path: root/include/acpi/acpixf.h
2015-08-25ACPICA: Update version to 20150818Bob Moore
ACPICA commit d93470de8febeecdc20633fde11cb0b200fa773b Version 20150818. Link: https://github.com/acpica/acpica/commit/d93470de Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-08-25ACPICA: Debugger: Split debugger initialization/termination APIsLv Zheng
ACPICA commit 7a3f22baab000b186779dac64ad71d9776b8f432 It is likely that the debugger is enabled only when a userspace program explicitly tells a kernel to do so, so it shouldn't be initialized as early as current implementation. The only tool requiring ACPI_DEBUGGER is acpiexec, so acpiexec need to call the new APIs by itself. And BSD developers may also get notified to invoke the APIs for DDB enabling. Lv Zheng. This patch doesn't affect Linux kernel as debugger is currently not enabled in the Linux kernel. Link: https://github.com/acpica/acpica/commit/7a3f22ba Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-23ACPICA: Update version to 20150717Bob Moore
ACPICA commit 8580ce04c1b7aa415c364b06e79edb8aca77dded Version 20150717. Link: https://github.com/acpica/acpica/commit/8580ce04 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-23ACPICA: Executer: Add OSL trace hook supportLv Zheng
ACPICA commit e8e4a9b19d0b72a7b165398bdc961fc2f6f502ec This patch adds OSL trace hook support. OSPMs are encouraged to use acpi_os_trace_point() with ACPI_USE_SYSTEM_TRACER defined to implement platform specific trace facility. Lv Zheng. Link: https://github.com/acpica/acpica/commit/e8e4a9b1 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-23ACPICA: Executer: Add interpreter tracing mode for method tracing facilityLv Zheng
ACPICA commit 07fffd02607685b655ed92ee15c160e6a810b60b The acpi_debug_trace() is the mechanism known as ACPI method tracing that is used by Linux as ACPICA debugging message reducer. This facility can be controlled through Linux ACPI subsystem - /sys/module/acpi/parameters. This facility requires CONFIG_ACPI_DEBUG to be enabled to see ACPICA trace logs in the kernel dmesg output. This patch enhances acpi_debug_trace() to make it not only a message reducer, but a real tracer to trace AML interpreter execution. Note that in addition to the AML tracer enabling, this patch also updates the facility with the following enhancements: 1. Allow a full path to be specified by the acpi_debug_trace() API. 2. Allow any method rather than just the entrance of acpi_evaluate_object() to be traced. 3. All interpreter ACPI_LV_TRACE_POINT messages are collected for ACPI_EXECUTER layer. The Makefile of drivers/acpi/acpica is also updated to include exdebug.o and the duplicated stubs are removed after that. Note that since this patch has enhanced the method tracing facility, Linux need also be updated after applying this patch. Lv Zheng. Link: https://github.com/acpica/acpica/commit/07fffd02 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-01ACPICA: Update version to 20150619Bob Moore
ACPICA commit 2fcf4f4c95e6a4875f39a929f8f92ef50cc53bb5 ACPICA commit d7a940bb308d001b5d2b196174fee36c7daa61d6 Version 20150619. Link: https://github.com/acpica/acpica/commit/2fcf4f4c Link: https://github.com/acpica/acpica/commit/d7a940bb Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-01ACPICA: Namespace: Change namespace override to avoid node deletionBob Moore
ACPICA commit c0ce529e1fbb8ec47d2522a3aa10f3ab77e16e41 There is no reference counting implemented for struct acpi_namespace_node, so it is currently not removable during runtime. This patch changes the namespace override code to keep the old struct acpi_namespace_node undeleted so that the override mechanism can happen during runtime. Bob Moore. Link: https://github.com/acpica/acpica/commit/c0ce529e Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-01ACPICA: Tables: Enable default 64-bit FADT addresses favorLv Zheng
ACPICA commit 4da56eeae0749dfe8491285c1e1fad48f6efafd8 The following commit temporarily disables correct 64-bit FADT addresses favor during the period the root cause of the bug is not fixed: Commit: 85dbd5801f62b66e2aa7826aaefcaebead44c8a6 ACPICA: Tables: Restore old behavor to favor 32-bit FADT addresses. With enough protections, this patch re-enables 64-bit FADT addresses by default. If regressions are reported against such change, this patch should be bisected and reverted. Note that 64-bit FACS favor and 64-bit firmware waking vector favor are excluded by this commit in order not to break OSPMs. Lv Zheng. Link: https://bugzilla.kernel.org/show_bug.cgi?id=74021 Link: https://github.com/acpica/acpica/commit/4da56eea Cc: 3.15.1+ <stable@vger.kernel.org> # 3.15.1+ Reported-and-tested-by: Oswald Buddenhagen <ossi@kde.org> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-01ACPICA: Tables: Enable both 32-bit and 64-bit FACSLv Zheng
