path: root/fs
2011-03-07ext2: Fix link count corruption under heavy link+rename loadJosh Hunt
commit e8a80c6f769dd4622d8b211b398452158ee60c0b upstream. vfs_rename_other() does not lock renamed inode with i_mutex. Thus changing i_nlink in a non-atomic manner (which happens in ext2_rename()) can corrupt it as reported and analyzed by Josh. In fact, there is no good reason to mess with i_nlink of the moved file. We did it presumably to simulate linking into the new directory and unlinking from an old one. But the practical effect of this is disputable because fsck can possibly treat file as being properly linked into both directories without writing any error which is confusing. So we just stop increment-decrement games with i_nlink which also fixes the corruption. CC: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Josh Hunt <johunt@akamai.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-07fuse: fix hang of single threaded fuseblk filesystemMiklos Szeredi
commit 5a18ec176c934ca1bc9dc61580a5e0e90a9b5733 upstream. Single threaded NTFS-3G could get stuck if a delayed RELEASE reply triggered a DESTROY request via path_put(). Fix this by a) making RELEASE requests synchronous, whenever possible, on fuseblk filesystems b) if not possible (triggered by an asynchronous read/write) then do the path_put() in a separate thread with schedule_work(). Reported-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-07Ocfs2/refcounttree: Fix a bug for refcounttree to writeback clusters in a ↵Tristan Ye
right number. commit acf3bb007e5636ef4c17505affb0974175108553 upstream. Current refcounttree codes actually didn't writeback the new pages out in write-back mode, due to a bug of always passing a ZERO number of clusters to 'ocfs2_cow_sync_writeback', the patch tries to pass a proper one in. Signed-off-by: Tristan Ye <tristan.ye@oracle.com> Signed-off-by: Joel Becker <jlbec@evilplan.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02ldm: corrupted partition table can cause kernel oopsTimo Warns
commit 294f6cf48666825d23c9372ef37631232746e40d upstream. The kernel automatically evaluates partition tables of storage devices. The code for evaluating LDM partitions (in fs/partitions/ldm.c) contains a bug that causes a kernel oops on certain corrupted LDM partitions. A kernel subsystem seems to crash, because, after the oops, the kernel no longer recognizes newly connected storage devices. The patch changes ldm_parse_vmdb() to Validate the value of vblk_size. Signed-off-by: Timo Warns <warns@pre-sense.de> Cc: Eugene Teo <eugeneteo@kernel.sg> Acked-by: Richard Russon <ldm@flatcap.org> Cc: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02epoll: prevent creating circular epoll structuresDavide Libenzi
commit 22bacca48a1755f79b7e0f192ddb9fbb7fc6e64e upstream. In several places, an epoll fd can call another file's ->f_op->poll() method with ep->mtx held. This is in general unsafe, because that other file could itself be an epoll fd that contains the original epoll fd. The code defends against this possibility in its own ->poll() method using ep_call_nested, but there are several other unsafe calls to ->poll elsewhere that can be made to deadlock. For example, the following simple program causes the call in ep_insert recursively call the original fd's ->poll, leading to deadlock: #include <unistd.h> #include <sys/epoll.h> int main(void) { int e1, e2, p[2]; struct epoll_event evt = { .events = EPOLLIN }; e1 = epoll_create(1); e2 = epoll_create(2); pipe(p); epoll_ctl(e2, EPOLL_CTL_ADD, e1, &evt); epoll_ctl(e1, EPOLL_CTL_ADD, p[0], &evt); write(p[1], p, sizeof p); epoll_ctl(e1, EPOLL_CTL_ADD, e2, &evt); return 0; } On insertion, check whether the inserted file is itself a struct epoll, and if so, do a recursive walk to detect whether inserting this file would create a loop of epoll structures, which could lead to deadlock. [nelhage@ksplice.com: Use epmutex to serialize concurrent inserts] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Nelson Elhage <nelhage@ksplice.com> Reported-by: Nelson Elhage <nelhage@ksplice.com> Tested-by: Nelson Elhage <nelhage@ksplice.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02eCryptfs: Copy up lower inode attrs in getattrTyler Hicks
