writes. In addition flush the disk cache on fsync if the sync cached
operation didn't sync the log to disk (this requires some additional
bookeping in the transaction and log code). If the device doesn't claim to
support barriers, the filesystem has an extern log volume or the trial
superblock write with barriers enabled failed we disable barriers and
print a warning. We should probably fail the mount completely, but that
could lead to nasty boot failures for the root filesystem. Not enabled by
default yet, needs more destructive testing first.
SGI-PV: 912426
SGI-Modid: xfs-linux:xfs-kern:198723a
Signed-off-by: Christoph Hellwig <hch@sgi.com>
Signed-off-by: Nathan Scott <nathans@sgi.com>
SGI-PV: 908809
SGI-Modid: xfs-linux:xfs-kern:198669a
SGI-PV: 942243
SGI-Modid: xfs-linux:xfs-kern:198658a
SGI-PV: 908809
SGI-Modid: xfs-linux:xfs-kern:198656a
reverse startup order
SGI-PV: 942063
SGI-Modid: xfs-linux:xfs-kern:198651a
Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
When the inode count is zero in inode writeback, the
WARN_ON(!(inode->i_state & I_WILL_FREE));
is broken, and needs to test for either I_WILL_FREE|I_FREEING.
When the inode is in I_FREEING state, it's already out of the visibility
of the vm so it can't be freed so it doesn't require the __iget and the
generic_delete_inode path can call the sync internally to the lowlevel
fs callback during the last iput. So the inode being in I_FREEING is
also a valid condition for calling the sync with i_count == 0.
The specific stack trace is this:
0xc00000007b8fb6e0 0xc00000000010118c .__writeback_single_inode +0x5c
0xc00000007b8fb6e0 0xc0000000001014dc (lr) .sync_inode +0x3c
0xc00000007b8fb790 0xc0000000001014dc .sync_inode +0x3c
0xc00000007b8fb820 0xc0000000001a5020 .ext2_sync_inode +0x64
0xc00000007b8fb8f0 0xc0000000001a65b4 .ext2_truncate +0x3f8
0xc00000007b8fba40 0xc0000000001a6940 .ext2_delete_inode +0xdc
0xc00000007b8fbac0 0xc0000000000f7a5c .generic_delete_inode +0x124
0xc00000007b8fbb50 0xc0000000000f5fe0 .iput +0xb8
0xc00000007b8fbbe0 0xc0000000000e9fd4 .sys_unlink +0x2a8
0xc00000007b8fbd10 0xc00000000001048c .ret_from_syscall_1 +0x0
This patch removes duplicate directory scanning code from fs/fat/dir.c. The
two functions that share identical code are fat_readdirx() and
fat_search_long(). This patch also renames fat_readdirx to __fat_readdir().
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Now, vfat_rename() is using vfat_find() for sanity check. This removes that
sanity check, the cost of sanity check is too high.
I recently picked up my older work to remove unnecessary #includes of
sched.h, starting from a patch by Dave Jones to not include sched.h
from module.h. This reduces the number of indirect includes of sched.h
by ~300. Another ~400 pointless direct includes can be removed after
this disentangling (patch to follow later).
However, quite a few indirect includes need to be fixed up for this.
In order to feed the patches through -mm with as little disturbance as
possible, I've split out the fixes I accumulated up to now (complete for
i386 and x86_64, more archs to follow later) and post them before the real
patch. This way this large part of the patch is kept simple with only
adding #includes, and all hunks are independent of each other. So if any
hunk rejects or gets in the way of other patches, just drop it. My scripts
will pick it up again in the next round.
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
If a filesystem passes an idiotic blocksize into bread(), __getblk_slow() will
warn and will return NULL. We have a report (from Hubert Tonneau
<hubert.tonneau@fullpliant.org>) of isofs_fill_super() doing this (passing in
a silly block size) against an unplugged CDROM drive.
But a couple of __getblk_slow() callers forgot to check for the NULL bh, hence
oops.
This patch adds tests for the return value of sb_getblk() in the ext2/3
filesystems. In fs/buffer.c it is stated that the getblk() function never
fails. However, it does can return NULL in some situations due to I/O
errors, which may lead us to NULL pointer dereferences
Signed-off-by: Glauber de Oliveira Costa <glommer@br.ibm.com>
I_WILL_FREE set
list_move(&inode->i_list, &inode_in_use);
} else {
list_move(&inode->i_list, &inode_unused);
+ inodes_stat.nr_unused++;
wake_up_inode(inode);
Are you sure the above diff is correct? It was added somewhere between
2.6.5 and 2.6.8. I think it's wrong.
