile: correct a bug in freeing bootmem by VA for the optional second initrd. arch: tile: mm: pgtable.c: Removed duplicated #include arch: tile: kernel/proc.c Removed duplicated #include Add fanotify syscalls to <asm-generic/unistd.h>. arch/tile: support new kunmap_atomic() naming convention. tile: remove unused ISA_DMA_THRESHOLD define Conflicts in arch/tile/configs/tile_defconfig (pick the mainline version with the reduced defconfig).
2010-08-14include: replace unifdef-y with header-ySam Ravnborg
unifdef-y and header-y has same semantic. So there is no need to have both. Drop the unifdef-y variant and sort all lines again Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-13Merge branch 'master' into for-linusChris Metcalf
2010-08-13Add fanotify syscalls to <asm-generic/unistd.h>.Chris Metcalf
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Eric Paris <eparis@redhat.com>
2010-08-11dma-mapping: remove dma_is_consistent APIFUJITA Tomonori
Architectures implement dma_is_consistent() in different ways (some misinterpret the definition of API in DMA-API.txt). So it hasn't been so useful for drivers. We have only one user of the API in tree. Unlikely out-of-tree drivers use the API. Even if we fix dma_is_consistent() in some architectures, it doesn't look useful at all. It was invented long ago for some old systems that can't allocate coherent memory at all. It's better to export only APIs that are definitely necessary for drivers. Let's remove this API. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11vfs: O_* bit numbers uniqueness checkWu Fengguang
The O_* bit numbers are defined in 20+ arch/*, and can silently overlap. Add a compile time check to ensure the uniqueness as suggested by David Miller. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: David Miller <davem@davemloft.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Eric Paris <eparis@redhat.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: Jamie Lokier <jamie@shareable.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10tty: Add EXTPROC support for LINEMODEhyc@symas.com
This patch is against the 2.6.34 source. Paraphrased from the 1989 BSD patch by David Borman @ cray.com: These are the changes needed for the kernel to support LINEMODE in the server. There is a new bit in the termios local flag word, EXTPROC. When this bit is set, several aspects of the terminal driver are disabled. Input line editing, character echo, and mapping of signals are all disabled. This allows the telnetd to turn off these functions when in linemode, but still keep track of what state the user wants the terminal to be in. New ioctl: TIOCSIG Generate a signal to processes in the current process group of the pty. There is a new mode for packet driver, the TIOCPKT_IOCTL bit. When packet mode is turned on in the pty, and the EXTPROC bit is set, then whenever the state of the pty is changed, the next read on the master side of the pty will have the TIOCPKT_IOCTL bit set. This allows the process on the server side of the pty to know when the state of the terminal has changed; it can then issue the appropriate ioctl to retrieve the new state. Since the original BSD patches accompanied the source code for telnet I've left that reference here, but obviously the feature is useful for any remote terminal protocol, including ssh. The corresponding feature has existed in the BSD tty driver since 1989. For historical reference, a good copy of the relevant files can be found here: http://anonsvn.mit.edu/viewvc/krb5/trunk/src/appl/telnet/?pathrev=17741 Signed-off-by: Howard Chu <hyc@symas.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10tty: Remove Hayes ESP ioctlsJeff Dike
Remove Hayes ESP ioctls The Hayes ESP driver has been removed from the tree: commit f53a2ade0bb9f2a81f473e6469155172a96b7c38 ("tty: esp: remove broken driver") so its ioctls aren't needed any more. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10Merge branch 'writable_limits' of git://decibel.fi.muni.cz/~xslaby/linuxLinus Torvalds
* 'writable_limits' of git://decibel.fi.muni.cz/~xslaby/linux: unistd: add __NR_prlimit64 syscall numbers rlimits: implement prlimit64 syscall rlimits: switch more rlimit syscalls to do_prlimit rlimits: redo do_setrlimit to more generic do_prlimit rlimits: add rlimit64 structure rlimits: do security check under task_lock rlimits: allow setrlimit to non-current tasks rlimits: split sys_setrlimit rlimits: selinux, do rlimits changes under task_lock rlimits: make sure ->rlim_max never grows in sys_setrlimit rlimits: add task_struct to update_rlimit_cpu rlimits: security, add task_struct to setrlimit Fix up various system call number conflicts. We not only added fanotify system calls in the meantime, but asm-generic/unistd.h added a wait4 along with a range of reserved per-architecture system calls.