commit 55f9cf6bbaa682958a7dd2755f883b768270c3ce upstream. The lower filesystem may do some type of inode revalidation during a getattr call. eCryptfs should take advantage of that by copying the lower inode attributes to the eCryptfs inode after a call to vfs_getattr() on the lower inode. I originally wrote this fix while working on eCryptfs on nfsv3 support, but discovered it also fixed an eCryptfs on ext4 nanosecond timestamp bug that was reported. https://bugs.launchpad.net/bugs/613873 Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02fs/partitions: Validate map_count in Mac partition tablesTimo Warns
commit fa7ea87a057958a8b7926c1a60a3ca6d696328ed upstream. Validate number of blocks in map and remove redundant variable. Signed-off-by: Timo Warns <warns@pre-sense.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02s390: remove task_show_regsMartin Schwidefsky
commit 261cd298a8c363d7985e3482946edb4bfedacf98 upstream. task_show_regs used to be a debugging aid in the early bringup days of Linux on s390. /proc/<pid>/status is a world readable file, it is not a good idea to show the registers of a process. The only correct fix is to remove task_show_regs. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02xfs: fix untrusted inode number lookupDave Chinner
Upstream commit: 4536f2ad8b330453d7ebec0746c4374eadd649b1 Commit 7124fe0a5b619d65b739477b3b55a20bf805b06d ("xfs: validate untrusted inode numbers during lookup") changes the inode lookup code to do btree lookups for untrusted inode numbers. This change made an invalid assumption about the alignment of inodes and hence incorrectly calculated the first inode in the cluster. As a result, some inode numbers were being incorrectly considered invalid when they were actually valid. The issue was not picked up by the xfstests suite because it always runs fsr and dump (the two utilities that utilise the bulkstat interface) on cache hot inodes and hence the lookup code in the cold cache path was not sufficiently exercised to uncover this intermittent problem. Fix the issue by relaxing the btree lookup criteria and then checking if the record returned contains the inode number we are lookup for. If it we get an incorrect record, then the inode number is invalid. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> [dannf: Backported to 2.6.32.y] Cc: dann frazier <dannf@debian.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02xfs: remove block number from inode lookup codeDave Chinner
Upstream commit: 7b6259e7a83647948fa33a736cc832310c8d85aa The block number comes from bulkstat based inode lookups to shortcut the mapping calculations. We ar enot able to trust anything from bulkstat, so drop the block number as well so that the correct lookups and mappings are always done. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> [dannf: Backported to 2.6.32.y] Cc: dann frazier <dannf@debian.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02xfs: rename XFS_IGET_BULKSTAT to XFS_IGET_UNTRUSTEDDave Chinner
Upstream commit: 1920779e67cbf5ea8afef317777c5bf2b8096188 Inode numbers may come from somewhere external to the filesystem (e.g. file handles, bulkstat information) and so are inherently untrusted. Rename the flag we use for these lookups to make it obvious we are doing a lookup of an untrusted inode number and need to verify it completely before trying to read it from disk. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> [dannf: backported to 2.6.32.y] Cc: dann frazier <dannf@debian.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02xfs: validate untrusted inode numbers during lookupDave Chinner
Upstream commit: 7124fe0a5b619d65b739477b3b55a20bf805b06d When we decode a handle or do a bulkstat lookup, we are using an inode number we cannot trust to be valid. If we are deleting inode chunks from disk (default noikeep mode), then we cannot trust the on disk inode buffer for any given inode number to correctly reflect whether the inode has been unlinked as the di_mode nor the generation number may have been updated on disk. This is due to the fact that when we delete an inode chunk, we do not write the clusters back to disk when they are removed - instead we mark them stale to avoid them being written back potentially over the top of something that has been subsequently allocated at that location. The result is that we can have locations of disk that look like they contain valid inodes but in reality do not. Hence we cannot simply convert the inode number to a block number and read the location from disk to determine if the inode is valid or not. As a result, and XFS_IGET_BULKSTAT lookup needs to actually look the inode up in the inode allocation btree to determine if the inode number is valid or not. It should be noted even on ikeep filesystems, there is the possibility that blocks on disk may look like valid inode clusters. e.g. if there are filesystem images hosted on the filesystem. Hence even for ikeep filesystems we really need to validate that the inode number is valid before issuing the inode buffer read. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> [dannf: backported to 2.6.32.y] Cc: dann frazier <dannf@debian.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02xfs: always use iget in bulkstatChristoph Hellwig
