Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
Pull x86/efi changes from Peter Anvin:
"The bulk of these changes are cleaning up the efivars handling and
breaking it up into a tree of files. There are a number of fixes as
well.
The entire changeset is pretty big, but most of it is code movement.
Several of these commits are quite new; the history got very messed up
due to a mismerge with the urgent changes for rc8 which completely
broke IA64, and so Ingo requested that we rebase it to straighten it
out."
* 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
efi: remove "kfree(NULL)"
efi: locking fix in efivar_entry_set_safe()
efi, pstore: Read data from variable store before memcpy()
efi, pstore: Remove entry from list when erasing
efi, pstore: Initialise 'entry' before iterating
efi: split efisubsystem from efivars
efivarfs: Move to fs/efivarfs
efivars: Move pstore code into the new EFI directory
efivars: efivar_entry API
efivars: Keep a private global pointer to efivars
efi: move utf16 string functions to efi.h
x86, efi: Make efi_memblock_x86_reserve_range more readable
efivarfs: convert to use simple_open()
Move non-public declarations and definitions from linux/proc_fs.h to
fs/proc/internal.h.
Make the PROC_I() and PDE() macros internal to procfs. This means making
PDE_DATA() out of line. This could be made more optimal by storing
PDE()->data into inode->i_private.
Also provide a __PDE_DATA() that is inline and internal to procfs.
Supply a function (proc_remove()) to remove a proc entry (and any subtree
rooted there) by proc_dir_entry pointer rather than by name and (optionally)
root dir entry pointer. This allows us to eliminate all remaining pde->name
accesses outside of procfs.
Acked-by: Grant Likely <grant.likely@linaro.or>
cc: linux-acpi@vger.kernel.org
cc: openipmi-developer@lists.sourceforge.net
cc: devicetree-discuss@lists.ozlabs.org
cc: linux-pci@vger.kernel.org
cc: netdev@vger.kernel.org
cc: netfilter-devel@vger.kernel.org
cc: alsa-devel@alsa-project.org
Don't access the proc_dir_entry in ReiserFS's r_open(), r_start() r_show()
procfs interface functions.
ReiserFS stores the ->show() method pointer in PDE->data and the super_block
pointer in PDE->parent->data. This isn't changing.
Currently, ReiserFS passes the PDE pointer into seq_file::private from
r_open() so that r_start() and r_show() can then access it. Instead, use
seq_open_private() to allocate a two-pointer struct that's passed through
seq_file::private and put the ->show() method and the sb pointers in there.
cc: reiserfs-devel@vger.kernel.org
Supply an accessor function for getting the private data from the parent
proc_dir_entry struct of the proc_dir_entry struct associated with an inode.
ReiserFS, for instance, stores the super_block pointer in the proc directory
it makes for that super_block, and a pointer to the respective seq_file show
function in each of the proc files in that directory.
This allows a reduction in the number of file_operations structs, open
functions and seq_operations structs required. The problem otherwise is that
each show function requires two pieces of data but only has storage for one
per PDE (and this has no release function).
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
cc: Jerry Chuang <jerry-chuang@realtek.com>
cc: Maxim Mikityanskiy <maxtram95@gmail.com>
cc: YAMANE Toshiaki <yamanetoshi@gmail.com>
cc: linux-wireless@vger.kernel.org
cc: linux-scsi@vger.kernel.org
cc: devel@driverdev.osuosl.org
Add proc_mkdir_data() to allow procfs directories to be created that are
annotated at the time of creation with private data rather than doing this
post-creation. This means no access is then required to the proc_dir_entry
struct to set this.
cc: Neela Syam Kolli <megaraidlinux@lsi.com>
Move some bits from linux/proc_fs.h to linux/of.h, signal.h and tty.h.
Also move proc_tty_init() and proc_device_tree_init() to fs/proc/internal.h as
they're internal to procfs.
cc: linux-arch@vger.kernel.org
cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
cc: Jri Slaby <jslaby@suse.cz>
Move PDE_NET() to fs/proc/proc_net.c as that's where the only user is.
