path: root/include/acpi/acutils.h
2007-06-02ACPICA: Support for external package objects as method argumentsBob Moore
Implemented support to allow Package objects to be passed as method arguments to the acpi_evaluate_object interface. Previously, this would return an AE_NOT_IMPLEMENTED exception. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-09ACPICA: LindentLen Brown
2007-02-02ACPICA: Update copyright to 2007.Bob Moore
Added 2007 copyright to all module headers and signons. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and the utilities. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Delete stale FADT functions outside tbfadt.c.Bob Moore
Moved all FADT-related functions to a new file, tbfadt.c. Eliminated the acpi_hw_initialize function - the FADT registers are now validated when the table is loaded. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Split acpi_format_exception into two partsBob Moore
Split acpi_format_exception into two parts. New function is acpi_ut_verify_exception and will be used to verify exception codes returned by user. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Fix unalignment in acpi_ut_repair_nameBob Moore
Update interface to acpi_ut_repair_name() to avoid alignment issues on IA64 Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060421Bob Moore
Removed a device initialization optimization introduced in 20051216 where the _STA method was not run unless an _INI was also present for the same device. This optimization could cause problems because it could allow _INI methods to be run within a not-present device subtree (If a not-present device had no _INI, _STA would not be run, the not-present status would not be discovered, and the children of the device would be incorrectly traversed.) Implemented a new _STA optimization where namespace subtrees that do not contain _INI are identified and ignored during device initialization. Selectively running _STA can significantly improve boot time on large machines (with assistance from Len Brown.) Implemented support for the device initialization case where the returned _STA flags indicate a device not-present but functioning. In this case, _INI is not run, but the device children are examined for presence, as per the ACPI specification. Implemented an additional change to the IndexField support in order to conform to MS behavior. The value written to the Index Register is not simply a byte offset, it is a byte offset in units of the access width of the parent Index Field. (Fiodor Suietov) Defined and deployed a new OSL interface, acpi_os_validate_address(). This interface is called during the creation of all AML operation regions, and allows the host OS to exert control over what addresses it will allow the AML code to access. Operation Regions whose addresses are disallowed will cause a runtime exception when they are actually accessed (will not affect or abort table loading.) Defined and deployed a new OSL interface, acpi_os_validate_interface(). This interface allows the host OS to match the various "optional" interface/behavior strings for the _OSI predefined control method as appropriate (with assistance from Bjorn Helgaas.) Restructured and corrected various problems in the exception handling code paths within DsCallControlMethod and DsTerminateControlMethod in dsmethod (with assistance from Takayoshi Kochi.) Modified the Linux source converter to ignore quoted string literals while converting identifiers from mixed to lower case. This will correct problems with the disassembler and other areas where such strings must not be modified. The ACPI_FUNCTION_* macros no longer require quotes around the function name. This allows the Linux source converter to convert the names, now that the converter ignores quoted strings. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060331Bob Moore
Implemented header file support for the following additional ACPI tables: ASF!, BOOT, CPEP, DBGP, MCFG, SPCR, SPMI, TCPA, and WDRT. With this support, all current and known ACPI tables are now defined in the ACPICA headers and are available for use by device drivers and other software. Implemented support to allow tables that contain ACPI names with invalid characters to be loaded. Previously, this would cause the table load to fail, but since there are several known cases of such tables on existing machines, this change was made to enable ACPI support for them. Also, this matches the behavior of the Microsoft ACPI implementation. https://bugzilla.novell.com/show_bug.cgi?id=147621 Fixed a couple regressions introduced during the memory optimization in the 20060317 release. The namespace node definition required additional reorganization and an internal datatype that had been changed to 8-bit was restored to 32-bit. (Valery Podrezov) Fixed a problem where a null pointer passed to acpi_ut_delete_generic_state() could be passed through to acpi_os_release_object which is unexpected. Such null pointers are now trapped and ignored, matching the behavior of the previous implementation before the deployment of acpi_os_release_object(). (Valery Podrezov, Fiodor Suietov) Fixed a memory mapping leak during the deletion of a SystemMemory operation region where a cached memory mapping was not deleted. This became a noticeable problem for operation regions that are defined within frequently used control methods. (Dana Meyers) Reorganized the ACPI table header files into two main files: one for the ACPI tables consumed by the ACPICA core, and another for the miscellaneous ACPI tables that are consumed by the drivers and other software. The various FADT definitions were merged into one common section and three different tables (ACPI 1.0, 1.0+, and 2.0) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14[ACPI] ACPICA 20060317Bob Moore
