path: root/include/asm-cris/ethernet.h
2007-11-14cris build fixes: update eth_v10.c ethernet driverJesper Nilsson
New (updated) version of ethernet driver for cris v10. - First steps to simplify and make the MII code more similar between the etrax100 and etraxfs ports. - Start the transmit queue before enabling tx interrupts to avoid race with the first frame. - Flip the comparition statement to stick to physical addresses to avoid phys_to_virt mapping a potential null pointer. This was not an error but the change simplifies debugging of address-space mappings. - Made myPrevRxDesc local to e100_rx since it was only used there. Fixed out of memory handling in e100_rx. If dev_alloc_skb() fails persistently the system is hosed anyway but at least it won't loop in an interrupt handler. - Correct some code formatting issues. - Add defines SET_ETH_ENABLE_LEDS, SET_ETH_DISABLE_LEDS and SET_ETH_AUTONEG used in new cris v10 ethernet driver. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Mikael Starvik <starvik@axis.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