Upstream commit: 7dce11dbac54fce777eea0f5fb25b2694ccd7900 The non-coherent bulkstat versionsthat look directly at the inode buffers causes various problems with performance optimizations that make increased use of just logging inodes. This patch makes bulkstat always use iget, which should be fast enough for normal use with the radix-tree based inode cache introduced a while ago. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> [dannf: backported to 2.6.32.y] Cc: dann frazier <dannf@debian.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02nfsd: correctly handle return value from nfsd_map_name_to_*NeilBrown
commit 47c85291d3dd1a51501555000b90f8e281a0458e upstream. These functions return an nfs status, not a host_err. So don't try to convert before returning. This is a regression introduced by 3c726023402a2f3b28f49b9d90ebf9e71151157d; I fixed up two of the callers, but missed these two. Reported-by: Herbert Poetzl <herbert@13thfloor.at> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02GFS2: Fix bmap allocation corner-case bugSteven Whitehouse
commit 07ccb7bf2c928fef4fea2cda69ba2e23479578db upstream. This patch solves a corner case during allocation which occurs if both metadata (indirect) and data blocks are required but there is an obstacle in the filesystem (e.g. a resource group header or another allocated block) such that when the allocation is requested only enough blocks for the metadata are returned. By changing the exit condition of this loop, we ensure that a minimum of one data block will always be returned. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: maximilian attems <max@stro.at> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02NFS: fix the return value of nfs_file_fsync()J. R. Okajima
commit 0702099bd86c33c2dcdbd3963433a61f3f503901 upstream. By the commit af7fa16 2010-08-03 NFS: Fix up the fsync code close(2) became returning the non-zero value even if it went well. nfs_file_fsync() should return 0 when "status" is positive. Signed-off-by: J. R. Okajima <hooanon05@yahoo.co.jp> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02sendfile(): check f_op.splice_write() rather than f_op.sendpage()Changli Gao
commit cc56f7de7f00d188c7c4da1e9861581853b9e92f upstream. sendfile(2) was reworked with the splice infrastructure, but it still checks f_op.sendpage() instead of f_op.splice_write() wrongly. Although if f_op.sendpage() exists, f_op.splice_write() always exists at the same time currently, the assumption will be broken in future silently. This patch also brings a side effect: sendfile(2) can work with any output file. Some security checks related to f_op are added too. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Cc: Przemyslaw Pawelczyk <przemyslaw@pawelczyk.it>
2011-03-02CRED: Fix kernel panic upon security_file_alloc() failure.Tetsuo Handa
commit 78d2978874e4e10e97dfd4fd79db45bdc0748550 upstream. In get_empty_filp() since 2.6.29, file_free(f) is called with f->f_cred == NULL when security_file_alloc() returned an error. As a result, kernel will panic() due to put_cred(NULL) call within RCU callback. Fix this bug by assigning f->f_cred before calling security_file_alloc(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02CRED: Fix get_task_cred() and task_state() to not resurrect dead credentialsDavid Howells