Implemented the use of a cache object for all internal namespace nodes. Since there are about 1000 static nodes in a typical system, this will decrease memory use for cache implementations that minimize per-allocation overhead (such as a slab allocator.) Removed the reference count mechanism for internal namespace nodes, since it was deemed unnecessary. This reduces the size of each namespace node by about 5%-10% on all platforms. Nodes are now 20 bytes for the 32-bit case, and 32 bytes for the 64-bit case. Optimized several internal data structures to reduce object size on 64-bit platforms by packing data within the 64-bit alignment. This includes the frequently used ACPI_OPERAND_OBJECT, of which there can be ~1000 static instances corresponding to the namespace objects. Added two new strings for the predefined _OSI method: "Windows 2001.1 SP1" and "Windows 2006". Split the allocation tracking mechanism out to a separate file, from utalloc.c to uttrack.c. This mechanism appears to be only useful for application-level code. Kernels may wish to not include uttrack.c in distributions. Removed all remnants of the obsolete ACPI_REPORT_* macros and the associated code. (These macros have been replaced by the ACPI_ERROR and ACPI_WARNING macros.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-03-31[ACPI] ACPICA 20060210Bob Moore
Removed a couple of extraneous ACPI_ERROR messages that appeared during normal execution. These became apparent after the conversion from ACPI_DEBUG_PRINT. Fixed a problem where the CreateField operator could hang if the BitIndex or NumBits parameter referred to a named object. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5359 Fixed a problem where a DeRefOf operation on a buffer object incorrectly failed with an exception. This also fixes a couple of related RefOf and DeRefOf issues. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5360 http://bugzilla.kernel.org/show_bug.cgi?id=5387 http://bugzilla.kernel.org/show_bug.cgi?id=5392 Fixed a problem where the AE_BUFFER_LIMIT exception was returned instead of AE_STRING_LIMIT on an out-of-bounds Index() operation. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5480 Implemented a memory cleanup at the end of the execution of each iteration of an AML While() loop, preventing the accumulation of outstanding objects. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5427 Eliminated a chunk of duplicate code in the object resolution code. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5336 Fixed several warnings during the 64-bit code generation. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-31[ACPI] ACPICA 20060127Bob Moore
Implemented support in the Resource Manager to allow unresolved namestring references within resource package objects for the _PRT method. This support is in addition to the previously implemented unresolved reference support within the AML parser. If the interpreter slack mode is enabled (true on Linux unless acpi=strict), these unresolved references will be passed through to the caller as a NULL package entry. http://bugzilla.kernel.org/show_bug.cgi?id=5741 Implemented and deployed new macros and functions for error and warning messages across the subsystem. These macros are simpler and generate less code than their predecessors. The new macros ACPI_ERROR, ACPI_EXCEPTION, ACPI_WARNING, and ACPI_INFO replace the ACPI_REPORT_* macros. Implemented the acpi_cpu_flags type to simplify host OS integration of the Acquire/Release Lock OSL interfaces. Suggested by Steven Rostedt and Andrew Morton. Fixed a problem where Alias ASL operators are sometimes not correctly resolved. causing AE_AML_INTERNAL http://bugzilla.kernel.org/show_bug.cgi?id=5189 http://bugzilla.kernel.org/show_bug.cgi?id=5674 Fixed several problems with the implementation of the ConcatenateResTemplate ASL operator. As per the ACPI specification, zero length buffers are now treated as a single EndTag. One-length buffers always cause a fatal exception. Non-zero length buffers that do not end with a full 2-byte EndTag cause a fatal exception. Fixed a possible structure overwrite in the AcpiGetObjectInfo external interface. (With assistance from Thomas Renninger) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-20[ACPI] ACPICA 20060113Bob Moore
Added 2006 copyright. At SuSE's suggestion, enabled all error messages without enabling function tracing, ie with CONFIG_ACPI_DEBUG=n Replaced all instances of the ACPI_DEBUG_PRINT macro invoked at the ACPI_DB_ERROR and ACPI_DB_WARN debug levels with the ACPI_REPORT_ERROR and ACPI_REPORT_WARNING macros, respectively. This preserves all error and warning messages in the non-debug version of the ACPICA code (this has been referred to as the "debug lite" option.) Over 200 cases were converted to create a total of over 380 error/warning messages across the ACPICA code. This increases the code and data size of the default non-debug version by about 13K. Added ACPI_NO_ERROR_MESSAGES flag to enable deleting all messages. The size of the debug version remains about the same. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-28[ACPI] ACPICA 20051216Bob Moore