2010-08-10Merge branch 'for-linus' of git://git.infradead.org/users/eparis/notifyLinus Torvalds
* 'for-linus' of git://git.infradead.org/users/eparis/notify: (132 commits) fanotify: use both marks when possible fsnotify: pass both the vfsmount mark and inode mark fsnotify: walk the inode and vfsmount lists simultaneously fsnotify: rework ignored mark flushing fsnotify: remove global fsnotify groups lists fsnotify: remove group->mask fsnotify: remove the global masks fsnotify: cleanup should_send_event fanotify: use the mark in handler functions audit: use the mark in handler functions dnotify: use the mark in handler functions inotify: use the mark in handler functions fsnotify: send fsnotify_mark to groups in event handling functions fsnotify: Exchange list heads instead of moving elements fsnotify: srcu to protect read side of inode and vfsmount locks fsnotify: use an explicit flag to indicate fsnotify_destroy_mark has been called fsnotify: use _rcu functions for mark list traversal fsnotify: place marks on object in order of group memory address vfs/fsnotify: fsnotify_close can delay the final work in fput fsnotify: store struct file not struct path ... Fix up trivial delete/modify conflict in fs/notify/inotify/inotify.c.
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09asm-generic/io.h: add big endian versions of io{read,write}{16,32}Mike Frysinger
The asm-generic/iomap.h provides these functions already, but the non-generic fallback defines do not. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09topology: alternate fix for ia64 tiger_defconfig build breakageLee Schermerhorn
Define stubs for the numa_*_id() generic percpu related functions for non-NUMA configurations in <asm-generic/topology.h> where the other non-numa stubs live. Fixes ia64 !NUMA build breakage -- e.g., tiger_defconfig Back out now unneeded '#ifndef CONFIG_NUMA' guards from ia64 smpboot.c Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Tested-by: Tony Luck <tony.luck@intel.com> Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09asm-generic: use raw_local_irq_save/restore instead local_irq_save/restoreMichal Simek
The start/stop_critical_timing functions for preemptirqsoff, preemptoff and irqsoff tracers contain atomic_inc() and atomic_dec() operations. Atomic operations use local_irq_save/restore macros to ensure atomic access but they are traced by the same function which is causing recursion problem. The reason is when these tracers are turn ON then the local_irq_save/restore macros are changed in include/linux/irqflags.h to call trace_hardirqs_on/off which call start/stop_critical_timing. Microblaze was affected because it uses generic atomic implementation. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09add f_flags to struct statfs(64)Christoph Hellwig
Add a flags field to help glibc implementing statvfs(3) efficiently. We copy the flag values from glibc, and add a new ST_VALID flag to denote that f_flags is implemented. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: arch/tile: check kmalloc() result arch/tile: catch up on various minor cleanups. arch/tile: avoid erroneous error return for PTRACE_POKEUSR. tile: set ARCH_KMALLOC_MINALIGN tile: remove homegrown L1_CACHE_ALIGN macro arch/tile: Miscellaneous cleanup changes. arch/tile: Split the icache flush code off to a generic <arch> header. arch/tile: Fix bug in support for atomic64_xx() ops. arch/tile: Shrink the tile-opcode files considerably. arch/tile: Add driver to enable access to the user dynamic network. arch/tile: Enable more sophisticated IRQ model for 32-bit chips. Move list types from <linux/list.h> to <linux/types.h>. Add wait4() back to the set of <asm-generic/unistd.h> syscalls. Revert adding some arch-specific signal syscalls to <linux/syscalls.h>. arch/tile: Do not use GFP_KERNEL for dma_alloc_coherent(). Feedback from fujita.tomonori@lab.ntt.co.jp. arch/tile: core support for Tilera 32-bit chips. Fix up the "generic" unistd.h ABI to be more useful.