commit de09a9771a5346029f4d11e4ac886be7f9bfdd75 upstream. It's possible for get_task_cred() as it currently stands to 'corrupt' a set of credentials by incrementing their usage count after their replacement by the task being accessed. What happens is that get_task_cred() can race with commit_creds(): TASK_1 TASK_2 RCU_CLEANER -->get_task_cred(TASK_2) rcu_read_lock() __cred = __task_cred(TASK_2) -->commit_creds() old_cred = TASK_2->real_cred TASK_2->real_cred = ... put_cred(old_cred) call_rcu(old_cred) [__cred->usage == 0] get_cred(__cred) [__cred->usage == 1] rcu_read_unlock() -->put_cred_rcu() [__cred->usage == 1] panic() However, since a tasks credentials are generally not changed very often, we can reasonably make use of a loop involving reading the creds pointer and using atomic_inc_not_zero() to attempt to increment it if it hasn't already hit zero. If successful, we can safely return the credentials in the knowledge that, even if the task we're accessing has released them, they haven't gone to the RCU cleanup code. We then change task_state() in procfs to use get_task_cred() rather than calling get_cred() on the result of __task_cred(), as that suffers from the same problem. Without this change, a BUG_ON in __put_cred() or in put_cred_rcu() can be tripped when it is noticed that the usage count is not zero as it ought to be, for example: kernel BUG at kernel/cred.c:168! invalid opcode: 0000 [#1] SMP last sysfs file: /sys/kernel/mm/ksm/run CPU 0 Pid: 2436, comm: master Not tainted 2.6.33.3-85.fc13.x86_64 #1 0HR330/OptiPlex 745 RIP: 0010:[<ffffffff81069881>] [<ffffffff81069881>] __put_cred+0xc/0x45 RSP: 0018:ffff88019e7e9eb8 EFLAGS: 00010202 RAX: 0000000000000001 RBX: ffff880161514480 RCX: 00000000ffffffff RDX: 00000000ffffffff RSI: ffff880140c690c0 RDI: ffff880140c690c0 RBP: ffff88019e7e9eb8 R08: 00000000000000d0 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000040 R12: ffff880140c690c0 R13: ffff88019e77aea0 R14: 00007fff336b0a5c R15: 0000000000000001 FS: 00007f12f50d97c0(0000) GS:ffff880007400000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007f8f461bc000 CR3: 00000001b26ce000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process master (pid: 2436, threadinfo ffff88019e7e8000, task ffff88019e77aea0) Stack: ffff88019e7e9ec8 ffffffff810698cd ffff88019e7e9ef8 ffffffff81069b45 <0> ffff880161514180 ffff880161514480 ffff880161514180 0000000000000000 <0> ffff88019e7e9f28 ffffffff8106aace 0000000000000001 0000000000000246 Call Trace: [<ffffffff810698cd>] put_cred+0x13/0x15 [<ffffffff81069b45>] commit_creds+0x16b/0x175 [<ffffffff8106aace>] set_current_groups+0x47/0x4e [<ffffffff8106ac89>] sys_setgroups+0xf6/0x105 [<ffffffff81009b02>] system_call_fastpath+0x16/0x1b Code: 48 8d 71 ff e8 7e 4e 15 00 85 c0 78 0b 8b 75 ec 48 89 df e8 ef 4a 15 00 48 83 c4 18 5b c9 c3 55 8b 07 8b 07 48 89 e5 85 c0 74 04 <0f> 0b eb fe 65 48 8b 04 25 00 cc 00 00 48 3b b8 58 04 00 00 75 RIP [<ffffffff81069881>] __put_cred+0xc/0x45 RSP <ffff88019e7e9eb8> ---[ end trace df391256a100ebdd ]--- Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02ocfs2_connection_find() returns pointer to bad structuredann frazier
commit 226291aa4641fa13cb5dec3bcb3379faa83009e2 upstream. If ocfs2_live_connection_list is empty, ocfs2_connection_find() will return a pointer to the LIST_HEAD, cast as a ocfs2_live_connection. This can cause an oops when ocfs2_control_send_down() dereferences c->oc_conn: Call Trace: [<ffffffffa00c2a3c>] ocfs2_control_message+0x28c/0x2b0 [ocfs2_stack_user] [<ffffffffa00c2a95>] ocfs2_control_write+0x35/0xb0 [ocfs2_stack_user] [<ffffffff81143a88>] vfs_write+0xb8/0x1a0 [<ffffffff8155cc13>] ? do_page_fault+0x153/0x3b0 [<ffffffff811442f1>] sys_write+0x51/0x80 [<ffffffff810121b2>] system_call_fastpath+0x16/0x1b Fix by explicitly returning NULL if no match is found. Signed-off-by: dann frazier <dann.frazier@canonical.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02NFSD: memory corruption due to writing beyond the stat arrayKonstantin Khorenko
commit 3aa6e0aa8ab3e64bbfba092c64d42fd1d006b124 upstream. If nfsd fails to find an exported via NFS file in the readahead cache, it should increment corresponding nfsdstats counter (ra_depth[10]), but due to a bug it may instead write to ra_depth[11], corrupting the following field. In a kernel with NFSDv4 compiled in the corruption takes the form of an increment of a counter of the number of NFSv4 operation 0's received; since there is no operation 0, this is harmless. In a kernel with NFSDv4 disabled it corrupts whatever happens to be in the memory beyond nfsdstats. Signed-off-by: Konstantin Khorenko <khorenko@openvz.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17NFS: Fix "kernel BUG at fs/aio.c:554!"Chuck Lever
