path: root/fs
2011-01-06NFS refactor nfs_find_client and reference client across callback processingAndy Adamson
Fixes a bug where the nfs_client could be freed during callback processing. Refactor nfs_find_client to use minorversion specific means to locate the correct nfs_client structure. In the NFS layer, V4.0 clients are found using the callback_ident field in the CB_COMPOUND header. V4.1 clients are found using the sessionID in the CB_SEQUENCE operation which is also compared against the sessionID associated with the back channel thread after a successful CREATE_SESSION. Each of these methods finds the one an only nfs_client associated with the incoming callback request - so nfs_find_client_next is not needed. In the RPC layer, the pg_authenticate call needs to find the nfs_client. For the v4.0 callback service, the callback identifier has not been decoded so a search by address, version, and minorversion is used. The sessionid for the sessions based callback service has (usually) not been set for the pg_authenticate on a CB_NULL call which can be sent prior to the return of a CREATE_SESSION call, so the sessionid associated with the back channel thread is not used to find the client in pg_authenticate for CB_NULL calls. Pass the referenced nfs_client to each CB_COMPOUND operation being proceesed via the new cb_process_state structure. The reference is held across cb_compound processing. Use the new cb_process_state struct to move the NFS4ERR_RETRY_UNCACHED_REP processing from process_op into nfs4_callback_sequence where it belongs. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06NFS associate sessionid with callback connectionAndy Adamson
The sessions based callback service is started prior to the CREATE_SESSION call so that it can handle CB_NULL requests which can be sent before the CREATE_SESSION call returns and the session ID is known. Set the callback sessionid after a sucessful CREATE_SESSION. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06NFS implement v4.0 callback_identAndy Adamson
Use the small id to pointer translator service to provide a unique callback identifier per SETCLIENTID call used to identify the v4.0 callback service associated with the clientid. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06NFS do not clear minor version at nfs_client freeAndy Adamson
Resetting the client minor version operations causes nfs4_destroy_callback to fail to shutdown the NFSv4.1 callback service. There is no reason to reset the client minorversion operations when the nfs_client struct is being freed. Remove the minorverion reset and rename the function. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06NFS use svc_create_xprt for NFSv4.1 callback serviceAndy Adamson
The new back channel transport means we call the normal creation routine as well as svc_xprt_put. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-04nfsv4: Switch to generic xattr handling codeAneesh Kumar K.V
This patch make nfsv4 use the generic xattr handling code to get the nfsv4 acl. This will help us to add richacl support to nfsv4 in later patches Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-04nfs: Set MS_POSIXACL alwaysAneesh Kumar K.V
We want to skip VFS applying mode for NFS. So set MS_POSIXACL always and selectively use umask. Ideally we would want to use umask only when we don't have inheritable ACEs set. But NFS currently don't allow to send umask to the server. So this is best what we can do and this is consistent with NFSv3 Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-04NFS: use ERR_CAST()Namhyung Kim
Use ERR_CAST() intead of wierd-looking cast. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-04nfs: fix mispelling of idmap CONFIG symbolJ. Bruce Fields
Trivial, but confusing when you're trying to grep through this code.... Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-04lockd: double unlock in next_host_state()Dan Carpenter
We unlock again after we goto out. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-04NFS: Don't leak in nfs_proc_symlink()Jesper Juhl
Hi, In fs/nfs/proc.c::nfs_proc_symlink() we will leak memory if either nfs_alloc_fhandle() or nfs_alloc_fattr() returns NULL but the other one doesn't. This patch ensures memory allocated by one when the other fails is always released (this is safe since nfs_free_fattr() and nfs_free_fhandle() both call kfree which deals gracefully with NULL pointers). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-21NFSv4: Convert a few commas into semicolons...Trond Myklebust
2010-12-21NFS: suppressing showing of default mount port value in /proc fixedStanislav Kinsbursky
Update: added check for zero value as it was before (note: can't simply check mountd_port for positive value because it's typeof unsigned short) Default value for mount server port is set to NFS_UNSPEC_PORT (-1) and will not be changed during parsing mount options for mound data version 6. This default value will be showed for mountport in /proc/mounts always since current default check is for zero value. This small mistake leads to big problem, because during umount.nfs execution from old user-space utils (at least nfs-utils 1.0.9) this value will be used as the server port to connect to. This request will be rejected (since port is 65535) and thus nfs mount point can't be unmounted. Note from Chuck Lever (chuck.lever@oracle.com): this is only possible if /etc/mtab is a link to /proc/mounts. Not all systems have this configuration. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-21nfs4: fix units bug causing hang on recoveryJ. Bruce Fields
