path: root/include/acpi/processor.h
2006-06-23Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (65 commits) ACPI: suppress power button event on S3 resume ACPI: resolve merge conflict between sem2mutex and processor_perflib.c ACPI: use for_each_possible_cpu() instead of for_each_cpu() ACPI: delete newly added debugging macros in processor_perflib.c ACPI: UP build fix for bugzilla-5737 Enable P-state software coordination via _PDC P-state software coordination for speedstep-centrino P-state software coordination for acpi-cpufreq P-state software coordination for ACPI core ACPI: create acpi_thermal_resume() ACPI: create acpi_fan_suspend()/acpi_fan_resume() ACPI: pass pm_message_t from acpi_device_suspend() to root_suspend() ACPI: create acpi_device_suspend()/acpi_device_resume() ACPI: replace spin_lock_irq with mutex for ec poll mode ACPI: Allow a WAN module enable/disable on a Thinkpad X60. sem2mutex: acpi, acpi_link_lock ACPI: delete unused acpi_bus_drivers_lock sem2mutex: drivers/acpi/processor_perflib.c ACPI add ia64 exports to build acpi_memhotplug as a module ACPI: asus_acpi_init(): propagate correct return value ... Manual resolve of conflicts in: arch/i386/kernel/cpu/cpufreq/acpi-cpufreq.c arch/i386/kernel/cpu/cpufreq/speedstep-centrino.c include/acpi/processor.h
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-02-09P-state software coordination for ACPI coreVenkatesh Pallipadi
http://bugzilla.kernel.org/show_bug.cgi?id=5737 Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-24[ACPI] merge 3549 4320 4485 4588 4980 5483 5651 acpica asus fops pnpacpi ↵Len Brown
branches into release Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-08[ACPI] make two processor functions staticAdrian Bunk
acpi_processor_write_throttling() acpi_processor_write_limit() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-01[ACPI] Avoid BIOS inflicted crashes by evaluating _PDC only onceVenkatesh Pallipadi
Linux invokes the AML _PDC method (Processor Driver Capabilities) to tell the BIOS what features it can handle. While the ACPI spec says nothing about the OS invoking _PDC multiple times, doing so with changing bits seems to hopelessly confuse the BIOS on multiple platforms up to and including crashing the system. Factor out the _PDC invocation so Linux invokes it only once. http://bugzilla.kernel.org/show_bug.cgi?id=5483 Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
2005-07-12[ACPI] enable C2 and C3 idle power states on SMPVenkatesh Pallipadi
http://bugzilla.kernel.org/show_bug.cgi?id=4401 Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
