path: root/include/acpi/acpi.h
2014-05-27ACPICA: Linux headers: Add <acpi/platform/aclinuxex.h>Lv Zheng
From ACPICA's perspective, <acpi/actypes.h> should be included after inclusion of <acpi/platform/acenv.h>. But currently in Linux, <acpi/platform/aclinux.h> included by <acpi/platform/acenv.h> has included <acpi/actypes.h> to find ACPICA types for inline functions. This causes the following problem: 1. Redundant code in <asm/acpi.h> and <acpi/platform/aclinux.h>: Linux must be careful to keep conditions for <acpi/actypes.h> inclusion consistent with the conditions for <acpi/platform/aclinux.h> inclusion. Which finally leads to the issue that we have to keep many useless macro definitions in <acpi/platform/aclinux.h> or <asm/acpi.h>. Such conditions include: COMPILER_DEPENDENT_UINT64 COMPILER_DEPENDENT_INT64 ACPI_INLINE ACPI_SYSTEM_XFACE ACPI_EXTERNAL_XFACE ACPI_INTERNAL_XFACE ACPI_INTERNAL_VAR_XFACE ACPI_MUTEX_TYPE DEBUGGER_THREADING ACPI_ACQUIRE_GLOBAL_LOCK ACPI_RELEASE_GLOBAL_LOCK ACPI_FLUSH_CPU_CACHE They have default implementations in <include/acpi/platform/acenv.h> while Linux need to keep a copy in <asm/acpi.h> to avoid build errors. This patch introduces <acpi/platform/aclinuxex.h> to fix this issue by splitting conditions and declarations (most of them are inline functions) into 2 header files so that the wrong inclusion of <acpi/actypes.h> can be removed from <acpi/platform/aclinux.h>. This patch also removes old ACPI_NATIVE_INTERFACE_HEADER mechanism which is not preferred by Linux and adds the platform/acenvex.h to be the solution to solve this issue. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-11ACPICA: Add support for extra, optional OS-specific header file.Lv Zheng
If OSPMs have something should appear after actypes.h to reference type definitions, the platform/acxxx.h is not sufficient as it is included by platform/acenv.h before including actypes.h. This patch introduces an OSPMs declarable headers to allow OSPMs to handle such requirement for their own purposes. This kind of header can also be used by Linux to collect the divergences that haven't been back ported yet. Lv Zheng. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-11ACPICA: Update ACPICA copyrights to 2014.Bob Moore
Update ACPICA copyrights to 2014. Includes all source headers and signons for the various tools. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-25ACPICA: Update ACPICA copyrights to 2013Bob Moore
2012-10-02UAPI: (Scripted) Convert #include "..." to #include <path/...> in kernel ↵David Howells
system headers Convert #include "..." to #include <path/...> in kernel system headers. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-07-17ACPICA: Update header files copyrights to 2012Bob Moore
Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-18ACPICA: Update all ACPICA copyrights and signons to 2011Bob Moore
2010-01-22ACPICA: Update all ACPICA copyrights and signons to 2010Bob Moore
Add 2010 copyright to all module headers and signons, including the Linux header. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and all utilities. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-31ACPICA: Restructure includes into public/privateBob Moore
acpi.h now includes only the "public" acpica headers. All other acpica headers are "private" and should not be included by acpica users. One new file, accommon.h is used to include the commonly used private headers for acpica code generation. Future plans are to move all private headers to a new subdirectory. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-23ACPICA: update Intel copyrightLen Brown
2007-02-02ACPICA: Update copyright to 2007.Bob Moore
Added 2007 copyright to all module headers and signons. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and the utilities. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-20[ACPI] ACPICA 20060113Bob Moore
Added 2006 copyright. At SuSE's suggestion, enabled all error messages without enabling function tracing, ie with CONFIG_ACPI_DEBUG=n Replaced all instances of the ACPI_DEBUG_PRINT macro invoked at the ACPI_DB_ERROR and ACPI_DB_WARN debug levels with the ACPI_REPORT_ERROR and ACPI_REPORT_WARNING macros, respectively. This preserves all error and warning messages in the non-debug version of the ACPICA code (this has been referred to as the "debug lite" option.) Over 200 cases were converted to create a total of over 380 error/warning messages across the ACPICA code. This increases the code and data size of the default non-debug version by about 13K. Added ACPI_NO_ERROR_MESSAGES flag to enable deleting all messages. The size of the debug version remains about the same. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
2005-07-12ACPICA 20050408 from Bob MooreRobert Moore
Fixed three cases in the interpreter where an "index" argument to an ASL function was still (internally) 32 bits instead of the required 64 bits. This was the Index argument to the Index, Mid, and Match operators. The "strupr" function is now permanently local (acpi_ut_strupr), since this is not a POSIX-defined function and not present in most kernel-level C libraries. References to the C library strupr function have been removed from the headers. Completed the deployment of static functions/prototypes. All prototypes with the static attribute have been moved from the headers to the owning C file. ACPICA 20050329 from Bob Moore An error is now generated if an attempt is made to create a Buffer Field of length zero (A CreateField with a length operand of zero.) The interpreter now issues a warning whenever executable code at the module level is detected during ACPI table load. This will give some idea of the prevalence of this type of code. Implemented support for references to named objects (other than control methods) within package objects. Enhanced package object output for the debug object. Package objects are now completely dumped, showing all elements. Enhanced miscellaneous object output for the debug object. Any object can now be written to the debug object (for example, a device object can be written, and the type of the object will be displayed.) The "static" qualifier has been added to all local functions across the core subsystem. The number of "long" lines (> 80 chars) within the source has been significantly reduced, by about 1/3. Cleaned up all header files to ensure that all CA/iASL functions are prototyped (even static functions) and the formatting is consistent. Two new header files have been added, acopcode.h and acnames.h. Removed several obsolete functions that were no longer used. Signed-off-by: Len Brown <len.brown@intel.com>
