path: root/include/asm-arm/arch-at91/timex.h
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-10[ARM] 5130/4: Support for the at91sam9g20sedji gaouaou
Support for the at91sam9g20 : Atmel 400Mhz ARM 926ej-s SOC. AT91sam9g20 is an evolution of the at91sam9260 with a faster clock speed. We created a new board for this device but based the chip support directly on 9260 files with little updates. Here is the chip page on Atmel wabsite: http://atmel.com/dyn/products/product_card.asp?part_id=4337 Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com> Signed-off-by: Justin Waters <justin.waters@timesys.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] 5057/1: [AT91] Calao Systems - board filesAndrew Victor
Add support for three AT91-based boards available from Calao Systems: USB_A9260, USB_A9263 and QIL_A9260. Signed-off-by: Grégory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] 4764/1: [AT91] AT91CAP9 core supportAndrew Victor
Add support for Atmel's AT91CAP9 Customizable Microcontroller family. <http://www.atmel.com/products/AT91CAP/Default.asp> Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] 4427/1: base Atmel at91x40 architecture definesGreg Ungerer
Base at91x40 architecture support defines. These parts are somewhat simpler than the ARM9 Atmel based parts. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-11[ARM] 4370/3: AT91: Support for Atmel AT91SAM9RL processors.Andrew Victor
Add support for Atmel's new AT91SAM9RL range of processors. Includes similar peripherals as other AT91SAM9 processors, but with a High-speed USB controller and various sizes of internal SRAM. Signed-off-by: Nicolas Ferre <nicolas.ferre@rfo.atmel.com> Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-08[ARM] 4145/2: AT91: Add support for AT91SAM9263 processorAndrew Victor
Add support for the Atmel AT91SAM9263 processor. It is similar to the AT91SAM9260 but with more integrated peripherals, 5 GPIO banks, etc. Original patch from Nicolas Ferre. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-08[ARM] 4124/1: Rename mach-at91rm9200 and arch-at91rm9200 directoriesAndrew Victor
Now that Linux includes support for the Atmel AT91SAM9260 and AT91SAM9261 processors in addition to the original Atmel AT91RM9200 (with support for more AT91 processors pending), the "mach-at91rm9200" and "arch-at91rm9200" directories should be renamed to indicate their more generic nature. The following git commands should be run BEFORE applying this patch: git-mv arch/arm/mach-at91rm9200 arch/arm/mach-at91 git-mv include/asm-arm/arch-at91rm9200 include/asm-arm/arch-at91 Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