commit 839f7ad6932d95f4d5ae7267b95c574714ff3d5b upstream. Nick Piggin reports: > I'm getting use after frees in aio code in NFS > > [ 2703.396766] Call Trace: > [ 2703.396858] [<ffffffff8100b057>] ? native_sched_clock+0x27/0x80 > [ 2703.396959] [<ffffffff8108509e>] ? put_lock_stats+0xe/0x40 > [ 2703.397058] [<ffffffff81088348>] ? lock_release_holdtime+0xa8/0x140 > [ 2703.397159] [<ffffffff8108a2a5>] lock_acquire+0x95/0x1b0 > [ 2703.397260] [<ffffffff811627db>] ? aio_put_req+0x2b/0x60 > [ 2703.397361] [<ffffffff81039701>] ? get_parent_ip+0x11/0x50 > [ 2703.397464] [<ffffffff81612a31>] _raw_spin_lock_irq+0x41/0x80 > [ 2703.397564] [<ffffffff811627db>] ? aio_put_req+0x2b/0x60 > [ 2703.397662] [<ffffffff811627db>] aio_put_req+0x2b/0x60 > [ 2703.397761] [<ffffffff811647fe>] do_io_submit+0x2be/0x7c0 > [ 2703.397895] [<ffffffff81164d0b>] sys_io_submit+0xb/0x10 > [ 2703.397995] [<ffffffff8100307b>] system_call_fastpath+0x16/0x1b > > Adding some tracing, it is due to nfs completing the request then > returning something other than -EIOCBQUEUED, so aio.c > also completes the request. To address this, prevent the NFS direct I/O engine from completing async iocbs when the forward path returns an error without starting any I/O. This fix appears to survive ^C during both "xfstest no. 208" and "fsx -Z." It's likely this bug has existed for a very long while, as we are seeing very similar symptoms in OEL 5. Copying stable. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07install_special_mapping skips security_file_mmap check.Tavis Ormandy
commit 462e635e5b73ba9a4c03913b77138cd57ce4b050 upstream. The install_special_mapping routine (used, for example, to setup the vdso) skips the security check before insert_vm_struct, allowing a local attacker to bypass the mmap_min_addr security restriction by limiting the available pages for special mappings. bprm_mm_init() also skips the check, and although I don't think this can be used to bypass any restrictions, I don't see any reason not to have the security check. $ uname -m x86_64 $ cat /proc/sys/vm/mmap_min_addr 65536 $ cat install_special_mapping.s section .bss resb BSS_SIZE section .text global _start _start: mov eax, __NR_pause int 0x80 $ nasm -D__NR_pause=29 -DBSS_SIZE=0xfffed000 -f elf -o install_special_mapping.o install_special_mapping.s $ ld -m elf_i386 -Ttext=0x10000 -Tbss=0x11000 -o install_special_mapping install_special_mapping.o $ ./install_special_mapping & [1] 14303 $ cat /proc/14303/maps 0000f000-00010000 r-xp 00000000 00:00 0 [vdso] 00010000-00011000 r-xp 00001000 00:19 2453665 /home/taviso/install_special_mapping 00011000-ffffe000 rwxp 00000000 00:00 0 [stack] It's worth noting that Red Hat are shipping with mmap_min_addr set to 4096. Signed-off-by: Tavis Ormandy <taviso@google.com> Acked-by: Kees Cook <kees@ubuntu.com> Acked-by: Robert Swiecki <swiecki@google.com> [ Changed to not drop the error code - akpm ] Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07NFS: Fix fcntl F_GETLK not reporting some conflictsSergey Vlasov
commit 21ac19d484a8ffb66f64487846c8d53afef04d2b upstream. The commit 129a84de2347002f09721cda3155ccfd19fade40 (locks: fix F_GETLK regression (failure to find conflicts)) fixed the posix_test_lock() function by itself, however, its usage in NFS changed by the commit 9d6a8c5c213e34c475e72b245a8eb709258e968c (locks: give posix_test_lock same interface as ->lock) remained broken - subsequent NFS-specific locking code received F_UNLCK instead of the user-specified lock type. To fix the problem, fl->fl_type needs to be saved before the posix_test_lock() call and restored if no local conflicts were reported. Reference: https://bugzilla.kernel.org/show_bug.cgi?id=23892 Tested-by: Alexander Morozov <amorozov@etersoft.ru> Signed-off-by: Sergey Vlasov <vsu@altlinux.ru> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07nfsd: Fix possible BUG_ON firing in set_change_infoNeil Brown
commit c1ac3ffcd0bc7e9617f62be8c7043d53ab84deac upstream. If vfs_getattr in fill_post_wcc returns an error, we don't set fh_post_change. For NFSv4, this can result in set_change_info triggering a BUG_ON. i.e. fh_post_saved being zero isn't really a bug. So: - instead of BUGging when fh_post_saved is zero, just clear ->atomic. - if vfs_getattr fails in fill_post_wcc, take a copy of i_ctime anyway. This will be used i seg_change_info, but not overly trusted. - While we are there, remove the pointless 'if' statements in set_change_info. There is no harm setting all the values. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07NFS: Fix panic after nfs_umount()Chuck Lever
