path: root/include/asm-arm/assembler.h
2006-03-23[ARM] Move enable_irq and disable_irq to assembler.hRussell King
5d25ac038a317d454a4321cba955f756400835a5 broke VFP builds due to enable_irq not being defined as an assembly macro. Move it to assembler.h so everyone can use it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-09[ARM] Clean up save_and_disable_irqs macro and allow use of ARMv6 CPSIDRussell King
save_and_disable_irqs does not need to use mov + msr (which was introduced to work around a documentation bug which was propagated into binutils.) Use msr with an immediate constant, and if we're building for ARMv6 or later, use the new CPSID instruction. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