Split the proc namespace stuff out into linux/proc_ns.h.
cc: Serge E. Hallyn <serge.hallyn@ubuntu.com>
cc: Eric W. Biederman <ebiederm@xmission.com>
Move proc_fd() to fs/proc/fd.h.
Uninline pid_delete_dentry() as it's only used by three function pointers.
Supply accessor functions to set attributes in proc_dir_entry structs.
The following are supplied: proc_set_size() and proc_set_user().
cc: linuxppc-dev@lists.ozlabs.org
cc: linux-media@vger.kernel.org
Pull networking updates from David Miller:
"Highlights (1721 non-merge commits, this has to be a record of some
sort):
1) Add 'random' mode to team driver, from Jiri Pirko and Eric
Dumazet.
2) Make it so that any driver that supports configuration of multiple
MAC addresses can provide the forwarding database add and del
calls by providing a default implementation and hooking that up if
the driver doesn't have an explicit set of handlers. From Vlad
Yasevich.
3) Support GSO segmentation over tunnels and other encapsulating
devices such as VXLAN, from Pravin B Shelar.
4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton.
5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita
Dukkipati.
6) In the PHY layer, allow supporting wake-on-lan in situations where
the PHY registers have to be written for it to be configured.
Use it to support wake-on-lan in mv643xx_eth.
From Michael Stapelberg.
7) Significantly improve firewire IPV6 support, from YOSHIFUJI
Hideaki.
8) Allow multiple packets to be sent in a single transmission using
network coding in batman-adv, from Martin Hundebøll.
9) Add support for T5 cxgb4 chips, from Santosh Rastapur.
10) Generalize the VXLAN forwarding tables so that there is more
flexibility in configurating various aspects of the endpoints.
From David Stevens.
11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver,
from Dmitry Kravkov.
12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo
Neira Ayuso.
13) Start adding networking selftests.
14) In situations of overload on the same AF_PACKET fanout socket, or
per-cpu packet receive queue, minimize drop by distributing the
load to other cpus/fanouts. From Willem de Bruijn and Eric
Dumazet.
15) Add support for new payload offset BPF instruction, from Daniel
Borkmann.
16) Convert several drivers over to mdoule_platform_driver(), from
Sachin Kamat.
17) Provide a minimal BPF JIT image disassembler userspace tool, from
Daniel Borkmann.
18) Rewrite F-RTO implementation in TCP to match the final
specification of it in RFC4138 and RFC5682. From Yuchung Cheng.
19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear
you like netlink, so I implemented netlink dumping of netlink
sockets.") From Andrey Vagin.
20) Remove ugly passing of rtnetlink attributes into rtnl_doit
functions, from Thomas Graf.
21) Allow userspace to be able to see if a configuration change occurs
in the middle of an address or device list dump, from Nicolas
Dichtel.
22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes
Frederic Sowa.
23) Increase accuracy of packet length used by packet scheduler, from
Jason Wang.
24) Beginning set of changes to make ipv4/ipv6 fragment handling more
scalable and less susceptible to overload and locking contention,
from Jesper Dangaard Brouer.
25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*()
instead. From Hong Zhiguo.
26) Optimize route usage in IPVS by avoiding reference counting where
possible, from Julian Anastasov.
27) Convert IPVS schedulers to RCU, also from Julian Anastasov.
28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger
Eitzenberger.
29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG,
nfnetlink_log, and nfnetlink_queue. From Gao feng.
30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa.
31) Support several new r8169 chips, from Hayes Wang.
32) Support tokenized interface identifiers in ipv6, from Daniel
Borkmann.
33) Use usbnet_link_change() helper in USB net driver, from Ming Lei.
34) Add 802.1ad vlan offload support, from Patrick McHardy.
35) Support mmap() based netlink communication, also from Patrick
McHardy.
36) Support HW timestamping in mlx4 driver, from Amir Vadai.
37) Rationalize AF_PACKET packet timestamping when transmitting, from
Willem de Bruijn and Daniel Borkmann.