2010-08-06Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits) tracing/kprobes: unregister_trace_probe needs to be called under mutex perf: expose event__process function perf events: Fix mmap offset determination perf, powerpc: fsl_emb: Restore setting perf_sample_data.period perf, powerpc: Convert the FSL driver to use local64_t perf tools: Don't keep unreferenced maps when unmaps are detected perf session: Invalidate last_match when removing threads from rb_tree perf session: Free the ref_reloc_sym memory at the right place x86,mmiotrace: Add support for tracing STOS instruction perf, sched migration: Librarize task states and event headers helpers perf, sched migration: Librarize the GUI class perf, sched migration: Make the GUI class client agnostic perf, sched migration: Make it vertically scrollable perf, sched migration: Parameterize cpu height and spacing perf, sched migration: Fix key bindings perf, sched migration: Ignore unhandled task states perf, sched migration: Handle ignored migrate out events perf: New migration tool overview tracing: Drop cpparg() macro perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call ... Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
2010-08-06Merge branch 'master' into for-linusChris Metcalf
2010-08-05Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: (63 commits) of/platform: Register of_platform_drivers with an "of:" prefix of/address: Clean up function declarations of/spi: call of_register_spi_devices() from spi core code of: Provide default of_node_to_nid() implementation. of/device: Make of_device_make_bus_id() usable by other code. of/irq: Fix endian issues in parsing interrupt specifiers of: Fix phandle endian issues of/flattree: fix of_flat_dt_is_compatible() to match the full compatible string of: remove of_default_bus_ids of: make of_find_device_by_node generic microblaze: remove references to of_device and to_of_device sparc: remove references to of_device and to_of_device powerpc: remove references to of_device and to_of_device of/device: Replace of_device with platform_device in includes and core code of/device: Protect against binding of_platform_drivers to non-OF devices of: remove asm/of_device.h of: remove asm/of_platform.h of/platform: remove all of_bus_type and of_platform_bus_type references of: Merge of_platform_bus_type with platform_bus_type drivercore/of: Add OF style matching to platform bus ... Fix up trivial conflicts in arch/microblaze/kernel/Makefile due to just some obj-y removals by the devicetree branch, while the microblaze updates added a new file.
2010-08-04Merge branch 'upstream/pvhvm' into upstream/xenJeremy Fitzhardinge
* upstream/pvhvm: Introduce CONFIG_XEN_PVHVM compile option blkfront: do not create a PV cdrom device if xen_hvm_guest support multiple .discard.* sections to avoid section type conflicts xen/pvhvm: fix build problem when !CONFIG_XEN xenfs: enable for HVM domains too x86: Call HVMOP_pagetable_dying on exit_mmap. x86: Unplug emulated disks and nics. x86: Use xen_vcpuop_clockevent, xen_clocksource and xen wallclock. xen: Fix find_unbound_irq in presence of ioapic irqs. xen: Add suspend/resume support for PV on HVM guests. xen: Xen PCI platform device driver. x86/xen: event channels delivery on HVM. x86: early PV on HVM features initialization. xen: Add support for HVM hypercalls. Conflicts: arch/x86/xen/enlighten.c arch/x86/xen/time.c
2010-08-02Merge commit 'v2.6.35' into perf/coreIngo Molnar
Conflicts: tools/perf/Makefile tools/perf/util/hist.c Merge reason: Resolve the conflicts and update to latest upstream. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-07-28fanotify: FMODE_NONOTIFY and __O_SYNC in sparc conflictSigned-off-by: Wu Fengguang
sparc used the same value as FMODE_NONOTIFY so change FMODE_NONOTIFY to be something unique. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28vfs: introduce FMODE_NONOTIFYEric Paris
This is a new f_mode which can only be set by the kernel. It indicates that the fd was opened by fanotify and should not cause future fanotify events. This is needed to prevent fanotify livelock. An example of obvious livelock is from fanotify close events. Process A closes file1 This creates a close event for file1. fanotify opens file1 for Listener X Listener X deals with the event and closes its fd for file1. This creates a close event for file1. fanotify opens file1 for Listener X Listener X deals with the event and closes its fd for file1. This creates a close event for file1. fanotify opens file1 for Listener X Listener X deals with the event and closes its fd for file1. notice a pattern? The fix is to add the FMODE_NONOTIFY bit to the open filp done by the kernel for fanotify. Thus when that file is used it will not generate future events. This patch simply defines the bit. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-27support multiple .discard.* sections to avoid section type conflictsJeremy Fitzhardinge