Note that cl_lease_time is in jiffies. This can cause a very long wait in the NFS4ERR_CLID_INUSE case. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-21nfs: Take advantage of kmem_cache_zalloc() in nfs_page_alloc()Jesper Juhl
Take advantage of kmem_cache_zalloc() in nfs_page_alloc(). Save a call to memset() and a few bytes. Before: [jj@dragon linux-2.6]$ size fs/nfs/pagelist.o text data bss dec hex filename 1765 0 8 1773 6ed fs/nfs/pagelist.o After: [jj@dragon linux-2.6]$ size fs/nfs/pagelist.o text data bss dec hex filename 1749 0 8 1757 6dd fs/nfs/pagelist.o Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-21NFS: Remove redundant unlikely()Tobias Klauser
IS_ERR() already implies unlikely(), so it can be omitted here. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Remove src_sap and src_len from nlm_lookup_host_info structChuck Lever
Clean up. The contents of the src_sap field is not used in nlm_alloc_host(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Remove nlm_lookup_host()Chuck Lever
Clean up. Remove the now unused helper nlm_lookup_host(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Make nrhosts an unsigned longChuck Lever
Clean up. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Rename nlm_hostsChuck Lever
Clean up. nlm_hosts now contains only server-side entries. Rename it to match convention of client side cache. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Clean up nlmsvc_lookup_host()Chuck Lever
Clean up. Change nlmsvc_lookup_host() to be purpose-built for server-side nlm_host management. This replaces the generic nlm_lookup_host() helper function, just like on the client side. The lookup logic is specialized for server host lookups. The server side cache also gets its own specialized equivalent of the nlm_release_host() function. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Create client-side nlm_host cacheChuck Lever
NFS clients don't need the garbage collection processing that is performed on nlm_host structures. The client picks up an nlm_host at mount time and holds a reference to it until the file system is unmounted. Servers, on the other hand, don't have a precise way to tell when an nlm_host is no longer being used, so zero refcount nlm_host entries are left to expire in the cache after a time. Basically there's nothing holding a reference to an nlm_host between individual server-side NLM requests, but we can't afford the expense of recreating them for every new NLM request from a client. The nlm_host cache adds some lifetime hysteresis to entries in the cache so the next time a particular nlm_host is needed, it's likely to be discovered by a lookup rather than created from whole cloth. With the new implementation, client nlm_host cache items are no longer garbage collected, and are destroyed directly by a new release function specialized for client entries, nlmclnt_release_host(). They are cached in their own data structure, and have their own lookup logic, simplified and specialized for client nlm_host entries. However, the client nlm_host cache still shares reboot recovery logic with the server nlm_host cache. The NSM "peer rebooted" downcall for clients and servers still come through the same RPC call. This is a legacy formal API that would be difficult to alter, and besides, the user space NSM implementation can't tell the difference between peers that are clients or servers. For this reason, the client cache continues to share the nlm_host_mutex (and reboot recovery logic) with the server cache. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Split nlm_release_call()Chuck Lever
The nlm_release_call() function is invoked from both the server and the client side. We're about to introduce a distinct server- and client-side nlm_release_host(), so nlm_release_call() must first be split into a client-side and a server-side version. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Add nlm_destroy_host_locked()Chuck Lever
Refactor the tail of nlm_gc_hosts() into nlm_destroy_host() so that this logic can be used separately from garbage collection. Rename it _locked() to document that it must be called with the hosts cache mutex held. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Add nlm_alloc_host()Chuck Lever
Refactor nlm_host allocation and initialization into a separate function. This will be the common piece of server and client nlm_host lookup logic after the nlm_host cache is split. Small change: use kmalloc() instead of kzalloc(), as we're overwriting almost all fields in the new nlm_host struct with non-zero values immediately after it is allocated. An added benefit is we now have an explicit reference to each field name where it is initialized (for all you cscope fans out there). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: reorganize nlm_host_rebootedJ. Bruce Fields