ACPICA commit f7b86f35416e3d1f71c3d816ff5075ddd33ed486 The following commit is reported to have broken s2ram on some platforms: Commit: 0249ed2444d65d65fc3f3f64f398f1ad0b7e54cd ACPICA: Add option to favor 32-bit FADT addresses. The platform reports 2 FACS tables (which is not allowed by ACPI specification) and the new 32-bit address favor rule forces OSPMs to use the FACS table reported via FADT's X_FIRMWARE_CTRL field. The root cause of the reported bug might be one of the followings: 1. BIOS may favor the 64-bit firmware waking vector address when the version of the FACS is greater than 0 and Linux currently only supports resuming from the real mode, so the 64-bit firmware waking vector has never been set and might be invalid to BIOS while the commit enables higher version FACS. 2. BIOS may favor the FACS reported via the "FIRMWARE_CTRL" field in the FADT while the commit doesn't set the firmware waking vector address of the FACS reported by "FIRMWARE_CTRL", it only sets the firware waking vector address of the FACS reported by "X_FIRMWARE_CTRL". This patch excludes the cases that can trigger the bugs caused by the root cause 2. There is no handshaking mechanism can be used by OSPM to tell BIOS which FACS is currently used. Thus the FACS reported by "FIRMWARE_CTRL" may still be used by BIOS and the 0 value of the 32-bit firmware waking vector might trigger such failure. This patch tries to favor 32bit FACS address in another way where both the FACS reported by "FIRMWARE_CTRL" and the FACS reported by "X_FIRMWARE_CTRL" are loaded so that further commit can set firmware waking vector in the both tables to ensure we can exclude the cases that trigger the bugs caused by the root cause 2. The exclusion is split into 2 commits as this commit is also useful for dumping more ACPI tables, it won't get reverted when such exclusion is no longer necessary. Lv Zheng. Link: https://bugzilla.kernel.org/show_bug.cgi?id=74021 Link: https://github.com/acpica/acpica/commit/f7b86f35 Cc: 3.14.1+ <stable@vger.kernel.org> # 3.14.1+ Reported-and-tested-by: Oswald Buddenhagen <ossi@kde.org> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-01ACPICA: Hardware: Enable 64-bit firmware waking vector for selected FACSLv Zheng
ACPICA commit 7aa598d711644ab0de5f70ad88f1e2de253115e4 The following commit is reported to have broken s2ram on some platforms: Commit: 0249ed2444d65d65fc3f3f64f398f1ad0b7e54cd ACPICA: Add option to favor 32-bit FADT addresses. The platform reports 2 FACS tables (which is not allowed by ACPI specification) and the new 32-bit address favor rule forces OSPMs to use the FACS table reported via FADT's X_FIRMWARE_CTRL field. The root cause of the reported bug might be one of the followings: 1. BIOS may favor the 64-bit firmware waking vector address when the version of the FACS is greater than 0 and Linux currently only supports resuming from the real mode, so the 64-bit firmware waking vector has never been set and might be invalid to BIOS while the commit enables higher version FACS. 2. BIOS may favor the FACS reported via the "FIRMWARE_CTRL" field in the FADT while the commit doesn't set the firmware waking vector address of the FACS reported by "FIRMWARE_CTRL", it only sets the firware waking vector address of the FACS reported by "X_FIRMWARE_CTRL". This patch excludes the cases that can trigger the bugs caused by the root cause 1. ACPI specification says: A. 32-bit FACS address (FIRMWARE_CTRL field in FADT): Physical memory address of the FACS, where OSPM and firmware exchange control information. If the X_FIRMWARE_CTRL field contains a non zero value then this field must be zero. A zero value indicates that no FACS is specified by this field. B. 64-bit FACS address (X_FIRMWARE_CTRL field in FADT): 64bit physical memory address of the FACS. This field is used when the physical address of the FACS is above 4GB. If the FIRMWARE_CTRL field contains a