gcc 4.4.4 will complain if you use a .discard section for both text and data ("causes a section type conflict"). Add support for ".discard.*" sections, and use .discard.text for a dummy function in the x86 RESERVE_BRK() macro. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2010-07-23Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: vmlinux.lds: fix .data..init_task output section (fix popwerpc boot) powerpc: Fix erroneous lmb->memblock conversions powerpc/mm: Add some debug output when hash insertion fails powerpc/mm: Fix bugs in huge page hashing powerpc/mm: Move around testing of _PAGE_PRESENT in hash code powerpc/mm: Handle hypervisor pte insert failure in __hash_page_huge powerpc/kexec: Fix boundary case for book-e kexec memory limits
2010-07-23vmlinux.lds: fix .data..init_task output section (fix popwerpc boot)Sam Ravnborg
The .data..init_task output section was missing a load offset causing a popwerpc target to fail to boot. Sean MacLennan tracked it down to the definition of INIT_TASK_DATA_SECTION(). There are only two users of INIT_TASK_DATA_SECTION() in the kernel today: cris and popwerpc. cris do not support relocatable kernels and is thus not impacted by this change. Fix INIT_TASK_DATA_SECTION() to specify load offset like all other output sections. Reported-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-07-20tracing: Properly align linker defined symbolsSam Ravnborg
We define a number of symbols in the linker scipt like this: __start_syscalls_metadata = .; *(__syscalls_metadata) But we do not know the alignment of "." when we assign the __start_syscalls_metadata symbol. gcc started to uses bigger alignment for structs (32 bytes), so we saw situations where the linker due to alignment constraints increased the value of "." after the symbol assignment. This resulted in boot fails. Fix this by forcing a 32 byte alignment of "." before the assignment. This patch introduces the forced alignment for ftrace_events and syscalls_metadata. It may be required in more places. Reported-by: Zeev Tarantov <zeev.tarantov@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> LKML-Reference: <20100710063459.GA14596@merkur.ravnborg.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-07-16unistd: add __NR_prlimit64 syscall numbersJiri Slaby
Add __NR_prlimit64 syscall numbers to asm-generic. Add them also to asm-x86, both 32 and 64-bit. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com>
2010-07-15tracing: Remove letfover markers sectionFrederic Weisbecker
Markers have been removed, but we forgot to remove their section. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
2010-07-05of/gpio: stop using device_node data pointer to find gpio_chipGrant Likely
Currently the kernel uses the struct device_node.data pointer to resolve a struct gpio_chip pointer from a device tree node. However, the .data member doesn't provide any type checking and there aren't any rules enforced on what it should be used for. There's no guarantee that the data stored in it actually points to an gpio_chip pointer. Instead of relying on the .data pointer, this patch modifies the code to add a lookup function which scans through the registered gpio_chips and returns the gpio_chip that has a pointer to the specified device_node. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> CC: Andrew Morton <akpm@linux-foundation.org> CC: Anton Vorontsov <avorontsov@ru.mvista.com> CC: Grant Likely <grant.likely@secretlab.ca> CC: David Brownell <dbrownell@users.sourceforge.net> CC: Bill Gatliff <bgat@billgatliff.com> CC: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: Jean Delvare <khali@linux-fr.org> CC: linux-kernel@vger.kernel.org CC: devicetree-discuss@lists.ozlabs.org
2010-07-05of/gpio: Kill of_gpio_chip and add members directly to gpio_chipAnton Vorontsov
The OF gpio infrastructure is great for describing GPIO connections within the device tree. However, using a GPIO binding still requires changes to the gpio controller just to add an of_gpio structure. In most cases, the gpio controller doesn't actually need any special support and the simple OF gpio mapping function is more than sufficient. Additional, the current scheme of using of_gpio_chip requires a convoluted scheme to maintain 1:1 mappings between of_gpio_chip and gpio_chip instances. If the struct of_gpio_chip data members were moved into struct gpio_chip, then it would simplify the processing of OF gpio bindings, and it would make it trivial to use device tree OF connections on existing gpiolib controller drivers. This patch eliminates the of_gpio_chip structure and moves the relevant fields into struct gpio_chip (conditional on CONFIG_OF_GPIO). This move simplifies the existing code and prepares for adding automatic device tree support to existing drivers. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Bill Gatliff <bgat@billgatliff.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jean Delvare <khali@linux-fr.org>
2010-06-25Add wait4() back to the set of <asm-generic/unistd.h> syscalls.Chris Metcalf
The initial pass at the generic ABI assumed that wait4() could be easily expressed using waitid(). Although it's true that wait4() can be built on waitid(), it's awkward enough that it makes more sense to continue to include wait4 in the generic syscall ABI. Since there is already a deprecated wait4 in the ABI, this change converts that wait4 into old_wait, and puts wait4 in the next available slot for new supported syscalls, after the platform-specific syscalls at number 260. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2010-06-18Merge commit 'v2.6.35-rc3' into perf/coreIngo Molnar
Merge reason: Go from -rc1 base to -rc3 base, merge in fixes.