commit 5b362ac3799ff4225c40935500f520cad4d7ed66 upstream. After a few unsuccessful NFS mount attempts in which the client and server cannot agree on an authentication flavor both support, the client panics. nfs_umount() is invoked in the kernel in this case. Turns out nfs_umount()'s UMNT RPC invocation causes the RPC client to write off the end of the rpc_clnt's iostat array. This is because the mount client's nrprocs field is initialized with the count of defined procedures (two: MNT and UMNT), rather than the size of the client's proc array (four). The fix is to use the same initialization technique used by most other upper layer clients in the kernel. Introduced by commit 0b524123, which failed to update nrprocs when support was added for UMNT in the kernel. BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=24302 BugLink: http://bugs.launchpad.net/bugs/683938 Reported-by: Stefan Bader <stefan.bader@canonical.com> Tested-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07fuse: fix ioctl when server is 32bitMiklos Szeredi
commit d9d318d39dd5cb686660504a3565aac453709ccc upstream. If a 32bit CUSE server is run on 64bit this results in EIO being returned to the caller. The reason is that FUSE_IOCTL_RETRY reply was defined to use 'struct iovec', which is different on 32bit and 64bit archs. Work around this by looking at the size of the reply to determine which struct was used. This is only needed if CONFIG_COMPAT is defined. A more permanent fix for the interface will be to use the same struct on both 32bit and 64bit. Reported-by: "ccmail111" <ccmail111@yahoo.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07fuse: verify ioctl retriesMiklos Szeredi
commit 7572777eef78ebdee1ecb7c258c0ef94d35bad16 upstream. Verify that the total length of the iovec returned in FUSE_IOCTL_RETRY doesn't overflow iov_length(). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09fuse: fix attributes after open(O_TRUNC)Ken Sumrall
commit a0822c55779d9319939eac69f00bb729ea9d23da upstream. The attribute cache for a file was not being cleared when a file is opened with O_TRUNC. If the filesystem's open operation truncates the file ("atomic_o_trunc" feature flag is set) then the kernel should invalidate the cached st_mtime and st_ctime attributes. Also i_size should be explicitly be set to zero as it is used sometimes without refreshing the cache. Signed-off-by: Ken Sumrall <ksumrall@android.com> Cc: Anfei <anfei.zhou@gmail.com> Cc: "Anand V. Avati" <avati@gluster.com> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09bio: take care not overflow page count when mapping/copying user dataJens Axboe
commit cb4644cac4a2797afc847e6c92736664d4b0ea34 upstream. If the iovec is being set up in a way that causes uaddr + PAGE_SIZE to overflow, we could end up attempting to map a huge number of pages. Check for this invalid input type. Reported-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09eCryptfs: Clear LOOKUP_OPEN flag when creating lower fileTyler Hicks
commit 2e21b3f124eceb6ab5a07c8a061adce14ac94e14 upstream. eCryptfs was passing the LOOKUP_OPEN flag through to the lower file system, even though ecryptfs_create() doesn't support the flag. A valid filp for the lower filesystem could be returned in the nameidata if the lower file system's create() function supported LOOKUP_OPEN, possibly resulting in unencrypted writes to the lower file. However, this is only a potential problem in filesystems (FUSE, NFS, CIFS, CEPH, 9p) that eCryptfs isn't known to support today. https://bugs.launchpad.net/ecryptfs/+bug/641703 Reported-by: Kevin Buhr Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09block: limit vec count in bio_kmalloc() and bio_alloc_map_data()Jens Axboe
commit f3f63c1c28bc861a931fac283b5bc3585efb8967 upstream. Reported-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22pipe: fix failure to return error code on ->confirm()Nicolas Kaiser
commit e5953cbdff26f7cbae7eff30cd9b18c4e19b7594 upstream. The arguments were transposed, we want to assign the error code to 'ret', which is being returned. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28mm: Move vma_stack_continue into mm.hStefan Bader
commit 39aa3cb3e8250db9188a6f1e3fb62ffa1a717678 upstream. So it can be used by all that need to check for that. Signed-off-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28execve: make responsive to SIGKILL with large argumentsRoland McGrath