non zero value then this field must be zero. A zero value indicates that no FACS is specified by this field. Thus the 32bit and 64bit firmware waking vector should indicate completely different resuming environment - real mode (1MB addressable) and non real mode (4GB+ addressable) and currently Linux only supports resuming from real mode. This patch enables 64-bit firmware waking vector for selected FACS via new acpi_set_firmware_waking_vectors() API so that it's up to OSPMs to determine which resuming mode should be used by BIOS and ACPICA changes won't trigger the bugs caused by the root cause 1. Lv Zheng. Link: https://bugzilla.kernel.org/show_bug.cgi?id=74021 Link: https://github.com/acpica/acpica/commit/7aa598d7 Reported-and-tested-by: Oswald Buddenhagen <ossi@kde.org> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-05-22ACPICA: Update version to 20150515.Bob Moore
ACPICA commit ed4de2e8b0a5dd6fc17773a055590bff0e995588 Version 20150515. Link: https://github.com/acpica/acpica/commit/ed4de2e8 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-04-14ACPICA: Update version to 20150410.Bob Moore
ACPICA commit 06198cfd96ef271f554a50f1830a5975468c39ac ACPICA commit 8a3c1df1edb5f9fc5c940500c598c0107d30df71 Version 20150410. Link: https://github.com/acpica/acpica/commit/06198cfd Link: https://github.com/acpica/acpica/commit/8a3c1df1 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-04-14ACPICA: Tables: Change acpi_find_root_pointer() to use acpi_physical_address.Lv Zheng
ACPICA commit 7d9fd64397d7c38899d3dc497525f6e6b044e0e3 OSPMs like Linux expect an acpi_physical_address returning value from acpi_find_root_pointer(). This triggers warnings if sizeof (acpi_size) doesn't equal to sizeof (acpi_physical_address): drivers/acpi/osl.c:275:3: warning: passing argument 1 of 'acpi_find_root_pointer' from incompatible pointer type [enabled by default] In file included from include/acpi/acpi.h:64:0, from include/linux/acpi.h:36, from drivers/acpi/osl.c:41: include/acpi/acpixf.h:433:1: note: expected 'acpi_size *' but argument is of type 'acpi_physical_address *' This patch corrects acpi_find_root_pointer(). Link: https://github.com/acpica/acpica/commit/7d9fd643 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-05ACPICA: Events: Introduce ACPI_GPE_DISPATCH_RAW_HANDLER to fix 2 issues for ↵Lv Zheng
the current GPE APIs ACPICA commit 199cad16530a45aea2bec98e528866e20c5927e1 Since whether the GPE should be disabled/enabled/cleared should only be determined by the GPE driver's state machine: 1. GPE should be disabled if the driver wants to switch to the GPE polling mode when a GPE storm condition is indicated and should be enabled if the driver wants to switch back to the GPE interrupt mode when all of the storm conditions are cleared. The conditions should be protected by the driver's specific lock. 2. GPE should be enabled if the driver has accepted more than one request and should be disabled if the driver has completed all of the requests. The request count should be protected by the driver's specific lock. 3. GPE should be cleared either when the driver is about to handle an edge triggered GPE or when the driver has completed to handle a level triggered GPE. The handling code should be protected by the driver's specific lock. Thus the GPE enabling/disabling/clearing operations are likely to be performed with the driver's specific lock held while we currently cannot do this. This is because: 1. We have the acpi_gbl_gpe_lock held before invoking the GPE driver's handler. Driver's specific lock is likely to be held inside of the handler, thus we can see some dead lock issues due to the reversed locking order or recursive locking. In order to solve such dead lock issues, we need to unlock the acpi_gbl_gpe_lock before invoking the handler. BZ 1100. 