2010-06-09arch: Implement local64_tPeter Zijlstra
On 64bit, local_t is of size long, and thus we make local64_t an alias. On 32bit, we fall back to atomic64_t. (architecture can provide optimized 32-bit version) (This new facility is to be used by perf events optimizations.) Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: linux-arch@vger.kernel.org Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-04Fix up the "generic" unistd.h ABI to be more useful.Chris Metcalf
Reserve 16 "architecture-specific" syscall numbers starting at 244. Allow use of the sys_sync_file_range2() API with the generic unistd.h by specifying __ARCH_WANT_SYNC_FILE_RANGE2 before including it. Allow using the generic unistd.h to create the "compat" syscall table by specifying __SYSCALL_COMPAT before including it. Use sys_fadvise64_64 for __NR3264_fadvise64 in both 32- and 64-bit mode. Request the appropriate __ARCH_WANT_COMPAT_SYS_xxx values when some deprecated syscall modes are selected. As part of this change to fix up the syscalls, also provide a couple of missing signal-related syscall prototypes in <linux/syscalls.h>. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2010-06-01Merge branch 'for-35' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-35' of git://repo.or.cz/linux-kbuild: (81 commits) kbuild: Revert part of e8d400a to resolve a conflict kbuild: Fix checking of scm-identifier variable gconfig: add support to show hidden options that have prompts menuconfig: add support to show hidden options which have prompts gconfig: remove show_debug option gconfig: remove dbg_print_ptype() and dbg_print_stype() kconfig: fix zconfdump() kconfig: some small fixes add random binaries to .gitignore kbuild: Include gen_initramfs_list.sh and the file list in the .d file kconfig: recalc symbol value before showing search results .gitignore: ignore *.lzo files headerdep: perlcritic warning scripts/Makefile.lib: Align the output of LZO kbuild: Generate modules.builtin in make modules_install Revert "kbuild: specify absolute paths for cscope" kbuild: Do not unnecessarily regenerate modules.builtin headers_install: use local file handles headers_check: fix perl warnings export_report: fix perl warnings ...
2010-05-27numa: introduce numa_mem_id()- effective local memory node idLee Schermerhorn
Introduce numa_mem_id(), based on generic percpu variable infrastructure to track "nearest node with memory" for archs that support memoryless nodes. Define API in <linux/topology.h> when CONFIG_HAVE_MEMORYLESS_NODES defined, else stubs. Architectures will define HAVE_MEMORYLESS_NODES if/when they support them. Archs can override definitions of: numa_mem_id() - returns node number of "local memory" node set_numa_mem() - initialize [this cpus'] per cpu variable 'numa_mem' cpu_to_mem() - return numa_mem for specified cpu; may be used as lvalue Generic initialization of 'numa_mem' occurs in __build_all_zonelists(). This will initialize the boot cpu at boot time, and all cpus on change of numa_zonelist_order, or when node or memory hot-plug requires zonelist rebuild. Archs that support memoryless nodes will need to initialize 'numa_mem' for secondary cpus as they're brought on-line. [akpm@linux-foundation.org: fix build] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Cc: Tejun Heo <tj@kernel.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Nick Piggin <npiggin@suse.de> Cc: David Rientjes <rientjes@google.com> Cc: Eric Whitney <eric.whitney@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27asm-generic: remove ARCH_HAS_SG_CHAIN in scatterlist.hFUJITA Tomonori
There are more architectures that don't support ARCH_HAS_SG_CHAIN than those that support it. This removes removes ARCH_HAS_SG_CHAIN in asm-generic/scatterlist.h and lets arhictectures to define it. It's clearer than defining ARCH_HAS_SG_CHAIN asm-generic/scatterlist.h and undefing it in arhictectures that don't support it. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27asm-generic: add NEED_SG_DMA_LENGTH to define sg_dma_len()FUJITA Tomonori
There are only two ways to define sg_dma_len(); use sg->dma_length or sg->length. This patch introduces NEED_SG_DMA_LENGTH that enables architectures to choose sg->dma_length or sg->length. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27asm-generic: remove ISA_DMA_THRESHOLD in scatterlist.hFUJITA Tomonori
This is the first half of the attempt to use asm-generic/scatterlist.h on every architecture. There are only two ways to define scatterlist structure. So it's easy to convert every architecture to use asm-generic/scatterlist.h. This patch: The trick for ISA_DMA_THRESHOLD in asm-generic/scatterlist.h doesn't work for powerpc. This lets architectures defin ISA_DMA_THRESHOLD. Hopefully, we can remove ISA_DMA_THRESHOLD in the future; we can do better to decide if the bouncing is necessary or not. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27dma-mapping: remove unnecessary sync_single_range_* in dma_map_opsFUJITA Tomonori