commit 9aea5a65aa7a1af9a4236dfaeb0088f1624f9919 upstream. An execve with a very large total of argument/environment strings can take a really long time in the execve system call. It runs uninterruptibly to count and copy all the strings. This change makes it abort the exec quickly if sent a SIGKILL. Note that this is the conservative change, to interrupt only for SIGKILL, by using fatal_signal_pending(). It would be perfectly correct semantics to let any signal interrupt the string-copying in execve, i.e. use signal_pending() instead of fatal_signal_pending(). We'll save that change for later, since it could have user-visible consequences, such as having a timer set too quickly make it so that an execve can never complete, though it always happened to work before. Signed-off-by: Roland McGrath <roland@redhat.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-28execve: improve interactivity with large argumentsRoland McGrath
commit 7993bc1f4663c0db67bb8f0d98e6678145b387cd upstream. This adds a preemption point during the copying of the argument and environment strings for execve, in copy_strings(). There is already a preemption point in the count() loop, so this doesn't add any new points in the abstract sense. When the total argument+environment strings are very large, the time spent copying them can be much more than a normal user time slice. So this change improves the interactivity of the rest of the system when one process is doing an execve with very large arguments. Signed-off-by: Roland McGrath <roland@redhat.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28setup_arg_pages: diagnose excessive argument sizeRoland McGrath
commit 1b528181b2ffa14721fb28ad1bd539fe1732c583 upstream. The CONFIG_STACK_GROWSDOWN variant of setup_arg_pages() does not check the size of the argument/environment area on the stack. When it is unworkably large, shift_arg_pages() hits its BUG_ON. This is exploitable with a very large RLIMIT_STACK limit, to create a crash pretty easily. Check that the initial stack is not too large to make it possible to map in any executable. We're not checking that the actual executable (or intepreter, for binfmt_elf) will fit. So those mappings might clobber part of the initial stack mapping. But that is just userland lossage that userland made happen, not a kernel problem. Signed-off-by: Roland McGrath <roland@redhat.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28ocfs2: Don't walk off the end of fast symlinks.Joel Becker
commit 1fc8a117865b54590acd773a55fbac9221b018f0 upstream. ocfs2 fast symlinks are NUL terminated strings stored inline in the inode data area. However, disk corruption or a local attacker could, in theory, remove that NUL. Because we're using strlen() (my fault, introduced in a731d1 when removing vfs_follow_link()), we could walk off the end of that string. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-26inotify: fix inotify oneshot supportEric Paris
commit ff311008ab8d2f2cfdbbefd407d1b05acc8164b2 upstream. During the large inotify rewrite to fsnotify I completely dropped support for IN_ONESHOT. Reimplement that support. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-26dasd: use correct label location for diag fba disksPeter Oberparleiter
commit cffab6bc5511cd6f67a60bf16b62de4267b68c4c upstream. Partition boundary calculation fails for DASD FBA disks under the following conditions: - disk is formatted with CMS FORMAT with a blocksize of more than 512 bytes - all of the disk is reserved to a single CMS file using CMS RESERVE - the disk is accessed using the DIAG mode of the DASD driver Under these circumstances, the partition detection code tries to read the CMS label block containing partition-relevant information from logical block offset 1, while it is in fact located at physical block offset 1. Fix this problem by using the correct CMS label block location depending on the device type as determined by the DASD SENSE ID information. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [bwh: Adjust for 2.6.32] Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-26xfs: prevent reading uninitialized stack memoryDan Rosenberg
commit a122eb2fdfd78b58c6dd992d6f4b1aaef667eef9 upstream. The XFS_IOC_FSGETXATTR ioctl allows unprivileged users to read 12 bytes of uninitialized stack memory, because the fsxattr struct declared on the stack in xfs_ioc_fsgetxattr() does not alter (or zero) the 12-byte fsx_pad member before copying it back to the user. This patch takes care of it. Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Reviewed-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com> Cc: dann frazier <dannf@debian.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-26ext4: Fix remaining racy updates of EXT4_I(inode)->i_flagsDmitry Monakhov