38) Bring parity to what's provided by /proc/net/packet socket dumping
and the info provided by netlink socket dumping of AF_PACKET
sockets. From Nicolas Dichtel.
39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin
Poirier"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
filter: fix va_list build error
af_unix: fix a fatal race with bit fields
bnx2x: Prevent memory leak when cnic is absent
bnx2x: correct reading of speed capabilities
net: sctp: attribute printl with __printf for gcc fmt checks
netlink: kconfig: move mmap i/o into netlink kconfig
netpoll: convert mutex into a semaphore
netlink: Fix skb ref counting.
net_sched: act_ipt forward compat with xtables
mlx4_en: fix a build error on 32bit arches
Revert "bnx2x: allow nvram test to run when device is down"
bridge: avoid OOPS if root port not found
drivers: net: cpsw: fix kernel warn on cpsw irq enable
sh_eth: use random MAC address if no valid one supplied
3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA)
tg3: fix to append hardware time stamping flags
unix/stream: fix peeking with an offset larger than data in queue
unix/dgram: fix peeking with an offset larger than data in queue
unix/dgram: peek beyond 0-sized skbs
openvswitch: Remove unneeded ovs_netdev_get_ifindex()
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"Mostly performance and bug fixes, plus some cleanups. The one new
feature this merge window is a new ioctl EXT4_IOC_SWAP_BOOT which
allows installation of a hidden inode designed for boot loaders."
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (50 commits)
ext4: fix type-widening bug in inode table readahead code
ext4: add check for inodes_count overflow in new resize ioctl
ext4: fix Kconfig documentation for CONFIG_EXT4_DEBUG
ext4: fix online resizing for ext3-compat file systems
jbd2: trace when lock_buffer in do_get_write_access takes a long time
ext4: mark metadata blocks using bh flags
buffer: add BH_Prio and BH_Meta flags
ext4: mark all metadata I/O with REQ_META
ext4: fix readdir error in case inline_data+^dir_index.
ext4: fix readdir error in the case of inline_data+dir_index
jbd2: use kmem_cache_zalloc instead of kmem_cache_alloc/memset
ext4: mext_insert_extents should update extent block checksum
ext4: move quota initialization out of inode allocation transaction
ext4: reserve xattr index for Rich ACL support
jbd2: reduce journal_head size
ext4: clear buffer_uninit flag when submitting IO
ext4: use io_end for multiple bios
ext4: make ext4_bio_write_page() use BH_Async_Write flags
ext4: Use kstrtoul() instead of parse_strtoul()
ext4: defragmentation code cleanup
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull compat cleanup from Al Viro:
"Mostly about syscall wrappers this time; there will be another pile
with patches in the same general area from various people, but I'd
rather push those after both that and vfs.git pile are in."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
syscalls.h: slightly reduce the jungles of macros
get rid of union semop in sys_semctl(2) arguments
make do_mremap() static
sparc: no need to sign-extend in sync_file_range() wrapper
ppc compat wrappers for add_key(2) and request_key(2) are pointless
x86: trim sys_ia32.h
x86: sys32_kill and sys32_mprotect are pointless
get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC
merge compat sys_ipc instances
consolidate compat lookup_dcookie()
convert vmsplice to COMPAT_SYSCALL_DEFINE
switch getrusage() to COMPAT_SYSCALL_DEFINE
switch epoll_pwait to COMPAT_SYSCALL_DEFINE
convert sendfile{,64} to COMPAT_SYSCALL_DEFINE
switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE
make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect
make HAVE_SYSCALL_WRAPPERS unconditional
consolidate cond_syscall and SYSCALL_ALIAS declarations
teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long
get rid of duplicate logics in __SC_....[1-6] definitions
Merge third batch of fixes from Andrew Morton:
"Most of the rest. I still have two large patchsets against AIO and
IPC, but they're a bit stuck behind other trees and I'm about to
vanish for six days.