Implemented optional support to allow unresolved names within ASL Package objects. A null object is inserted in the package when a named reference cannot be located in the current namespace. Enabled via the interpreter slack flag which Linux has enabled by default (acpi=strict to disable slack). This should eliminate AE_NOT_FOUND exceptions seen on machines that contain such code. Implemented an optimization to the initialization sequence that can improve boot time. During ACPI device initialization, the _STA method is now run if and only if the _INI method exists. The _STA method is used to determine if the device is present; An _INI can only be run if _STA returns present, but it is a waste of time to run the _STA method if the _INI does not exist. (Prototype and assistance from Dong Wei) Implemented use of the C99 uintptr_t for the pointer casting macros if it is available in the current compiler. Otherwise, the default (void *) cast is used as before. Fixed some possible memory leaks found within the execution path of the Break, Continue, If, and CreateField operators. (Valery Podrezov) Fixed a problem introduced in the 20051202 release where an exception is generated during method execution if a control method attempts to declare another method. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-10[ACPI] ACPICA 20051102Bob Moore
Modified the subsystem initialization sequence to improve GPE support. The GPE initialization has been split into two parts in order to defer execution of the _PRW methods (Power Resources for Wake) until after the hardware is fully initialized and the SCI handler is installed. This allows the _PRW methods to access fields protected by the Global Lock. This will fix systems where a NO_GLOBAL_LOCK exception has been seen during initialization. Fixed a regression with the ConcatenateResTemplate() ASL operator introduced in the 20051021 release. Implemented support for "local" internal ACPI object types within the debugger "Object" command and the acpi_walk_namespace() external interfaces. These local types include RegionFields, BankFields, IndexFields, Alias, and reference objects. Moved common AML resource handling code into a new file, "utresrc.c". This code is shared by both the Resource Manager and the AML Debugger. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-10[ACPI] ACPICA 20051021Bob Moore
Implemented support for the EM64T and other x86_64 processors. This essentially entails recognizing that these processors support non-aligned memory transfers. Previously, all 64-bit processors were assumed to lack hardware support for non-aligned transfers. Completed conversion of the Resource Manager to nearly full table-driven operation. Specifically, the resource conversion code (convert AML to internal format and the reverse) and the debug code to dump internal resource descriptors are fully table-driven, reducing code and data size and improving maintainability. The OSL interfaces for Acquire and Release Lock now use a 64-bit flag word on 64-bit processors instead of a fixed 32-bit word. (Alexey Starikovskiy) Implemented support within the resource conversion code for the Type-Specific byte within the various ACPI 3.0 *WordSpace macros. Fixed some issues within the resource conversion code for the type-specific flags for both Memory and I/O address resource descriptors. For Memory, implemented support for the MTP and TTP flags. For I/O, split the TRS and TTP flags into two separate fields. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
2005-07-30[ACPI] ACPICA 20050729 from Bob MooreRobert Moore
Implemented support to ignore an attempt to install/load a particular ACPI table more than once. Apparently there exists BIOS code that repeatedly attempts to load the same SSDT upon certain events. Thanks to Venkatesh Pallipadi. Restructured the main interface to the AML parser in order to correctly handle all exceptional conditions. This will prevent leakage of the OwnerId resource and should eliminate the AE_OWNER_ID_LIMIT exceptions seen on some machines. Thanks to Alexey Starikovskiy. Support for "module level code" has been disabled in this version due to a number of issues that have appeared on various machines. The support can be enabled by defining ACPI_ENABLE_MODULE_LEVEL_CODE during subsystem compilation. When the issues are fully resolved, the code will be enabled by default again. Modified the internal functions for debug print support to define the FunctionName parameter as a (const char *) for compatibility with compiler built-in macros such as __FUNCTION__, etc. Linted the entire ACPICA source tree for both 32-bit and 64-bit. Signed-off-by: Robert Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-14ACPICA 20050708 from Bob Moore <robert.moore@intel.com>Robert Moore
The use of the CPU stack in the debug version of the subsystem has been considerably reduced. Previously, a debug structure was declared in every function that used the debug macros. This structure has been removed in favor of declaring the individual elements as parameters to the debug functions. This reduces the cumulative stack use during nested execution of ACPI function calls at the cost of a small increase in the code size of the debug version of the subsystem. With assistance from Alexey Starikovskiy and Len Brown. Added the ACPI_GET_FUNCTION_NAME macro to enable the compiler-dependent headers to define a macro that will return the current function name at runtime (such as __FUNCTION__ or _func_, etc.) The function name is used by the debug trace output. If ACPI_GET_FUNCTION_NAME is not defined in the compiler-dependent header, the function name is saved on the CPU stack (one pointer per function.) This mechanism is used because apparently there exists no standard ANSI-C defined macro that that returns the function name. Alexey Starikovskiy redesigned and reimplemented the "Owner ID" mechanism used to track namespace objects created/deleted by ACPI tables and control method execution. A bitmap is now used to allocate and free the IDs, thus solving the wraparound problem present in the previous implementation. The size of the namespace node descriptor was reduced by 2 bytes as a result. Removed the UINT32_BIT and UINT16_BIT types that were used for the bitfield flag definitions within the headers for the predefined ACPI tables. These have been replaced by UINT8_BIT in order to increase the code portability of the subsystem. If the use of UINT8 remains a problem, we may be forced to eliminate bitfields entirely because of a lack of portability. Alexey Starikovksiy enhanced the performance of acpi_ut_update_object_reference. This is a frequently used function and this improvement increases the performance of the entire subsystem. Alexey Starikovskiy fixed several possible memory leaks and the inverse - premature object deletion. Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-13ACPICA 20050617-0624 from Bob Moore <robert.moore@intel.com>Robert Moore