Minor reorganization; no change in behavior. This will save some duplicated code after we split the client and server host caches. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> [ cel: Forward-ported to 2.6.37 ] Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: define host_for_each{_safe} macrosJ. Bruce Fields
We've got a lot of loops like this, and I find them a little easier to read with the macros. More such loops are coming. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> [ cel: Forward-ported to 2.6.37 ] Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16SUNRPC: New xdr_streams XDR decoder APIChuck Lever
Now that all client-side XDR decoder routines use xdr_streams, there should be no need to support the legacy calling sequence [rpc_rqst *, __be32 *, RPC res *] anywhere. We can construct an xdr_stream in the generic RPC code, instead of in each decoder function. This is a refactoring change. It should not cause different behavior. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16SUNRPC: New xdr_streams XDR encoder APIChuck Lever
Now that all client-side XDR encoder routines use xdr_streams, there should be no need to support the legacy calling sequence [rpc_rqst *, __be32 *, RPC arg *] anywhere. We can construct an xdr_stream in the generic RPC code, instead of in each encoder function. Also, all the client-side encoder functions return 0 now, making a return value superfluous. Take this opportunity to convert them to return void instead. This is a refactoring change. It should not cause different behavior. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFS: Remove unused UMNT response data structureChuck Lever
Clean up. The UMNT request has a NULL response. There's no need to set up a mountres structure for it. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFS: Avoid return code checking in mount XDR encoder functionsChuck Lever
Clean up. The trend in the other XDR encoder functions is to BUG() when encoding problems occur, since a problem here is always due to a local coding error. Then, instead of a status, zero is unconditionally returned. Update the mount client XDR encoders to behave this way. To finish the update, use the new-style be32_to_cpup() and cpu_to_be32() macros, and compute the buffer sizes using raw integers instead of sizeof(). This matches the conventions used in other XDR functions. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NSM: Avoid return code checking in NSM XDR encoder functionsChuck Lever
Clean up. The trend in the other XDR encoder functions is to BUG() when encoding problems occur, since a problem here is always due to a local coding error. Then, instead of a status, zero is unconditionally returned. Update the NSM XDR encoders to behave this way. To finish the update, use the new-style be32_to_cpup() and cpu_to_be32() macros, and compute the buffer sizes using raw integers instead of sizeof(). This matches the conventions used in other XDR functions Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFS: Squelch compiler warning in decode_getdeviceinfo()Chuck Lever
Clean up. .../linux/nfs-2.6/fs/nfs/nfs4xdr.c: In function ‘decode_getdeviceinfo’: .../linux/nfs-2.6/fs/nfs/nfs4xdr.c:5008: warning: comparison between signed and unsigned integer expressions Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFS: Simplify ->decode_dirent() calling sequenceChuck Lever
Clean up. The pointer returned by ->decode_dirent() is no longer used as a pointer. The only call site (xdr_decode() in fs/nfs/dir.c) simply extracts the errno value encoded in the pointer. Replace the returned pointer with a standard integer errno return value. Also, pass the "server" argument as part of the nfs_entry instead of as a separate parameter. It's faster to derive "server" in nfs_readdir_xdr_to_array() since we already have the directory's inode handy. "server" ought to be invariant for a set of entries in the same directory, right? The legacy versions of decode_dirent() don't use "server" anyway, so it's wasted work for them to derive and pass "server" for each entry. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFS: Fix hdrlen calculation in NFSv4's decode_read()Chuck Lever
When computing the length of the header, be sure to include the four octets consumed by "count". Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Move nlmdbg_cookie2a() to svclock.cChuck Lever
Clean up. nlmdbg_cookie2a() is used only in svclock.c. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFS: Repair whitespace damage in NFS PROC macroChuck Lever
Clean up. When I was making other changes in this area, checkscript.pl complained about the use of leading blanks in the PROC macros in the xdr files. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFSD: Update XDR decoders in NFSv4 callback clientChuck Lever
Clean up. Remove old-style NFSv4 XDR macros in favor of the style now used in fs/nfs/nfs4xdr.c. These were forgotten during the recent nfs4xdr.c rewrite. Additional whitespace cleanup adds to the size of this patch. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFSD: Update XDR encoders in NFSv4 callback clientChuck Lever
Clean up. Remove old-style NFSv4 XDR macros in favor of the style now used in fs/nfs/nfs4xdr.c. These were forgotten during the recent nfs4xdr.c rewrite. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Introduce new-style XDR functions for NLMv4Chuck Lever