- random fixlets
- inotify
- more of the MM queue
- show_stack() cleanups
- DMI update
- kthread/workqueue things
- compat cleanups
- epoll udpates
- binfmt updates
- nilfs2
- hfs
- hfsplus
- ptrace
- kmod
- coredump
- kexec
- rbtree
- pids
- pidns
- pps
- semaphore tweaks
- some w1 patches
- relay updates
- core Kconfig changes
- sysrq tweaks"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (109 commits)
Documentation/sysrq: fix inconstistent help message of sysrq key
ethernet/emac/sysrq: fix inconstistent help message of sysrq key
sparc/sysrq: fix inconstistent help message of sysrq key
powerpc/xmon/sysrq: fix inconstistent help message of sysrq key
ARM/etm/sysrq: fix inconstistent help message of sysrq key
power/sysrq: fix inconstistent help message of sysrq key
kgdb/sysrq: fix inconstistent help message of sysrq key
lib/decompress.c: fix initconst
notifier-error-inject: fix module names in Kconfig
kernel/sys.c: make prctl(PR_SET_MM) generally available
UAPI: remove empty Kbuild files
menuconfig: print more info for symbol without prompts
init/Kconfig: re-order CONFIG_EXPERT options to fix menuconfig display
kconfig menu: move Virtualization drivers near other virtualization options
Kconfig: consolidate CONFIG_DEBUG_STRICT_USER_COPY_CHECKS
relay: use macro PAGE_ALIGN instead of FIX_SIZE
kernel/relay.c: move FIX_SIZE macro into relay.c
kernel/relay.c: remove unused function argument actor
drivers/w1/slaves/w1_ds2760.c: fix the error handling in w1_ds2760_add_slave()
drivers/w1/slaves/w1_ds2781.c: fix the error handling in w1_ds2781_add_slave()
threadgroup_lock() takes signal->cred_guard_mutex to ensure that
thread_group_leader() is stable. This doesn't look nice, the scope of
this lock in do_execve() is huge.
And as Dave pointed out this can lead to deadlock, we have the
following dependencies:
do_execve: cred_guard_mutex -> i_mutex
cgroup_mount: i_mutex -> cgroup_mutex
attach_task_by_pid: cgroup_mutex -> cred_guard_mutex
Change de_thread() to take threadgroup_change_begin() around the
switch-the-leader code and change threadgroup_lock() to avoid
->cred_guard_mutex.
Note that de_thread() can't sleep with ->group_rwsem held, this can
obviously deadlock with the exiting leader if the writer is active, so it
does threadgroup_change_end() before schedule().
Reported-by: Dave Jones <davej@redhat.com>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Li Zefan <lizefan@huawei.com>
Cc: <stable@vger.kernel.org>
set_task_comm() does memset() + wmb() before strlcpy(). This buys
nothing and to add to the confusion, the comment is wrong.
- We do not need memset() to be "safe from non-terminating string
reads", the final char is always zero and we never change it.
- wmb() is paired with nothing, it cannot prevent from printing
the mixture of the old/new data unless the reader takes the lock.
Cc: John Stultz <johnstul@us.ibm.com>
Currently, a write to a procfs file will return the number of bytes
successfully written. If the actual string is longer than this, the
remainder of the string will not be be written and userspace will
complete the operation by issuing additional write()s.
Hence
$ echo -n "abcdefghijklmnopqrs" > /proc/self/comm
results in
$ cat /proc/$$/comm
pqrs
since the final four bytes were written with a second write() since
TASK_COMM_LEN == 16. This is obviously an undesired result and not
equivalent to prctl(PR_SET_NAME). The implementation should not need to
know the definition of TASK_COMM_LEN.
This patch truncates the string to the first TASK_COMM_LEN bytes and
returns the bytes written as the length of the string written so the
second write() is suppressed.
$ cat /proc/$$/comm
abcdefghijklmno
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: John Stultz <john.stultz@linaro.org>
wait_for_dump_helpers() calls wake_up/kill_fasync from inside the
wait_event-like loop. This is not needed and in fact this is not
strictly correct, we can/should do this only once after we change
pipe->writers. We could even check if it becomes zero.
