path: root/include/asm-arm/arch-pxa/pxa3xx-regs.h
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4830/1: Add support for the CLK_POUT pin on PXA3xx CPUsMark Brown
Expose control of the PXA3xx 13MHz CLK_POUT pin via the clock API Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] pxa: add preliminary suspend/resume code for pxa3xxeric miao
1. clear RDH bit after resuming back from D3, otherwise, the multi function pins will retain the low power state 2. save/restore essential system registers Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] pxa: Add PXA3 standby code hooked into the IRQ wake schemeRussell King
Wakeup sources on PXA3 are enabled at two levels. First, the MFP configuration has to be set to enable which edges a specific pin will trigger a wakeup. The pin also has to be routed to a functional unit. Lastly, the functional unit must be enabled as a wakeup source in the appropriate AD*ER registers (AD2D0ER for standby resume.) This doesn't fit well with the IRQ wake scheme - we currently do a best effort conversion from IRQ numbers to functional unit wake enable bits. For instance, there's several USB client related enable bits but there's no corresponding IRQs to determine which you'd want. Conversely, there's a single enable bit covering several functional units. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-15[ARM] pxa: PXA3xx base supporteric miao
Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