2. Since GPE disabling/enabling/clearing should be determined by the GPE driver's state machine, we shouldn't perform such operations inside of ACPICA for a GPE handler to mess up the driver's state machine. BZ 1101. Originally this patch includes a logic to flush GPE handlers, it is dropped due to the following reasons: 1. This is a different issue; 2. Linux OSL has fixed this by flushing SCI in acpi_os_wait_events_complete(). We will pick up this topic when the Linux OSL fix turns out to be not sufficient. Note that currently the internal operations and the acpi_gbl_gpe_lock are also used by ACPI_GPE_DISPATCH_METHOD and ACPI_GPE_DISPATCH_NOTIFY. In order not to introduce regressions, we add one ACPI_GPE_DISPATCH_RAW_HANDLER type to be distiguished from ACPI_GPE_DISPATCH_HANDLER. For which the acpi_gbl_gpe_lock is unlocked before invoking the GPE handler and the internal enabling/disabling operations are bypassed to allow drivers to perform them at a proper position using the GPE APIs and ACPI_GPE_DISPATCH_RAW_HANDLER users should invoke acpi_set_gpe() instead of acpi_enable_gpe()/acpi_disable_gpe() to bypass the internal GPE clearing code in acpi_enable_gpe(). Lv Zheng. Known issues: 1. Edge-triggered GPE lost for frequent enablings On some buggy silicon platforms, GPE enable line may not be directly wired to the GPE trigger line. In that case, when GPE enabling is frequently performed for edge-triggered GPEs, GPE status may stay set without being triggered. This patch may maginify this problem as it allows GPE enabling to be parallel performed during the process the GPEs are handled. This is an existing issue, because: 1. For task context: Current ACPI_GPE_DISPATCH_METHOD practices have proven that this isn't a real issue - we can re-enable edge-triggered GPE in a work queue where the GPE status bit might already be set. 2. For IRQ context: This can even happen when the GPE enabling occurs before returning from the GPE handler and after unlocking the GPE lock. Thus currently no code is included to protect this. Link: https://github.com/acpica/acpica/commit/199cad16 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-05ACPICA: Update version to 20150204David E. Box
ACPICA commit e06b1624b02dc8317d144e9a6fe9d684c5fa2f90 Version 20150204. Link: https://github.com/acpica/acpica/commit/e06b1624 Signed-off-by: David E. Box <david.e.box@linux.intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-05ACPICA: Update Copyright headers to 2015David E. Box
ACPICA commit 8990e73ab2aa15d6a0068b860ab54feff25bee36 Link: https://github.com/acpica/acpica/commit/8990e73a Signed-off-by: David E. Box <david.e.box@linux.intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-26ACPI: Introduce acpi_unload_parent_table() usages in Linux kernelLv Zheng
ACPICA has implemented acpi_unload_parent_table() which can exactly replace the acpi_get_id()/acpi_unload_table_id() implemented in Linux kernel. The acpi_unload_parent_table() has been unit tested in ACPICA simulation environment. This patch can also help to reduce the source code differences between Linux and ACPICA. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Tested-by: Octavian Purdila <octavian.purdila@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-11-28ACPICA: Update version to 20141107.Bob Moore
Version 20141107. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-10-21ACPICA: Update version to 20140926.Bob Moore
Version 20140926. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-09-30ACPICA: Introduce acpi_enable_all_wakeup_gpes()Rafael J. Wysocki
Add a routine for host OSes to enable all wakeup GPEs and disable all of the non-wakeup ones at the same time. It will be used for the handling of GPE wakeup from suspend-to-idle in Linux. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-09-03ACPICA: Update version to 20140828.Bob Moore
Version 20140828. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-08-05Merge branch 'acpica'Rafael J. Wysocki
* acpica: ACPICA: Update version to 20140724. ACPICA: ACPI 5.1: Update for PCCT table changes. ACPICA/ARM: ACPI 5.1: Update for GTDT table changes. ACPICA/ARM: ACPI 5.1: Update for MADT changes. ACPICA/ARM: ACPI 5.1: Update for FADT changes. ACPICA: ACPI 5.1: Support for the _CCA predifined name. ACPICA: ACPI 5.1: New notify value for System Affinity Update. ACPICA: ACPI 5.1: Support for the _DSD predefined name. ACPICA: Debug object: Add current value of Timer() to debug line prefix. ACPICA: acpihelp: Add UUID support, restructure some existing files. ACPICA: Utilities: Fix local printf issue. ACPICA: Tables: Update for DMAR table changes. ACPICA: Remove some extraneous printf arguments. ACPICA: Update for comments/formatting. No functional changes. ACPICA: Disassembler: Add support for the ToUUID opererator (macro). ACPICA: Remove a redundant cast to acpi_size for ACPI_OFFSET() macro. ACPICA: Work around an ancient GCC bug.