The only way I can imagine the i_count to be zero in the above path, is
that I_WILL_FREE is set. And if I_WILL_FREE is set, then we must not
increase nr_unused. So I believe the above change is buggy and it will
definitely overstate the number of unused inodes and it should be backed
out.
Note that __writeback_single_inode before calling __sync_single_inode, can
drop the spinlock and we can have both the dirty and locked bitflags clear
here:
spin_unlock(&inode_lock);
__wait_on_inode(inode);
iput(inode);
XXXXXXX
spin_lock(&inode_lock);
use inode again here
a construct like the above makes zero sense from a reference counting
standpoint.
Either we don't ever use the inode again after the iput, or the
inode_lock should be taken _before_ executing the iput (i.e. a __iput
would be required). Taking the inode_lock after iput means the iget was
useless if we keep using the inode after the iput.
So the only chance the 2.6 was safe to call __writeback_single_inode
with the i_count == 0, is that I_WILL_FREE is set (I_WILL_FREE will
prevent the VM to free the inode in XXXXX).
Potentially calling the above iput with I_WILL_FREE was also wrong
because it would recurse in iput_final (the second mainline bug).
The below (untested) patch fixes the nr_unused accounting, avoids recursing
in iput when I_WILL_FREE is set and makes sure (with the BUG_ON) that we
don't corrupt memory and that all holders that don't set I_WILL_FREE, keeps
a reference on the inode!
Signed-off-by: Andrea Arcangeli <andrea@suse.de>
Fix warnings from sparse due to un-declared functions that should either
have a header file or have been declared static
fs/ext2/bitmap.c:14:15: warning: symbol 'ext2_count_free' was not declared. Should it be static?
fs/ext2/namei.c:92:15: warning: symbol 'ext2_get_parent' was not declared. Should it be static?
fs/ext3/bitmap.c:15:15: warning: symbol 'ext3_count_free' was not declared. Should it be static?
fs/ext3/namei.c:1013:15: warning: symbol 'ext3_get_parent' was not declared. Should it be static?
fs/ext3/xattr.c:214:1: warning: symbol 'ext3_xattr_block_get' was not declared. Should it be static?
fs/ext3/xattr.c:358:1: warning: symbol 'ext3_xattr_block_list' was not declared. Should it be static?
fs/ext3/xattr.c:630:1: warning: symbol 'ext3_xattr_block_find' was not declared. Should it be static?
fs/ext3/xattr.c:863:1: warning: symbol 'ext3_xattr_ibody_find' was not declared. Should it be static?
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
de_thread() sends SIGKILL to all sub-threads and waits them to die in 'D'
state. It is possible that one of the threads already dequeued coredump
signal. When de_thread() unlocks ->sighand->lock that thread can enter
do_coredump()->coredump_wait() and cause a deadlock.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Roland McGrath <roland@redhat.com>
Correct some typos and inconsistent use of "initialise" vs "initialize" in
comments. Reported by Ioannis Barkas.
Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
I noticed some problems while running ext3 with the debug flag set on.
More precisely, I was unable to umount the filesystem. Some investigation
took me to the patch that follows.
At a first glance , the lock/unlock I've taken out seems really not
necessary, as the main code (outside debug) does not lock the super. The
only additional danger operations that debug code introduces seems to be
related to bitmap, but bitmap operations tends to be all atomic anyway.
I also took the opportunity to fix 2 spelling errors.
This patch deletes pointless code from coredump_wait().
1. It does useless mm->core_waiters inc/dec under mm->mmap_sem,
but any changes to ->core_waiters have no effect until we drop
->mmap_sem.
2. It calls yield() for absolutely unknown reason.
This patch fixes incorrect error path in proc_get_inode(), when module
can't be get due to being unloaded. When try_module_get() fails, this
function puts de(!) and still returns inode with non-getted de.
There are still unresolved known bugs in proc yet to be fixed:
- proc_dir_entry tree is managed without any serialization
- create_proc_entry() doesn't setup de->owner anyhow,
so setting it later manually is inatomic.
- looks like almost all modules do not care whether
it's de->owner is set...
Signed-Off-By: Denis Lunev <den@sw.ru>
Signed-Off-By: Kirill Korotaev <dev@sw.ru>
Remove last remains of NFS exportability support.