ACPICA 20050617: Moved the object cache operations into the OS interface layer (OSL) to allow the host OS to handle these operations if desired (for example, the Linux OSL will invoke the slab allocator). This support is optional; the compile time define ACPI_USE_LOCAL_CACHE may be used to utilize the original cache code in the ACPI CA core. The new OSL interfaces are shown below. See utalloc.c for an example implementation, and acpiosxf.h for the exact interface definitions. Thanks to Alexey Starikovskiy. acpi_os_create_cache acpi_os_delete_cache acpi_os_purge_cache acpi_os_acquire_object acpi_os_release_object Modified the interfaces to acpi_os_acquire_lock and acpi_os_release_lock to return and restore a flags parameter. This fits better with many OS lock models. Note: the current execution state (interrupt handler or not) is no longer passed to these interfaces. If necessary, the OSL must determine this state by itself, a simple and fast operation. Thanks to Alexey Starikovskiy. Fixed a problem in the ACPI table handling where a valid XSDT was assumed present if the revision of the RSDP was 2 or greater. According to the ACPI specification, the XSDT is optional in all cases, and the table manager therefore now checks for both an RSDP >=2 and a valid XSDT pointer. Otherwise, the RSDT pointer is used. Some ACPI 2.0 compliant BIOSs contain only the RSDT. Fixed an interpreter problem with the Mid() operator in the case of an input string where the resulting output string is of zero length. It now correctly returns a valid, null terminated string object instead of a string object with a null pointer. Fixed a problem with the control method argument handling to allow a store to an Arg object that already contains an object of type Device. The Device object is now correctly overwritten. Previously, an error was returned. ACPICA 20050624: Modified the new OSL cache interfaces to use ACPI_CACHE_T as the type for the host-defined cache object. This allows the OSL implementation to define and type this object in any manner desired, simplifying the OSL implementation. For example, ACPI_CACHE_T is defined as kmem_cache_t for Linux, and should be defined in the OS-specific header file for other operating systems as required. Changed the interface to AcpiOsAcquireObject to directly return the requested object as the function return (instead of ACPI_STATUS.) This change was made for performance reasons, since this is the purpose of the interface in the first place. acpi_os_acquire_object is now similar to the acpi_os_allocate interface. Thanks to Alexey Starikovskiy. Modified the initialization sequence in acpi_initialize_subsystem to call the OSL interface acpi_osl_initialize first, before any local initialization. This change was required because the global initialization now calls OSL interfaces. Restructured the code base to split some files because of size and/or because the code logically belonged in a separate file. New files are listed below. utilities/utcache.c /* Local cache interfaces */ utilities/utmutex.c /* Local mutex support */ utilities/utstate.c /* State object support */ parser/psloop.c /* Main AML parse loop */ Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-12ACPICA 20050408 from Bob MooreRobert Moore
Fixed three cases in the interpreter where an "index" argument to an ASL function was still (internally) 32 bits instead of the required 64 bits. This was the Index argument to the Index, Mid, and Match operators. The "strupr" function is now permanently local (acpi_ut_strupr), since this is not a POSIX-defined function and not present in most kernel-level C libraries. References to the C library strupr function have been removed from the headers. Completed the deployment of static functions/prototypes. All prototypes with the static attribute have been moved from the headers to the owning C file. ACPICA 20050329 from Bob Moore An error is now generated if an attempt is made to create a Buffer Field of length zero (A CreateField with a length operand of zero.) The interpreter now issues a warning whenever executable code at the module level is detected during ACPI table load. This will give some idea of the prevalence of this type of code. Implemented support for references to named objects (other than control methods) within package objects. Enhanced package object output for the debug object. Package objects are now completely dumped, showing all elements. Enhanced miscellaneous object output for the debug object. Any object can now be written to the debug object (for example, a device object can be written, and the type of the object will be displayed.) The "static" qualifier has been added to all local functions across the core subsystem. The number of "long" lines (> 80 chars) within the source has been significantly reduced, by about 1/3. Cleaned up all header files to ensure that all CA/iASL functions are prototyped (even static functions) and the formatting is consistent. Two new header files have been added, acopcode.h and acnames.h. Removed several obsolete functions that were no longer used. Signed-off-by: Len Brown <len.brown@intel.com>