Change this code to use use wait_event_interruptible(), this can also
help to make this wait freezable.
With this patch we check pipe->readers without pipe_lock(), this is
fine. Once we see pipe->readers == 1 we know that the handler
decremented the counter, this is all we need.
Acked-by: Mandeep Singh Baines <msb@chromium.org>
Cc: Neil Horman <nhorman@redhat.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Tejun Heo <tj@kernel.org>
Cleanup. Every linux_binfmt->core_dump() sets PF_DUMPCORE, move this into
zap_threads() called by do_coredump().
By discussion with Mandeep.
Change dump_write(), dump_seek() and do_coredump() to check
signal_pending() and abort if it is true. dump_seek() does this only
before f_op->llseek(), otherwise it relies on dump_write().
We need this change to ensure that the coredump won't delay suspend, and
to ensure it reacts to SIGKILL "quickly enough", a core dump can take a
lot of time. In particular this can help oom-killer.
We add the new trivial helper, dump_interrupted() to add the comments and
to simplify the potential freezer changes. Perhaps it will have more
callers.
Ideally it should do try_to_freeze() but then we need the unpleasant
changes in dump_write() and wait_for_dump_helpers(). It is not trivial to
change dump_write() to restart if f_op->write() fails because of
freezing(). We need to handle the short writes, we need to clear
TIF_SIGPENDING (and we can't rely on recalc_sigpending() unless we change
it to check PF_DUMPCORE). And if the buggy f_op->write() sets
TIF_SIGPENDING we can not distinguish this case from the race with
freeze_task() + __thaw_task().
So we simply accept the fact that the freezer can truncate a core-dump but
at least you can reliably suspend. Hopefully we can tolerate this
unlikely case and the necessary complications doesn't worth a trouble.
But if we decide to make the coredumping freezable later we can do this on
top of this change.
Now that the coredumping process can be SIGKILL'ed, the setting of
->group_exit_code in do_coredump() can race with complete_signal() and
SIGKILL or 0x80 can be "lost", or wait(status) can report status ==
SIGKILL | 0x80.
But the main problem is that it is not clear to me what should we do if
binfmt->core_dump() succeeds but SIGKILL was sent, that is why this patch
comes as a separate change.
This patch adds 0x80 if ->core_dump() succeeds and the process was not
killed. But perhaps we can (should?) re-set ->group_exit_code changed by
SIGKILL back to "siginfo->si_signo |= 0x80" in case when core_dumped == T.
Tested-by: Mandeep Singh Baines <msb@chromium.org>
Cc: Roland McGrath <roland@hack.frob.com>
prepare_signal() blesses SIGKILL sent to the dumping process but this
signal can be "lost" anyway. The problems is, complete_signal() sees
SIGNAL_GROUP_EXIT and skips the "kill them all" logic. And even if the
dumping process is single-threaded (so the target is always "correct"),
the group-wide SIGKILL is not recorded in task->pending and thus
__fatal_signal_pending() won't be true. A multi-threaded case has even
more problems.
And even ignoring all technical details, SIGNAL_GROUP_EXIT doesn't look
right to me. This coredumping process is not exiting yet, it can do a lot
of work dumping the core.
With this patch the dumping process doesn't have SIGNAL_GROUP_EXIT, we set
signal->group_exit_task instead. This makes signal_group_exit() true and
thus this should equally close the races with exit/exec/stop but allows to
kill the dumping thread reliably.
Notes:
- It is not clear what should we do with ->group_exit_code
if the dumper was killed, see the next change.
- we need more (hopefully straightforward) changes to ensure
that SIGKILL actually interrupts the coredump. Basically we
need to check __fatal_signal_pending() in dump_write() and
dump_seek().
There are 2 well known and ancient problems with coredump/signals, and a
lot of related bug reports:
- do_coredump() clears TIF_SIGPENDING but of course this can't help
if, say, SIGCHLD comes after that.
In this case the coredump can fail unexpectedly. See for example
wait_for_dump_helper()->signal_pending() check but there are other
reasons.