2014-07-31ACPICA: Update version to 20140724.Bob Moore
Version 20140724. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-27Merge branch 'acpi-headers'Rafael J. Wysocki
* acpi-headers: ACPI: Add support to force header inclusion rules for <acpi/acpi.h>. ACPI / SFI: Fix wrong <acpi/acpi.h> inclusion in SFI/ACPI wrapper - table definitions. ACPICA: Linux: Allow ACPICA inclusion for CONFIG_ACPI=n builds. ACPICA: Linux: Add support to exclude <asm/acenv.h> inclusion. ACPICA: Linux: Add stub implementation of ACPICA 64-bit mathematics. ACPICA: Linux: Add stub support for Linux specific variables and functions.
2014-07-23ACPICA: Add new GPE public interface - acpi_mark_gpe_for_wake.Rafael J. Wysocki
ACPICA commit c49dbfed2bc069d0038ea7e1294409bfde7c2c8c Some potential callers of acpi_setup_gpe_for_wake may know in advance that there won't be any notify handlers installed for device wake notifications from the given GPE (one example is a button GPE in Linux). For these cases, acpi_mark_gpe_for_wake should be used instead of acpi_setup_gpe_for_wake. This will set the ACPI_GPE_CAN_WAKE flag for the GPE without trying to setup implicit wake notification for it (since there's no handler method). Rafael Wysocki. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com>
2014-07-20ACPICA: Linux: Add stub support for Linux specific variables and functions.Lv Zheng
There are global variables and functions not upstreamed to the ACPICA code base. Such symbols still can be referenced by external users as they are listed in the acpixf.h. This patch uses ACPI_GLOBAL and ACPI_EXTERNAL_RETURN_STATUS mechanism to add stub support for such symbols. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-08ACPICA: Update version to 20140627Bob Moore
Version 20140627. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-08ACPICA: Utilities: Introduce acpi_log_error() to improve portabilityLv Zheng
Invocations like fprintf(stderr) and perror() are not portable, this patch introduces acpi_log_error() as a replacement, it is implemented using new portable API - acpi_ut_file_vprintf(). Note that though acpi_os_initialize() need to be invoked prior than using this new API, since no users are introduced in this patch, such invocations are not added for applications that link utprint.c in this patch. Futher patches that introduce users of acpi_log_error() should take care of this. This patch is only useful for ACPICA applications, most of which are not shipped in the Linux kernel. Note that follow-up commits will update acpidump to use this new API to improve portability. Lv Zheng. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-06-01ACPICA: Tables: Add mechanism to control early table checksum verification.Lv Zheng
It is reported that Linux x86 kernel cannot map large tables. The following large SSDT table on such platform fails to pass checksum verification and cannot be installed: ACPI: SSDT 0x00000000B9638018 07A0C4 (v02 INTEL S2600CP 00004000 INTL 20100331) It sounds strange that in the 64-bit virtual memory address space, we cannot map a single ACPI table to do checksum verification. The root cause is: 1. ACPICA doesn't split IO memory mapping and table mapping; 2. Linux x86 OSL implements acpi_os_map_memory() using a size limited fix-map mechanism during early boot stage, which is more suitable for only IO mappings. ACPICA originally only mapped table header for signature validation, and this header mapping is required by OSL override mechanism. There was no checksum verification because we could not map the whole table using this OSL. While the following ACPICA commit enforces checksum verification by mapping the whole table during Linux boot stage and it finally triggers this issue on some platforms: Commit: 86dfc6f339886559d80ee0d4bd20fe5ee90450f0 Subject: ACPICA: Tables: Fix table checksums verification before installation. Before doing further cleanups for the OSL table mapping and override implementation, this patch introduces an option for such OSPMs to temporarily discard the checksum verification feature. It then can be re-enabled easily when the ACPICA and the underlying OSL is ready. This patch also deletes a comment around the limitation of mappings because it is not correct. The limitation is not how many times we can map in the early stage, but the OSL mapping facility may not be suitable for mapping the ACPI tables and thus may complain us the size limitation. The acpi_tb_verify_table() is renamed to acpi_tb_verify_temp_table() due to the work around added, it now only applies to the table descriptor that hasn't been installed and cannot be used in other cases. Lv Zheng. Tested-by: Yuanhan Liu <yuanhan.liu@linux.intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-05-27Merge back earlier ACPICA material.Rafael J. Wysocki
Conflicts: drivers/acpi/acpica/acglobal.h
2014-05-07ACPICA: Update version to 20140424.Bob Moore
Version 20140424. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-05-07ACPICA: Comment/format update, no functional change.Bob Moore
Add some additional commenting the the public acpixf.h file. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-05-07ACPICA: Back port of improvements on exception code.Bob Moore