commit 84a8dce2710cc425089a2b92acc354d4fbb5788d upstream. A few functions were still modifying i_flags in a racy manner. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-26inotify: send IN_UNMOUNT eventsEric Paris
commit 611da04f7a31b2208e838be55a42c7a1310ae321 upstream. Since the .31 or so notify rewrite inotify has not sent events about inodes which are unmounted. This patch restores those events. Signed-off-by: Eric Paris <eparis@redhat.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-26aio: check for multiplication overflow in do_io_submitJeff Moyer
commit 75e1c70fc31490ef8a373ea2a4bea2524099b478 upstream. Tavis Ormandy pointed out that do_io_submit does not do proper bounds checking on the passed-in iocb array:        if (unlikely(nr < 0))                return -EINVAL;        if (unlikely(!access_ok(VERIFY_READ, iocbpp, (nr*sizeof(iocbpp)))))                return -EFAULT;                      ^^^^^^^^^^^^^^^^^^ The attached patch checks for overflow, and if it is detected, the number of iocbs submitted is scaled down to a number that will fit in the long.  This is an ok thing to do, as sys_io_submit is documented as returning the number of iocbs submitted, so callers should handle a return value of less than the 'nr' argument passed in. Reported-by: Tavis Ormandy <taviso@cmpxchg8b.com> Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-26char: Mark /dev/zero and /dev/kmem as not capable of writebackJan Kara
commit 371d217ee1ff8b418b8f73fb2a34990f951ec2d4 upstream. These devices don't do any writeback but their device inodes still can get dirty so mark bdi appropriately so that bdi code does the right thing and files inodes to lists of bdi carrying the device inodes. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20NFS: Fix a typo in nfs_sockaddr_match_ipaddr6Trond Myklebust
commit b20d37ca9561711c6a3c4b859c2855f49565e061 upstream. Reported-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20binfmt_misc: fix binfmt_misc priorityJan Sembera
commit ee3aebdd8f5f8eac41c25c80ceee3d728f920f3b upstream. Commit 74641f584da ("alpha: binfmt_aout fix") (May 2009) introduced a regression - binfmt_misc is now consulted after binfmt_elf, which will unfortunately break ia32el. ia32 ELF binaries on ia64 used to be matched using binfmt_misc and executed using wrapper. As 32bit binaries are now matched by binfmt_elf before bindmt_misc kicks in, the wrapper is ignored. The fix increases precedence of binfmt_misc to the original state. Signed-off-by: Jan Sembera <jsembera@suse.cz> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20sysfs: checking for NULL instead of ERR_PTRDan Carpenter
commit 57f9bdac2510cd7fda58e4a111d250861eb1ebeb upstream. d_path() returns an ERR_PTR and it doesn't return NULL. Signed-off-by: Dan Carpenter <error27@gmail.com> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20ocfs2: Fix incorrect checksum validation errorSunil Mushran
commit f5ce5a08a40f2086435858ddc80cb40394b082eb upstream. For local mounts, ocfs2_read_locked_inode() calls ocfs2_read_blocks_sync() to read the inode off the disk. The latter first checks to see if that block is cached in the journal, and, if so, returns that block. That is ok. But ocfs2_read_locked_inode() goes wrong when it tries to validate the checksum of such blocks. Blocks that are cached in the journal may not have had their checksum computed as yet. We should not validate the checksums of such blocks. Fixes ossbz#1282 http://oss.oracle.com/bugzilla/show_bug.cgi?id=1282 Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Singed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20fuse: flush background queue on connection closeMiklos Szeredi
commit 595afaf9e6ee1b48e13ec4b8bcc8c7dee888161a upstream. David Bartly reported that fuse can hang in fuse_get_req_nofail() when the connection to the filesystem server is no longer active. If bg_queue is not empty then flush_bg_queue() called from request_end() can put more requests on to the pending queue. If this happens while ending requests on the processing queue then those background requests will be queued to the pending list and never ended. Another problem is that fuse_dev_release() didn't wake up processes sleeping on blocked_waitq. Solve this by: a) flushing the background queue before calling end_requests() on the pending and processing queues b) setting blocked = 0 and waking up processes waiting on blocked_waitq() Thanks to David for an excellent bug report. Reported-by: David Bartley <andareed@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