- At the same time, dumping a huge core on the slow media can take a
lot of time/resources and there is no way to kill the coredumping
task reliably. In particular this is not oom_kill-friendly.
This patch tries to fix the 1st problem, and makes the preparation for the
next changes.
We add the new SIGNAL_GROUP_COREDUMP flag set by zap_threads() to indicate
that this process dumps the core. prepare_signal() checks this flag and
nacks any signal except SIGKILL.
Note that this check tries to be conservative, in the long term we should
probably treat the SIGNAL_GROUP_EXIT case equally but this needs more
discussion. See marc.info/?l=linux-kernel&m=120508897917439
Notes:
- recalc_sigpending() doesn't check SIGNAL_GROUP_COREDUMP.
The patch assumes that dump_write/etc paths should never
call it, but we can change it as well.
- There is another source of TIF_SIGPENDING, freezer. This
will be addressed separately.
These are the only users of call_usermodehelper_fns(). This function
suffers from not being able to determine if the cleanup is called. Even
if in this places the cleanup pointer is NULL, convert them to use the
separate call_usermodehelper_setup() + call_usermodehelper_exec()
functions so we can remove the _fns variant.
Cc: James Morris <james.l.morris@oracle.com>
Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Cc: Hin-Tak Leung <htl10@users.sourceforge.net>
__hfsplus_ext_write_extent() suppresses errors coming from
hfs_brec_find(). The patch implements error code propagation.
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Reviewed-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Use a more current logging style.
Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
hfsplus now uses "hfsplus: " for all messages.
Coalesce formats.
Prefix debugging messages too.
Cc: Vyacheslav Dubeyko <slava@dubeyko.com>
Rename macro and uses.
Add do {} while (0) to macro.
Add DBG_ to macro.
Add and use hfs_dbg_cont variant where appropriate.
fs/hfsplus/bfind.c: In function 'hfs_find_1st_rec_by_cnid':
(1) include/uapi/linux/swab.h:60:2: warning: 'search_cnid' may be used uninitialized in this function [-Wmaybe-uninitialized]
(2) include/uapi/linux/swab.h:60:2: warning: 'cur_cnid' may be used uninitialized in this function [-Wmaybe-uninitialized]
[akpm@linux-foundation.org: make the workaround more explicit]
hfs_find_init() may fail with ENOMEM, but there are places, where the
returned value is not checked. The consequences can be very unpleasant,
e.g. kfree uninitialized pointer and inappropriate mutex unlocking.
The patch adds checks for errors in hfs_find_init().
Found by Linux Driver Verification project (linuxtesting.org).
page->mapping->host cannot be NULL in nilfs_writepage(), so remove the
unneeded test.
The fixes the smatch warning: "fs/nilfs2/inode.c:211 nilfs_writepage()
error: we previously assumed 'inode' could be null (see line 195)".
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Change test_bit(PG_locked, &page->flags) to PageLocked().
of driver's internal error or metadata corruption
The NILFS2 driver remounts itself in RO mode in the case of discovering
metadata corruption (for example, discovering a broken bmap). But
usually, this takes place when there have been file system operations
before remounting in RO mode.
Thereby, NILFS2 driver can be in RO mode with presence of dirty pages in
modified inodes' address spaces. It results in flush kernel thread's
infinite trying to flush dirty pages in RO mode. As a result, it is
possible to see such side effects as: (1) flush kernel thread occupies
50% - 99% of CPU time; (2) system can't be shutdowned without manual
power switch off.
SYMPTOMS:
(1) System log contains error message: "Remounting filesystem read-only".
(2) The flush kernel thread occupies 50% - 99% of CPU time.
(3) The system can't be shutdowned without manual power switch off.
REPRODUCTION PATH:
(1) Create volume group with name "unencrypted" by means of vgcreate utility.