This is the linuxize result of the following commit: Subject: ACPICA: Improve handling of exception code blocks. Split exception codes into three distinct blocks; for the main ASL compiler, Table compiler, and the preprocessor. This allows easy addition of new codes into each block without disturbing the others. Adds one new file, aslmessages.c The iASL changes are not in this patch as iASL currently is not shipped in the kernel. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-05-07ACPICA: OSL: Add configurability for generic external functions.Lv Zheng
OSPMs like Linux trend to include all header files but leave empty inline stub functions for a feature that is not configured during build. This patch adds wrappers mechanism to be used around ACPICA external interfaces to facilitate OSPM with such configurability. This patch doesn't include code for Linux to use this new mechanism, thus no functional change. Lv Zheng. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-05-07ACPICA: OSL: Add section to collect the divergence in acpixf.h.Lv Zheng
This patch re-orders the interface prototypes defined in acpixf.h, moving those having not back ported to ACPICA into a seperate section to reduce the source code differences between Linux and ACPICA. This can help to reduce the cost of linuxizing the follow up commits. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-05-07ACPICA: OSL: Add configurability for debug output functions.Lv Zheng
This patch extends ACPI_HW_DEPENDENT_x mechanism to all debugging output related functions so that the OSPMs can have full control to configure them into stub functions. This patch doesn't include code for Linux to use this new mechanism, thus no functional change. Lv Zheng. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-05-07ACPICA: OSL: Add configurability for error message functions.Lv Zheng
This patch extends ACPI_HW_DEPENDENT_x mechanism to all error message related functions so that the OSPMs can have full control to configure them into stub functions. This patch doesn't include code for Linux to use this new mechanism, thus no functional change. Lv Zheng. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-05-07ACPICA: OSL: Move external globals from utglobal.c to acpixf.h using ↵Lv Zheng
ACPI_INIT_GLOBAL/ACPI_GLOBAL. OSPMs like Linux trend to include all header files but leave empty stub macros for a feature that is not configured during build. This patch cleans up global variables that are defined in utglobal.c using ACPI_INIT_GLOBAL mechanism. In Linux, such global variables are used by the subsystems external to ACPICA. This patch also cleans up global variables that are defined in utglobal.c using ACPI_GLOBAL mechanism. In Linux, such global variables are not used or should not be used by the subsystems external to ACPICA. External global variables can be redefined by OSPMs using ACPI_INIT_GLOBAL/ACPI_GLOBAL macros. Thus the ACPI_GLOBAL/ACPI_INIT_GLOBAL mechanisms can be used by OSPM to implement stubs for such external globals. This patch doesn't include code for Linux to use this new mechanism, thus no functional changes. Lv Zheng. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-05-07ACPICA: Update global variable definitions. No functional change.Lv Zheng
Move all of the public globals to acpixf.h for the convenience of users. Also: Adds #ifndef/#endif conditions arround ACPI_GLOBAL and ACPI_INIT_GLOBAL definition so that OSPMs might be able to: 1. Redefine ACPI_GLOBAL/ACPI_INIT_GLOBAL into no-op, and 2. Redefine external global variables into immediates to implement stubs for them. Lv Zheng. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-04-20ACPICA: Update version to 20140325.Bob Moore
Version 20140325. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-04-20ACPICA: Tables: Add acpi_install_table() API for early table installation.Lv Zheng
This patch adds a new API - acpi_install_table(). OSPMs can use this API to install tables during early boot stage. Lv Zheng. References: https://lkml.org/lkml/2014/2/28/372 Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> [rjw: Subject] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-04-20ACPICA: Tables: Avoid SSDT installation with acpi_gbl_disable_ssdt_table_load.Lv Zheng
It is reported that when acpi_gbl_disable_ssdt_table_load is specified, user still can see it installed into /sys/firmware/acpi/tables on Linux boxes. This is because the option only stops table "loading", but doesn't stop table "installing", thus it is still in the acpi_gbl_root_table_list. With previous cleanups, it is possible to prevent SSDT installations to make it not such confusing. The global variable is also renamed. Lv Zheng. Signed-off-by: Lv Zheng <lv.zheng@intel.com> [rjw: Subject] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-04-01Merge branch 'acpica'Rafael J. Wysocki
* acpica: ACPICA: Enable auto-serialization as a default kernel behavior. ACPICA: Ignore sync_level for methods that have been auto-serialized. ACPICA: Add additional named objects for the auto-serialize method scan. ACPICA: Add auto-serialization support for ill-behaved control methods. ACPICA: Remove global option to serialize all control methods.