The code is actually buggy (as reported by Akshat Aranya), since 'alias'
will be leaked if it's non-null and alias->d_flags has DCACHE_DISCONNECTED.
This is not an active bug, since there will never be any disconnected
dentries. But it's better to get rid of the unnecessary complexity anyway.
de_thread() calls del_timer_sync(->real_timer) under ->sighand->siglock.
This is deadlockable, it_real_fn sends a signal and needs this lock too.
Also, delete unneeded ->real_timer.data assignment.
Now that RCU applied on 'struct file' seems stable, we can place f_rcuhead
in a memory location that is not anymore used at call_rcu(&f->f_rcuhead,
file_free_rcu) time, to reduce the size of this critical kernel object.
The trick I used is to move f_rcuhead and f_list in an union called f_u
The callers are changed so that f_rcuhead becomes f_u.fu_rcuhead and f_list
becomes f_u.f_list
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
lookup_flags() is only called from the non-create case, so it needn't check
for O_CREAT|O_EXCL.
Cc: Al Viro <viro@ftp.linux.org.uk>
task_struct is an internal structure to the kernel with a lot of good
information, that is probably interesting in core dumps. However there is
no way for user space to know what format that information is in making it
useless.
I grepped the GDB 6.3 source code and NT_TASKSTRUCT while defined is not
used anywhere else. So I would be surprised if anyone notices it is
missing.
In addition exporting kernel pointers to all the interesting kernel data
structures sounds like the very definition of an information leak. I
haven't a clue what someone with evil intentions could do with that
information, but in any attack against the kernel it looks like this is the
perfect tool for aiming that attack.
So since NT_TASKSTRUCT is useless as currently defined and is potentially
dangerous, let's just not export it.
(akpm: Daniel Jacobowitz <dan@debian.org> "would be amazed" if anything was
using NT_TASKSTRUCT).
TIOCSTART and TIOCSTOP are defined in asm/ioctls.h and asm/termios.h by
various architectures but not actually implemented anywhere but in the IRIX
compatibility layer, so remove their COMPATIBLE_IOCTL from parisc, ppc64
and sparc64.
Move the TIOCSLTC COMPATIBLE_IOCTL to common code, guided by an ifdef to
only show up on architectures that support it (same as the code handling it
in tty_ioctl.c), aswell as it's brother TIOCGLTC that wasn't handled so
far.
Trivial, saves one 'if' branch in de_thread().
Signed-off-by: James Lamanna <jlamanna@gmail.com>
Signed-off-by: Domen Puncer <domen@coderock.org>
Fix the problem (BUG 4964) with unmapped buffers in transaction's
t_sync_data list. The problem is we need to call filesystem's own
invalidatepage() from block_write_full_page().
block_write_full_page() must call filesystem's invalidatepage(). Otherwise
following nasty race can happen:
proc 1 proc 2
- write some new data to 'offset'
=> bh gets to the transactions data list
- starts truncate
=> i_size set to new size
- mpage_writepages()
- ext3_ordered_writepage() to 'offset'
- block_write_full_page()
- page->index > end_index+1
- block_invalidatepage()
- discard_buffer()
- clear_buffer_mapped()
- commit triggers and finds unmapped buffer - BOOM!
This patch allows SELinux to canonicalize the value returned from
getxattr() via the security_inode_getsecurity() hook, which is called after
the fs level getxattr() function.
The purpose of this is to allow the in-core security context for an inode
to override the on-disk value. This could happen in cases such as
upgrading a system to a different labeling form (e.g. standard SELinux to
MLS) without needing to do a full relabel of the filesystem.
In such cases, we want getxattr() to return the canonical security context
that the kernel is using rather than what is stored on disk.
The implementation hooks into the inode_getsecurity(), adding another
parameter to indicate the result of the preceding fs-level getxattr() call,
so that SELinux knows whether to compare a value obtained from disk with
the kernel value.
We also now allow getxattr() to work for mountpoint labeled filesystems
(i.e. mount with option context=foo_t), as we are able to return the
kernel value to the user.
Signed-off-by: James Morris <jmorris@namei.org>
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Add CONFIG_X86_32 for i386. This allows selecting options that only apply
to 32-bit systems.
(X86 && !X86_64) becomes X86_32
(X86 || X86_64) becomes X86
Signed-off-by: Brian Gerst <bgerst@didntduck.org>
Doh!