(2) Run script (prepared by Anthony Doggett <Anthony2486@interfaces.org.uk>):
----------------[BEGIN SCRIPT]--------------------
#!/bin/bash
VG=unencrypted
#apt-get install nilfs-tools darcs
lvcreate --size 2G --name ntest $VG
mkfs.nilfs2 -b 1024 -B 8192 /dev/mapper/$VG-ntest
mkdir /var/tmp/n
mkdir /var/tmp/n/ntest
mount /dev/mapper/$VG-ntest /var/tmp/n/ntest
mkdir /var/tmp/n/ntest/thedir
cd /var/tmp/n/ntest/thedir
sleep 2
date
darcs init
sleep 2
dmesg|tail -n 5
date
darcs whatsnew || true
date
sleep 2
dmesg|tail -n 5
----------------[END SCRIPT]--------------------
(3) Try to shutdown the system.
REPRODUCIBILITY: 100%
FIX:
This patch implements checking mount state of NILFS2 driver in
nilfs_writepage(), nilfs_writepages() and nilfs_mdt_write_page()
methods. If it is detected the RO mount state then all dirty pages are
simply discarded with warning messages is written in system log.
[akpm@linux-foundation.org: fix printk warning]
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Cc: Anthony Doggett <Anthony2486@interfaces.org.uk>
Cc: ARAI Shun-ichi <hermes@ceres.dti.ne.jp>
Cc: Piotr Szymaniak <szarpaj@grubelek.pl>
Cc: Zahid Chowdhury <zahid.chowdhury@starsolutions.com>
Cc: Elmer Zhang <freeboy6716@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
The comment I originally added in commit a3defbe5c337 ("binfmt_elf: fix
PIE execution with randomization disabled") is not really 100% accurate
-- sysctl is not the only way how PF_RANDOMIZE could be forcibly unset
in runtime.
Another option of course is direct modification of personality flags
(i.e. running through setarch wrapper).
Make the comment more explicit and accurate.
Add a new configuration option CONFIG_BINFMT_SCRIPT to configure support
for interpreted scripts starting with "#!"; allow compiling out that
support, or building it as a module. Embedded systems running exclusively
compiled binaries could leave this support out, and systems that don't
need scripts before mounting the root filesystem can build this as a
module.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
It is always safe to use RCU_INIT_POINTER to NULL a pointer. This results
in slightly smaller/faster code.
Signed-off-by: Eric Wong <normalperson@yhbt.net>
This reduces the amount of code inside the ready list iteration loops for
better readability IMHO.
Cc: Davide Libenzi <davidel@xmailserver.org>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Technically we do not need to hold ep->mtx during ep_free since we are
certain there are no other users of ep at that point. However, lockdep
complains with a "suspicious rcu_dereference_check() usage!" message; so
lock the mutex before ep_remove to silence the warning.
Cc: Arve Hjønnevåg <arve@android.com>
Cc: NeilBrown <neilb@suse.de>,
Cc: Rafael J. Wysocki <rjw@sisk.pl>
This prevents wakeup_source destruction when a user hits the item with
EPOLL_CTL_MOD while ep_poll_callback is running.
Tested with CONFIG_SPARSE_RCU_POINTER=y and "make fs/eventpoll.o C=2"
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
It is common for epoll users to have thousands of epitems, so saving a
cache line on every allocation leads to large memory savings.
Since epitem allocations are cache-aligned, reducing sizeof(struct
epitem) from 136 bytes to 128 bytes will allow it to squeeze under a
cache line boundary on x86_64.
Via /sys/kernel/slab/eventpoll_epi, I see the following changes on my
x86_64 Core2 Duo (which has 64-byte cache alignment):
object_size : 192 => 128
objs_per_slab: 21 => 32
Also, add a BUILD_BUG_ON() to check for future accidental breakage.
[akpm@linux-foundation.org: use __packed, for all architectures]
There is string_unescape_inplace() function which decodes strings in generic
way. Let's use it.
Cc: linux-fsdevel@vger.kernel.org
Writeback has been recently converted to use workqueue instead of its
private thread pool implementation. One negative side effect of this
conversion is that there's no easy to tell which backing device a
writeback work item was working on at the time of task dump, be it
sysrq-t, BUG, WARN or whatever, which, according to our writeback
brethren, is important in tracking down issues with a lot of mounted
file systems on a lot of different devices.