2014-03-26ACPICA: Add auto-serialization support for ill-behaved control methods.Bob Moore
This change adds support to automatically mark a control method as "serialized" if the method creates any named objects. This will positively prevent the method from being entered by more than one thread and thus preventing a possible abort when an attempt is made to create an object twice. Implemented by parsing all non-serialize control methods at table load time. This feature is disabled by default and this patch also adds a new Linux kernel parameter "acpi_auto_serialize" to allow this feature to be turned on for a specific boot. References: https://bugzilla.kernel.org/show_bug.cgi?id=52191 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-03-26ACPICA: Remove global option to serialize all control methods.Lv Zheng
According to the reports, the "acpi_serialize" mechanism is broken as: A. The parallel method calls can still happen when the interpreter lock is released under the following conditions: 1. External callbacks are invoked, for example, by the region handlers, the exception handlers, etc.; 2. Module level execution is performed when Load/LoadTable opcodes are executed, and 3. The _REG control methods are invoked to complete the region registrations. B. For the following situations, the interpreter lock need to be released even for a serialized method while currently, the lock-releasing operation is marked as a no-op by acpi_ex_relinquish/reacquire_interpreter() when this mechanism is enabled: 1. Wait opcode is executed, 2. Acquire opcode is executed, and 3. Sleep opcode is executed. This patch removes this mechanism and the internal acpi_ex_relinquish/reacquire_interpreter() APIs. Lv Zheng. References: https://bugzilla.kernel.org/show_bug.cgi?id=52191 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-03-20Merge branch 'acpica'Rafael J. Wysocki
* acpica: (29 commits) ACPICA: Revert "Headers: Deploy #pragma pack (push) and (pop)." ACPICA: Update version to 20140214. ACPICA: Prevent infinite loops when traversing corrupted lists. ACPICA: Debugger: Add missing objects; Traverse linked lists ACPICA: Add text: ACPICA policy for new _OSI strings. No functional change. ACPICA: Update for _PRP predefined name. ACPICA: Cleanup/improve global variable declarations. ACPICA: Comment update - no functional change. ACPICA: Do not abort _PRT repair on a single subpackage failure. ACPICA: Harden _PRT repair code; check for minimum package length. ACPICA: Restore code that repairs NULL package elements in return values. ACPICA: Properly handle NULL entries in _PRT return packages. ACPICA: Update conditional compilation flags for resource dump functions. ACPICA: Predefined names: Add support for the _PRP method. ACPICA: Headers: Deploy #pragma pack (push) and (pop). ACPICA: Add boot option to disable auto return object repair ACPICA: acpidump: Remove integer types translation protection. ACPICA: acpidump: Add sparse declarators support. ACPICA: Add "Windows 2013" string to _OSI support. ACPICA: Update version to 20140114. ...
2014-03-18ACPICA: Revert "Headers: Deploy #pragma pack (push) and (pop)."Robert Moore
This reverts commit aae576e5faefa8ba70647efa320d4747b6375f1e. Push and Pop are not portable "enough", and caused problems for some ACPICA customers. Signed-off-by: Robert Moore <Robert.Moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-03-18ACPICA: Update version to 20140214.Bob Moore
Version 20140214. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-27ACPICA: Headers: Deploy #pragma pack (push) and (pop).Bob Moore
Use push and pop to both guarantee that the correct alignment is used, and to restore the alignment to whatever it was before the header was included. It is reported that the #pragma pack(push/pop) directives are not supported by the specific GCCs, but this patch still doesn't affect kernel build as there are already #pragma pack([1]) directives used in the old ACPICA headers, which means there shouldn't be GCCs that are currently used to compile the ACPI kernels do not support #pragma pack() directives. References: https://bugs.acpica.org/show_bug.cgi?id=1058 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-11ACPICA: Update version to 20140114.Bob Moore
Version 20140114. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