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Basic overcommit checking for hugetlb_file_map() based on an implementation
used with demand faulting in SLES9.
Since demand faulting can't guarantee the availability of pages at mmap
time, this patch implements a basic sanity check to ensure that the number
of huge pages required to satisfy the mmap are currently available.
Despite the obvious race, I think it is a good start on doing proper
accounting. I'd like to work towards an accounting system that mimics the
semantics of normal pages (especially for the MAP_PRIVATE/COW case). That
work is underway and builds on what this patch starts.
Huge page shared memory segments are simpler and still maintain their
commit on shmget semantics.
Signed-off-by: Adam Litke <agl@us.ibm.com>
Below is a patch to implement demand faulting for huge pages. The main
motivation for changing from prefaulting to demand faulting is so that huge
page memory areas can be allocated according to NUMA policy.
Thanks to consolidated hugetlb code, switching the behavior requires changing
only one fault handler. The bulk of the patch just moves the logic from
hugelb_prefault() to hugetlb_pte_fault() and find_get_huge_page().
Reformat hugelbfs_forget_inode and add the missing but harmless
write_inode_now call. It looks the same as generic_forget_inode now except
for the call to truncate_hugepages instead of truncate_inode_pages.
hugetlbfs_do_delete_inode is the same as generic_delete_inode now, so remove
it in favour of the latter.
Make hugetlbfs looks the same as generic_detelte_inode, fixing a bunch of
missing updates to it at the same time. Rename it to
hugetlbfs_do_delete_inode and add a real hugetlbfs_delete_inode that
implements ->delete_inode.
Move hugetlbfs accounting into ->alloc_inode / ->destroy_inode. This keeps
the code simpler, fixes a loeak where a failing inode allocation wouldn't
decrement the counter and moves hugetlbfs_delete_inode and
hugetlbfs_forget_inode closer to their generic counterparts.
Christoph Lameter demonstrated very poor scalability on the SGI 512-way, with
a many-threaded application which concurrently initializes different parts of
a large anonymous area.
This patch corrects that, by using a separate spinlock per page table page, to
guard the page table entries in that page, instead of using the mm's single
page_table_lock. (But even then, page_table_lock is still used to guard page
table allocation, and anon_vma allocation.)
In this implementation, the spinlock is tucked inside the struct page of the
page table page: with a BUILD_BUG_ON in case it overflows - which it would in
the case of 32-bit PA-RISC with spinlock debugging enabled.
Splitting the lock is not quite for free: another cacheline access. Ideally,
I suppose we would use split ptlock only for multi-threaded processes on
multi-cpu machines; but deciding that dynamically would have its own costs.
So for now enable it by config, at some number of cpus - since the Kconfig
language doesn't support inequalities, let preprocessor compare that with
NR_CPUS. But I don't think it's worth being user-configurable: for good
testing of both split and unsplit configs, split now at 4 cpus, and perhaps
change that to 8 later.
There is a benefit even for singly threaded processes: kswapd can be attacking
one part of the mm while another part is busy faulting.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Final step in pushing down common core's page_table_lock. follow_page no
longer wants caller to hold page_table_lock, uses pte_offset_map_lock itself;
and so no page_table_lock is taken in get_user_pages itself.
But get_user_pages (and get_futex_key) do then need follow_page to pin the
page for them: take Daniel's suggestion of bitflags to follow_page.
Need one for WRITE, another for TOUCH (it was the accessed flag before:
vanished along with check_user_page_readable, but surely get_numa_maps is
wrong to mark every page it finds as accessed), another for GET.
And another, ANON to dispose of untouched_anonymous_page: it seems silly for
that to descend a second time, let follow_page observe if there was no page
table and return ZERO_PAGE if so. Fix minor bug in that: check VM_LOCKED -
make_pages_present ought to make readonly anonymous present.
Give get_numa_maps a cond_resched while we're there.
Remove the page_table_lock from around the calls to unmap_vmas, and replace
the pte_offset_map in zap_pte_range by pte_offset_map_lock: all callers are
now safe to descend without page_table_lock.
Don't attempt fancy locking for hugepages, just take page_table_lock in
unmap_hugepage_range. Which makes zap_hugepage_range, and the hugetlb test in
zap_page_range, redundant: unmap_vmas calls unmap_hugepage_range anyway. Nor
does unmap_vmas have much use for its mm arg now.