This patch restores that information using the new worker description
facility. bdi_writeback_workfn() calls set_work_desc() to identify
which bdi it's working on. The description is printed out together with
the worqueue name and worker function as in the following example dump.
WARNING: at fs/fs-writeback.c:1015 bdi_writeback_workfn+0x2b4/0x3c0()
Modules linked in:
Pid: 28, comm: kworker/u18:0 Not tainted 3.9.0-rc1-work+ #24 empty empty/S3992
Workqueue: writeback bdi_writeback_workfn (flush-8:16)
ffffffff820a3a98 ffff88015b927cb8 ffffffff81c61855 ffff88015b927cf8
ffffffff8108f500 0000000000000000 ffff88007a171948 ffff88007a1716b0
ffff88015b49df00 ffff88015b8d3940 0000000000000000 ffff88015b927d08
Call Trace:
[<ffffffff81c61855>] dump_stack+0x19/0x1b
[<ffffffff8108f500>] warn_slowpath_common+0x70/0xa0
[<ffffffff8108f54a>] warn_slowpath_null+0x1a/0x20
[<ffffffff81200144>] bdi_writeback_workfn+0x2b4/0x3c0
[<ffffffff810b4c87>] process_one_work+0x1d7/0x660
[<ffffffff810b5c72>] worker_thread+0x122/0x380
[<ffffffff810bdfea>] kthread+0xea/0xf0
[<ffffffff81c6cedc>] ret_from_fork+0x7c/0xb0
Cc: Jan Kara <jack@suse.cz>
Call cond_resched() in shrink_dcache_parent() to maintain interactivity.
Before this patch:
void shrink_dcache_parent(struct dentry * parent)
while ((found = select_parent(parent, &dispose)) != 0)
shrink_dentry_list(&dispose);
select_parent() populates the dispose list with dentries which
shrink_dentry_list() then deletes. select_parent() carefully uses
need_resched() to avoid doing too much work at once. But neither
shrink_dcache_parent() nor its called functions call cond_resched(). So
once need_resched() is set select_parent() will return single dentry
dispose list which is then deleted by shrink_dentry_list(). This is
inefficient when there are a lot of dentry to process. This can cause
softlockup and hurts interactivity on non preemptable kernels.
This change adds cond_resched() in shrink_dcache_parent(). The benefit
of this is that need_resched() is quickly cleared so that future calls
to select_parent() are able to efficiently return a big batch of dentry.
These additional cond_resched() do not seem to impact performance, at
least for the workload below.
Here is a program which can cause soft lockup if other system activity
sets need_resched().
int main()
struct rlimit rlim;
int i;
int f[100000];
char buf[20];
struct timeval t1, t2;
double diff;
/* cleanup past run */
system("rm -rf x");
/* boost nfile rlimit */
rlim.rlim_cur = 200000;
rlim.rlim_max = 200000;
if (setrlimit(RLIMIT_NOFILE, &rlim))
err(1, "setrlimit");
/* make directory for files */
if (mkdir("x", 0700))
err(1, "mkdir");
if (gettimeofday(&t1, NULL))
err(1, "gettimeofday");
/* populate directory with open files */
for (i = 0; i < 100000; i++) {
snprintf(buf, sizeof(buf), "x/%d", i);
f[i] = open(buf, O_CREAT);
if (f[i] == -1)
err(1, "open");
/* close some of the files */
for (i = 0; i < 85000; i++)
close(f[i]);
/* unlink all files, even open ones */
system("rm -rf x");
if (gettimeofday(&t2, NULL))
diff = (((double)t2.tv_sec * 1000000 + t2.tv_usec) -
((double)t1.tv_sec * 1000000 + t1.tv_usec));
printf("done: %g elapsed\n", diff/1e6);
return 0;
Signed-off-by: Greg Thelen <gthelen@google.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
Cc: <stable@kernel.org>