sync_single_range_for_cpu and sync_single_range_for_device hooks are unnecessary because sync_single_for_cpu and sync_single_for_device can be used instead. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: modify initialization of switch operationsAlexandre Bounine
Modify the way how RapidIO switch operations are declared. Multiple assignments through the linker script replaced by single initialization call. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Thomas Moll <thomas.moll@sysgo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: add Port-Write handling for EMAlexandre Bounine
Add RapidIO Port-Write message handling in the context of Error Management Extensions Specification Rev.1.3. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27gpiolib: introduce set_debounce methodFelipe Balbi
A few architectures, like OMAP, allow you to set a debouncing time for the gpio before generating the IRQ. Teach gpiolib about that. Mark said: : This would be generally useful for embedded systems, especially where : the interrupt concerned is a wake source. It allows drivers to avoid : spurious interrupts from noisy sources so if the hardware supports it : the driver can avoid having to explicitly wait for the signal to become : stable and software has to cope with fewer events. We've lived without : it for quite some time, though. David said: : I looked at adding debounce support to the generic GPIO calls (and thus : gpiolib) some time back, but decided against it. I forget why at this : time (check list archives) but it wasn't because of lack of utility in : certain contexts. : : One thing to watch out for is just how variable the hardware capabilities : are. Atmel GPIOs have something like a fixed number of 32K clock cycles : for debounce, twl4030 had something odd, OMAPs were more like the Atmel : chips but with a different clock. In some cases debouncing had to be : ganged, not per-GPIO. And so forth. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Cc: Tony Lindgren <tony@atomide.com> Cc: David Brownell <david-b@pacbell.net> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27gpiolib: document that names can contain printk format specifiersUwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27gpiolib: make names array and its values constUwe Kleine-König
gpiolib doesn't need to modify the names and I assume most initializers use string constants that shouldn't be modified anyhow. [akpm@linux-foundation.org: fix drivers/gpio/cs5535-gpio.c] Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Kevin Wells <kevin.wells@nxp.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25include/asm-generic/kmap_types.h: add helpful reminderAndrew Morton
2010-05-25asm-generic: don't warn that atomic_t is only 24 bitPeter Fritzsche
32-bit Sparc used to only allow usage of 24-bit of it's atomic_t type. This was corrected with linux 2.6.3 when Keith M Wesolowski changed the implementation to use the parisc approach of having an array of spinlocks to protect the atomic_t. These warnings were also removed from the sparc implementation when the new implementation was merged in BKrev:402e4949VThdc6D3iaosSFUgabMfvw, but the warning still remained in some other places without any 24-bit-only atomic_t implementation inside the kernel. We should remove these warnings to allow users to rely on the full 32-bit range of atomic_t. Signed-off-by: Peter Fritzsche <peter.fritzsche@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-21Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel-iommu: Set a more specific taint flag for invalid BIOS DMAR tables intel-iommu: Combine the BIOS DMAR table warning messages panic: Add taint flag TAINT_FIRMWARE_WORKAROUND ('I') panic: Allow warnings to set different taint flags intel-iommu: intel_iommu_map_range failed at very end of address space intel-iommu: errors with smaller iommu widths intel-iommu: Fix boot inside 64bit virtualbox with io-apic disabled intel-iommu: use physfn to search drhd for VF intel-iommu: Print out iommu seq_id intel-iommu: Don't complain that ACPI_DMAR_SCOPE_TYPE_IOAPIC is not supported intel-iommu: Avoid global flushes with caching mode. intel-iommu: Use correct domain ID when caching mode is enabled intel-iommu mistakenly uses offset_pfn when caching mode is enabled intel-iommu: use for_each_set_bit() intel-iommu: Fix section mismatch dmar_ir_support() uses dmar_tbl.