We'd like to prevent local buffer overflows caused by malicious or broken servers. New xdr_stream style decoders can do that. For efficiency, we also want to be able to pass xdr_streams from call_encode() to all XDR encoding functions, rather than building an xdr_stream in every XDR encoding function in the kernel. Same idea as the NLM v3 XDR overhaul. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFS: Move and update xdr_decode_foo() functions that we're keepingChuck Lever
Clean up. Move the timestamp decoder to match the placement and naming conventions of the other helpers. Fold xdr_decode_fattr() into decode_fattr3(), which is now it's only user. Fold xdr_decode_wcc_attr() into decode_wcc_attr(), which is now it's only user. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFS: Remove unused old NFSv3 decoder functionsChuck Lever
Clean up. Remove unused legacy result decoder functions, and any now unused decoder helper functions. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFS: Switch in new NFSv3 decoder functionsChuck Lever
The naming scheme of the new decoder functions, which follows the NFSv4 XDR decoder functions, is slightly different than the scheme used for the old functions. Rename the functions as a separate step to keep the patches clean. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFS: Introduce new-style XDR decoding functions for NFSv2Chuck Lever
We'd like to prevent local buffer overflows caused by malicious or broken servers. New xdr_stream style decoders can do that. For efficiency, we also eventually want to be able to pass xdr_streams from call_decode() to all XDR decoding functions, rather than building an xdr_stream in every XDR decoding function in the kernel. Static helper functions are left without the "inline" directive. This allows the compiler to choose automatically how to optimize these for size or speed. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFS: Update xdr_encode_foo() functions that we're keepingChuck Lever
Clean up. Move the timestamp and the sattr encoder to match the placement convention of the other helpers, update their coding style, and refresh their documenting comments. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFS: Remove unused old NFSv3 encoder functionsChuck Lever
Clean up. Remove unused legacy argument encoder functions, and any now unused encoder helper functions. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFS: Replace old NFSv3 encoder functions with xdr_stream-based onesChuck Lever
The naming scheme of the new encoder functions, which follows the NFSv4 XDR encoder functions, is slightly different than the scheme used for the old functions. Rename the functions as a separate step to keep the patches clean. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFS: Introduce new-style XDR encoding functions for NFSv3Chuck Lever
We're interested in taking advantage of the safety benefits of xdr_streams. These data structures allow more careful checking for buffer overflow while encoding. More careful type checking is also introduced in the new functions. For efficiency, we also eventually want to be able to pass xdr_streams from call_encode() to all XDR encoding functions, rather than building an xdr_stream in every XDR encoding function in the kernel. To do this means all encoders must be ready to handle a passed-in xdr_stream. The new encoders follow the modern paradigm for XDR encoders: BUG on error, and always return a zero status code. Static helper functions are left without the "inline" directive. This allows the compiler to choose automatically how to optimize these for size or speed. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Introduce new-style XDR functions for NLMv3Chuck Lever
We'd like to prevent local buffer overflows caused by malicious or broken servers. New xdr_stream style decoders can do that. For efficiency, we also eventually want to be able to pass xdr_streams from call_encode() and call_decode() to all XDR encoding functions, rather than building an xdr_stream in every XDR encoding and decoding function in the kernel. To do all of this, rewrite the XDR encoding and decoding functions in fs/lockd/xdr.c to use xdr_streams. This makes them more or less incompatible with server-side XDR helper functions, so break them out into a separate source file. Static helper functions are left without the "inline" directive. This allows the compiler to choose automatically how to optimize these for size or speed. SHARE-related functionality doesn't seem to be used, as those functions are hiding behind a #define that isn't set anywhere that I can find. And, they've been in there forever (at least as far back as the kernel's git history goes), yet remain unused. Let's take the opportunity to bin them. It should be easy enough for someone to introduce proper XDR functions if at some point SHARE-related NLM functionality is desired. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Clean up. Move the timestamp decoder to match the placement and naming conventions of the other helpers. Fold xdr_decode_fattr() into decode_fattr(), which is now it's only user. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