The tlb_start_vma and tlb_end_vma in unmap_page_range are now called without
page_table_lock: if they're implemented at all, they typically come down to
flush_cache_range (usually done outside page_table_lock) and flush_tlb_range
(which we already audited for the mprotect case).
Convert those common loops using page_table_lock on the outside and
pte_offset_map within to use just pte_offset_map_lock within instead.
These all hold mmap_sem (some exclusively, some not), so at no level can a
page table be whipped away from beneath them. But whereas pte_alloc loops
tested with the "atomic" pmd_present, these loops are testing with pmd_none,
which on i386 PAE tests both lower and upper halves.
That's now unsafe, so add a cast into pmd_none to test only the vital lower
half: we lose a little sensitivity to a corrupt middle directory, but not
enough to worry about. It appears that i386 and UML were the only
architectures vulnerable in this way, and pgd and pud no problem.
Second step in pushing down the page_table_lock. Remove the temporary
bridging hack from __pud_alloc, __pmd_alloc, __pte_alloc: expect callers not
to hold page_table_lock, whether it's on init_mm or a user mm; take
page_table_lock internally to check if a racing task already allocated.
Convert their callers from common code. But avoid coming back to change them
again later: instead of moving the spin_lock(&mm->page_table_lock) down,
switch over to new macros pte_alloc_map_lock and pte_unmap_unlock, which
encapsulate the mapping+locking and unlocking+unmapping together, and in the
end may use alternatives to the mm page_table_lock itself.
These callers all hold mmap_sem (some exclusively, some not), so at no level
can a page table be whipped away from beneath them; and pte_alloc uses the
"atomic" pmd_present to test whether it needs to allocate. It appears that on
all arches we can safely descend without page_table_lock.
update_mem_hiwater has attracted various criticisms, in particular from those
concerned with mm scalability. Originally it was called whenever rss or
total_vm got raised. Then many of those callsites were replaced by a timer
tick call from account_system_time. Now Frank van Maarseveen reports that to
be found inadequate. How about this? Works for Frank.
Replace update_mem_hiwater, a poor combination of two unrelated ops, by macros
update_hiwater_rss and update_hiwater_vm. Don't attempt to keep
mm->hiwater_rss up to date at timer tick, nor every time we raise rss (usually
by 1): those are hot paths. Do the opposite, update only when about to lower
rss (usually by many), or just before final accounting in do_exit. Handle
mm->hiwater_vm in the same way, though it's much less of an issue. Demand
that whoever collects these hiwater statistics do the work of taking the
maximum with rss or total_vm.
And there has been no collector of these hiwater statistics in the tree. The
new convention needs an example, so match Frank's usage by adding a VmPeak
line above VmSize to /proc/<pid>/status, and also a VmHWM line above VmRSS
(High-Water-Mark or High-Water-Memory).
There was a particular anomaly during mremap move, that hiwater_vm might be
captured too high. A fleeting such anomaly remains, but it's quickly
corrected now, whereas before it would stick.
What locking? None: if the app is racy then these statistics will be racy,
it's not worth any overhead to make them exact. But whenever it suits,
hiwater_vm is updated under exclusive mmap_sem, and hiwater_rss under
page_table_lock (for now) or with preemption disabled (later on): without
going to any trouble, minimize the time between reading current values and
updating, to minimize those occasions when a racing thread bumps a count up
and back down in between.
Remove PageReserved() calls from core code by tightening VM_RESERVED
handling in mm/ to cover PageReserved functionality.
PageReserved special casing is removed from get_page and put_page.
All setting and clearing of PageReserved is retained, and it is now flagged
in the page_alloc checks to help ensure we don't introduce any refcount
based freeing of Reserved pages.
MAP_PRIVATE, PROT_WRITE of VM_RESERVED regions is tentatively being
deprecated. We never completely handled it correctly anyway, and is be
reintroduced in future if required (Hugh has a proof of concept).
Once PageReserved() calls are removed from kernel/power/swsusp.c, and all
arch/ and driver code, the Set and Clear calls, and the PG_reserved bit can
be trivially removed.
Last real user of PageReserved is swsusp, which uses PageReserved to
determine whether a struct page points to valid memory or not. This still
needs to be addressed (a generic page_is_ram() should work).
A last caveat: the ZERO_PAGE is now refcounted and managed with rmap (and
thus mapcounted and count towards shared rss). These writes to the struct
page could cause excessive cacheline bouncing on big systems. There are a
number of ways this could be addressed if it is an issue.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Refcount bug fix for filemap_xip.c
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
