path: root/include/asm-arm/arch-omap/memory.h
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08ARM: OMAP: Sync headers with linux-omapTony Lindgren
This patch syncs omap specific headers with linux-omap. Most of the changes needed because of bitrot caused by driver changes in linux-omap tree. Integrating this is needed for adding support for various omap drivers. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-02ARM: OMAP: omap1510->15xx conversions needed for sx1Vladimir Ananiev
Convert 1510->15xx in generic omap code, so that sx1 can work. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Tony Lindgren <tony@atomide.com>
2005-11-10[ARM] 3143/1: OMAP 4/5: Update omap include filesTony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. This patch contains changes to common header files for omap1xxx and omap24xx by various omap developers, and improved cpu detection by Imre Deak Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-29[ARM] 3060/1: allow constants found in asm/memory.h to be used in asm codeNicolas Pitre
Patch from Nicolas Pitre This patch allows for assorted type of cleanups by letting assembly code use the same set of defines for constant values and avoid duplicated definitions that might not always be in sync, or that might simply be confusing due to the different names for the same thing. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-15[ARM] Remove PFN_TO_NID for !DISCONTIGMEMRussell King
Platform classes need not define PFN_TO_NID when DISCONTIGMEM is not selected. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-07[ARM] 2888/1: OMAP 3/4: Update omap include files, take 2Tony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. The highlights of the patch are: - Start adding 24xx support by Paul Mundt - Clean-up of cpu detection by Dirk Behme and Tony Lindgren - Add DSP header by Toshihiro Kobayashi - Add support for mtd-xip by Vladimir Barinov - Add various new mux registers - Move OMAP specific serial defines back to serial.h Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
